查看: 444|回复: 3
代码补充求助
    2021-10-26 15:48
    发表于 2022-9-14 14:47 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    如下代码,请问这段应该怎么改才能实现每层都有100这个数值
    源码:procedure(quickartset()
          let(()
                 layerlist = car(list(axlGetParam("paramLayerGroup:ETCH")->groupMembers))
                 layercont = length(layerlist)
                 layertotal = layercont
                 num = 0
                             delnum = 0
                     oldartlayerlist = car(list(axlGetParam("artwork")->groupMembers)) ;("top" "bottom")
                             oldartlayerlistcount = length(oldartlayerlist)
                             deloldartlayerlist = list()
                             while((oldartlayerlistcount-1 >= delnum)
                             drlid = axlGetParam(strcat("artwork:" nth(delnum oldartlayerlist)))
                             deloldartlayerlist = append1(deloldartlayerlist drlid)
                             delnum = delnum+1
                             axlDeleteObject(deloldartlayerlist)
                             ;delet done
                 namelist = list("01_" "02_" "03_" "04_" "05_" "06_" "07_" "08_" "09_" "10_" "11_" "12_" "13_" "14_" "15_"
                             "16_" "17_" "18_" "19_" "20_" "21_" "22_" "23_" "24_" "25_" "26_" "27_" "28_" "29_" "30_" "31_" "32_" "33_" "34_" "35_" "36_" "37_" "38_" "39_" "40_" "41_" "42_" "43_" "44_" "45_" "46_" "47_" "48_" "49_" "50_")
                 drilllist = list("1" "2" "3" "4" "5" "6" "7" "8" "9" "10" "11" "12 " "13" "14" "15" "16" "17" "18" "19"
                             "20" "21" "22" "23" "24" "25" "26" "27" "28" "29" "30" "31" "32" "33" "34" "35" "36" "37" "38" "39" "40" "41" "42" "43" "44" "45" "46" "47" "48" "49" "50")
                 drilllayer = strcat("MANUFACTURING/NCLEGEND-1-"  nth(layertotal-1 drilllist))
                 drilllayerlist = list("BOARD GEOMETRY/OUTLINE" "MANUFACTURING/PHOTOPLOT_OUTLINE" "BOARD GEOMETRY/ASSEMBLY_NOTES" "BOARD GEOMETRY/DESIGN_OUTLINE" "BOARD GEOMETRY/CUTOUT")
                 drillname = strcat(nth(layertotal namelist) "DRILL")
                 layercheck = axlIsLayer(drilllayer)
                             if((layercheck == nil)
                            then
                            axlUIConfirm("Please NC drill first")
                             else
                 while((layercont >= 1)
                         numadd = nth(num namelist)
                         layeradd = list("BOARD GEOMETRY/DESIGN_OUTLINE" "BOARD GEOMETRY/CUTOUT" "BOARD GEOMETRY/OUTLINE" strcat("ETCH/",car(layerlist))
                                       strcat("VIA CLASS/",car(layerlist)) strcat("PIN/",car(layerlist)))
                         layername = strcat(numadd,car(layerlist))
                         Filmcreat(layername layeradd)
                           layercont = layercont-1
                           layerlist = cdr(layerlist)
                           num = num+1
                ;DRILL   ——————————with B/B VIA
                 posbdrillist = car(list(axlGetParam("paramLayerGroup:MANUFACTURING")->groupMembers))
                             posbdrilltotal = length(posbdrillist)
                             numdrl = 0
                 while((posbdrilltotal-1 >= numdrl)
                             posbdrillayer = nth(numdrl posbdrillist)
                             if(strncmp("NCLEGEND" posbdrillayer 8) == 0
                               drilllayerlist = append1(drilllayerlist strcat("MANUFACTURING/" posbdrillayer))
                               numdrl = numdrl+1
                               ; drilllayerlist = append1(drilllayerlist "MANUFACTURING/"
                       Filmcreat(drillname     drilllayerlist)
               ;user preferrence layer1
               Filmcreat(strcat(nth(layertotal+11 namelist) "PROBE_BOTTOM")  '("PIN/FILMMASKBOTTOM" "VIA CLASS/FILMMASKBOTTOM" "MANUFACTURING/PROBE_BOTTOM" "BOARD GEOMETRY/DESIGN_OUTLINE" "BOARD GEOMETRY/CUTOUT" "BOARD GEOMETRY/OUTLINE" ))
              ;Filmcreat(strcat(nth(layertotal+8 namelist) "user preferrence layer1")  '("BOARD GEOMETRY/OUTLINE"
              ;                     "REF DES/SILKSCREEN_BOTTOM" "PACKAGE GEOMETRY/SILKSCREEN_BOTTOM" "BOARD GEOMETRY/SILKSCREEN_BOTTOM" ))
                                    ; axlShell("artwork")
                                    axlVisibleSet(old_visList)
                                    axlUIWRedraw(nil)
          let( ()
          axlShell("setwindow pcb")
          axlShell("generaledit")
          axlShell("artwork ")
          axlShell("setwindow form.film_control")
              axlShell(sprintf(nil "FORM film_control filmtree  %s" layerlist))
          axlShell("FORM film_control shape_bounding_box 100 ")
          axlShell("FORM film_control ok ")
    2021-10-26 15:48
     楼主| 发表于 2022-9-14 16:36 | 只看该作者
    2021-10-26 15:48
     楼主| 发表于 2022-9-15 08:49 | 只看该作者
    Vincent_杜 发表于 2022-9-14 22:19
    先把需求说清楚,100是干嘛的
    就是这两句的100
    GMT+8, 2025-11-22 13:56 , Processed in 0.187500 second(s), 29 queries , Gzip On.
