) k; |7 M/ D- [$ B( ]0 R! m奇怪!这个选项没有勾选,原理图有个错误提示,不知道跟这个关系大不8 U+ ^' }; z+ ?
ERROR(ORCAP-17054): The value defined for Ratsnest Schedule on this net is incorrect.This property will not be updated. Use the Property Editor to define the RATSNEST_SCHEDULE property. VCC3V3: SABRE LITE, 11 UART (187.96, 139.70)
, N; [& A# l) b7 eERROR(ORCAP-17054): The value defined for Ratsnest Schedule on this net is incorrect.This property will not be updated. Use the Property Editor to define the RATSNEST_SCHEDULE property. GND: SABRE LITE, 11 UART (106.68, 83.82) ( d* A/ C4 Z" D4 f# }; H+ H) {, M
: e( o, O/ C+ R: V1 ]1 A6 o
高速信号的约束规则检查& B3 h! {6 l q8 T
