查看: 1109|回复: 3
出gerber出错,请各位帮忙看一下
发表于 2013-5-16 21:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
(------------------------------------------------------------)! B, X6 z. L, O: r! S2 \4 }* K
(                                                            )+ A( O# m+ b6 e+ Z2 P5 h$ r
(        ARTWORK LOG                                         )9 z8 D/ x  f) n, z4 r
) E- F3 e+ W# F! n3 j4 v(        Drawing          : MSI-1358_V1_1-key.brd            )5 G4 b, i. P4 D$ d  ^( [  v
(        Software Version : unreleased                       )7 t- U! C  h" u# [
(        Date/Time        : Thu May 16 21:19:25 2013         )7 c( L7 i2 e4 [4 X: G
(                                                            ); `$ Y8 X& ], A7 ~9 r8 _7 C
(------------------------------------------------------------)1 ~5 s' |! d: ~: P
1 _* d  K3 l" M! Y8 j: i6 ~, y: Y, Z( y6 p' s1 n6 u9 }
. |6 R% Q5 ^  q: l9 N, Q ******************************************
: a( {$ M/ b0 s7 j WARNING: DRC OUT OF DATE on this layout.' q$ z6 G2 c8 S7 h8 x9 U
2 V4 e' g0 a% B" G! q! s2 ]
. T$ u& k! }1 Y/ x4 _( m0 n2 c* b ---- Photoplot outline rectangle not found ... using drawing extents  W- R) `5 Q3 ?
& A& I1 d" m. ]( ^6 ^9 B
8 D( N- z8 f4 y9 O4 l* P
3 {- K& t. S3 ?, `7 L3 xResults from parameter file ...
! N% b4 g5 _: ?3 }) O1 Y    DEVICE-TYPE           GERBER_RS274X1 w# A6 n4 G: X9 }* y  w
    OUTPUT-UNITS          INCHES
: J. d6 f0 v% i, P    FILM-SIZE             24000 16000  C& h) n% l$ a1 u1 v
    FORMAT                5.35 a, r! y5 `  U; x, @
    ABORT-ON-ERROR        NO
6 q0 u+ f, \5 \: x9 Z    SCALE                 18 F, c' r) Q5 ]1 _3 ^1 C
    SUPPRESS-LEAD-ZEROES  YES
5 \. U* K/ @* E- y+ o; m    SUPPRESS-TRAIL-ZEROES NO; r( t/ M2 H- l# \$ a- O% s
    SUPPRESS-EQUAL        YES* r+ r- V1 W/ f, l3 q4 N
    UNDEF-APT-CONT        NO; _) _6 z; X- c/ a
4 x/ R( z( [% k3 Q WARNING: for raster artwork formats, artwork accuracy must be
  T# T8 r. @% t  at least one place greater than the database accuracy, up
! X& ^7 ^' O7 R0 B  to the maximum accuracy allowed by the selected output format., a- a( t6 A) `- N- p) o
: ^. a8 ]9 G, x' i* }
  Increase the accuracy by increasing the "Decimal Places" in
5 N& I9 n# G4 |9 @  the FORMAT section of the artwork parameters and then rerun4 a8 w! {% F8 W3 K
  artwork.
/ f: Q& u7 E+ I  ~7 Y1 \) K  k, B9 N+ f6 u# Y
  The current output is rounding down the data.  Failure to change
! L( L2 W! L9 c6 U, i  G  the format may result in inaccurate arc coordinates in the output! l; M5 J6 ^9 d
  files and possible shape/void plotting failures.
# L$ n( \# m8 C" V- d4 v- S
8 n: L3 C4 `1 h2 a0 h8 |" m& \  V3 V
+ w% S9 _+ d1 \/ c( j: i9 E* f     PROCESSING FILM < drill >
3 c# r$ x3 `' u0 g     TO FILE < D:/Documents/Desktop/99/drill.art > ...
& }. j, H" @# }' d# F' ?6 w================================================================
" W, d! a7 B3 Q2 |& l' q' t: R3 V% L: A! g3 @' ]
  FILM PARAMETERS :
+ ^! I$ B# W" @* M9 ]! u5 d% f% X9 g  ---------------------------------------------------------
% I8 B3 P' J' y1 M# F  Undefined line width                5.00
7 m& u& ]1 _, I9 ]. _2 B4 Z  Mirror code                         NONE
2 `# ^8 k* k- r$ Q  Rotate angle                        NONE1 f/ @% _; f$ G& F
  Offset x:                           0.00
8 ^9 B/ s) \) o+ q& I5 {) u  Offset y:                           0.00. E2 [8 @& m6 O5 Z. C7 a
  Plot negative                       NO. \* F, {. ~# I
  Suppress unconnected internal pads  NO
9 p# t' z* D' R9 y  f! o% z7 ^( a, b1 p( n0 {
    WARNING: 0 width line found at (17257.00 7693.00)0 W7 k; [3 q( q& x4 W+ P9 K8 T
           ... using undefined line width of 5.00
2 r3 C6 M) v& Y' g# F7 T! J$ Y  n8 ]1 p. r5 c, G! N
    WARNING: Multiple 0 width lines; all will be treated the same as the first.
3 ?0 W$ Z* l4 Y$ S+ ]7 z           ... using undefined line width of 5.003 s  u* D6 k( n+ }! F
8 \- p- [3 h0 ~9 w    WARNING: text composed 0 width line found at (17706.50 10596.50)
- ^& n  m1 Y6 ]- S$ d1 b& B           ... using undefined line width of 5.00# _: w( }  u# n
. Z! L2 j9 w/ K# g: s7 v+ i6 j
    WARNING: text having Multiple 0 width lines; all will be treated the same as the first.. C& _1 ~7 {( a" w" u- }
+ H. d- g4 e% w* L% o6 w7 o/ [: s1 c) {: \+ u# E
) \! f: A3 ?/ N5 D) u( o2 q% ^+ m7 ~- t/ c3 R3 X/ {& ^% N  |
  APERTURES USED:
9 `: r7 T* p8 g% {' U# O) ]  ---------------------------------------------------------* v# Q4 I, ^* b' J: v
  TYPE       SIZE/NAME                   ROT   MIRROR MODE / }( T0 B* a& f- r4 s
  ---------------------------------------------------------6 u( m% r( [3 F) y. w3 E' L
  CIRCLE     0.00500                                  DARK $ f  Z  j* @( |' C! Y6 x
# f  D. {9 N1 ?: X' O9 ~; S     drill created with warnings- t& n: N% i9 i6 y7 r; B4 j
" ]; i! S0 K" T- E- ]& ^' l
" e- ]/ X1 x/ B6 G8 K0 o+ |
! g$ N" K; G+ l2 A     PROCESSING FILM < solder_bot >
( K/ w' m; d$ M1 f9 J     TO FILE < D:/Documents/Desktop/99/solder_bot.art > ...
. K0 e" a4 ]8 y% P( T  t4 y) v================================================================! ]7 n  u4 C6 l# V
# n/ l+ t) W. M+ b( r9 h
  FILM PARAMETERS :
, E4 z' o1 v1 l. t+ I  ---------------------------------------------------------2 a+ r* e+ H; F. W. r3 ~
. K$ H: ?! P. k. ]8 }  Mirror code                         NONE
! k# L, ?3 W4 o, s/ i- a" n/ O  Rotate angle                        NONE: l3 I6 w$ P$ {! Y7 g. |3 c
  Offset x:                           0.00
. V7 u9 |/ B% r3 D4 D9 [; }  Offset y:                           0.00
/ ~; ?- u. a5 Y! r; V& O  Plot negative                       NO
( s% B, v- `. W8 `$ D9 G% W& Z  Suppress unconnected internal pads  NO+ q7 t- [8 Z; [
) g4 E% C/ W" ^/ U
2 Y1 q% \+ Z3 J
6 g0 d+ I" ^$ b, V3 @% n& I  APERTURES USED:
! k+ C3 F, }+ W9 @$ b: e  ---------------------------------------------------------: \/ I( {/ R, Q* `3 o9 e4 V
% f2 g6 h/ j. B# U' O  ---------------------------------------------------------
, R2 p: A1 L0 t; s9 n  CIRCLE     0.00500                                  DARK   n& s/ z. \2 v4 _  m
  CIRCLE     0.03000                                  DARK
% \0 ?! j# \; }/ P" u6 `  CIRCLE     0.04330                                  DARK
0 r: c7 v' m3 B7 N  CIRCLE     0.04600                                  DARK
9 ?4 G& M- Z  @" b  CIRCLE     0.04900                                  DARK
: ~) o* G, k  W3 T  n: K# ?5 \  CIRCLE     0.05300                                  DARK
5 w$ F& Q5 b6 R# K5 c; `  CIRCLE     0.06000                                  DARK
; p- I. {$ m# q0 Y% u+ q  CIRCLE     0.06100                                  DARK
+ x9 b2 Q( A- b, }6 x8 f: f  SQUARE     0.04200                     0.000 NO     DARK ! X, c: d1 b0 B8 c  {6 [
  SQUARE     0.04600                     0.000 NO     DARK
. V+ H( \- c# j/ _5 Q: y  RECTANGLE  0.02600     x 0.03000       0.000 NO     DARK
6 J* p" p/ f6 M* Z+ e/ r  RECTANGLE  0.02600     x 0.03000      90.000 NO     DARK - S* t4 X; Q- O
  RECTANGLE  0.03800     x 0.02600       0.000 NO     DARK : p% u6 `5 A- U# D& M3 \
  RECTANGLE  0.04000     x 0.03600       0.000 NO     DARK 0 l2 Q4 n5 _: C: k" u& ~9 P
  RECTANGLE  0.04000     x 0.03600      90.000 NO     DARK
" v1 D8 L( X1 _6 L8 T  RECTANGLE  0.04200     x 0.05600       0.000 NO     DARK
( ?; D; j5 D1 }3 Q. i0 U  RECTANGLE  0.19685     x 0.19685      90.000 NO     DARK / d3 L( I* p, o5 W1 k* H3 J+ G4 ^! i# |
  OBLONG     0.01378     x 0.04331       0.000 NO     DARK
& @) Z: B) q9 S" S& |9 ^# O  OBLONG     0.01378     x 0.04331      90.000 NO     DARK
% M2 Y3 q7 y, }6 ]7 K  OBLONG     0.01600     x 0.03600       0.000 NO     DARK
; u8 D0 c& j! X$ Z4 s/ k6 Z' Y  OBLONG     0.01600     x 0.03600      90.000 NO     DARK
. U6 e& T! W8 X& n  OBLONG     0.06000     x 0.15900       0.000 NO     DARK
7 L# W  f5 ], a  OBLONG     0.07100     x 0.14400       0.000 NO     DARK
  C( o( z7 e7 `- s  OBLONG     0.07100     x 0.16700       0.000 NO     DARK
5 w* Q' _5 D& C, ^3 |  OBLONG     0.07500     x 0.15600       0.000 NO     DARK
  g: ~( T4 W; o  E% L4 w1 D  PAD SHAPE  SHAPE26X34                 90.000 YES    DARK
( D6 u0 z% `  A  PAD SHAPE  SHAPE26X34                270.000 YES    DARK - a( l9 Q* _% C
! _7 w% @3 v+ R* q* x
     solder_bot created with warnings" x- D$ f; P4 Z; u( Q, K" u0 ?
( h' d! R5 `6 ~2 E
$ J7 e! ?" c* q. \" \================================================================
3 a8 [! j, {5 R$ [1 w6 P. B8 o     PROCESSING FILM < solder_top >" c- p% @4 [6 r- [1 w- i* U. Z6 ~/ U
     TO FILE < D:/Documents/Desktop/99/solder_top.art > ...+ G  F4 t" a. J8 Q% {# T0 e0 y" B
( W  ~3 D; V5 P+ r* \
' G& n, x% `* s8 u2 @5 T# P) d1 L  FILM PARAMETERS :
& |+ i' I3 ^1 H( E4 K6 d9 _  ---------------------------------------------------------2 r2 v8 T+ K* g0 V( y
) d3 l2 D6 \. ?1 n  Mirror code                         NONE
* J. f9 {) Z6 F  Rotate angle                        NONE
% J6 V8 j0 q, a6 E$ Y2 b5 e8 G3 i  Offset x:                           0.00' l  u, J2 b6 p. }. j
  Offset y:                           0.008 f' T* a3 L$ L7 C2 s# F4 U
  Plot negative                       NO$ c# c1 @+ Q) g% R$ |7 ]( W: \
7 E+ n6 r5 ]& H$ O' j+ D  q3 e
# Q% p5 f2 Y! p! N5 y
# @5 ~1 x0 V4 ]! }+ x: Y7 ]. V( B  APERTURES USED:$ p, A! B# E1 [
  ---------------------------------------------------------1 D* \/ E. x1 `5 J1 g  [
  U' M9 u  ]" d1 y  ---------------------------------------------------------
1 H+ p+ w' R7 k% o) [  CIRCLE     0.00500                                  DARK
2 z3 a2 w$ q9 q  CIRCLE     0.03000                                  DARK . a& A' g& {3 H+ d1 R* [6 G; k0 ?
  CIRCLE     0.04600                                  DARK - Q% q8 d5 G1 E& ?, o7 r, S( L
  CIRCLE     0.04724                                  DARK 9 i4 Q# j( O" `) M
  CIRCLE     0.04900                                  DARK 9 \; p6 d9 @2 H  @, ^% s- j# V, K) _
  CIRCLE     0.05300                                  DARK
$ X& B/ D  j' x  CIRCLE     0.06100                                  DARK   I& g7 G! m# E
  SQUARE     0.04600                     0.000 NO     DARK 1 H; `8 {/ m& R1 @
  RECTANGLE  0.01600     x 0.05300       0.000 NO     DARK & W' K8 k2 J9 A4 ~9 _; H0 \0 M9 A. J7 l
  RECTANGLE  0.01700     x 0.10800       0.000 NO     DARK 8 ]& D' a3 k) N3 g$ t3 h7 O1 x
  RECTANGLE  0.03600     x 0.10400       0.000 NO     DARK 6 [, [% c; d( v4 \! ?
  RECTANGLE  0.03800     x 0.10400       0.000 NO     DARK
9 Z9 U7 _1 t( o# f% K: [  RECTANGLE  0.04900     x 0.10400       0.000 NO     DARK
1 g; \8 K5 ]% u' F' _* H, E  RECTANGLE  0.05500     x 0.10400       0.000 NO     DARK
: b2 F; Y, @  Z5 l! C. J& d! z  RECTANGLE  0.06300     x 0.08900       0.000 NO     DARK 2 I0 I# y0 e/ f$ q
  RECTANGLE  0.06500     x 0.08500       0.000 NO     DARK
3 |$ P# i: E( W; r1 s5 A* P  RECTANGLE  0.07100     x 0.08100       0.000 NO     DARK " H4 r1 m3 j# k1 s4 x( m9 y
  RECTANGLE  0.09300     x 0.14400       0.000 NO     DARK
1 J% @( i, I- Q3 E* c7 S/ c  OBLONG     0.03100     x 0.08100       0.000 NO     DARK 1 ^7 P- U: S4 a3 r, n  L0 r6 [4 [
  OBLONG     0.04100     x 0.08100       0.000 NO     DARK
& @  P2 b1 }% D  z0 @7 K  OBLONG     0.06000     x 0.15900       0.000 NO     DARK
/ Q8 ^* j% V$ M, x* z8 m& t$ \  OBLONG     0.07100     x 0.14400       0.000 NO     DARK
; ?0 E  y2 H, x5 m: A1 L8 Q  OBLONG     0.07100     x 0.16700       0.000 NO     DARK 6 e; S- m/ n* g4 t1 g( m
. R8 h' ?8 v' j3 e$ B8 \2 [  OBLONG     0.08394     x 0.03346       0.000 NO     DARK
* |( X: o6 S: D& ^0 E4 B2 ]! o  PAD SHAPE  SHAPE26X34                  0.000 NO     DARK
3 c& T' P  Z9 n( S& \  PAD SHAPE  SHAPE26X34                180.000 NO     DARK 1 ]' l7 D6 Z$ d4 ~; [. j( {
) b& p# T* A! j! ]! u
     solder_top created with warnings
, n/ |' {  x' y% I/ \8 C* b
. f. T* a4 _1 M) _1 n6 @5 P2 u% _- c4 o8 }. v
' B; m# k% N3 ]* @7 ^) f% H( o     PROCESSING FILM < paste_bot >! h: T0 K4 n8 P3 H% S
     TO FILE < D:/Documents/Desktop/99/paste_bot.art > ...
# |( F% b$ c9 O: o) g; E================================================================
9 x+ ~) Y; I4 s' `+ L. l7 m2 x) k; b
  FILM PARAMETERS :
, j" y1 U; u+ k/ f  ---------------------------------------------------------
9 t* Y9 Y: ?4 x- ?0 X9 l" R  Undefined line width                5.00
" I% C6 W) a& w; b) {4 w  Mirror code                         NONE
+ @% {- o+ D% @% o( F  Rotate angle                        NONE
% O$ c( i, D* V. D  Offset x:                           0.00
# z' }7 M% r: l( s! t. o' l- l  Offset y:                           0.00# ^1 n0 m3 o: v  p+ a+ \
  Plot negative                       NO$ d& \( l2 y& o* S9 |0 \
% @% L& U( X+ s* y! z
/ }& H  n+ @- V: T, l) {+ ?+ l0 f, g$ D  U
: J3 ]4 S8 o1 H3 ~& z6 a/ Y
  APERTURES USED:
) Q( n  r: g/ m; ^+ K; E  ---------------------------------------------------------
/ k# h% s1 o  {$ [! X' U  TYPE       SIZE/NAME                   ROT   MIRROR MODE
1 g: C: w% }6 S3 {0 s  ---------------------------------------------------------! j& y, r! r+ L" O/ v# n
  CIRCLE     0.00500                                  DARK
  x# z* w  s: \) C* v! s  CIRCLE     0.03940                                  DARK $ n0 k% P9 X1 P) x- I, R
  CIRCLE     0.06000                                  DARK
9 r* d$ q# q+ F8 f4 J" z: a  SQUARE     0.03600                     0.000 NO     DARK
8 N% ^# q7 }/ C  RECTANGLE  0.02000     x 0.02400       0.000 NO     DARK # W( O! @3 g) ?1 L- l- g, d
  RECTANGLE  0.02000     x 0.02400      90.000 NO     DARK
9 g2 |% S9 N7 i) ^5 T0 j' ?  RECTANGLE  0.03200     x 0.02000       0.000 NO     DARK
( c! @# d9 [% g" ]  RECTANGLE  0.03400     x 0.03000       0.000 NO     DARK ( ~# P2 o# m6 |
  RECTANGLE  0.03400     x 0.03000      90.000 NO     DARK
* U0 H, q& [+ I3 s2 h3 I7 U  RECTANGLE  0.03600     x 0.05000       0.000 NO     DARK
% j( Z$ B8 ]( U$ C  OBLONG     0.00984     x 0.03937       0.000 NO     DARK
! D: z+ ]% {: ?. k6 N1 U  OBLONG     0.00984     x 0.03937      90.000 NO     DARK
$ }! v, @5 s5 k, `% r% h  OBLONG     0.01200     x 0.03200       0.000 NO     DARK 5 b- ?  U  x8 v
  OBLONG     0.01200     x 0.03200      90.000 NO     DARK 6 m) ~, H0 {% o$ K6 d! T
  OBLONG     0.19291     x 0.19291      90.000 NO     DARK
' ]# M3 f" `# [% c) b+ s  PAD SHAPE  SHAPE20X28                 90.000 YES    DARK
' c; \  Y: a, e" p9 H' p9 n  PAD SHAPE  SHAPE20X28                270.000 YES    DARK
; S  _1 M2 p( }7 x" C. {2 |8 U. K' J3 z, ^4 m, c+ d
     paste_bot created with warnings
" t3 {. [! d5 q0 f# e1 D7 @. f+ _' d0 q$ \# W" z# Z$ S/ M% h
- m& u, a7 M( R  h0 u; r================================================================
* O0 F9 d' W7 u% t" g$ |" Q     PROCESSING FILM < paste_top >& D9 f6 z: |4 S9 E5 N; T
     TO FILE < D:/Documents/Desktop/99/paste_top.art > ...
; j4 A& n1 j5 B6 x% ^2 e================================================================
( a( ~" p. f1 b% h4 `6 _- E! `- S- ]" q% J* H2 l! I3 {) Q# I
  FILM PARAMETERS :
; w: @8 P! S/ |  ---------------------------------------------------------
4 z) c& T' R6 S7 g- I- T: g" T  Undefined line width                5.006 b% t# a3 }% A! O8 I
  Mirror code                         NONE$ \6 Y" A4 `7 q8 i+ {' s
  Rotate angle                        NONE
5 W4 w( r" w  Q8 f3 H" x6 j4 o  Offset x:                           0.00, X3 a4 H& s4 ~4 X
  Offset y:                           0.00
6 t9 G; R% H5 v3 T! }+ Y  Plot negative                       NO
7 W& I2 j$ x- W  Suppress unconnected internal pads  NO2 q. a9 }: H( i; Y7 Z! h6 T
7 X1 }* m. I- U5 U6 R6 p2 K9 t8 q9 _! u7 X% T  A, o
2 Z1 a, c" G! `& j  APERTURES USED:
/ o5 G/ h! P9 q6 X  J& j% {  ---------------------------------------------------------; J8 u  i; C. z" ~3 B0 Z3 Y; }$ k
- m  y# L1 N, _0 g  p7 z  ---------------------------------------------------------
- E7 M" A, G6 T8 l& t. u  CIRCLE     0.00500                                  DARK
( w) V9 J" \0 X! K% p1 l! ?6 @  CIRCLE     0.04000                                  DARK
6 G) h, {6 j/ E' g/ w3 S! }1 M  CIRCLE     0.04724                                  DARK " a- U9 L( W& e+ g7 Q) e
  CIRCLE     0.05500                                  DARK 4 Q7 O) A" B# s! G
  SQUARE     0.04000                     0.000 NO     DARK
5 K# V3 e7 x0 _" R4 {) }  RECTANGLE  0.01000     x 0.04700       0.000 NO     DARK
) z0 f3 C  `7 o, \8 C0 `! X  RECTANGLE  0.01100     x 0.10200       0.000 NO     DARK - S. X7 d( C/ V! o
  RECTANGLE  0.03000     x 0.09800       0.000 NO     DARK
7 y/ N/ [) F5 o6 `) ]# U  RECTANGLE  0.03200     x 0.09800       0.000 NO     DARK
* q( S, O, l( Z3 V8 E  RECTANGLE  0.04300     x 0.09800       0.000 NO     DARK 7 F2 d& Z) i; D# q3 v& g
  RECTANGLE  0.04900     x 0.09800       0.000 NO     DARK
9 G* P8 u- k/ \5 l; A. e9 Y  RECTANGLE  0.05700     x 0.08300       0.000 NO     DARK / B& Z! \) F9 F7 L2 o# d: `) B% N
  RECTANGLE  0.05900     x 0.07900       0.000 NO     DARK
1 N# v* [; M* k) H  RECTANGLE  0.06500     x 0.07500       0.000 NO     DARK
7 x0 O9 ]4 _* k- Z  RECTANGLE  0.08700     x 0.13800       0.000 NO     DARK 7 F& g( ]2 _8 u' g' o) T. @% d6 r
  OBLONG     0.02500     x 0.07500       0.000 NO     DARK
/ m4 O+ l8 b' i- C$ d4 {: O* H& W. h8 r  OBLONG     0.03500     x 0.07500       0.000 NO     DARK
/ I: }0 _2 K& P/ |7 L; h, x% y: C  OBLONG     0.05400     x 0.15300       0.000 NO     DARK
% H# ], X; w/ W  Z( C7 }  OBLONG     0.06500     x 0.13800       0.000 NO     DARK , G% u2 t  ^: |6 ?
  OBLONG     0.06500     x 0.16100       0.000 NO     DARK 3 T9 r5 f. V3 ?' A& g/ J. X
  OBLONG     0.06900     x 0.15000       0.000 NO     DARK + D, J, R0 Q' \4 C: g% p
  OBLONG     0.08000     x 0.02953       0.000 NO     DARK
) t2 `/ a* Y5 a& H0 t( f  PAD SHAPE  SHAPE20X28                  0.000 NO     DARK + o; j) \5 ]2 N' W$ g4 z# K4 p2 J5 z
  PAD SHAPE  SHAPE20X28                180.000 NO     DARK + T3 M# {- @* I. j
3 T: P0 `' W; l1 ^: n, u     paste_top created with warnings1 H' Q/ x& s! h3 P1 G
! d: y, N4 I- J) `* H
* _9 J9 a& M, h8 V1 b7 S================================================================
  T3 T- i4 v  l9 v     PROCESSING FILM < SILK_BOT >- Y1 F% P/ J* l+ x$ v
     TO FILE < D:/Documents/Desktop/99/SILK_BOT.art > ...
! W' S8 r4 B, Q================================================================2 m  z8 b4 y' Y$ ~- T' r
; E  A* l1 `& ]2 n9 i- s; d0 d
  FILM PARAMETERS :1 c) n! f7 K5 `( e* r( a
3 x+ d! U. U2 c$ v  Undefined line width                5.00
% I6 ^( v4 B/ W  Mirror code                         NONE
; X- J7 l! I( q* T5 r) k: P  Rotate angle                        NONE/ i1 M* {4 ^; |
  Offset x:                           0.00, G7 {! X3 {5 ^# K
  Offset y:                           0.00) R2 ]" z1 j* o% s$ @/ J( Y, }0 i
  Plot negative                       NO
) I) ^$ f5 o5 q. \% D! _  Suppress unconnected internal pads  NO
4 d: B( Q) I. e, H6 P& F- j$ q& c) Y
% l- B; A1 R/ f  L2 u+ ^3 I9 }, E% a
  APERTURES USED:
  L; D+ b: W, t5 p" y4 S: C  ---------------------------------------------------------
' l' h' `. j. Q9 n  TYPE       SIZE/NAME                   ROT   MIRROR MODE
3 q. z2 `3 U& P  ---------------------------------------------------------
4 |  X3 a* s8 g# ?* c  R) G  CIRCLE     0.00390                                  DARK 4 o" S. u& b- x8 Q+ k* P
  CIRCLE     0.00500                                  DARK
/ S$ c3 o# ~3 v) z( i7 u, A8 a  F" \0 ?# ]) w* y: ~# ^
     SILK_BOT created with warnings" \' t# w! C7 z1 j% E) s
( G3 o8 M  t+ w- W5 F$ {
1 k& _' H- j+ E3 n8 ~6 c
================================================================; [, k- f5 X5 Q( d- i, V& [  R! y
     PROCESSING FILM < SILK_TOP >8 w) F/ y! B  h! z) a  f. d
     TO FILE < D:/Documents/Desktop/99/SILK_TOP.art > ...
, N. A+ x  T& R. R1 D================================================================
7 m1 |% \- i9 N9 E) W) n6 V4 i" [% q( m) ~. R, ?9 J
  FILM PARAMETERS :
! S# F, f6 O1 x' Y& C* {  ---------------------------------------------------------6 ~: v. }9 [0 ?
* c9 m2 C/ @! ]  W2 b$ v  Mirror code                         NONE/ I% a3 e% [, }4 G1 `  l
  Rotate angle                        NONE
; s% E, a# p; I0 T1 k8 o3 i! j  Offset x:                           0.00
9 H  U0 Q2 G5 W5 W; W" `  Offset y:                           0.00
. j8 `" }6 }" M+ c# ^# R( m6 \  Plot negative                       NO# k) b* V) S; [: W& `
. _# A5 h( U* A+ W3 m% ^8 b" k% T; r, T: a
    WARNING: Segment with same start and end points at
4 G) w8 `' p7 ^2 i" h7 ?        (9516.44 9028.15) will be ignored. Increasing output
4 s: n  @5 W6 s        accuracy may allow segment to be generated.
% R  F, }0 E* \3 v6 ^; r/ i  b- ^& M, Q, E4 v, y
% k6 E$ W0 r' Q; {( F1 f        (9526.69 9029.69) will be ignored. Increasing output
9 E" N0 S3 C5 Q; k" {6 Q# I: [        accuracy may allow segment to be generated.* y1 [( q% Y$ [& P* A
2 A, I6 W+ a  P4 Z
    WARNING: Segment with same start and end points at, c7 e) W, R, y  G+ Z
        (10127.72 9269.39) will be ignored. Increasing output4 V6 I5 f0 i, J6 o
/ F/ f0 F) g) J$ R. F5 K+ Y, J$ c% p9 P
    WARNING: Segment with same start and end points at( p& j( R: Z6 u
        (10141.97 9283.34) will be ignored. Increasing output
2 o' b6 O9 z" h1 ?        accuracy may allow segment to be generated.: H4 j, [0 }! r
. i1 q1 ?! x# K9 @1 _
/ R) l) _8 E% g, O        (10127.72 9298.79) will be ignored. Increasing output: o6 `2 K. m% v+ X# f
- c  a- M! \- l  L4 m9 M' s3 W7 s9 E( C8 w
- d' h: w' s2 {" Z        (10142.84 9284.05) will be ignored. Increasing output
" d! E% n3 ~7 v) r$ W& i+ P        accuracy may allow segment to be generated.5 V# i  W! U2 I. a1 N# _
3 i4 Y, U5 g# ?) s, e/ W9 r( L: m* R
    WARNING: Segment with same start and end points at  A1 V6 m9 v) V8 [+ O1 u0 `
        (10128.02 9269.09) will be ignored. Increasing output
  m% k- l( l: r3 {) i7 Z. e( F: X# ?        accuracy may allow segment to be generated.
' _' L7 E6 z0 W5 G" O7 T+ W4 v$ P; i' A$ l3 I5 n! _
    WARNING: Segment with same start and end points at' a  ]  i7 Q! ]5 C. k% }
        (14925.41 7863.94) will be ignored. Increasing output
3 ]9 D7 J& P# u2 T        accuracy may allow segment to be generated.
1 S2 d- s0 U" H
4 _, t& m: d' D+ U    WARNING: Segment with same start and end points at/ k# T) Z% ^2 V' i; u0 f) E( p0 D: Z, K
        (13755.58 7716.52) will be ignored. Increasing output7 A7 P2 z. v' ~. ]/ I) `2 a: C+ a( m
0 E) s8 \7 g4 s) o+ [
$ i2 c$ W- v# e, S2 i2 [: H9 m1 |
( J: e: `6 d% `9 ^2 O1 o  APERTURES USED:
: P  O. }7 l8 W1 J  ---------------------------------------------------------7 U- F% u* M3 \4 y6 F1 _1 }- F
$ R* `8 d+ k* \( P  ---------------------------------------------------------# A8 A! O# \/ i/ z+ d/ t
  CIRCLE     0.00500                                  DARK
7 i1 h( k* T8 ~4 h* }5 s: V  CIRCLE     0.00600                                  DARK
, g. e5 ~) w6 ~8 y- U9 N4 D9 f% }  CIRCLE     0.00700                                  DARK % ~, l5 }6 I- B; c
  CIRCLE     0.00800                                  DARK
. s9 x" m, i* U! v1 ^3 v1 b
/ o" x3 ~" g; s" ^     SILK_TOP created with warnings
: v+ L- w. V5 g; U9 L( v3 y% X9 B; p& l) W5 B
* ^' e4 u& \# J5 g- q; b: ~/ ]================================================================4 T7 g6 g* `9 O  s8 {% x
     PROCESSING FILM < BOTTOM >. d3 h- }8 ^. A7 t5 c1 v4 f
     TO FILE < D:/Documents/Desktop/99/BOTTOM.art > ...3 }$ a% J! h$ b" [
- T; O0 h7 M( K( C. n' |/ {" z& b- Z( I+ f: K- _& P( L2 ?
  FILM PARAMETERS :9 E2 u/ B0 b2 ^, V4 ?
  ---------------------------------------------------------, P6 v- B8 L( P* d
  Undefined line width                5.00- l  n% L& I" A/ a2 |. M
  Mirror code                         NONE
& L6 _$ v* {# m+ F$ h; ^) |% ?  Rotate angle                        NONE, I7 [8 J6 J$ I; d1 l
  Offset x:                           0.001 w4 V$ V* i0 F
  Offset y:                           0.00  e6 g6 x: }  F1 q0 F
  Plot negative                       NO
( A% E, N" ?( R- c4 Z  Suppress unconnected internal pads  NO
1 G7 Q! t! A$ Z- N. d
. T' M+ v9 e- U1 m* G
9 @! ~9 ]; c: D7 [    ERROR: aborting film - Shape with first seg=(11210.08 7727.26) [layer=BOTTOM]
0 H; p' \- ]$ O* b% m0 d        has a void with extents [(12294.72 7788.51) (12369.76 7959.55)] that touches
$ G, c# p0 L" L1 o$ `1 I' {        another shape with first seg=(11210.08 7727.26). Manually resolve problem.
, i8 U& R" A* a' F- j
9 r, }( W" _6 _    ERROR: aborting film - artwork will not be generated!
5 a* L8 n: v) x0 [+ c3 F$ d- g, \% \ Error in BOTTOM--halting output.  Artwork file not generated.% Q3 S" _$ J' _$ l- o" D/ h7 o  i
*** ERROR with BOTTOM( F5 S" `; _  G2 e
4 P0 k& c1 Z; e5 Y( @7 }) O9 o/ k8 F4 M, u% P$ e- X; j& Q- G- z$ i( \& `
0 _. L9 q/ ?) H9 w3 q
8 J5 N9 q' p4 f: ~- A  \================================================================% n" O9 P. ?6 a* K
     PROCESSING FILM < GND2 >
5 g  H# t0 m: Z! u     TO FILE < D:/Documents/Desktop/99/GND2.art > ...
2 A) Y( A8 O) m+ b================================================================
. Y( B, ~! Y% e7 I- n; R2 o- X* _# u* ?% D6 F/ m
  FILM PARAMETERS :
  T! W* q9 d/ u1 G1 r  ---------------------------------------------------------
/ m! S+ Z8 ~/ u$ L+ q" d* K  Undefined line width                5.00
8 f! L3 D' x! x! b# _0 t$ v  Mirror code                         NONE
* W4 z/ s0 v9 e, P0 @4 C  Rotate angle                        NONE# h; z7 {; C) u+ h" _
  Offset x:                           0.00
  @% z  g8 ?3 I' v6 M+ Y  Offset y:                           0.00& [& P  z  ?. G6 W% S+ R6 i
  Plot negative                       NO
! ]2 K5 i  z4 J) _5 E" E4 c  Suppress unconnected internal pads  NO
  r+ z) T  G3 m7 ~' |# p0 W" m% z  S2 @4 t+ {$ c. w. m
3 Z7 w/ w( F2 y$ _0 b& `        (12333.42 8070.95) will be ignored. Increasing output- k) S' L% R- [" f$ I
        accuracy may allow segment to be generated.8 s! u5 e' A' X3 F. Z
  Q( T' i: [: d- }    WARNING: Segment with same start and end points at
1 [' w  e- }8 S) J2 ]5 q        (13689.30 8070.96) will be ignored. Increasing output
+ q  i3 v/ C" ^. ]% T5 K        accuracy may allow segment to be generated.. B( F( E) r& W
8 o4 n4 m2 D. ^# U' Y7 I7 K$ C
: u2 E1 h0 Y! _2 b9 H" G
7 y! U4 b8 l2 f  APERTURES USED:
8 p4 ]( x6 \& W6 Q: H7 C7 w  ---------------------------------------------------------$ d0 x( }8 O3 c$ i3 W7 P
0 m9 k9 d# J% ~6 K6 V8 r5 p. A  ---------------------------------------------------------
+ e% h1 {/ f" i/ K% ~+ E  CIRCLE     0.00500                                  DARK 3 a+ Z( C6 D9 L$ S, I. v6 }/ X
  CIRCLE     0.02000                                  DARK + i1 p1 K* F& S. x4 n, {1 y/ ^; Z
  CIRCLE     0.02400                                  DARK
: Z; v2 \# ]* E  CIRCLE     0.04000                                  DARK
8 a  T6 @( W& I" t1 j" i  CIRCLE     0.04300                                  DARK
% ]- j# R. ]& Y( j9 _- K: Z8 z  CIRCLE     0.04700                                  DARK ; l- C4 P2 T/ o5 h
  CIRCLE     0.05500                                  DARK
$ h! l( q* J7 a' C3 o  CIRCLE     0.06000                                  DARK ( z. j: ^9 _. E1 W, i5 e1 _! I7 x  O
  OBLONG     0.05400     x 0.12800       0.000 NO     DARK
8 B8 @1 o/ u2 x1 t, F& B( \, g* H  OBLONG     0.06500     x 0.11300       0.000 NO     DARK
3 ]0 K, M+ c8 q* w& s: j  OBLONG     0.06500     x 0.13600       0.000 NO     DARK
- x) o1 I1 {! B, s8 [  OBLONG     0.06900     x 0.12500       0.000 NO     DARK
9 |6 h" [4 W. A7 }' J
3 L& N7 s* H* K" ?/ k4 ]$ G     GND2 created with warnings! G( F) Y7 p$ G# e# \
+ [5 N5 v" D4 p" w% G( X( E0 h: ?1 }6 A
. p- ]* Y3 p. a: X. k! a1 \  |1 T7 V
# `; F( K9 a! N( c+ f/ y     PROCESSING FILM < SIG >
" k6 n3 o" D* d! ~# V$ }8 V. K     TO FILE < D:/Documents/Desktop/99/SIG.art > ...2 \; x7 p! O  _; H# o
================================================================$ @% Z3 H, w7 @1 d9 F! l
' F: T* [4 H4 x& ~% V) G
  FILM PARAMETERS :
, y. t  {. ?) `# |" M8 b3 o  ---------------------------------------------------------
* A/ Z4 b; q( J, w  Undefined line width                5.001 e2 b4 O& B/ a: s6 O7 r% `
  Mirror code                         NONE
3 b5 O$ \1 X" f; a3 T' H- B  Rotate angle                        NONE# P/ Y; B$ N, |" H  T) C& u
  Offset x:                           0.007 x" s9 V7 p. O% F/ e: b
  Offset y:                           0.000 n' Y  M) G, ]7 Y
  Plot negative                       NO: `0 _6 c2 Q' H, K( L! }3 h
5 `' E( p% C  P9 Z% }/ N' T( w: f+ J
2 W, X/ j" J& K/ U3 Q; n$ V- k' Z        (10849.82 8267.53) will be ignored. Increasing output
0 A% A0 b7 U" ~2 R        accuracy may allow segment to be generated.
' F  u$ T8 ?  ]* N& |+ @/ H; i6 Z$ k+ n7 c: {2 w! E8 e1 `
    WARNING: Segment with same start and end points at& T1 j! Q, w. H9 }7 j5 m
        (10849.69 8268.11) will be ignored. Increasing output" Y/ U- b% `& K" h3 O% Z
, a" }% t4 i1 o1 _, L/ l, [8 F9 Z2 _# B0 V. r/ ?+ b/ x5 J3 s6 \
  X3 @/ @7 m$ l  Y- A9 Q        (10831.89 8250.31) will be ignored. Increasing output
( S( l1 _0 |' ]$ O2 n4 _/ x        accuracy may allow segment to be generated.# B, G8 C% Y5 c- g! \
. U4 e9 j) L* @# B7 n  M! r) K    WARNING: Segment with same start and end points at
* W* x+ x2 p. M, T3 P, W$ A        (10831.89 8190.31) will be ignored. Increasing output
0 n5 I" X+ J3 s        accuracy may allow segment to be generated.: [0 R$ e- a$ D- l
! l8 D' c- t# Y$ e; E
) U7 }4 X3 w5 |4 E6 B        (10874.89 8009.20) will be ignored. Increasing output
6 _2 ^# f  \2 U8 |8 M  T9 d/ o        accuracy may allow segment to be generated.; ]8 g/ F. r- `9 w) N: ?, n
4 s" d) t, }$ u; M
    WARNING: Segment with same start and end points at  M# c# z5 L! n, I: M( G, U4 v( |: M
        (10874.89 8009.19) will be ignored. Increasing output$ ?9 S. N  X7 G
4 L: Y: r. G4 Z' Q9 o
2 U/ a! c4 x& E6 v    WARNING: Segment with same start and end points at
9 L8 H3 X4 L! b$ b( e        (12333.42 8070.95) will be ignored. Increasing output2 @, ~( F8 A# g
        accuracy may allow segment to be generated.8 V- v' I; }0 `$ i5 O
+ m! |: h6 U- v, N0 L9 G
0 p0 ~2 t! Z/ b+ k        (13689.30 8070.96) will be ignored. Increasing output
& m1 B, g! u- T1 A0 X0 v* h        accuracy may allow segment to be generated.7 q6 _* D/ m6 S- W% U+ v/ J
2 f$ C, V, U# L2 c/ r
6 D5 H1 Y: j( t$ i        (15022.82 7964.66) will be ignored. Increasing output
: I) Z( ~# M2 N8 }; q        accuracy may allow segment to be generated.7 X" U+ x4 U2 `# h& {0 H) G0 }( G
, h% a$ A, i7 c7 M' F- V    WARNING: Segment with same start and end points at
: U4 U2 n4 e& f7 v6 g* t        (10618.75 7691.98) will be ignored. Increasing output
6 d1 X, n; G& f4 |        accuracy may allow segment to be generated./ m- M- v0 d$ ~  v: h/ ~9 \
2 @2 Z8 d# e1 K3 H7 ~" P
+ P* I/ g1 B! `7 @, M6 I        (10562.38 7691.98) will be ignored. Increasing output9 r8 p/ z! B" a% t. |( _2 n
, C' e$ {, B0 G+ Y
, p4 }! @! Q% U# M  P( e1 A    WARNING: Segment with same start and end points at4 L# m; r3 s4 g3 G
        (10562.37 7691.98) will be ignored. Increasing output
! P7 v$ r; X7 L        accuracy may allow segment to be generated.
+ f( y2 T6 V6 Q. y$ Y, e/ j. q. r& |, H4 u! t$ D0 b
    WARNING: Segment with same start and end points at& T0 A' N! V7 O# n5 {% a
        (10159.98 8986.71) will be ignored. Increasing output
  V0 A: o4 n- d3 j/ ~5 X& X3 {        accuracy may allow segment to be generated.
6 ~( K  D) D: R, y
  e  f; X- `) j# l3 }1 n$ l4 h7 \    WARNING: Segment with same start and end points at0 M% ?% X/ |2 ?4 F  Y
        (9968.32 9057.48) will be ignored. Increasing output" d5 j# p) N' q0 r, L# f: j/ L
0 F" {- i& S: c) C+ s/ Q/ s& n; H5 b5 {6 R. ?/ n. o! Q
' i$ b* \  ~4 |2 o; t        (9488.92 8836.26) will be ignored. Increasing output
; |% o: \4 ?5 e/ y4 Y0 d  f* z: ?: z        accuracy may allow segment to be generated.
; E" U1 c( L- _& s1 S( \' I
' U* {% I* a% g, H! O- `9 i    WARNING: Segment with same start and end points at4 E1 x7 a# f6 Y
        (9508.59 8856.40) will be ignored. Increasing output
6 B# V+ N+ ]1 B; H  g9 L( G        accuracy may allow segment to be generated.
$ L; F8 t$ N2 S5 M# l3 ~+ u! r8 ?" e$ d/ v
    WARNING: Segment with same start and end points at& T: H! e, U3 D8 }& l4 @& k
        (9548.59 8866.40) will be ignored. Increasing output$ d8 p0 g3 m* R3 z
! H- u& q5 ~6 ]; g% `8 Q, f( ~0 a: A
    WARNING: Segment with same start and end points at% O, |" Q7 Z) L. C5 G2 n3 u
        (10555.87 9195.08) will be ignored. Increasing output
& G# x0 U! S' m0 o* }        accuracy may allow segment to be generated.9 Y0 @( c7 D  \3 D& q( h+ F
- q* m) R# d/ L  j2 b" g* o    WARNING: Segment with same start and end points at% E, J- O1 C+ m+ C3 g
        (10498.74 9183.92) will be ignored. Increasing output
% i1 t" V% }+ u! ]; _        accuracy may allow segment to be generated.
0 Z, X4 ^5 X1 u- W& H2 b6 H
, U( i) i7 ?# h" a4 l1 L    WARNING: Segment with same start and end points at: n1 s  @1 `1 R3 ]2 g8 m9 V
        (10456.40 9206.41) will be ignored. Increasing output$ }1 N1 N% m7 V6 m
        accuracy may allow segment to be generated.5 r! |* }' t6 o* w6 r
) E' g2 I" ?* J+ l6 A: O    WARNING: Segment with same start and end points at
0 I/ E5 |. a- K/ X7 R        (10497.28 7856.12) will be ignored. Increasing output
( }2 G* o" [0 f5 u: S        accuracy may allow segment to be generated.5 E( {+ U/ ^$ D. ~/ o
/ }7 G2 k! F" ?3 m$ p
    WARNING: Segment with same start and end points at# o# B4 r1 ?& u* o" u
        (10563.19 7694.00) will be ignored. Increasing output
- F! n2 j/ P8 \% m- C        accuracy may allow segment to be generated.
$ d  H! V' v% C& b( L  G5 I: g8 ]' v& `$ g( e
7 ]: w( [& B6 z7 R: u" r        (10563.20 7694.00) will be ignored. Increasing output3 }* F4 R9 `) n. M' r- T
        accuracy may allow segment to be generated.& @% a' T% W4 \
# s% H. i3 x" }6 g9 V- C    WARNING: Segment with same start and end points at
+ X& e' D* Y, b9 `0 O        (10617.91 7693.99) will be ignored. Increasing output; n; O- B+ @/ T+ C3 M
& d3 S% T% E9 X2 f" K* {  L, V! h0 {7 _: j7 e9 r9 j. |: V) k. i9 \
    WARNING: Segment with same start and end points at/ ^- U/ C8 Q% V$ ^/ w
        (10595.12 7749.00) will be ignored. Increasing output: u# U( v  h8 ]  Z& a) U
' l3 a& I- U2 ~; p, A7 ~" [2 T  G5 t% k5 J& i4 Y
    WARNING: Segment with same start and end points at( ?# `4 B* ^8 j& d$ H
        (10586.01 7748.99) will be ignored. Increasing output' e/ O; C6 {  r& K5 ]) r* Y
        accuracy may allow segment to be generated.$ }% V7 m$ w  a  o/ ~& N6 \) n/ d; D, E
% R6 u8 u5 K6 A/ N/ ]' j    WARNING: Segment with same start and end points at
( P, Z7 W$ b1 b( X8 e        (10586.00 7749.00) will be ignored. Increasing output9 ^+ R0 B% L5 t& g+ U0 d
7 k( @7 _1 |2 I" S$ K8 |. M, W$ L, t7 `6 \8 q: w
    WARNING: Segment with same start and end points at/ y. s% q9 R$ D) f' ^7 B
        (10484.27 7850.72) will be ignored. Increasing output" H0 ]& K2 s# o1 `' i4 v" `
0 \: H6 K; h" B) W1 @$ g/ b1 t  k% F, Y: U) r: F/ k1 l
/ l$ l4 U1 r! z9 m        (10599.68 7738.00) will be ignored. Increasing output
0 u! X4 u. t% v  o; O5 `; x        accuracy may allow segment to be generated.
7 y& G* n7 r& U  e6 q  S7 W' h2 `/ i$ `8 E: R5 B$ @
    WARNING: Segment with same start and end points at$ H( v" u; f0 @" M, T. r# E
        (10581.45 7737.99) will be ignored. Increasing output
% e) P: ]5 w* O* b# K        accuracy may allow segment to be generated.
$ v" E+ _4 U/ {- h' C
2 z1 I* P' e% x8 N% A5 y* S# l    WARNING: Segment with same start and end points at- i2 r4 o& P9 `* G8 j6 {
        (10581.44 7738.00) will be ignored. Increasing output7 M- q4 Y( ?; A0 C: Z/ [& o
( I6 j! ^4 C+ [) p$ C9 }$ B7 Z( s$ G( \# m: {" u
    WARNING: Segment with same start and end points at  K4 A; s+ M- P5 q6 k2 P& S# D/ o
        (10613.36 7705.00) will be ignored. Increasing output0 K& V+ X1 K/ n, A3 ?- i
        accuracy may allow segment to be generated.. U; a0 w- w8 o% d9 `
) ~1 l( h4 g/ R. B$ F    WARNING: Segment with same start and end points at
: w# {8 k2 O! t$ w! K! g1 X# D; @        (10567.77 7704.99) will be ignored. Increasing output
: a0 z; e. d% R& F: U. W        accuracy may allow segment to be generated.3 z" N9 r- t: U$ Z4 x
6 {' w3 J" L: X' h) I5 _) R
  r* H* t/ e5 m6 n2 ]        (10567.76 7705.00) will be ignored. Increasing output
5 v1 z( n6 l! X( I1 P8 F, |        accuracy may allow segment to be generated./ W$ P7 L& b$ v
& L6 y9 Q/ P( [! J  G2 l0 J% N' X
, a1 k" q. {, ^        (10576.87 7727.00) will be ignored. Increasing output8 X3 z5 P! V; G* R
        accuracy may allow segment to be generated." M# F2 O! d* {2 I4 S2 ^! h) b3 m
1 @" l- M; y4 ~/ F  e7 j$ f    WARNING: Segment with same start and end points at2 ]; C0 w9 v8 o9 j6 B
        (10576.88 7727.00) will be ignored. Increasing output( E7 Y3 u( j3 {+ G$ i/ B
! b' Q; f$ z+ `" D  _
+ ?! q  B9 d7 t( H" R    WARNING: Segment with same start and end points at. D4 X$ N- Q4 g. @, V( P- c4 L
        (10604.23 7726.99) will be ignored. Increasing output5 v" S+ N3 Q% m! c' I
$ O& N$ t# r% V9 F- Q
6 p/ O4 B8 \* _5 B% P5 e9 e    WARNING: Segment with same start and end points at
/ ~6 ]/ v6 D' u/ d, g        (10572.31 7716.00) will be ignored. Increasing output
" @* A! X0 o: E9 j/ e" X, n0 b* c        accuracy may allow segment to be generated.
; R1 P& q5 a" a9 i: s, F0 y
. n* A- A$ _0 W3 W3 _" f    WARNING: Segment with same start and end points at' }6 y! c) c6 D
        (10572.32 7716.00) will be ignored. Increasing output
0 C+ S6 R; e* c6 B        accuracy may allow segment to be generated./ m8 _- P: P+ n8 I. @
" i4 |" n! m5 S. E/ P9 p5 s5 S    WARNING: Segment with same start and end points at
$ @! Y& B; i" l6 k+ \  b        (10608.79 7715.99) will be ignored. Increasing output3 f$ }3 P. F! H9 n
6 j# s" z* z; ]! \- U8 M, D0 A' a$ v6 L$ \3 G2 A
1 ?: R" Q- |6 R* d6 H. B
. d+ L9 q) Y2 X3 h& q- _  APERTURES USED:
7 c5 _0 C; T; O$ L! F  ---------------------------------------------------------
% i- N- f5 ?9 R/ m1 q  TYPE       SIZE/NAME                   ROT   MIRROR MODE ) ?! U: O* @2 c, n4 g9 I- r
; o3 c, J2 K) v% J  CIRCLE     0.00450                                  DARK
0 K6 K* }4 s9 z8 m8 |  CIRCLE     0.00500                                  DARK ! q* \; N1 l8 S6 y( \
  CIRCLE     0.00600                                  DARK + m' `' j9 G2 l! j1 F5 r( x  i
  CIRCLE     0.00800                                  DARK % ~; t+ F' [/ O+ U
  CIRCLE     0.01500                                  DARK
  N, L9 Z" q  r2 C  CIRCLE     0.02000                                  DARK
/ S7 N- e" X+ f9 p) o( _1 s% X  CIRCLE     0.02400                                  DARK
: p2 m% C" F' @. s7 t4 `9 D7 {  CIRCLE     0.03000                                  DARK . U+ A1 r: w3 [5 M. l: v, k
  CIRCLE     0.04000                                  DARK , I* ]" s5 ~3 R: e! ^! u. `
  CIRCLE     0.04300                                  DARK
$ U( K* F0 b2 v, a) C. ~2 i; w  CIRCLE     0.04700                                  DARK % x1 C. L, c# L, ~' T
  CIRCLE     0.05500                                  DARK ; F0 N$ T8 z0 G6 V* d/ M# ]: A
  CIRCLE     0.06000                                  DARK 9 \5 i/ [- h! u, ~2 w% A
  a4 {+ g; g9 a+ t( K9 w" f  OBLONG     0.06500     x 0.11300       0.000 NO     DARK 7 T2 |6 X* Q, u* b& g- F& t
8 }% d2 y5 p1 I, ]% z  OBLONG     0.06900     x 0.12500       0.000 NO     DARK
: q/ ~# w! u- F# f! O1 ~5 `" p4 x: C" m3 P/ v  l
     SIG created with warnings
, H( W) l) @0 z6 o2 Q$ j& X
1 r" C" |' r$ R( c
# e( T, y* ~# i- n  d================================================================
+ {! p/ [6 j+ K: ^* _; z$ P     PROCESSING FILM < POWER >
. u; I. Y( `' i9 w# S5 H, z     TO FILE < D:/Documents/Desktop/99/POWER.art > ...) R6 A! [, ^0 ]. L
================================================================. j$ t8 k& F0 r4 U  l% f
* i# w, C& |7 @$ }6 ~+ T  FILM PARAMETERS :1 n" P) B/ J- N( F# \% V. R
  ---------------------------------------------------------( G: [; p+ W  m( f
8 ?" s2 i. s% f+ @1 \  Mirror code                         NONE: D1 e1 j/ Q/ X- o8 T2 G# {2 S' f9 }
  Rotate angle                        NONE
; Z( f8 z4 Q6 y+ K  Offset x:                           0.00
; N- A, W: n: {1 d6 L* p  Offset y:                           0.001 @' B) {3 }3 p/ K
  Plot negative                       NO" \' t  @; S( |) j$ @' V
  Suppress unconnected internal pads  NO% ]0 ~7 b9 ?% j5 F* K
* `9 x1 ~1 z! |1 m" z: L    WARNING: Segment with same start and end points at
6 p9 i/ e" }" `. F        (12333.42 8070.95) will be ignored. Increasing output
. |. h+ Y! C/ F. A; u9 J        accuracy may allow segment to be generated.
3 g( v4 O& F) K0 c  L% }1 ^( ?; C: b0 t( w
# x% ]) e0 Y! c7 |        (13689.30 8070.96) will be ignored. Increasing output
( [8 d# e, d% B, z" r& H9 f) R- j        accuracy may allow segment to be generated.
5 F7 F; `. e! m6 H. ]0 q: N! m4 r/ v; C0 ^
    WARNING: Segment with same start and end points at4 o, `5 p  l' m$ ~  S0 ^4 p
        (15022.82 7964.66) will be ignored. Increasing output3 }' V& E' h. s; t) N
        accuracy may allow segment to be generated./ ^9 ~( _" U; Z; U) K: z# C
$ Y' i5 @2 M# |: z- e5 g% M7 X, m
    WARNING: Segment with same start and end points at" D: M$ ^* V1 F7 m% S1 v6 I
        (10229.61 9150.02) will be ignored. Increasing output8 w$ w& }" z2 g
        accuracy may allow segment to be generated.  w4 M, k$ s! X% n8 p
# h' @5 R3 u9 I
    WARNING: Segment with same start and end points at! b: e3 Y* k: |5 V6 m( r
        (10229.64 9150.02) will be ignored. Increasing output1 N3 W8 y8 X( p- S7 V
        accuracy may allow segment to be generated., C; S* v- a8 c( i! V3 M7 h
3 M6 F( R" N% G( n  {2 L' S6 w) k    WARNING: Segment with same start and end points at
+ s  W) `, `4 u' \5 \        (10230.36 9150.02) will be ignored. Increasing output1 c. l& w) x1 {+ d" U* f" k
        accuracy may allow segment to be generated.' q" b3 _9 ^! q6 `
6 M6 n( Q. T4 f9 M5 L    WARNING: Segment with same start and end points at
! r% i3 D% E- s, q+ }        (10255.00 9110.73) will be ignored. Increasing output. [' _- ~& F3 H, N
7 J! X; x0 m+ D" \. G' i4 ^2 W7 r8 s1 G! J# V  o% C
" @6 j. t) d5 C9 q" w        (10255.00 9109.31) will be ignored. Increasing output
( S- m' c( p; ^' N( C- Z9 y        accuracy may allow segment to be generated.
$ o$ w3 Y. W2 b
' C4 a! u6 x1 u& F+ g
$ i' j5 ~* j0 U$ r
$ V6 N- L" G5 k" t  APERTURES USED:
0 [2 M! f: k% F# J0 p5 O  ---------------------------------------------------------# p2 h; J7 B% i- L
6 i% p" V# z9 l' ~& j$ b5 N$ y' @  ---------------------------------------------------------
6 x! f+ I' o9 I: H  CIRCLE     0.00500                                  DARK 9 x/ X. O* ~) s5 b4 e1 c
  CIRCLE     0.01000                                  DARK
, c+ C& f& T4 W: X8 G& k) {9 |. X  CIRCLE     0.01500                                  DARK   z% W4 t+ ~" }3 Y% J
  CIRCLE     0.02000                                  DARK
6 E- m8 @! |7 H; V, s2 {  CIRCLE     0.02400                                  DARK
8 G' S* g& ]& ^6 l9 i5 D8 o  CIRCLE     0.04000                                  DARK
! |: \  `5 F* a% S8 z* z  CIRCLE     0.04300                                  DARK
  H1 g' P6 D/ c1 W5 W' b  CIRCLE     0.04700                                  DARK % e, j6 }# w0 A+ H/ p1 T4 F
  CIRCLE     0.05500                                  DARK
  A3 \* l# H' f* ~- m/ r0 f3 \" v; ?  CIRCLE     0.06000                                  DARK
# B+ o  k9 Q& s4 p8 k( p  OBLONG     0.05400     x 0.12800       0.000 NO     DARK 9 U! v0 \+ U8 k9 K9 b" E
  OBLONG     0.06500     x 0.11300       0.000 NO     DARK " u2 Q6 y5 j2 ]" C
  OBLONG     0.06500     x 0.13600       0.000 NO     DARK / O3 T% v* v& n' p
  OBLONG     0.06900     x 0.12500       0.000 NO     DARK / c; d9 I* U# S. i
( L, P3 H/ x  ?8 J% p1 @4 Z' c7 e  B# E     POWER created with warnings; J4 s/ W" {! s: H) Q
! o6 q+ C) N7 ]; }& K
" n. q+ y9 }' f================================================================
$ Q' q0 H: n5 }  e     PROCESSING FILM < GND1 >- S! v0 b5 F3 ]: o; j
     TO FILE < D:/Documents/Desktop/99/GND1.art > ...  l- l& A  O1 T
  o/ c, c$ E- s* q0 u3 i7 v
) v6 O5 q1 V. d- o" U7 R$ y  FILM PARAMETERS :) K; ~9 A  }6 q8 L9 G5 T3 u0 j/ L( `" s
  ---------------------------------------------------------: q3 {9 y6 s$ \  \& z
' X1 B) h; j! n; }5 Z% H  Mirror code                         NONE
0 P8 R1 q, d6 S  |7 Q  Rotate angle                        NONE
! y. |/ `- v1 L. O; n7 {  Offset x:                           0.00
5 u& j% O% ]2 M$ E5 ]  Offset y:                           0.009 P3 x% [1 {  q# q
  Plot negative                       NO
8 t- D% l& E8 S8 L! O7 Y  Suppress unconnected internal pads  NO
: M! s% G2 P& Y. X% ~9 u0 o5 n" o* ?5 P
. `4 k. @" c% _1 s; |3 ~& s        (12333.42 8070.95) will be ignored. Increasing output
; u3 w2 H! q4 E6 j6 o) e        accuracy may allow segment to be generated.$ t1 x6 |! M* @/ |* i4 n4 |
, `7 n: Q' X/ [    WARNING: Segment with same start and end points at
. F. S, x  T1 H        (13689.30 8070.96) will be ignored. Increasing output" ?7 R$ H; \) c# R
4 M# T% f0 ]' H: n, u1 Y0 Q2 n+ w3 C3 ~; Z5 V. Y* X
3 x0 Q% [# A' D6 h! B( I/ E! y& I$ H/ P
  APERTURES USED:
: C+ W1 a0 Z$ a' `  ---------------------------------------------------------$ H; W6 ^( O: d
  TYPE       SIZE/NAME                   ROT   MIRROR MODE 9 @' O* U. i: t
4 v8 q% e# i8 p- X& A% ~  CIRCLE     0.00500                                  DARK
5 M9 C7 K0 @5 w$ ]' q; l  CIRCLE     0.02000                                  DARK % \$ T+ a( G! l. J
  CIRCLE     0.02400                                  DARK
8 @. Z" r! V1 A5 w  CIRCLE     0.04000                                  DARK
2 h- q# {9 M9 L( a- u  U3 @  CIRCLE     0.04300                                  DARK ( @7 C( |2 K4 I9 b$ A8 ^" I3 {
  CIRCLE     0.04700                                  DARK
% y( R" G0 v9 n) k7 q) B6 {  CIRCLE     0.05500                                  DARK
  m" A1 q% q8 ]' B3 ]% W  CIRCLE     0.06000                                  DARK
3 R+ U; j. s- V4 W% T5 Y' a" ^  OBLONG     0.05400     x 0.12800       0.000 NO     DARK
% ]' v) f- {1 \% \# l- a  OBLONG     0.06500     x 0.11300       0.000 NO     DARK
9 c5 H+ w, I$ R. A' b  z& S# q  G  OBLONG     0.06500     x 0.13600       0.000 NO     DARK
8 U% L6 `6 p5 q2 \, I% K( h/ v  OBLONG     0.06900     x 0.12500       0.000 NO     DARK
# b. Y- m  e/ g0 x! W: T% u" f' @# a- o& c2 L! E! t$ B* x! I7 g
     GND1 created with warnings
9 b5 g" J+ Y. {' n, n
" I/ p4 i, }. D/ ?9 L. v) |
5 e, o" a3 s' O& r================================================================: f% y, F* v! |. k
     PROCESSING FILM < TOP >
6 `& M9 [' q2 q3 `: d) ]/ |& ?     TO FILE < D:/Documents/Desktop/99/TOP.art > ...
, s; Q5 x3 J( G2 ~1 d5 n% u================================================================0 ^# @! D9 m2 t2 q) ?+ ]1 P0 O/ v
( z: N! U. h6 w- i  FILM PARAMETERS :: }9 }$ O# @9 B6 V- k0 n5 V8 h
  ---------------------------------------------------------; Z3 J  m# [5 g8 t# i  l
  Undefined line width                5.00% v- k" m. L" ~4 f0 ~) o
  Mirror code                         NONE
' }; K# {- [7 u) n+ r$ D, g  Rotate angle                        NONE
) a2 V8 L1 l2 v  Offset x:                           0.00
( T9 S4 h# `' Z% U  Offset y:                           0.00) I7 l" Z' v. _3 d) r+ ]) q
  Plot negative                       NO
5 J  |% C$ P9 E! k0 z. `1 X  Suppress unconnected internal pads  NO" d+ A' L. K+ {- q2 z7 c+ _1 Y
" c1 b8 a' N2 x% U6 S    WARNING: Film contains DRC error(s).& V: z+ T6 i* l
    WARNING: Segment with same start and end points at' M! d/ R! c9 F  |
' q8 P" x, y6 Q. ~        accuracy may allow segment to be generated.$ j2 w9 H1 k3 \: w
% Z9 }) C" C0 B5 O( ^. f4 G6 R    WARNING: Segment with same start and end points at
0 T+ z" R& J9 d, s( d% D        (13689.30 8070.96) will be ignored. Increasing output
' P8 A$ i$ b: A& l, q' J' x2 W        accuracy may allow segment to be generated.
1 G; Z- q5 a8 r  |+ y1 \" A: {& f0 }+ t2 |1 G
# K) e3 F5 V/ M5 F4 t9 e        (10837.53 8279.82) will be ignored. Increasing output
6 C7 l4 {9 ~6 t$ G/ X8 a        accuracy may allow segment to be generated.- a6 x/ h+ m( E+ n$ z' c
1 Q) |2 @7 @: t, S: @4 u4 Y
    WARNING: Segment with same start and end points at5 `* d- k% m" c  k
        (10838.11 8190.31) will be ignored. Increasing output
# I  r- g4 q' W2 C+ w        accuracy may allow segment to be generated.! S+ W& S6 i0 a- a2 H, Z
& ?) G1 j5 f7 }3 a* [; s/ F( Y1 c* k    WARNING: Segment with same start and end points at
  E) v0 m  D( X" C        (10874.76 8008.61) will be ignored. Increasing output
3 G6 _% E/ j7 B; Y3 J1 u7 D        accuracy may allow segment to be generated.) t3 _+ r3 F5 J! C8 j
; l6 `* f: Z4 D. O) e4 F' C
    WARNING: Segment with same start and end points at& |! b6 ~3 r$ H8 F7 I
        (10251.89 8270.02) will be ignored. Increasing output) d0 V, V/ E8 Q0 V1 d
! w+ `3 [2 W& t3 ], `" K# Z: D
, }5 L6 p! x) y) K# s6 Z    WARNING: Segment with same start and end points at
6 {2 [  k: w1 v. U/ j        (10252.31 8275.22) will be ignored. Increasing output
/ B& i" y( t1 |6 w) [" f        accuracy may allow segment to be generated.
1 V, N# M& m" q) c. B$ O; j; L4 T; V: E( V+ {/ p1 g2 Z3 Z8 `& b
" |1 E1 c- B; n& }9 r. \% J+ l        (10650.26 8947.01) will be ignored. Increasing output" A( Y0 P( F% q1 F) j, [/ D' [
        accuracy may allow segment to be generated.( G. G+ ?7 I+ e" ^1 a
. p% f" R! e/ P7 N- U8 `" k9 u6 ^* M    WARNING: Segment with same start and end points at5 M/ g7 n/ N  N% T" f2 p( c
        (10685.52 8947.45) will be ignored. Increasing output: Y. Z  W9 t3 U+ c  i" W
3 h) r! H6 W, v# c6 e, ^5 _1 q/ k* G, @. q" v8 H
2 G1 c) [! x$ n1 X8 n3 u0 ?' D$ B        (9623.74 8638.92) will be ignored. Increasing output
* D" E2 }3 O$ f        accuracy may allow segment to be generated.4 F' @9 ?) ?" {6 m) U: ?
& M7 W7 _. P9 t( E
    WARNING: Segment with same start and end points at4 o0 e' Z5 G5 U2 {* T
        (9738.92 8741.26) will be ignored. Increasing output
. y- @0 _+ m( N6 p% V4 v        accuracy may allow segment to be generated.
) o2 V% Z5 m* `5 s0 ]  v: d' u, N/ j! ?' j% C! X& v
    WARNING: Segment with same start and end points at6 \' G# y/ |  G; d
        (9799.84 8751.38) will be ignored. Increasing output
% @  v8 X2 i$ g8 u. A        accuracy may allow segment to be generated.
0 [5 Q8 ~: x5 `/ F& Y3 z# Z3 u1 C
8 Q7 }0 {% W9 }0 C    WARNING: Segment with same start and end points at
4 i* C; O9 r$ ^. c4 q        (9805.45 8751.25) will be ignored. Increasing output$ \( c( I6 u' M; k( `' g$ g! s
" \+ x4 u3 v+ f8 B, s' d" }! c5 k+ R, H, z5 B& A
    WARNING: Segment with same start and end points at0 f" P. t# l. q8 b. v7 P( H) f
        (9859.13 8749.92) will be ignored. Increasing output; `2 m7 \- M' c
        accuracy may allow segment to be generated.. r; i% g$ }) ^" @
6 }  X2 m- ~, t2 e: t* {9 }; U
    WARNING: Segment with same start and end points at; w* Z! z% t. L* e; g
        (10685.74 8725.29) will be ignored. Increasing output
, W' y' Y* A$ N" k8 _: Q# G8 x$ W        accuracy may allow segment to be generated.* f9 P2 H2 X0 p1 _8 Z/ \5 F
, F4 X6 \, i# O+ U9 d    WARNING: Segment with same start and end points at
2 k' U% r7 F0 A, ?# P! A% v2 r9 f        (10650.48 8724.85) will be ignored. Increasing output
# O$ w9 _6 Z9 b8 k        accuracy may allow segment to be generated.
. u: R6 y1 ^/ n1 a+ q2 e- m+ K% [$ l3 a4 T) W
, B6 B6 q' c4 i. X* J        (10632.02 8770.07) will be ignored. Increasing output
/ N# r- C% t- E  ?( `+ f1 `        accuracy may allow segment to be generated.
! d8 O2 J3 Q) }* V' [, [- o8 d1 m/ L* ?/ q8 V
- p3 n5 u& @0 s4 U        (12617.86 7825.24) will be ignored. Increasing output
1 j  L$ {- k) M  d8 m$ n( M        accuracy may allow segment to be generated.
# I# w9 C, ?. j" N
, M& i% \& Q5 q. I    WARNING: Segment with same start and end points at
9 c( L% u2 U8 [# g% C        (12577.55 7825.11) will be ignored. Increasing output
. l% \/ i9 `3 c  s; p        accuracy may allow segment to be generated.) `. X" ?3 p2 r' h4 Q. b
6 G" O& V/ r4 t; z& T    WARNING: Segment with same start and end points at/ f6 M2 {1 X5 L8 I$ y& K/ O3 `" ]
        (12416.68 7847.50) will be ignored. Increasing output
, G0 _4 e, _  W) Z        accuracy may allow segment to be generated.7 U9 s6 @2 S0 q  |/ [( P  c0 Q
, j0 P* P9 a, Y: J) W# [# y    WARNING: Segment with same start and end points at2 A7 Q6 Q# [( Q' f6 H
        (12611.23 7969.61) will be ignored. Increasing output8 v8 _# D- x- @) l1 F: z! ~
0 h1 B3 H' K0 d8 r, ]* L; D5 e: m
    WARNING: Segment with same start and end points at& z0 L% V- k4 p! ~0 d
        (12685.18 7977.53) will be ignored. Increasing output
( R0 S& m( L0 B* N        accuracy may allow segment to be generated.
  E, v+ r2 y* ~$ Q; y; w
/ O0 j% t& O& T5 b9 o    WARNING: Segment with same start and end points at
* e* y1 j0 p8 ]4 O% q        (12709.45 7963.32) will be ignored. Increasing output& e7 Z# ~+ g  }/ I# |
8 Y; G. c' M* O5 H/ D( N* c! j) r3 O+ W; \/ D' _3 u
    WARNING: Segment with same start and end points at7 R2 E0 Q- G( o( W
        (12748.31 7968.04) will be ignored. Increasing output
: E; U# K5 \/ p3 o, o( Y5 y        accuracy may allow segment to be generated.
! S% w+ n1 d1 |1 g7 r* T, B  @4 u) S+ Q% l+ n+ }6 f# s) S. Q! S
/ C; k( S2 ~4 @% V        (13074.14 7942.98) will be ignored. Increasing output0 m# B; P% n! e( I- Q+ V) ]8 m  K3 h
        accuracy may allow segment to be generated.8 ^5 a4 c9 L8 k. X3 l! `
8 Y# ^1 l" |: ?% ]' [
    WARNING: Segment with same start and end points at' \/ O- V8 a# u1 R
        (12413.82 8006.14) will be ignored. Increasing output
/ s; \( ?3 t& S8 ]: E( p9 `; n        accuracy may allow segment to be generated.7 k4 l% \6 ?! }1 Z) q
- a0 M1 m2 ?  @; v  a5 i    WARNING: Segment with same start and end points at
) E# S2 q* X; w, a' F/ w5 K        (14482.52 7744.48) will be ignored. Increasing output5 s: l0 \) `8 [2 B# t) N
        accuracy may allow segment to be generated.$ l. S  H: S8 F
+ f" a* |$ Q  `9 o1 x2 P/ r* a
    WARNING: Segment with same start and end points at/ A. O1 i) \: ?! g$ n
        (10468.74 8894.25) will be ignored. Increasing output+ [: |9 p% d& r' b
        accuracy may allow segment to be generated.1 V! `9 ]' o$ u) B! b
$ Q! Z; ?/ [" Z/ n0 }# J
    WARNING: Segment with same start and end points at  X+ j6 q; F% n5 |
        (10444.86 8963.10) will be ignored. Increasing output- _; A! J0 s) k7 `8 P
% J# m- _& f& V$ l" w% a7 @: t) o9 a' l5 U$ n( W  ]5 y/ U0 N) O4 j7 s
& Z9 m2 h# {3 L/ j; P6 T        (10193.74 9003.92) will be ignored. Increasing output
+ T7 b7 b0 [; ?( r5 C        accuracy may allow segment to be generated.
- \! ?7 a7 s, v2 a. v/ n5 l+ }2 ^' B9 u; l
% I( W" I+ E) D4 |        (10168.92 9106.26) will be ignored. Increasing output
0 R4 I( E9 @, @! s        accuracy may allow segment to be generated.
! c, y% C* P2 g6 V: Y
0 R7 P& {. s6 x  w1 ~4 f    WARNING: Segment with same start and end points at
8 m) S+ R$ s6 C+ k' h        (10188.59 9126.40) will be ignored. Increasing output
, @7 T; o" z' A# P# \, t        accuracy may allow segment to be generated./ n& h' n; n! O- u+ F! d# c
/ Z3 |  l% ]: O7 n6 u    WARNING: Segment with same start and end points at4 h' t; X0 F8 Y) ^, a4 Y9 x6 a
        (10555.87 9195.08) will be ignored. Increasing output9 m6 x% b2 i$ E2 j
        accuracy may allow segment to be generated.! v( _! L& y( H( O- T3 `
6 D1 L. B  Y- H, U/ I6 [
  \9 |: Q* V$ j        (10530.15 9227.84) will be ignored. Increasing output2 s, R3 \0 F# Z, b: d: d) d
7 `1 N: A) X" I6 O8 k
6 z8 W( k0 o4 a4 w    WARNING: Segment with same start and end points at
8 z  @$ ~5 E7 N+ }        (10498.74 9183.92) will be ignored. Increasing output# R; ~6 ~% O0 [; Z
        accuracy may allow segment to be generated.& h' {9 c$ f6 G: u% H
4 X% m+ _9 [  o; }
    WARNING: Segment with same start and end points at# f4 R  K5 w( A6 m
        (10359.89 9160.81) will be ignored. Increasing output
6 @6 q; Q% n1 D- t/ D        accuracy may allow segment to be generated.
  Q% _6 |4 [) Z) o5 t
: p+ M+ f- y* p: Y3 N6 T, z' q# _    WARNING: Segment with same start and end points at0 [! S1 M" _9 y( V) c
        (10510.77 9126.24) will be ignored. Increasing output! `) {8 ?' |; D0 L
  b! t8 x. L- \
* _: C, L, S1 O* g    WARNING: Segment with same start and end points at* q+ y/ ?: s2 M; E! c8 O- r
        (10515.93 9125.66) will be ignored. Increasing output5 l# E- q8 Z* i
        accuracy may allow segment to be generated.$ K9 T) a5 c( K: ~1 ]
9 C  g  M5 ]7 T
    WARNING: Segment with same start and end points at6 Z9 X8 `2 L1 B
        (10626.40 9103.63) will be ignored. Increasing output
  u. c% Z3 }; p3 E8 k; n        accuracy may allow segment to be generated.8 f6 q1 Z- Z  R% y; v& ~( ?1 _
8 }$ q( G6 I% Y    WARNING: Segment with same start and end points at( f) h0 I# Y. S8 D5 h% A
        (10460.32 8999.40) will be ignored. Increasing output, e1 a( O# c7 v2 p3 [0 E
        accuracy may allow segment to be generated.% v4 d0 D! F# Q* h$ R
+ F) M6 Y" i, r7 g# W5 n0 w    WARNING: Segment with same start and end points at2 u3 @' _& {; P# e0 j4 Q; n2 o
        (10479.86 8979.81) will be ignored. Increasing output& B8 L9 Y" _7 w  M" }; w( q
/ G9 P8 j# E, E5 Z' j( J& F, B1 o8 m6 y% u" O& Q# [1 [
    WARNING: Segment with same start and end points at4 q- S' B% Q( h/ B
        (10473.90 8893.67) will be ignored. Increasing output( I8 ^& [, F) c7 f( X  f( F$ B
3 s4 u% q0 z( H8 P$ h: @+ h  D4 s; I8 U; C8 l% q/ F" m; @2 j/ f! F+ r6 I
    WARNING: Segment with same start and end points at- S7 y" W. c" o% p4 O
        (13641.76 8004.98) will be ignored. Increasing output0 ]6 t! `3 z0 o
        accuracy may allow segment to be generated.5 L4 Y" f/ ~7 Z3 [% B7 t
$ J% g, v8 g3 k1 y/ s    WARNING: Segment with same start and end points at  G# z0 ?  u% |/ u- x
        (14216.98 7694.64) will be ignored. Increasing output, u  ?, k$ U6 ~# ~+ B- x- _
        accuracy may allow segment to be generated., G/ n0 I# d1 l/ Q9 w; B* n
' ]/ p! V% {, A3 S( g6 P
    WARNING: Segment with same start and end points at- M, |& i" S% Y- a3 E) x2 R
        (12425.47 7835.00) will be ignored. Increasing output
2 j+ k0 ~: h) G# W        accuracy may allow segment to be generated.5 X' S5 t4 k0 @5 p9 J6 P* M
) G0 Z7 r  L& M: J
    WARNING: Segment with same start and end points at) g. a  Q0 s, n: |& S- i
        (12775.00 7975.00) will be ignored. Increasing output* n! g% b$ w1 X
$ \  H$ D1 ~, v. u5 b. e7 p4 T; b6 Q* N5 e9 V$ n- y
    WARNING: Segment with same start and end points at% O8 B0 \' A5 h, q6 |
        (10472.50 8970.00) will be ignored. Increasing output; z' ?; L. ]& h: s' X
        accuracy may allow segment to be generated.8 t2 `- p: l$ t5 }
% Q$ x4 _0 x0 r1 {9 J& }    WARNING: Segment with same start and end points at
. Z4 [/ x+ L- o3 S6 X/ D' L# i8 R/ |/ `        (12443.85 8095.00) will be ignored. Increasing output
; [9 i& X/ Q) L, `9 z4 G7 P: h( a" g        accuracy may allow segment to be generated.
5 q, }# i. _- x6 x$ R
! u2 I% I; F0 d7 V. p    WARNING: Segment with same start and end points at
- s6 K( {" q/ A2 M# @+ ~$ S) a- [9 N1 `        (12035.24 8025.00) will be ignored. Increasing output8 U9 Z3 Q  N5 A
        accuracy may allow segment to be generated.$ w3 o* G8 u1 i
. p6 X, x/ z( h" I    WARNING: Segment with same start and end points at
8 S/ n3 ^3 r4 c+ t. n        (11763.48 7785.01) will be ignored. Increasing output
, U: b+ |5 k2 F6 }* D  w        accuracy may allow segment to be generated.( t4 |& s' C" T; ^& R- @% M
" U' r# P0 ^3 k, t# x    WARNING: Segment with same start and end points at
. i+ w/ ]8 z6 |        (11759.32 7795.00) will be ignored. Increasing output8 [0 O$ o1 j& H4 p4 C. i" [
* H; N2 Q# r/ d& K9 \
+ S& U, e# y8 H/ O' t8 `    WARNING: Segment with same start and end points at
2 Y/ U. B5 u% H3 p        (12039.38 8035.01) will be ignored. Increasing output
9 O, w( A8 }% O# U8 t- ^0 c  V        accuracy may allow segment to be generated.' {& K2 B! b/ X# X, W. _5 B, P: E
3 }2 Y2 D( H) W* d4 M+ C
    WARNING: Segment with same start and end points at& G3 s- [; z* A4 E( {
        (12447.99 8105.01) will be ignored. Increasing output; G3 M# q- q. G) W8 K
        accuracy may allow segment to be generated.) J$ ?9 A# L7 z' Y* k# B2 _2 t
5 v0 G  R: r# u: `  q; `6 F    WARNING: Segment with same start and end points at
+ [! J& L1 k. b2 h! r- R- X        (12411.80 8006.96) will be ignored. Increasing output" }& D* h8 |2 k( f. d+ r, i7 B' p
        accuracy may allow segment to be generated.' u9 g& d% j$ u5 e
6 n  H# @1 Z2 y    WARNING: Segment with same start and end points at
) ^! W3 |6 r& o/ M! K, x& Q6 U2 D        (13073.68 7956.00) will be ignored. Increasing output- a( c& C/ x8 w+ x4 \# V1 t
' D+ I4 _6 d( f9 F1 L9 R% P* M, r9 u2 o+ e( \
  V8 b  f) B- u1 C( t0 u        (12400.80 8011.53) will be ignored. Increasing output
8 j/ D/ [2 Y" a# h, }        accuracy may allow segment to be generated.
0 }! y2 W; E0 p# e5 {$ l; L4 s9 w& W7 @7 f( h$ t! y
$ C8 ~& T6 z5 \* }% t; t/ I. o        (12378.80 8020.65) will be ignored. Increasing output
. m* k6 T9 i9 T, E        accuracy may allow segment to be generated.
: D5 r1 C% t; {5 p& \! v+ {/ {% t1 y' [/ _& i! p
2 D1 f: J% ^3 c9 L/ @        (12389.80 8016.09) will be ignored. Increasing output
2 y; \+ ?- g5 g% l        accuracy may allow segment to be generated.+ T" E- K4 Z4 ^+ m9 O
1 `4 z; I, Y1 U' b! Y& g    WARNING: Segment with same start and end points at
2 f# {+ b. F5 Q! ^) j: s! Z4 c6 c+ |        (12026.33 8003.50) will be ignored. Increasing output
; o. L6 }: L) U2 Z! F  @        accuracy may allow segment to be generated.$ k/ n" O" P3 h) g8 T* c$ V
4 E, S) r$ q# A6 ^0 t    WARNING: Segment with same start and end points at
, w. ?1 ~: X& l4 n; y5 a+ C        (11772.39 7763.51) will be ignored. Increasing output9 u+ y! p8 S2 O7 a3 w
        accuracy may allow segment to be generated.$ ]& ~3 z2 N/ F6 o
/ K" m3 k/ ?# q5 g    WARNING: Segment with same start and end points at% `" J* [( ?3 ^6 V
        (13078.23 7944.99) will be ignored. Increasing output" v- x  [" N5 C4 Z. w4 d
2 ^7 ~  u2 ~: l+ e9 G. A, z
# \6 _1 o& Y4 \. X7 n7 ]2 V    WARNING: Segment with same start and end points at
. x8 A# _  |7 {; E/ m9 C        (10381.34 7936.34) will be ignored. Increasing output9 ~# e! ^2 Q1 K6 X4 }
        accuracy may allow segment to be generated.9 q* O! T4 V4 u4 u# ]
6 ~" b" [5 ~8 S; c) B$ O4 J% H. r- _& U( [
% a* x/ R, r2 n2 x1 A  APERTURES USED:
5 ~& g- z+ i) F& H' D% h- U/ N, ]  ---------------------------------------------------------
& {4 u% p" e  c  TYPE       SIZE/NAME                   ROT   MIRROR MODE # i6 K* v0 O2 x; W* E/ ]0 z
$ D+ T9 {; A3 k, Q: Z* k  CIRCLE     0.00400                                  DARK 9 J3 z8 M2 V! d, q4 u2 n
  CIRCLE     0.00450                                  DARK ; V- f# Q2 t! s, \7 ?; d
  CIRCLE     0.00500                                  DARK 6 ?/ G4 R9 J0 C0 y0 o6 P$ y, O7 `5 C
  CIRCLE     0.00600                                  DARK % x7 J& a+ H# E  [
  CIRCLE     0.00800                                  DARK 5 ]3 c2 [( S) d* @" \# a4 V
  CIRCLE     0.01000                                  DARK
2 A# g5 R* `8 u, I  CIRCLE     0.01500                                  DARK , B& D; O# j# ]! L1 C6 Y$ W- y- P( D
  CIRCLE     0.02000                                  DARK
/ R7 h' D- I* y; D1 c" ]! m  r  CIRCLE     0.02400                                  DARK
8 ~+ M3 n- m3 {- u* v  CIRCLE     0.04000                                  DARK
! F& r: u$ c3 y6 E  CIRCLE     0.04300                                  DARK
4 k/ p' j8 K( D  CIRCLE     0.04700                                  DARK
3 t; k8 \1 ?* x. R# S" L  CIRCLE     0.04724                                  DARK
8 T- E/ f6 s& t; R5 i  CIRCLE     0.05500                                  DARK
% \4 }, \/ e# [0 }/ g4 U  SQUARE     0.04000                     0.000 NO     DARK
3 ~; L4 i9 y: r  RECTANGLE  0.01000     x 0.04700       0.000 NO     DARK 1 e7 S$ k+ a# ^
8 m' N7 s  P8 F  v0 Q  \  RECTANGLE  0.03000     x 0.09800       0.000 NO     DARK 4 D) s) M, C) y$ \& S5 Q8 b
! V, ~+ \5 A2 K) P8 b. G  RECTANGLE  0.04300     x 0.09800       0.000 NO     DARK
1 \* f% h, Q5 l# C$ U0 {9 t  RECTANGLE  0.04900     x 0.09800       0.000 NO     DARK
' M% c: X+ J9 h. ]- H" k6 M  RECTANGLE  0.05700     x 0.08300       0.000 NO     DARK . `, o2 T7 c" _4 e
  RECTANGLE  0.05900     x 0.07900       0.000 NO     DARK # I1 G# P2 \& s6 N( D0 H' p8 @
  RECTANGLE  0.06500     x 0.07500       0.000 NO     DARK ( ~( M2 p4 R( M/ G* Q- j
- t6 E5 e* O$ H- P% ^; C  Z5 L7 Y+ e  OBLONG     0.02500     x 0.07500       0.000 NO     DARK 9 W$ E3 a7 c& M1 X
! P; t5 U2 Q6 |( [1 q9 r6 h  OBLONG     0.05400     x 0.15300       0.000 NO     DARK 4 }1 V' u2 F9 }! \; D& d; Y
5 \# C6 ]1 k8 E& q  OBLONG     0.06500     x 0.16100       0.000 NO     DARK + `! f' U3 v1 t
9 W3 [3 g7 M% s: G9 G* D6 ^" q3 b+ @  OBLONG     0.08000     x 0.02953       0.000 NO     DARK 5 S5 A' p" x/ J% b1 ?8 F
$ E/ j5 P' W0 I$ r4 E' ]( }, Z  PAD SHAPE  SHAPE20X28                180.000 NO     DARK
. q2 F4 E# y" H9 a9 l/ P# q4 {2 S/ b. c0 x" b
     TOP created with warnings* U% x) f( S! q7 s$ B
6 L1 \9 g0 }- Y+ B5 R! N
: \; P  a$ y5 A1 a! y# p% E" _------------------------------------------------------
" C8 `& g  y; h& d SUMMARY:" D# p$ X7 a3 e2 E3 v
        drill created with warnings0 f# }$ g& i3 ?7 G
3 a( e: h  k' L2 T        solder_top created with warnings/ C+ n7 [  \% |5 k$ ^* T
        paste_bot created with warnings7 S! O5 `* B: d: v* Y2 i
4 ^4 G, ]5 I& B8 d6 X        SILK_BOT created with warnings$ E; s3 G; A( w8 v2 w* `
        SILK_TOP created with warnings' x. G0 W- P9 p5 `# B& Y) w+ k
7 W  D+ q: N) D5 v" s& Q        GND2 created with warnings5 t. G' `! n( Y. u. F
        SIG created with warnings- C1 T4 H  O" O
* |( j; G" m7 D, R' a        GND1 created with warnings4 j$ _5 J: x0 Y! S) q- a5 s5 |
! d) G1 C  U3 }3 t" {0 V ARTWORK Error
发表于 2013-5-16 21:46 | 只看该作者
WARNING: DRC OUT OF DATE on this layout.你更新下DRC
发表于 2013-5-16 23:00 | 只看该作者
查看出現Error 的資料座標位置是不是發生兩個 sahpe 共搭同一個 Void ?' l4 q8 C, w$ ^( V
把這兩個 sahpe 何必起來應該就可以了.7 o. m- U: ~5 L5 O0 u' _0 q: M6 k
8 S" s' M* _) O( q
另外你的 Format 社的應該是有問題 , 系統預設的 5.3 應該是會發生精度不足的問題.
0 y$ }% s/ c: i  ?請修正為 2.5 或 3.5
    郁闷
    2024-4-23 15:52
  • 签到天数: 57 天
    [LV.5]常住居民I
    发表于 2013-5-17 15:29 | 只看该作者
    # d% w7 Q' e; M3 m1 C! j6 `3 Y. L, x
    点击shape add,画上MAUFACTUING---Photoplot_outline 应该就好了,将整个要出GERBER的PCB和钻孔信息画在里面
    GMT+8, 2025-11-24 17:48 , Processed in 0.312500 second(s), 23 queries , Gzip On.
