! u( H( _, M. f8 t, U9 b3 W6 X3 v: O6 B6 P* `; R" _
嬰飛靈(Infineon)官網上有這麼一句話。! r+ f5 x" P( g* m; u
& _% z4 z0 `2 G& }; A! SLoad Capacitance of Tri-State data bus of many SRAMs connected together Eventhough only one SRAM will be using the data bus at a time, it will see the load capacitancedue to all other data busses from idle SRAMs. If the pin capaticance of one SRAM's Tri-State Data bus is 15pF and if 5 busses are connected together, thenthe active driver will see a load of 15 x 5 = 75pF.
9 Q* z6 f( u1 L ]1 y: c
1 N( B- u: N/ b% l% oCY14B116L-Z45XI - Infineon Technologies- j+ w8 i2 H0 B) ^- N
0 W8 Q3 u4 K, m: j通常我會檢查 最大負載電容( Maximum Bus Load Capacitance)和 輸入/輸出驅動電流( Input / Output Driving Current)I OH、I OL、I IH、I IL,不過後者在芯片資料中好像沒寫,也要看你 MCU 端的數據。 6 _ F( ^- R( | i
* O) b- t C# g
但他們都拿五顆當例子了,我覺得在 NVSRAM 端可能沒問題,剩下就是你 MCU 端推得動、推不動的問題了。
) c9 b( f8 q8 D, `" ]" m6 M; P" t7 R7 s( r% Z' ~ \; K' x4 R6 v# B
 / i) E1 \$ w9 E |6 _) B0 i) I$ J6 [7 {
; E$ y, b0 I) h( F" P1 C9 `
- a4 G) u; r) e |
