本帖最后由 超級狗 于 2024-5-10 08:09 编辑 ; H# C# |) a0 U
' y+ c8 C$ ^6 I6 a4 S5 V3 D
嬰飛靈(Infineon)的講法!
# w) j9 ~1 ]) [9 Q) B6 g V& R
. n8 v8 p; j7 J' `- @5 Q3 w. u, y* ^' a% K4 O7 w4 ^ e' b
I2C Communication7 h A& ^* `. z( k# @
In the case of a I2C single Master – single Slave configuration, a series resistor is recommended to be placed close to the Master device. For all other configurations, series resistors are placed close to each of the Master / Slave device connected to the bus. Refer to the (I2C Bus Specification user guide) to choose the right value for series resistors and corresponding pull-up resistors.! {6 _; ?* T! o" L5 n1 y
6 k- W) H. x7 R; |, e* f) i! L% M+ N5 C' X4 P
SPI Communication
3 A- H/ u5 h4 IIn the case of SPI communication, for the Master device, place the series resistors near the Master In Slave Out (MISO) pin. For the Slave device, place the series resistor near the Master Out Slave In (MOSI) pin.
2 G- _, L2 {6 i+ j# |+ V
6 O7 y1 \( m, j* @
; X( B( S6 N& N
2 [$ R9 `' D, C4 j( e* m' p7 o9 t& I: m' i: y
