| SYM_NAME | COMP_DEVICE_TYPE | REFDES |
| 1X6RCPT_2P54_VT_TH | 1X6RCPT_THLF-G79672-001 | J1A5 |
| 1X8RCPT_2P54_VT_TH | 1X8RCPT_THLF-G79625-001 | J1B1;J2A1 |
| 1X10RCPT_2P54_VT_TH | 1X10RCPT_THLF-G79666-001 | J2B1 |
| 2X4HDR7 | 2X4HDR7_THLF-A91836-079 | J1B2 |
| 2X5HDR_SHRD_1P27MM_VT_TH | 2X5HDR_THLF-G84017-001 | J4A1 |
| 102276-001 | 1X2HDR_THLF-A91829-027 | J1A4;J3A1 |
| 102276-003 | 1X3HDR_THLF-A91829-001 | J1A6;J2 |
| 628492-001 | LABEL_SMLF-A19177-001 | LB3 |
| BGA4_1_05MM | CM1230_02_BGALF-D30400-001 | U1L1;U1L2;U1L3;U1L4;U2B2;U2B3 |
| BGA8_1_05MM | TPS22920_BGALF-G94441-001 | U2A2;U2A4;U2L1;U2M1 |
| BGA393_15X15MM | CLANTON_CUSTOMER_R1P2_BGALF-IPD031-201 | U2A5 |
| CONN6_H18587001 | CONN6_H18587001_TH-CONN,H18587-001 | J1 |
| CONN_SDCARD_8P_PP | CONN_SDCARD_8P_PP_SMLF-G46739-001 | J4A2 |
| FBGA78_8X11P5_8MM | MT41K128M8_FBGALF-G83568-001 | U1A1;U1B5 |
| JK_3P_RA | PWRJACK_THLF-D33700-002 | J4A3 |
| JK_STX3000_3P_2GH | AUDIOJACK_1PORT_3P_THLF-G76363-001 | J3B1 |
| LB_1500X500_PKG | LABEL_SMLF-A88430-001 | LB6V1 |
| LQFP48_7X7_P5MM | DP83848I_LQFPLF-G60296-001 | U4B1 |
| MK_EU_WEEE_9X5MM | LABEL_MECH_SMLF-IPD281-121,E | LB1 |
| MLF10_3X3_05MM_EP | TPS51200_SONLF-E17764-001 | U2A3 |
| QFN10_06_08_5MA | TS5A23159_QFN-IC,G63512-001 | U1;U2;U3;U4;U5;U6;U7;U9;U10 |
| QFN20_14_18_5MB | TXS0108E_QFN-IC,H18588-001 | EU1 |
| QFN40_6X6_05MM_EP2X3 | TPS652510_QFNLF-G43225-001 | U3A1 |
| RCPT_USB_5P_6MTG_SM | MICRO_USB_5P_SMT_SMLF-E77884-001 | J2B3 |
| RCPT_USB_5P_DIP_SM | MICRO_USB_5P_SMT_SMLF-G58911-001 | J3B2 |
| RJ45_L8291J | RJ45_GBE_L8291J_THLF-C98527-001 | J4B1 |
| SKT_MPCIE_FULL_52P_LATCH | MPCIE_LATCH_KIT,F | J2L1 |
| SMC0201 | CAPN_0201LF-1UF,20%,4V,0201LF | C3L15;C3L17;C3L18;C3L20;C3L24;C3L26;C3L28;C3L29 |
| SMC0402A | CAPN_0402LF-0.15UF,10%,10V,0402LF | C1A3;C1A4;C1A11;C1A12;C1A17;C1A18 |
| SMC0402A | CAPN_0402LF-0.1UF,10%,16V,0402LF | C1A5;C1A6;C1A7;C1A8;C1A9;C1A10;C1A13;C1A15;C1A16;C1A20;3 ~' q9 s5 D Q8 l! }
C1A21;C1A22;C1A23;C1A25;C1B1;C1L3;C1M1;C1M2;C1M3;C1M4;
- ~ P+ Y! T7 v9 NC1M5;C1M7;C1M9;C1M10;C1M11;C1M12;C1M13;C1M14;C2A3;C2A8;
) ~1 Y6 z, e Z# YC2A9;C2A10;C2B1;C2B5;C2B6;C2B7;C2B9;C2B11;C2L7;C2M2;C2M4;
0 U0 C& q) q2 y, |! `$ c' a/ wC2M5;C2M10;C3A2;C3A3;C3A4;C3A5;C3A6;C3A7;C3A22;C3A23;C3A24;
& E" V& A" }# GC3A25;C3A26;C3B18;C3L13;C3M10;C3M12;C3M13;C4A1;C4A3;C4B4;C4B7;
6 w r+ ?; E5 V/ GC4L2;C4L3;C4M2;C4M3;C4M4;C4M5;C1;C2;C3;C4;C5;C6;C7;C8;C9;C10;C11;& ~# N% y* \ i
C12;C14 |
| SMC0402A | CAPN_0402LF-1UF,10%,6.3V,0402LF | C1L1;C1L2;C1M6;C1M8;C2A1;C2A2;C2A4;C2A5;C2B3;C2L1;C2L5;C2L10;C2L13;
# Y* j3 B8 X5 ?3 cC3B5;C3B12;C3B13;C3B15;C3L8;C3L9;C3L10;C3L11;C3L14;C3L21;C3M3;C4B3;
% F# x1 ^8 \) P# CC4L1;C13 |
| SMC0402A | CAPN_0402LF-18PF,5%,50V,0402LF | C2A6;C3A10;C3L5;C3L6 |
| SMC0402A | CAPN_0402LF-0.01UF,10%,50V,0402LF | C2A7;C2B12;C2B13;C2L2;C3A20;C3A21;C3B16;C3B17;C3L19;C4B6 |
| SMC0402A | CAPN_0402LF-4700PF,10%,50V,0402LF | C2L3;C2M6;C3A11;C3A14;C3A15;C3B6 |
| SMC0402A | CAPN_0402LF-4700PF,10%,50V,0402LF,E | C2L14 |
| SMC0402A | CAPN_0402LF-220PF,5%,50V,0402LF | C2M8;C2M9 |
| SMC0402A | CAPN_0402LF-.1UF,10%,16V,0402LF,E | C3A8;C3A9 |
| SMC0402A | CAPN_0402LF-1000PF,10%,50V,0402LF | C3A12;C3A13;C3B8;C3L1;C3L25;C3L27;C3L30;C3M1;C3M2;C3M5;C3M6;C3M7;C3M8 |
| SMC0402A | CAPN_0402LF-10PF,5%,50V,0402LF | C3A16;C3A17;C3B2 |
| SMC0402A | CAPN_0402LF-10UF,20%,4V,0402LF | C3L22 |
| SMC0402A | CAPN_0402LF-1PF,.25PF,25V,0402LF | C4M1 |
| SMC0603 | CAPN_0603LF-2.2UF,10%,6.3V,0603LF | C1A14;C1A24;C3L12;C3L16;C3L23;C3M4 |
| SMC0603 | CAPN_0603LF-22UF,20%,6.3V,0603LF | C2B2;C3B10 |
| SMC0603 | CAPN_0603LF-10UF,20%,6.3V,0603LF | C2B4;C3M9 |
| SMC0603 | CAPN_0603LF-.047UF,10%,16V,0603LF | C3A18;C3A19;C4A2 |
| SMC0603 | CAPN_0603LF-470PF,10%,50V,0603LF | C3B14 |
| SMC0603 | CAPN_0603LF-4.7UF,10%,6.3V,0603LF | C3L2;C4M6 |
| SMC0805 | CAPN_0805LF-10.00UF,10%,6.3V,0805LF | C1A1;C1A2;C3L3;C3L4;C3L7 |
| SMC0805 | CAPN_0805LF-22.0UF,20%,6.3V,0805LF | C1A19;C2L4;C2L6;C2L11;C3A1;C3B1;C3B7;C3B9;C3B11 |
| SMC0805 | CAPN_0805LF-10UF,10%,16V,0805LF | C2L8;C2L9;C2L12;C3B3;C3B4 |
| SMC0805 | CAPN_0805LF-47UF,20%,6.3V,0805LF | C3M11;C4B1;C4B2 |
| SMC0805P | CAP_P_0805LF-10UF,10%,16V,0805LF | C4B5 |
| SMC1210_110T | CAPN_1210LF-100UF,20%,6.3V,1210LF | C2M7 |
| SMF0402 | FERR_BD_SMLF-G22224-001 | FB3L1;FB3M1 |
| SMF0805 | FERRITE_SMLF-656554-032 | FB1M1 |
| SMF2411 | FUSE_SMT_SMLF-G89151-001 | F4B1 |
| SMI_255_255 | INDUCTOR_SMLF-A32422-019 | L2M1;L3A1;L4B1 |
| SML03025_4P | CHOKE_4P_03025LF-E53905-001 | L3M1;L3M2 |
| SMLED0603 | LED_0603LF-E16297-001 | DS2A1;DS3A1;DS3B1;DS4A1;DS4A2 |
| SMR0402A | RESN_0402LF-4.99K,1%,0402LF | R1A1;R1A7;R1A8;R1A9;R1A10;R1A11;R1A12;R1A13;R1A14;R1A15;R1A16;
6 H) D9 x3 H( T' v) U' c9 r. RR1A17;R2B24;R2B25 |
| SMR0402A | RESN_0402LF-36.5,1%,0402LF | R1A2;R1A3;R1A4;R1A5;R1A6;R1A18;R1A19;R1A20;R4L3;R4L4;R4L5;R4L6;- z- v+ B Z- `6 o
R4L7;R4L8;R4L12;R4L13;R4L14;R4L15;R4L16;R4L17;R4L18;R4L20;R4L21;0 ?: V4 B6 j6 M& Z; o
R4L22;R4L23 |
| SMR0402A | RESN_0402LF-100K,1%,0402LF | R1A21;R4B6 |
| SMR0402A | RESN_0402LF-33.2,1%,0402LF | R1B1;R1B2;R1L5;R1L7;R2B5;R2B6;R2B7;R2B8;R2B9;R2B10;R2B11;R2B14;: \9 {, ]7 p- c; w5 }/ C' ?
R2B18;R2B20;R2B21;R2L4;R2L5;R2L6;R2L7;R2L8;R2L12;R2L13;R2M5;R2M7;. t* }+ j8 \+ {) P; k' e
R2M8;R2M9;R2M10;R2M11;R2M12;R2M13;R2M14;R3M1;R3M2;R3M5;R3M6;! |% z4 n" U; V8 }# y
R3M8;R3M10;R3M11;R3M14;R3M16;R3M17;R3M18;R3M19;R3M20;R3M21;
0 P: t+ k* {4 q+ W9 [R4M7;R4M8;R4M9;R4M10;R4M11;R4M12;R13;R14;R15 |
| SMR0402A | RESN_0402LF-1K,1%,0402LF,E | R1L1;R1L2;R2L1;R2L10 |
| SMR0402A | RESN_0402LF-1K,1%,0402LF | R1L3;R1L10;R2A1;R2A3;R3A5;R3A8;R3A11;R3A12;R3B6;R3B12;R4A2;R4L1;R4L2 |
| SMR0402A | RESN_0402LF-10.0K,1%,0402LF | R1L11;R2B4;R2B12;R2B13;R2B16;R2B19;R2B22;R2L3;R3A10;R3A14;R3A17;8 ]; j w2 l J* Y( ~7 |' S% d
R3A20;R3L1;R4B8;R4L9 |
| SMR0402A | RESN_0402LF-110,1%,0402LF | R1M1;R1M2;R3L11 |
| SMR0402A | RESN_0402LF-2.2K,5%,0402LF | R1M3;R1M4;R1M5;R2M2;R3A13;R3A15;R1 |
| SMR0402A | RESN_0402LF-49.9,1%,0402LF | R1M7;R1M8;R1M9;R1M10;R2A12;R2A13;R2A14;R3L13 |
| SMR0402A | RESN_0402LF-4.7K,5%,0402LF | R1M11;R2M15;R3B11;R3M15;R4B1;R4M2 |
| SMR0402A | RESN_0402LF-0,0,0402LF | R1M12;R2A5;R2M1 |
| SMR0402A | RESN_0402LF-10K,5%,0402LF | R2A4;R2A6;R2A7;R2B1;R2B15;R2B30;R2L2;R2L9;R2L11;R2L16;R2L17;4 `, ~3 e7 V# w0 [2 R% u
R2L18;R2M3;R3B3;R3B4;R3B10;R3L3;R3M22;R4A6;R2;R3;R4;R7;R10;R11 |
| SMR0402A | RESN_0402LF-7.5K,1%,0402LF | R2A8;R2A10;R2A11 |
| SMR0402A | RESN_0402LF-10M,5%,0402LF | R2A9 |
| SMR0402A | RESN_0402LF-22.6,1%,0402LF | R2B2;R3A6;R3A7 |
| SMR0402A | RESN_0402LF-10.0K,1%,0402LF,E | R2B17;R3M7;R3M9 |
| SMR0402A | RESN_0402LF-0,0,0402LF,E | R2B28;R3A3;R3A4;R3A9;R3A24;R3L8;R3L9;R3L10;R3L12;R3L14 |
| SMR0402A | RESN_0402LF-33.2,1%,0402LF,E | R2B29;R3M13 |
| SMR0402A | RESN_0402LF-40.2K,1%,0402LF | R2L14;R2M4;R3A16 |
| SMR0402A | RESN_0402LF-158K,1%,0402LF | R2L15 |
| SMR0402A | RESN_0402LF-40.2K,1%,0402LF,E | R2L19 |
| SMR0402A | RESN_0402LF-158K,1%,0402LF,E | R2L20 |
| SMR0402A | RESN_0402LF-49.9,1%,0402LF,E | R2L21 |
| SMR0402A | RESN_0402LF-45.3K,1%,0402LF | R2M6 |
| SMR0402A | RESN_0402LF-24.9K,1%,0402LF | R3A1;R3A2;R3A22;R3A23;R3B1 |
| SMR0402A | RESN_0402LF-12.7K,1%,0402LF | R3A18 |
| SMR0402A | RESN_0402LF-180K,1%,0402LF | R3A19;R3B2 |
| SMR0402A | RESN_0402LF-147K,1%,0402LF | R3A21;R4A7 |
| SMR0402A | RESN_0402LF-1.5K,1%,0402LF | R3B5;R4B2;R4B3 |
| SMR0402A | RESN_0402LF-1M,5%,0402LF | R3L2 |
| SMR0402A | RESN_0402LF-8.06K,1%,0402LF | R3L4 |
| SMR0402A | RESN_0402LF-32.4,1%,0402LF | R3L5 |
| SMR0402A | RESN_0402LF-274,1%,0402LF | R3L6 |
| SMR0402A | RESN_0402LF-34,1%,0402LF | R3L7 |
| SMR0402A | RESN_0402LF-330,5%,0402LF | R4A9;R8;R9 |
| SMR0402A | RESN_0402LF-4.87K,1%,0402LF | R4B4 |
| SMR0402A | RESN_0402LF-100K,1%,0402LF,E | R4B5 |
| SMR0402A | RESN_0402LF-30.1,1%,0402LF | R4L10;R4L11 |
| SMR0402A | RESN_0402LF-240,1%,0402LF | R4L19;R4M1 |
| SMR0402A | RESN_0402LF-100K,5%,0402LF,E | R5;R6 |
| SMR0402A | RESN_0402LF-0,5%,0402LF | R12 |
| SMR0603 | RESN_0603LF-0,0,0603LF | R1M6 |
| SMY2414_2P | CRYSTAL_SMLF-G91801-001 | Y3L1 |
| SMY_FC255 | CRYSTAL_SMLF-E68732-001 | Y2A1 |
| SOI8_50IN_213X210 | W25Q64FV_8P_SOICLF-H10285-001 | U2B4 |
| SOT23 | DIOSOT23C_SOT23CLF-C52251-001 | CR3A1;CR3M1 |
| SOT23 | FET_SOT23LF-C81974-001 | Q1L1;Q1L2;Q1;Q2;Q3;Q4 |
| SOT23B | MOSFETP_3PIN_SOT23LF-D32396-001 | Q3B2 |
| SOT23_5P | TPS2051BDBVR_SOT23LF-E58210-001 | U3B1 |
| SOT363 | NPN_DW1SOTLF-C52264-001 | Q3B1 |
| SPOKE_N156_CNR_PKG_2_7 | MTG_HOLE_4V_THLF-SPOKE_N156_CNR_PKG_2_7 | MH1;MH2;MH3;MH4 |
| SSOP16_65MM | MAX3232_TSSOPLF-C76254-001 | U3B2 |
| SSOP48_30_25IA | CY8C9540A_SSOP-IC,H18589-001 | U8 |
| SSW2RPB | SWSPSTPB_SM2PLF-D90553-001 | S1A1;S1 |
| TEST_PAD_S20 | TEST_PAD_S20_PADLF-IPD231-098,E | TP1;TP2 |
| TQFN20_4X4_05MM_EP | AD7298_LFCSPLF-G83474-001 | U2B1 |
| VIA_18-10-28_SMB_T-POINT | T_POINT1_TPLF-VIA_18-10-28_SMB,TP | TP2A1;TP2A2 |
