| SYM_NAME | COMP_DEVICE_TYPE | REFDES |
| 97C04 | SW_DIP-4_SM_97C04_SW DIP-4/SM | SW1 |
| 290V_10X9MM | 290VAA5F201B2_290V_10X9MM_290VA | S17;S18 |
| 0402_MLP | DIODE_TVS_BIDIR_0402_MLP_0402ES | D3;D4;D5;D6;D7 |
| 0603_CC | CAP_NP_0603_CC_1000PF_5% | C1213 |
| 1206_CC | CAP_NP_1206_CC_10UF_10% | C175;C197;C205;C209;C218;C237;C241;C243;C275;C290;C295;
( }% Y4 n2 G# b- z& L0 qC303;C304;C314;C316;C333;C353;C369;C375;C376;C1166;C1168;5 r/ l' O! }- J: [+ ?! p
C1175;C1178;C1217;C1219;C1223;C1226;C1236 |
| 1812 | FUSE_RESETTABLE_1812_2.6A | F1 |
| ANTENNA-2450 | ANTENNA_2P4GHZ_ANTENNA-2450_ANT | E2 |
| ANTENNA-RGFR | ANTENNA_RGFR_ANTENNA-RGFR_ANTEN | E1 |
| BATT_MS | LICELL_BATT_MS_LICELL | BT1 |
| CC0603 | CAP_NP_CC0603_0.1 UF_10% | C26;C27;C31;C39;C127;C131;C164;C168;C173;C174;C177;C178;C179;% I" _7 C& q. }/ u; ?" o2 d+ z K$ U& Z
C195;C200;C201;C202;C204;C206;C207;C208;C215;C222;C232;C233;
) d9 y; p0 V; a% Y# ]9 HC234;C235;C238;C239;C240;C268;C276;C278;C279;C291;C302;C305;
/ z; s$ }+ {+ o0 O; Z5 PC306;C313;C315;C317;C320;C332;C349;C354;C355;C367;C368;C370;
5 s# F) {' `) U- z- `C371;C372;C373;C374;C1162;C1163;C1164;C1165;C1169;C1170;C1173;3 y* \$ r+ O$ F
C1174;C1176;C1177;C1179;C1183;C1187;C1188;C1189;C1192;C1193;0 B5 k9 |1 a. h
C1194;C1195;C1197;C1201;C1203;C1208;C1209;C1214;C1215;C1216;. t6 S6 b8 P0 r2 Q! \" w* L
C1218;C1220;C1221;C1224;C1225;C1227;C1230;C1231;C1232;C1233;) W' z) _6 D6 F3 G' g/ G
C1235;C1237 |
| CC0603 | CAP_NP_CC0603_1.0 UF_10% | C28;C274;C1161;C1167 |
| CC0603 | CAP_NP_CC0603_0.47UF_10% | C33;C329;C330;C334;C335 |
| CC0603 | CAP_NP_CC0603_10PF_5% | C38 |
| CC0603 | CAP_NP_CC0603_0.01UF_10% | C128;C130;C188;C198;C220;C236;C242;C244;C245;C248;C249;C256;
% U2 W( X( f& a: \7 oC257;C258;C265;C269;C277;C288;C289;C318;C319;C323;C324;C325;+ t& L4 l% w! x* J
C337;C338;C339;C351;C1190;C1196;C1198;C1202;C1204;C1222 |
| CC0603 | CAP_NP_CC0603_15PF_1% | C167;C357 |
| CC0603 | CAP_NP_CC0603_0.022UF_10% | C203 |
| CC0603 | CAP_NP_CC0603_100PF_10% | C212;C1211;C1212 |
| CC0603 | CAP_NP_CC0603_1.8PF_0.1PF | C281;C283 |
| CC0603 | CAP_NP_CC0603_2.7PF_ | C282 |
| CC0603 | CAP_NP_CC0603_220PF_10% | C1157;C1158 |
| CC0603 | CAP_NP_CC0603_0.082UF_10% | C1191 |
| CC0603 | CAP_NP_CC0603_18PF_10% | C1199;C1200 |
| CC0603 | CAP_NP_CC0603_30PF_10% | C1210 |
| CC0603 | CAP_NP_CC0603_24PF_5% | C1238 |
| CC1210 | CAP_NP_CC1210_22UF_20% | C246 |
| CC1812 | CAP_NP_CC1812_1000PF_20% | C166;C358 |
| CC7343-43 | CAP_POL_CC7343-43_220UF_10% | C1154;C1155 |
| CC7343A | CAP_POL_CC7343A_100UF_10% | C129;C176;C180;C1159 |
| CC7343A | MOT_TCAP_CC7343A_120UF | C181;C182 |
| CHIPFET | NTHS5404_CHIPFET_NTHS5404 | Q4;Q7;Q8 |
| CHOKE_CM_4PIN | ZJYS51R5-2P_CHOKE_CM_4PIN_ZJYS5 | U78 |
| CON8_RJ45_TH2 | RJ45-4_0_CON8_RJ45_TH2_RJ45-8 | J16 |
| CON9_DB_PLG_2P74_RA | CONN_DB9M_MTGTABS_CON9_DB_PLG_2 | CON1 |
| CON_120S_QSH_SM_05PITCH | QSH060_CON_120S_QSH_SM_05PITCH_ | J4 |
| CON_BBC_40P_0P4_SM | FX12B-40P_CON_BBC_40P_0P4_SM_CO | J32 |
| CON_COMBO_420DA45P | 420DA6J45PC0103_CON_COMBO_420DA | P5 |
| CON_FFC_12_0P5_RA | 12 PIN ZIF CONNECTOR_CON_FFC_12 | CN76;CN77 |
| CON_JACK_2F_RA_TH_21XX | CONN_AV_1X2_F_CON_JACK_2F_RA_TH | J20 |
| CON_JACK_3F_RA_TH_32XX | RL-1515-3_CON_JACK_3F_RA_TH_32X | J21 |
| CON_SEAF500_REV_NUMBERED | SEAM-10X50_CON_SEAF500_REV_NUMB | J78 |
| CON_SEAM500_REV_NUMBERED | SEAM-10X50_CON_SEAM500_REV_NUMB | J73 |
| CON_ZF1_4F_1MM_SM | ZF1_4_CON_ZF1_4F_1MM_SM_CONN SK | J22;J23 |
| CON_ZF5_15F_0P5_SM | ZF5_15_CON_ZF5_15F_0P5_SM_ZF5_1 | CN16;CN19 |
| CON_ZF5_24F_0P5_SM | ZF5_24_CON_ZF5_24F_0P5_SM_ZF5_2 | CN14 |
| CON_ZF5_40F_0P5_SM | CON40_CON_ZF5_40F_0P5_SM_ZF5_40 | J14;J27 |
| HDD_44_K | ATA_HDD_CONN_4_HDD_44_K_ASP-666 | J41 |
| HDR2X5 | CONN_HDR_5X2_HDR2X5_CON_2X5 | J30;J31 |
| HDR102 | CONN_HDR_2X1_HDR102_HDR 1X2 TH | J26;J28 |
| HDR103_49MIL | CONN_HDR_3X1_HDR103_49MIL_CON_1 | CN79 |
| HDR205 | CONN_HDR_5X2_HDR205_HDR 2X5 | P2 4 |
| HDR210_TMM_SM | CONN_HDR_10X2_HDR210_TMM_SM_HDR | P3 |
| HDR225_FTSH_SM | CONN_HDR_25X2_HDR225_FTSH_SM_HD | J79 |
| IND_0603 | INDUCTOR_IND_0603_0.27UH_10% | L22 |
| IND_0603 | INDUCTOR_IND_0603_0.120UH_10% | L23 |
| IND_0603 | INDUCTOR_IND_0603_1.8NH_0.3NH | L24;L27 |
| IND_0603 | INDUCTOR_IND_0603_0.001UH_ | L25 |
| IND_0603 | INDUCTOR_IND_0603_470OHM_25% | L26;L31;L32;L33;L34;L41;L42;L43;L44;L49;L53;L55;L70;L77;L81;L84;
) T) a5 J( s, f% Z5 pL85;L86;L89;L90;L91;L97;L98;L99;L100;L101;L102;L105;L106;L130 |
| IND_0603 | INDUCTOR_IND_0603_2.5K_25% | L35;L66;L67;L68 |
| IND_0603 | BEAD_FERRITE_IND_0603_220OHM_25 | L96;L113;L114;L115;L116;L117;L118;L119;L131;L132;L133;L134;L135;8 ?+ W, b# n3 Q
L136;L137;L138;L139;L140;L141;L142;L143;L144;L145;L146;L147;L148;L149;L150 |
| IND_1206 | BEAD_IND_1206_68OHM | L151;L152 |
| IND_VLS252012 | IND_IND_VLS252012_4.7UH_20% | L6 |
| JACK4_RA_SMT | 3.5MM_AUDIO_JACK_JACK4_RA_SMT_C | J80 |
| JUMP2X2-6040 | HDR-2X2_JUMP2X2-6040_HDR 2X2 | J25 |
| LED_0603_C1 | LED_LED_0603_C1_RED | D2 |
| LQFP64 | ADV7180BSTZ_LQFP64_ADV7180 | U76 |
| MICRO_USB_CONN_9PIN | MICRO_USB_CONN_9PIN_MICRO_USB_C | J10 |
| MIC_WM-63PR | MIC_MIC_WM-63PR_MIC | P1 |
| QFN20_3X3MM_A | SI4702_QFN20_3X3MM_A_SI4702 | U47 |
| QFN36 | LAN8700_QFN36_LAN8700 | U80 |
| QFN64_0P65_12X12 | APM6628_QFN64_0P65_12X12_APM662 | U55 |
| RAPC722 | PHONE_JACK_RAPC722_CON_1_PWR | J12 |
| RC0603 | RES_RC0603_2.2K_5% | R11 |
| RC0603 | RES_RC0603_22K_5% | R13 |
| RC0603 | RES_RC0603_75_5% | R78;R217 |
| RC0603 | RES_RC0603_750_5% | R106 |
| RC0603 | RES_RC0603_7.5K_5% | R164;R165;R171;R175;R176;R179;R180;R181;R184;R195;R196;R251;2 ~: p; l: x( z! U
R252;R291 |
| RC0603 | RES_RC0603_12.4K_1% | R170 |
| RC0603 | RES_RC0603_150_5% | R172;R174 |
| RC0603 | RES_RC0603_49.9_1% | R173;R206;R210;R218;R219;R282;R283;R293;R294;R295 |
| RC0603 | RES_RC0603_10K_5% | R186;R187;R190;R191;R193;R197;R199;R242;R244;R257;R260;R261;9 }: H' V9 A* @7 H' S$ `2 p. [/ m
R262;R263;R270;R271;R272;R273;R274;R289;R290;R296;R297;R298;
9 b; {/ Q/ D/ H) `7 T5 z: @! t" [0 CR300;R301;R302;R303;R304;R305;R310;R315;R339;R340;R345;R348;3 F- \. D! [ ?
R349;R350;R351;R352;R353;R354;R355;R356;R357;R361;R363;R364;
; v" y) X# x7 L5 P$ J0 I! F& }R365;R368;R369;R1121;R1122;R1123;R1136;R1153;R1166;R1168;' ?7 L5 t! y8 C3 ?8 f
R1184;R1185;R1186;R1187;R1190;R1191;R1192;R1193;R1194;R1196;R1199;R1200 |
| RC0603 | RES_RC0603_4.7K_5% | R188;R1125;R1128;R1129 |
| RC0603 | RES_RC0603_5.6K_5% | R192 |
| RC0603 | RES_RC0603_0_1% | R198;R220;R221;R229;R236;R238;R239;R240;R241;R243;R245;R246;& h ~9 f) k/ B: k. P0 k' R% p W
R247;R248;R249;R250;R254;R255;R256;R259;R264;R265;R266;R267;2 e# ^' D8 ?1 G- @
R268;R269;R279;R284;R288;R307;R312;R313;R314;R317;R318;R321;5 `! ^# J* J Q7 W# y" u' U( [
R322;R323;R324;R325;R326;R327;R328;R329;R330;R331;R334;R335;
) [$ n* H1 d0 s& R- w7 [R346;R347;R358;R359;R360;R362;R366;R367;R370;R371;R373;R381;# S5 y9 H( y8 a4 M
R382;R383;R384;R387;R388;R389;R390;R406;R407;R408;R409;R410;9 \ R( n2 f& \6 ?# c# M# F$ T
R411;R1111;R1112;R1113;R1126;R1127;R1130;R1131;R1132;R1133;
2 z( ]7 ]( y+ M0 QR1134;R1135;R1137;R1138;R1141;R1142;R1144;R1145;R1148;R1149;
, X$ A% t3 `5 D6 s8 A- ~4 v/ P( Q* ~R1150;R1151;R1154;R1155;R1156;R1157;R1158;R1159;R1161;R1162;* x8 c( C9 i: c. L7 _/ U& h5 o+ x+ A
R1164;R1165;R1167;R1170;R1171;R1172;R1173;R1174;R1175;R1176;1 Z8 K' \0 c) g; r
R1177;R1178;R1179;R1180;R1181;R1182;R1183;R1188;R1189;R1195;# [0 T% F5 G- P( i& `- K+ i* D# M
R1197;R1198;R1201;R1202;R1203;R1204;R1205;R1206;R1210;R1211;
/ V6 R3 k+ X& h6 v) l ~' H, G+ GR1212 |
| RC0603 | RES_RC0603_33_5% | R212;R213;R214;R215;R216;R280 |
| RC0603 | RES_RC0603_15K_1% | R222 |
| RC0603 | RES_RC0603_200_5% | R230;R231;R1114;R1115 |
| RC0603 | RES_RC0603_1K_5% | R253;R275;R276;R277;R278;R286;R287;R292;R308;R309;R311;R316;
# V, i8 k" }4 ^, i; j* k+ NR319;R320;R332;R333;R336;R337;R338;R341;R342;R343;R344 |
| RC0603 | RES_RC0603_47K_5% | R258;R441;R1106;R1107;R1169 |
| RC0603 | RES_RC0603_10_5% | R285 |
| RC0603 | RES_RC0603_100K_5% | R299;R306;R1152;R1160;R1163 |
| RC0603 | RES_RC0603_75K_5% | R385 |
| RC0603 | RES_RC0603_100K_1% | R386;R1207;R1209 |
| RC0603 | RES_RC0603_453K_1% | R391 |
| RC0603 | RES_RC0603_100_5% | R440;R1143 |
| RC0603 | RES_RC0603_36_1% | R1116;R1118;R1120 |
| RC0603 | RES_RC0603_39.0_1% | R1117;R1119;R1124 |
| RC0603 | RES_RC0603_1.69K_1% | R1139 |
| RC0603 | RES_RC0603_1.0M_5% | R1140 |
| RC0603 | RES_RC0603_62_5% | R1146;R1147 |
| RC0603 | RES_RC0603_240.0K_1% | R1208 |
| RC1206 | RES_RC1206_0.02_1% | R439;R442;R443 |
| S08_1P27_4X5 | TLE6250_GV33_S08_1P27_4X5_TLE62 | U77 |
| SC70_6LEAD | FDG6331L_6P_SC70_6LEAD_FDG6331L | U4 |
| SOT23-5 | RT9706_SOT23-5_RT9706 | U54 |
| SOT23_S6 | SRV05-4_SOT23_S6_SRV05-4 | U71;U73 |
| SOT363 | MOSFET_P_6P_SOT363_NTJS4151P | Q5 |
| SOT363_A | NL7SZ18_SOT363_A_NL7SZ18 | U74 |
| SOT666_IP | ESDA6V1-5P6_SOT666_IP_ESDA6V1-5 | U22 |
| SOT-23 | MOSFET_P_SOT-23_IRLML6401 | Q6 |
| SOT-23 | DIODE_NUP2105L_SOT-23_NUP2105L | U79 |
| SW4_STJW_SM | TACT SWITCH_SW4_STJW_SM_STJW-69 | S13;S14;S15;S16 |
| SW_DIP16_8POS_SM | SW_DIP_8_SW_DIP16_8POS_SM_SW DI | SW2 |
| TDFN12_0P5_3X3P5 | PI3USB10ZEE_TDFN12_0P5_3X3P5_PI | U84;U85 |
| TESTPOINT_7MM_3MM_TH | TEST POINT L_TESTPOINT_7MM_3MM_ | TP48;TP49;TP50;TP51 |
| TESTPOINT_35MIL | TEST PAD_TESTPOINT_35MIL_35 MIL | TL4;TP8;TP9;TP10;TP11;TP12;TP13;TP14;TP15;TP16;TP17;TP18;
5 Z; h& l0 b" _, X8 {) F- ]TP19;TP20;TP21;TP22;TP23;TP24;TP25;TP26;TP27;TP28;TP29;TP30;
2 l+ f e% m0 T# G- ]+ jTP31;TP32;TP33;TP34;TP35;TP36;TP37;TP38;TP40;TP41;TP42;TP43;
5 G; x1 N- k; nTP44;TP45;TP46;TP47;TP52;TP53;TP54;TP55;TP56 |
| TO-263-5 | MIC29152BU_TO-263-5_MIC29302WU | U87 |
| TP-DUAL | TP_2MMX2P5MM_TP-DUAL_TP_2MMX2.5 | CN17;CN18 |
| TSSOP16 | IDT74CBTLV3257_TSSOP16_IDT74CBT | U26 |
| USB_A_SM2_SAMTEC | USB_A_USB_A_SM2_SAMTEC_CONN USB | J18 |
| USOP-8 | MAX4071_USOP-8_MAX4071 | U29 |
| WDFN6_2X2MM | RT8010PQW_WDFN6_2X2MM_RT8010 | U3 |
| XFMR_HX1188 | HX1188_XFMR_HX1188_HX1188 | T3 |
| XTAL4_5X3P2MM_SM | CLKGEN-SM_XTAL4_5X3P2MM_SM_25.0 | X1 |
| XTLOSC4_5X3MM_SM | CRYSTAL_JXS63_XTLOSC4_5X3MM_SM_ | Y18 |
| XTLOSCL_4_7X5MM_SM | CRYSTAL-SG3030JF_XTLOSCL_4_7X5M | Y14 |
