3 }6 [6 ?" p% s# @) V. o2 L$ ?
0 N" a0 j9 R# s, c原理图有DxDesigner和PDF格式的。
) H8 l5 c% V* a) QPCB为allegro格式,22层板。! k$ z5 e9 b7 s, v$ n" Q6 r
# X# z. w5 c0 H, S& `/ u$ Y6 U
Cad File name:
1 V7 [% D, D5 L; Z7 qXILINX_ML510_REVC_FAB.ZIP# T4 B! R$ A4 e4 y' R5 r; [
file list
% F0 c! v/ b; _, p" C8 g4 K, pNUMBER OF COPPER LAYERS: 22; C- e* b! L4 N9 S" d
L1_TOP.ART + TOP COPPER LAYER (PRIMARY SIDE). I6 E2 t$ V3 J
L2_PWR.art + INNER PWR PLANE# o$ o& d; |+ D4 t9 |
L3_GND.art + INNER GND PLANE0 N) T+ R/ R9 v4 @' z4 z# g# Q" q5 z+ X
L4_INNER.art + INNER SIGNAL) p/ a3 }2 [) S# K7 T
L5_INNER.art + INNER SIGNAL
! T+ _/ t' q9 z8 TL6_GND.art + INNER GND PLANE
; l, u% @3 q& g) ^* ~. AL7_PWR.art + INNER PWR PLANE, M" |, Y0 i1 N* B$ c1 x
L8_INNER.art + INNER SIGNAL
$ c* a5 s* q/ E7 q: {' t) C' y) ^$ ML9_INNER.art + INNER SIGNAL
1 H9 }( Z0 ^) X: s L6 gL10_GND.art + INNER GND PLANE% A, `( @& B# C- Y& ~+ L
L11_INNER.art + INNER SIGNAL+ W* U/ H2 c( |
L12_INNER.art + INNER SIGNAL/ o0 _& N' L7 Q* Z t
L13_GND.art + INNER GND PLANE
! Q5 J. v: P8 R1 U. L" S9 |! Z/ `L14_INNER.art + INNER SIGNAL
5 { P+ v1 \& ~0 i3 A# o; NL15_INNER.art + INNER SIGNAL
' q. W9 v6 \9 I2 } y/ K) x* uL16_PWR.art + INNER PWR PLANE& Z d- h/ k @) t9 t7 M( N8 U& V
L17_GND.art + INNER GND PLAN
7 d* r5 P$ i0 V, U9 ?! L6 XL18_INNER.art + INNER SIGNAL! P/ ]* f$ y* P( g2 o# e
L19_INNER.art + INNER SIGNAL7 D" I( I7 A; i* y5 c
L20_GND.art + INNER GND PLANE8 t" y1 F3 @7 p. l5 a2 f5 K% Z4 {* j
L21_PWR.art + INNER PWR PLANE/ {+ W8 N1 U* R6 ]( |# a0 n
L22_BOTTOM.art + BOTTOM COPPER LAYER (SECONDARY SIDE)
5 L! `' C. v; K1 r2 mSILK_TOP.art TOP SILK SCREEN* N8 H; Z5 u7 R" x, @
SILK_BOT.art BOTTOM SILK SCREEN4 v! J0 x1 M9 j& h+ e% P
MASK_TOP.art TOP SOLDER MASK (PRIMARY SIDE)) x+ k V* d' B, Y
MASK_BOTTOM.art BOTTOM SOLDER MASK (SECONDARY SIDE) z' I" l" u) ], [. X/ Z
FAB_DWG.art FABRICATION DRAWING8 ?( l9 M# Q! m& t7 A0 U( l
ML510.DRL NC DRILL FILE
5 o5 v; X4 o8 k% }1 kFAB_DWG.PDF FABRICATION DRAWING IN PDF FORMAT
* ~# H" L- K2 B3 p6 u3 J LML510_REVB.IPC IPC 356D NETLIST |
