" m% s( e1 w0 _
根據踢哀(TI)的講法:
8 T0 @* D6 X. W/ n3 u溫度的變化相對緩慢,不用太高的取樣速率(Sampling Rate),SAR(Successive Approximation Register)ADC 的速度剛好也不快,所以這種狀況下是不需要外部運放緩衝(Buffer)電路的。. j. B, x% n! E0 ~
% C5 a# y5 D9 t8 _$ }' C& D
原文節錄: A+ {0 B1 H! l9 @* a$ _
Thermistors are used to monitor temperature in applications such as appliances, wireless environmental sensors, and smoke and heat detectors. In these applications, the thermistor voltage changes slowly thus it is not necessary to sample at high sampling rates. This means that there is no need for a driving input amplifier to condition the input voltage. A similar circuit design, Driving SAR directly without a front-end buffer circuit, explains how to measure introduced drift from external components which can prove to be helpful in these applications.
) V) M; [# D, V9 V
. ^5 M) \6 b( F |
