. U9 g+ d& C/ J4 t7 F* R% ~' H. M5 E' O( r
MIC29302+HCPL0631+LM2663+TPS73633+2N3904智能车主控板++原理图+PCB作品文件分享 b. P3 B( i6 Y6 t5 {
4 N" N x+ d0 }) w" C3 I
AD画的,画的很不错,有需要的可以看看。- ~# T; g) r$ V7 @
层数:2层
6 G0 r0 @) g7 I: `+ t用途:智能车主控
, R5 i4 W& ^8 S+ i6 Q9 H0 lpcb作品截图如下:
( B9 E! a, j' Q6 z' [/ i
, N, x" {5 O; ]- G& L8 F% e
0 u4 R$ t3 w0 K. k6 S6 H" F
' a5 [+ x5 p$ O" ]7 ~. G; Y附件:0 h; z; c* v8 K, f
% m4 ?3 D1 M7 i0 N7 @2 e! t8 Y. D/ l% b) b& Z1 T+ Q, K
BOM:
! c. `) V, T6 _7 x3 R& K- k6 n5 X2 c7 Q4 p, J8 L0 b* {* v
/ O* H; ~/ s( s. a2 l9 k; C! h$ L
Comment | Quantity | Footprint | 4.7uF | 3 | 0805_Res | 47uF | 1 | C型钽电容_6032_28 | 10uF | 1 | 0805_Res | 0.1uF | 4 | 0805_Res | 100uF | 1 | D型钽电容_7343_31 | 47uF | 1 | D型钽电容_7343_31 | 22uf | 1 | C型钽电容_6032_28 | 22uF | 4 | B型钽电容_3528_21 | 104 | 1 | 0805_RES | 1N5819 | 2 | 0805_Dio | SS34 | 1 | 0805_Dio | LED_2 | 5 | 0805_Dio | Diode 1N4005 | 1 | SS34_3D | HOLE | 3 | 铜柱孔3 | - | 1 | 单面焊盘2*3MM_1PIN | + | 1 | 单面焊盘2*3MM_1PIN | AD-KEY | 1 | HDR1X3 | CON4 | 1 | B0505S-2W | OLED | 1 | HDR1X6 | CON12_2 | 1 | HDR2X6 | CON12 | 1 | HDR2X6 | motor drive | 1 | HDR2X3 | bluetooth | 1 | HDR1X4 | HEADER 10X2 | 1 | HDR2X10 | HEADER 11X2 | 2 | HDR2X11 | CON2 | 2 | 2PIN杜邦插座_1.27mm | BM | 1 | HDR2X4 | servo drive | 1 | HDR1X3 | CCD | 1 | HDR1X5 | 6.8uH | 1 | CDRH3D16_4.2*1.8 | 0k | 1 | 0603_Res | lm2940 | 1 | PCBComponent_1 | Bell | 1 | 蜂鸣器侧装 | 2N3904 | 1 | TO-92A | 1k | 19 | 0805_Res | 3.9k | 1 | 0805_Res | 1k | 7 | 0603_Res | 2.2k | 1 | 0603_Res | 3.3k | 3 | 0603_Res | SW-SPST | 2 | 开关 | SW DIP-4 | 1 | 4路拨码开关 | TPS73633 | 1 | SOT23_5-LEADS | LM2663 | 1 | SOP_8(OPA) | HCPL0631 | 3 | SOP_8(OPA) | MIC29302 | 1 | TO_263_5(10.5*8.4mm)
4 N; q) J% h- T9 `4 c7 K+ s( p p2 I7 `
| . d, P% M" p* c) x
