STM32F405VG+MAX3232+M24C64RMN1+TLP181+MAX1487+格雷码 解码器原理图+PCB作品文件分享。2 K& o' s d8 ? X) K+ L% Z
用AD画的,有需要的可以看看。
' O! d9 F. g, t- u7 S
5 }# A2 b2 X1 {) m; F层数:4层1 Z# W4 K. g( j1 n* p
用途:解码器
5 R3 u& c9 H% m6 ipcb作品截图如下:3 h, k. B$ k& S I3 t F- Q: {" C* Q
& a' T2 s& s, M. i3 l6 \- ~$ F5 ~3 @- p1 D7 s2 f: \
+ U# K( t. `. D* ~附件:
6 z1 C- I, }" w( _& u/ f/ g: D/ i# q+ M, i/ W: r, F: K4 o
. d4 U& f- y6 Z8 ^" ?, _- E
: v2 B6 q( h& v7 rBOM:
' q, @ l1 O2 @2 RComment | Quantity | Footprint | femtoSMDC005F | 12 | FEMTOSMDC005F | Battery | 1 | 5.0dz | 0.1uF/6.3V | 11 | 1608[0603] | 10pF | 3 | 1608[0603] | 2.2uF/6.3V | 2 | 1608[0603] | 10uF/6.3V | 2 | 1608[0603] | 0.22uF | 3 | 1608[0603] | 1uF | 3 | 1608[0603] | 22uF/50V | 1 | 6032 | 270pF | 1 | 1608[0603] | 15uF/6.3V | 1 | 0805 | 0.1uF | 1 | 1608[0603] | 1uF/50V | 1 | C1206 | 68uF/16V | 3 | 7343 | 0.01uF/6.3VNPO | 1 | 0805 | 10uF/6.3V NPO | 1 | 0805 | TPSE686M020R0150 | 4 | 7343 | 0.47uF/16V | 1 | 0805 | TPSV686M025R0150 | 2 | 7343 | 0.1uF/6.3V NPO | 2 | 0805 | 220pF | 3 | 1608[0603] | 4.7uF/6.3V | 1 | 0805 | 22uF/6.3V/1206 | 1 | C1206 | 10uF/6.3V NPO | 1 | 0805 | 0.1uF | 3 | 6-0805 | 4.7uF/6.3V | 1 | C1206 | 1uF/50V | 2 | 1206 | 100pF | 4 | 1608[0603] | 1000pF/250V | 13 | C1808 | 133nF | 1 | 1608[0603] | 0.5uF | 3 | 1608[0603] | 68uF/50V | 1 | 7343 | !!!PPS | 1 | C1206 | 0.5uF | 3 | C1206 | 68uF/20V | 1 | 7343 | 0.1uF/50V | 15 | 0603 | 0.1uF/16V | 2 | 2012[0805] | 0.47uF/16V | 6 | 2012[0805] | 0.1uF/6.3V | 3 | 0805 | 0.1uF | 1 | 0805 | 100pF | 1 | 0805 | Battery | 1 | CR2032 | BAT54C-2 | 1 | BAT54C-2 | 1N4007 | 46 | SMA | MBRS340T3 | 3 | SMB | B360A | 1 | SMA | 1N4148 | 1 | MiniMELF | LED | 20 | LED0603k | SMD250F | 1 | SMD250F | nanoSMDC012F | 21 | RB1206K | TX2-24V | 1 | TX2-24V | 47uH | 1 | VLF3012A | VLC6045T-4R7M | 3 | VLC6045T-6R8M | VLC6045T-6R8M | 1 | VLC6045T-6R8M | VLF3010AT-2R2M1R0 | 1 | VLF3010A | Speaker | 1 | KLJ-1230 | Header 5X2 | 1 | HDR2X5 | Header 10 | 1 | HDR1X10 | FCC_10PIN_1.0 | 1 | FCC10_1.0 | DTU | 1 | KF2EDGV-3.81-5 | COMBICON | 4 | KF2EDGVT-3.81-2X5 | Header 3X2 | 4 | HDR2X3 | COMBICON2x7 | 2 | KF2EDGVT-3.81-2X7 | Header 2 | 1 | HDR1X2 | MOSN | 1 | sot-23 | IRF7401 | 3 | SO-8_N | Si2333DS | 2 | SOT-23 | 2N7002 | 6 | sot-23 | 9013 | 3 | sot-23 | 10K | 7 | 2012[0805] | 1K | 7 | 2012[0805] | 10K | 6 | 1608[0603] | 100K | 3 | 1608[0603] | 1M | 1 | 2012[0805] | 2.1K | 1 | 1608[0603] | 34K | 1 | 1608[0603] | 40.2K | 1 | 1608[0603] | 59K | 1 | 1608[0603] | 0.02 | 3 | 6332[2512] | 680 | 2 | 2012[0805] | 218K | 3 | 1608[0603] | 24.9K | 3 | 1608[0603] | 75K | 1 | 1608[0603] | 1ohm | 1 | 2012[0805] | 680 | 5 | 1608[0603] | 2K | 9 | 1608[0603] | 1.3K | 1 | 3216[1206] | 220K | 1 | 2012[0805] | 150K | 2 | 2012[0805] | 200R | 4 | 6332[2512] | 20K | 2 | 1608[0603] | 300K | 1 | 2012[0805] | 200K | 4 | 2012[0805] | 51K | 1 | 2012[0805] | 100K | 1 | 2012[0805] | 5.1K | 14 | 3216(1206) | 5.1K | 1 | 3216[1206] | 2.7K | 15 | 1608[0603] | 5.1K | 15 | 1608[0603] | 1002 | 4 | 1608[0603] | 0ohm | 2 | 1608[0603] | 75 | 1 | 1608[0603] | 110 | 1 | 1608[0603] | Green/D3 | 1 | LED0603 | SW DIP-4 | 1 | SO8 | T8013-SEBQ | 1 | HPKG | TEST | 9 | TEST | STM32F405VG | 1 | LQFP100_N | REF3130AIDBZ | 1 | SOT23 | M24C64RMN1 | 1 | SOP8_N | MAX668 | 3 | MAX668 | LT1761 | 1 | SOT23-5 | LTC4090 | 1 | LTC4090 | REF102AU | 1 | SOIC-OA8_M | CD4052BCM | 1 | M16A_N | LM358AM | 1 | M08A_N | MC78L05ACD | 1 | 751-05_N | OP07CS8 | 1 | S8_N | TLC556CDR | 1 | D014_N | TLP181 | 15 | SOP4 | MAX1487 | 2 | SOP8_N | MAX3232 | 2 | SOIC16 | SM712 | 1 | SOT23A | SM712 | 1 | sot-23 | ESD 50V | 1 | 6332[2512] | ESD 16V 0603 | 8 | 1608[0603] | 5032 | 1 | YY4_5032 | XTAL | 1 | X32678 | 4 g8 N# m' i- x7 ]/ X- j' q9 N
( \) H6 o0 J8 L4 l9 M( C+ h
