查看: 1631|回复: 6
双面板灌铜问题求教
发表于 2009-2-7 08:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
最近做了一块新的双面板的板子,在灌铜出现如下记事本信息,可以灌铜:
1 g, p+ i2 l- S+ J& U- w/ k+ J# ~, i0 ^! o4 g1 B5 g
; S# R% h% S9 R6 |, {; F
THERMAL RELIEF ERRORS REPORT -- QS-MSPD03-A1.pcb -- Sat Feb 07 06:51:27 2009
' H* J' e  H( s% o8 p9 W  P" Y3 [8 G8 o4 {1 |" j+ R8 J
       Drilled pads with                    Nondrilled pads with
/ W- S; z/ E, K8 Gless than 50% thermal extensions      less than 50% thermal extensions+ E1 }1 `) M$ |  E2 D0 T! W' U7 H4 V5 n) r
Report of Thermal Spokes Generator.# {0 i9 q4 ~' M. Q: \7 z
On Bottom:% }  i' {$ Q6 e$ r; E
                                        CON1.59 (101.294, 22.81894) # = 06 j' j" x) }" P
                                        J1.6    (1.35567, 81.92433) # = 0
/ d6 c8 @2 F7 ^% \- k3 L                                        J1.5    (1.35567, 73.32433) # = 07 n' Z5 U. B  m& `4 g
On Top:
6 F% D( b! w- g                                        U3.28   (38.24533, 6.996) # = 0
/ ?3 J$ \2 f% z& `( G/ h                                        U2.91   (48.22467, 46.587) # = 1
1 N  V. O4 A6 F1 G7 ]( @! \* b                                        U2.33   (37.29967, 29.662) # = 0
) e4 R% y! n  K% c5 y% T* D, T                                        U2.30   (36.09967, 29.662) # = 0/ i% H+ B4 z& t2 `5 y9 u* d6 q8 d2 E
                                        U4.38   (7.21033, 33.401) # = 0: N+ a' p4 t0 b& }
                                        U2.115  (43.29967, 55.912) # = 1
& _% W' L* a& ?7 a$ a, q# H2 X                                        C121.1  (24.97, 61.60933) # = 1
; v) I5 E8 R( Q% Z1 w                                        C65.2   (31.38433, 61.60933) # = 09 P; W5 b# W1 c. v
                                        C34.2   (26.72167, 61.60933) # = 0
% h6 k4 r8 H9 I- R( J                                        CN8.1   (77.11, 45.22633) # = 0  |+ [3 L( n# ~5 m* c, ], r
                                        C26.1   (96.876, 50.80367) # = 1( c! ~. @% j: M
CN1.2   (92.893, 81.84633) # = 1+ y- Z) {1 l. v3 ?0 {# u% C( D
                                        C88.1   (38.54833, 65.999) # = 1
& d* z2 Q, Q/ i                                        C18.1   (83.90833, 14.99367) # = 1
1 N# j2 s/ H0 }' A$ D. P                                        R12.2   (82.59033, 9.459) # = 1, K' q6 M. ]/ o) K8 p
                                        C107.2  (108.83067, 24.37833) # = 07 I  B) Q6 _2 o4 z
                                        C116.1  (104.612, 23.685) # = 1
/ W/ N  m; B4 J                                        CN7.29  (114.48167, 46.79733) # = 0
7 K0 d7 v9 u5 f' n% r                                        CN6.16  (73.89233, 27.71833) # = 0' d2 t" w4 w8 u
                                        R117.2  (97.751, 34.52467) # = 0% w7 ?6 s5 J! L6 \4 x/ W! X3 @: r( b
                                        Q11.2   (52.23133, 65.47267) # = 1
% ]! N0 p7 R* F) [                                        C91.1   (65.06753, 36.39501) # = 1
& B0 }# V8 v% y0 a% M                                        C57.2   (57.362, 22.507) # = 0/ ^, ^- [6 N( i) w/ H+ F6 u! n
                                        C113.2  (71.72767, 30.46967) # = 16 B5 x; d" x; o0 @# p- D
                                        U7.7    (21.968, 23.83633) # = 00 s! W# V  f% y! z/ y% h
                                        R20.2   (100.10933, 8.49433) # = 0
" M6 }5 Z% T( N2 I' \5 ~, ~                                        C67.2   (21.47, 20.647) # = 0
$ l) p4 O9 x; \2 ?. G( @                                        R127.2  (97.876, 36.15167) # = 0: w. N) }/ f3 w  h1 n: L2 j- E, q9 n' F
                                        C80.2   (32.66633, 17.85967) # = 0/ x8 s( v& \; t1 }/ d  y- H; J
                                        CN6.7   (73.89233, 23.21833) # = 0+ i2 }6 c; z9 n8 H% A& m4 v
                                        C40.2   (17.489, 50.371) # = 0" \" A; _3 k; b3 U$ m
                                        CN8.21  (77.11, 55.22633) # = 0! U: I+ i/ Q6 l# G% @! r1 }3 ~" _
                                        C39.2   (109.961, 20.211) # = 0: U" b( G  L. h$ i" K
                                        CN8.26  (77.11, 57.72633) # = 1; W9 u6 I8 m1 {- a% d; ~9 l1 ?
                                        C21.1   (69.32467, 6.146) # = 09 F5 x% b/ }6 w2 ?" B  s
                                        D2.2    (93.05307, 8.08817) # = 10 R0 C- |" x* {0 f' O8 S
                                        C51.2   (53.16633, 47.10233) # = 0/ v8 l4 g% U5 g8 T; M; E
                                        ZD1.2   (100.73467, 18.71433) # = 1
5 {1 S5 t3 f' a: b) ^) \                                        C89.2   (49.505, 61.53967) # = 1
% M6 T7 y2 y' c" b) D                                        R59.1   (39.99533, 63.06367) # = 1
# X# e! k, A6 a: F) F                                        C82.1   (37.22967, 63.06367) # = 0
3 S2 H# ?* n1 ]                                        C81.1   (38.589, 63.06367) # = 0
" a4 G" X2 V4 o# M* l, ^                                        R64.1   (35.84823, 63.06357) # = 0
* U" T6 E' G- \# x5 Y0 ]1 C                                        R6.2    (19.39533, 61.16) # = 1
% l. ^/ i( w1 [3 O. p0 c                                        C96.2   (50.354, 79.19) # = 1( h$ h( l: V& j) \
                                        C53.2   (17.92133, 45.94567) # = 0: U( ~; F8 x8 V9 N$ m: o
                                        C86.2   (41.31433, 63.06367) # = 15 T$ Q3 u  n4 s! v6 i; T
                                        C87.1   (45.903, 60.085) # = 1
& l6 a% g2 \3 @8 y/ e                                        CN8.27  (79.41, 43.27633) # = 0- C; @" T: I, S. k
                                        C124.1  (103.66167, 84.20467) # = 0
4 w8 A9 [7 b2 W1 F                                        U8.3    (98.70567, 86.39) # = 0# }+ F- e' u/ X$ O! w1 s" U6 X
                                        C45.2   (14.993, 46.32267) # = 0
1 y" d0 k. a( i. j1 F+ r                                        U4.13   (8.21033, 13.801) # = 0
8 c7 E5 l7 A5 w9 U                                        R33.1   (16.271, 52.34533) # = 0
0 Q# ^3 ^+ h( g, m+ a; v7 o                                        C27.2   (17.80433, 55.72233) # = 04 ~% d4 ^( w% y8 A
                                        C78.2   (42.75068, 59.99373) # = 0
. {5 H5 ]% y, V, x3 g+ {CN5.1   (3.179, 37.31367) # = 1$ S7 j% [" }! R% v* {+ B
                                        C62.2   (57.127, 5.22033) # = 0  |& p, q( J  a: K6 k% R# M3 U  ~- t
                                        U3.52   (57.44533, 6.996) # = 0% E; i% j9 d9 Q; ]
                                        U3.41   (48.64533, 6.996) # = 1; `% h4 M( G/ W; H
                                        U3.46   (52.64533, 6.996) # = 0' A. f* `* j7 T) Y; z
                                        U2.104  (48.22467, 51.787) # = 1- X/ G! e' Y- b5 e* g$ {+ p
                                        C75.2   (40.14312, 59.99373) # = 0
/ T8 v+ L5 l" }9 c  b                                        U2.130  (37.29967, 55.912) # = 0
+ Z6 n$ u) p* i$ f4 ?, s6 M0 h                                        U2.175  (21.97467, 48.587) # = 1
1 B% P6 M( |0 x5 z2 r6 d                                        U2.168  (21.97467, 51.387) # = 10 o2 l; Z2 a' t9 n$ V# j
Total Drilled pads:    2               Total Nondrilled pads:   671 i0 K: h! y4 q1 S7 C8 |( k
Report of Violating Thermal Spokes Remover.
- ]; W/ @2 ?3 e, D5 G6 I: bOn Top:
! \0 p9 u5 h- n                                        U2.16   (30.49967, 29.662) # = 08 n( u5 D$ q0 N7 h$ c
                                        U2.91   (48.22467, 46.587) # = 0. k$ I- B" ^/ O! O
                                        U2.101  (48.22467, 50.587) # = 0
9 L4 R1 a6 K: o+ Z6 @6 f9 n0 u. o                                        U2.104  (48.22467, 51.787) # = 0: Z( B; ~; t. z/ j1 n( t
                                        U2.115  (43.29967, 55.912) # = 07 l8 g  N4 c4 Z1 `8 k' v5 f
                                        U2.121  (40.89967, 55.912) # = 12 Y5 f1 V- a7 T
                                        U2.168  (21.97467, 51.387) # = 0" H5 W" N7 s: y
                                        U2.175  (21.97467, 48.587) # = 0
/ w; m$ N+ {: O  F2 ]: t1 WTotal Drilled pads:    0               Total Nondrilled pads:    8
3 y) e1 Z0 s/ `9 u" G8 \0 R+ e- X3 J请教高手原因?
发表于 2009-2-7 11:09 | 只看该作者
这个好像没有问题吧,一般铺完都会出现这样的结果,只要保证Total Drilled pads这项为零。个人见解,
发表于 2009-2-7 14:32 | 只看该作者
本帖最后由 steveshi 于 2009-2-7 14:34 编辑 3 p" Q, C7 C4 V5 T8 z
8 v% j: U! l) _: j: v/ J  ^0 _
CON1.59 (101.294, 22.81894) # = 0 表示这个pad(第59个pad)没有连接到ground,在检查的时候要连一段线到gnd之后,DRC才检测ok.
发表于 2009-2-9 17:21 | 只看该作者
這是spoke少於兩個的警告,一般都不太去理會..
 楼主| 发表于 2009-2-10 07:59 | 只看该作者
SMT元件铺铜不能满,是有问题的
 楼主| 发表于 2009-2-10 16:04 | 只看该作者
已经搞定了,原来很简单
发表于 2013-4-11 11:13 | 只看该作者
很简单是怎么搞定的?
GMT+8, 2025-8-3 12:49 , Processed in 0.109375 second(s), 23 queries , Gzip On.
