Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
BAT600 | BATTERY_5_BAT600_3.3V BATTERY | 3.3V BATTERY | IC | 1 | BT1 |
C0603 | CAP NP_C0603_100NF | 100nF | IC | 33 | C29; C30; C139; C141; C143; C148; C150; C152; C155; C156; C157; C158; C160; C186; C205; C236; C244; C245; C246; C247; C251; C253; C289; C326; C327; C328; C329; C330; C352; C362; C444; C481; C496 |
C0603 | CAP NP_C0603_100PF | 100pF | IC | 18 | C138; C225; C226; C227; C228; C229; C230; C231; C232; C242; C243; C261; C349; C351; C353; C354; C355; C356 |
C0603 | CAP NP_C0603_20PF | 20pF | IC | 1 | C147 |
C0603 | CAP NP_C0603_20P | 20p | IC | 1 | C149 |
C0603 | CAP NP_C0603_NC | NC | IC | 1 | C159 |
C0603 | CAP NP_C0603_100N | 100n | IC | 11 | C175; C176; C177; C178; C197; C198; C199; C200; C201; C202; C203 |
C0603 | CAP NP_0_C0603_104 | 104 | IC | 5 | C182; C190; C193; C194; C206 |
C0603 | CAP NP_C0603_104 | 104 | IC | 2 | C237; C239 |
C0603 | CAP NP_C0603_1UF | 1uF | IC | 9 | C363; C488; C489; C490; C491; C492; C493; C494; C495 |
C0603 | 0.1UF-10V-10%-X5R-0402_C0603_10 | 104 | IC | 5 | C390; C391; C394; C397; C398 |
C0603 | 0.1UF-10V-10%-X5R-0402_C0603__1 | 10nF | IC | 1 | C395 |
C0603 | CAP NP_C0603_47P/NC | 47p/NC | IC | 1 | C410 |
C0603 | CAP NP_C0603_10NF | 10nF | IC | 1 | C497 |
C0603 | CAP NP_C0603_6PF | 6pF | IC | 2 | C498; C499 |
C0805 | CAP NP_C0805_10UF | 10uF | IC | 21 | C4; C5; C6; C8; C10; C151; C181; C183; C233; C234; C240; C241; C248; C249; C250; C252; C331; C332; C364; C365; C482 |
C0805 | CAP NP_C0805_10U | 10u | IC | 2 | C238; C254 |
C1206 | CAP NP_0_C1206_10NF/100V | 10nF/100V | IC | 1 | C207 |
CAP-D10L16-DIP-2 | CAP_0_CAP-D10L16-DIP-2_1000UF/1 | 1000uF/16V(ECA1CM102) | IC | 1 | C453 |
CON4-B | CON4_CON4-B_CON4 | CON4 | IC | 1 | CON6 |
CON-FPC-P05-40P | LCD-888_4_CON-FPC-P05-40P_LCD-8 | LCD-888 | IC | 1 | LCD2 |
CON-FPC-P05-45P | LCD-888_1_CON-FPC-P05-45P_LCD-8 | LCD-888 | IC | 1 | LCD1 |
DB9RA_M | CONNECTOR DB9_2_DB9RA_M_CONNECT | CONNECTOR DB9 | IC | 1 | COM0 |
DC023B | DC-JACK_1_DC023B_DC-JACK | DC-JACK | IC | 1 | CN1 |
DFN10-19P7X111-2TH | MMA7660FC_DFN10-19P7X111-2TH_MM | MMA7660FC | IC | 1 | U7 |
DO-214AA-SMB | DIODE ZENER1_8_DO-214AA-SMB_5.6 | 5.6V | IC | 1 | D1 |
EARJACK5 | PHONEJACK STEREO SW_EARJACK5_PH | PHONEJACK STEREO SW | IC | 1 | MIC2 |
EARJACK5 | AUDIO_1_EARJACK5_AUDIO_3F37-4 | AUDIO_3F37-4 | IC | 1 | SPK1 |
F0805 | FUSE_F0805_500MA | 500mA | IC | 3 | F4; F5; F6 |
F3528 | FUSE_0_F3528_2A | 2A | IC | 1 | F1 |
H1 | CON1_H1_CON1 | CON1 | IC | 10 | H1; H2; H3; H4; H5; H8; H14; H15; H16; H17 |
HDMI0119-20-RM-A | HDMI_0_HDMI0119-20-RM-A_HDMI | HDMI | IC | 1 | CON8 |
HR911105A | HR911103A_5_HR911105A_HR911105A | HR911105A | IC | 1 | LAN1 |
KEY-A06 | KEY2PIN_0_KEY-A06_KEY-A06 | KEY-A06 | IC | 4 | K1; K2; K3; K4 |
KEY-A06 | KEY2PIN_0_KEY-A06_RESET | RESET | IC | 1 | RESET1 |
LED | LED_LED_RLED | RLED | IC | 1 | D2 |
MIC2 | MIC_MIC2_MIC | mic | IC | 1 | MIC1 |
MICRO_USB-B_HRS_ZX62D-B-5PA8 | MINIUSB_1_MICRO_USB-B_HRS_ZX62D | MicroUSB | IC | 1 | MICROUSB1 |
OSC2PR-1 | CRYSTAL_OSC2PR-1_25MHZ | 25MHz | IC | 1 | Y2 |
OSC2PR-1 | CRYSTAL_OSC2PR-1_24MHZ | 24MHz | IC | 1 | Y5 |
PH-4A | CON4_3_PH-4A_NC | NC | IC | 1 | CON7 |
QFN32-19P7-2TH | WM8960GEFL_0_QFN32-19P7-2TH_WM8 | WM8960GEFL | IC | 1 | U50 |
QFN48-19P7-TH | DM9621_1_QFN48-19P7-TH_DM9621 | DM9621 | IC | 1 | U66 |
QFN48-19P7-TH | CON40_0_QFN48-19P7-TH_USB4604 | USB4604 | IC | 1 | U80 |
R0603 | FB_R0603_10R | 10R | IC | 2 | FB1; FB2 |
R0603 | FB_R0603_0R/NC | 0R/NC | IC | 1 | FB3 |
R0603 | R_R0603_1K | 1K | IC | 8 | R3; R5; R33; R188; R215; R230; R231; R350 |
R0603 | R_R0603_0R/NC | 0R/NC | IC | 1 | R4 |
R0603 | R_R0603_330R | 330R | IC | 1 | R6 |
R0603 | R_R0603_0R | 0R | DISCRETE | 18 | R7; R108; R189; R199; R242; R343; R344; R389; R390; R401; R405; R406; R407; R408; R409; R410; R424; R425 |
R0603 | R_R0603_10K | 10K | IC | 20 | R10; R11; R48; R49; R50; R61; R198; R218; R219; R220; R221; R228; R229; R397; R398; R403; R428; R429; R439; R440 |
R0603 | R_R0603_4.7K | 4.7K | IC | 13 | R31; R32; R40; R41; R42; R43; R52; R54; R56; R58; R60; R72; R222 |
R0603 | R_R0603_2K | 2K | IC | 13 | R34; R44; R45; R46; R47; R51; R53; R55; R57; R59; R71; R186; R415 |
R0603 | RESISTOR_R0603_51K | 51K | IC | 6 | R83; R84; R85; R87; R88; R89 |
R0603 | RESISTOR_R0603_10K | 10K | IC | 1 | R86 |
R0603 | R_R0603_22R | 22R | DISCRETE | 9 | R95; R125; R184; R187; R224; R225; R226; R227; R417 |
R0603 | R_R0603_100K | 100K | IC | 2 | R110; R223 |
R0603 | R_0_R0603_49.9R,1% | 49.9R,1% | IC | 4 | R127; R129; R132; R133 |
R0603 | R_0_R0603_330R | 330R | IC | 2 | R130; R131 |
R0603 | R_R0603_NC | NC | IC | 4 | R238; R239; R240; R241 |
R0603 | R_R0603_10K/NC | 10K/NC | IC | 2 | R399; R400 |
R0603 | 100K-1/16W-5%-0603_R0603_100K | 100K | IC | 2 | R470; R479 |
R0603 | 100K-1/16W-5%-0603_R0603_0R | 0R | IC | 2 | R471; R487 |
R0603 | 100K-1/16W-5%-0603_R0603_12K,1% | 12K,1% | IC | 2 | R472; R481 |
R0603 | 100K-1/16W-5%-0603_R0603_10K | 10K | IC | 8 | R478; R482; R483; R484; R485; R488; R489; R490 |
R0603 | 100K-1/16W-5%-0603_R0603_6.98K | 6.98K | IC | 1 | R486 |
RN-8P4R-31P5X062A | R_PAK4_RN-8P4R-31P5X062A_0R_? | 0R | IC | 6 | RN19; RN20; RN61; RN62; RN64; RN67 |
SDCARD | SD_0_SDCARD_SD/MMC CARD | SD/MMC CARD | IC | 1 | CON12 |
SIP-2-2 | JUMPER_SIP-2-2_JUMPER | JUMPER | IC | 1 | J1 |
SIP-3-2 | CON3_SIP-3-2_CON3 | CON3 | IC | 12 | DS1; DS2; DS3; DS4; DS5; DS6; DS7; DS8; DS9; DS10; PWM0; PWM1 |
SIP-4-2 | CON4_SIP-4-2_CON4 | CON4 | IC | 8 | CON1; CON3; CON4; CON14; CON15; CON16; CON18; USBH3 |
SIP-6-2 | CON6_SIP-6-2_CON6 | CON6 | IC | 2 | CON13; cpld_ISP |
SIP-10X2-3 | J2X10_SIP-10X2-3_J2X10 | J2X10 | IC | 1 | CON17 |
SLP1006P2T | DIODE DIAC_0_SLP1006P2T_RCLAMP0 | RClamp0531T/NC | IC | 4 | D26; D27; D28; D29 |
SOD-523 | DIODE TVS BI-DIR_1_SOD-523_PESD | PESD5V0S1BB/NC | IC | 3 | D41; D42; D43 |
SOIC16-50X204 | MAX232SOP_SOIC16-50X204_MAX3232 | MAX3232SOP | IC | 1 | U14 |
SOP8 | AT24LC04_SOP8_24AA025E48-I/SN | 24AA025E48-I/SN | IC | 1 | U6 |
SOT-23-D | DIODE_DUAL_CK_AJA_1_SOT-23-D_BA | BAT54C | IC | 1 | DN3 |
SOT-23-Q | NPN-BEC_SOT-23-Q_MMBT3904AL | MMBT3904AL | IC | 1 | Q1 |
SOT-23-Q-MOS | VN0610LL_0_SOT-23-Q-MOS_AO3414 | AO3414 | IC | 10 | Q18; Q19; Q20; Q21; Q22; Q23; Q24; Q25; Q26; Q32 |
SPEAKER | BEEP-2_SPEAKER_TMB-12-A05 | TMB-12-A05 | IC | 1 | BP1 |
SW35 | SWITH-5P_SW35_SWITH-5P | SWITH-5P | IC | 2 | S1; S2 |
TINYPRO | TINY210PRO_TINYPRO_TINY210PRO | TINY210PRO | IC | 1 | TINY4412 |
TO-252 | AMS1117_0_TO-252_AMS1086CD-3.3 | AMS1086CD-3.3 | IC | 1 | U1 |
TO-252 | AMS1117_0_TO-252_AMS1086CD-1.8 | AMS1086CD-1.8 | IC | 1 | U2 |
TPC1 | TP_TPC1_TP | TP | IC | 2 | LCD_CLK; LCD_VS |
TQFP100-19P7 | ALTERA_EPM240T100 | EPM240T100 | IC | 1 | U74 |
TSSOP14-25P6X228 | CON14A_0_TSSOP14-25P6X228_TXS01 | TXS0104EPWR | IC | 2 | U5; U72 |
TSSOP20-25P6X228 | TXB0108_TSSOP20-25P6X228_TXS010 | TXS0108 | IC | 1 | U3 |
TSSOP48-19P7X295 | SN74LVC16T245_1_TSSOP48-19P7X29 | SN74LVC16T245 | IC | 1 | U38 |
UDIO-SDWIFI | CON10_2_UDIO-SDWIFI_TF-CON | TF-con | IC | 1 | UDIO_WIFI |
USB-A2 | USBPORT_0_USB-A2_USB A | USB A | IC | 2 | USBH1; USBH2 |
VR3_7X7 | RESISTOR VAR_0_VR3_7X7_10K | 10K | IC | 1 | W2 |
