查看: 1291|回复: 2
power pcb and orcad10.5 are conflict
发表于 2008-6-25 10:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
when I  finish the setup of the power pcb and orcad10.5 ,i find both of them conflict,how to solve that problem?" S5 Z! P$ Z. z8 x& F/ \
thanks first !!! v. d/ |) e! i# H
$ ]  ]6 t' a8 M[ Last edited by panhaojie at 2008-6-25 10:26 ]
 楼主| 发表于 2008-6-25 13:56 | 只看该作者
nobody answers the question?
ok, i have solved it ...
发表于 2008-6-27 18:52 | 只看该作者
I F Y
YOU  are   very  ox.    ..2 v9 L! n$ p- d& S; }; F. [5 U, W4 p
Are  you  MM  or GG ???/
GMT+8, 2025-11-26 08:33 , Processed in 0.156250 second(s), 24 queries , Gzip On.
