查看: 387|回复: 1
[padsVX.0][2层板]车载音响+AU6860B+PT2313L+BK1080H
发表于 2019-12-20 14:03 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
文件名:[padsVX.0][2层板]车载音响+AU6860B+PT2313L+BK1080H
0 I4 T' ]1 R# {
文件描述
1. 作品功能:车载音响
2. 软件版本:padsVX.0
3. 层数:2层板
4. 用到的主要芯片/接口:[padsVX.0][2层板]车载音响+AU6860B+PT2313L+BK1080H
5. PCB板尺寸:157mm*40mm
. R1 t( q& X9 s) S
顶层
# b5 Z& z# b7 N
底层
; S6 G: Q! w% ]6 [" D( w
全层
  P( I! D+ B. L
8 z) X" ^7 W1 l4 s% m
BOM
REFDESCOMP_DEVICE_TYPECOMP_VALUE
位号类型属性
C1C06034.7uF
C24X5MMNC
C3C0603NC
C4C06032.2u
C5C06032.2u
C6C060347P
C74X5MMNC
C8C06034.7uF
C9C06034.7uF
C10C0603NC
C11C06030.1uF
C12C06030.1uF
C13C06034.7uF
C14C080522uF
C15C0603272
C16C060347PF
C17C0603272
C18C06030.1uF
C19C06031UF
C20C06030.1uF
C21C06030.1uF
C22C06031UF
C23C0603473
C24C0603473
C25C0603473
C26C0603473
C27C06031UF
C28C06031UF
C29C06031UF
C30C06031UF
C31C0603102
C32C06030.1UF
C33C080510UF
C34C06030.1UF
C35C060318P
C36SD-PDW-HB
C37C08051K/NC
C386031uF
C396031uF
C40C06031UF
C41C06031UF
C426032.2uF
C436031uF
C44C08051K/NC
C456031uF
C46C06034.7UF
C476032.2uF
C48EC3216A10uF
C49EC3216A10uF
C50EC3216A10uF
CH-1KEY-DIP
CH1+KEY-DIP
D1IN41488.2V/NC
DISPLAY_LEDLED54611BR
IRIR1
J1AUX_JACK-3P---
J2CON\SIP6\2.5MMAAA
J4K7A
J12CON-2.0-3A
J19CON-2.0-12
JMPTEST3AAA
JMP1TEST3AAA
JMP2TEST3AAAA
JMP3TEST3AAAA
JMP4TEST3AAA
JMP5TEST3AAA
K24KBB
K26KBB
K27KBB
K28KBB
K29KBB
K32KBB
L1603NC
L2603100N
LED8LED_2.5
LED9LED_2.5
LED11LED_2.5
LED12LED_2.5
LED13LED_2.5
LED14LED_2.5
LED15LED_2.5
LED16LED_2.5
MOD1KEY-DIP
MUTE1KEY-DIP
POWSW
Q1NPN
Q2NPN
R1R06035.6k
R2R06031k
R36034.7R
R4R06035.6k
R5R060310k
R6R0603100
R7R0603100
R8R06031k
R9R06032k2
R10R06036.8k
R11R06036.8k
R12R060310K
R136034.7R
R14R06033K3
R15R060310K
R16R060310K
R1760310K
R1860310K
R19603NC
R2060310K
R2160310K
R2260310K
R2360310K
R2460310K
R2560310K
R26603100K
R27603100K
R45R0603470R
R55R0603470
SCA1KEY-DIP
SCA1+KEY-DIP
SDCON\SIP6\2.5MMAAB
SW1VOL-5PA
U1SO28-2313PT2313L
U25807M5807M/NC
U3SOP_RDA5817BK1080H
U4SOT-23(BCE)LP6235
U5AU6860BAU6860B
U6SOT23-5LP321
U10DIP8\SOA24C02
U14SOT23-5LP321
U30BK-BTA26AAAABT
USBUSB_LI
Y1XTAL-3X812.00MHZ
Y2XTAL
! f. \2 u& _: _: {6 ~
" C; K* {  v4 R2 o
附件:
原理图和PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
) {( m  t2 a# o! F; ~( M
4 A4 J# v4 W" S; V, [3 R( M
    擦汗
    2020-11-12 15:07
  • 签到天数: 40 天
    [LV.5]常住居民I
    发表于 2020-6-21 16:38 | 只看该作者
    谢谢分享啊啊
    + C1 ^4 D) S. I# v7 n' }$ ?
    GMT+8, 2025-7-28 18:53 , Processed in 0.125000 second(s), 27 queries , Gzip On.
