R" A7 J) \4 v' \0 @各位大佬,
2 \1 B6 h, K( w# t1 c; Z, w点击SAVE提示报警告,但没看出是哪里出问题,是不是sigrity哪里要设置规则,新手,烦请各位指点
5 k) h, {2 \0 o( H; N![]()
* \4 A6 d; b' M1 o/ H: ~ ]
2 N- T% f& c! m' g4 C. l' q![]()
- f+ Q+ Z) K$ H& {) F! o
+ ^6 ]& X) C- D6 z! Z+ @, a+ o. R3 @/ XWARNING [Node Placement]: Node206971::GND at (143.578mm, 132.688mm) on layer Signal$TOP has a placement warning
7 e5 T2 Y, M9 t7 g0 `2 ~WARNING [Node Placement]: Node206117::GND at (95.517mm, 109.995mm) on layer Signal$BOTTOM has a placement warning, y; R' d& P1 y9 I z. N" @
WARNING [Node Placement]: Node207005::GND at (156.575mm, 57.134mm) on layer Signal$BOTTOM has a placement warning
. O- X) Q3 d; a# [WARNING [Node Placement]: Node206160::GND at (155.173mm, 79.820mm) on layer Signal$BOTTOM has a placement warning9 @; v# b; X. V- B$ E4 d: r* p$ I
WARNING [Node Placement]: Node206179::GND at (144.899mm, 63.703mm) on layer Signal$BOTTOM has a placement warning
( o& ~* ^0 N3 n7 Z# VWARNING [Via Placement]: Via11200::GND at (78.553mm, 122.712mm) with lower node on Signal$BOTTOM has a placement warning4 B+ T4 O4 {9 { f- U( a. o, r- A$ ?9 i
WARNING [Via Placement]: Via12064::GND at (95.546mm, 122.578mm) with lower node on Signal$BOTTOM has a placement warning( U; m/ m1 g/ l# T. D% W
WARNING [Via Placement]: Via13072::GND at (164.985mm, 70.455mm) with lower node on Signal$BOTTOM has a placement warning
4 _9 _: Q+ O6 V4 D0 D! i& hWARNING [Via Placement]: Via24423::GND at (115.047mm, 10.426mm) with lower node on Signal$BOTTOM has a placement warning
; P8 q9 S4 @7 `! Z4 G* j& e WWARNING [Via Placement]: Via27191::GND at (200.754mm, 52.577mm) with lower node on Signal$BOTTOM has a placement warning
1 j. u6 w' i& |1 J) i, RWARNING [Via Placement]: Via38951::GND at (152.865mm, 79.728mm) with lower node on Signal$BOTTOM has a placement warning0 U3 ?; Y) t1 ~. ~5 `
WARNING [Via Placement]: Via38961::GND at (153.665mm, 79.728mm) with lower node on Signal$BOTTOM has a placement warning
2 U) w/ V/ ]2 ^( SWARNING [Via Placement]: Via38991::GND at (154.465mm, 83.728mm) with lower node on Signal$BOTTOM has a placement warning7 T0 ~2 M A* P
WARNING [Via Placement]: Via39041::GND at (160.065mm, 79.728mm) with lower node on Signal$BOTTOM has a placement warning1 d) G; v4 X) V
WARNING [Via Placement]: Via39061::GND at (158.465mm, 79.728mm) with lower node on Signal$BOTTOM has a placement warning8 s6 e* L9 U9 [4 p( `3 e/ E
WARNING [Via Placement]: Via39091::GND at (156.065mm, 79.728mm) with lower node on Signal$BOTTOM has a placement warning
3 i' P9 G- ~* M) W7 g2 fWARNING [Via Placement]: Via39101::GND at (159.265mm, 79.728mm) with lower node on Signal$BOTTOM has a placement warning) A( D: E \" _- s- U
WARNING [Via Placement]: Via39131::GND at (155.265mm, 79.728mm) with lower node on Signal$BOTTOM has a placement warning
& I( f9 o- Q9 j2 G# }4 i' g4 FWARNING [Via Placement]: Via39361::GND at (148.865mm, 69.631mm) with lower node on Signal$BOTTOM has a placement warning
, d0 u+ a! w: P1 [5 J5 b0 v: \4 wWARNING [Via Placement]: Via39371::GND at (148.065mm, 69.631mm) with lower node on Signal$BOTTOM has a placement warning2 S u; F' Y% y; X0 c
WARNING [Via Placement]: Via39471::GND at (153.665mm, 65.631mm) with lower node on Signal$BOTTOM has a placement warning
c6 \! |) k' b- F& X9 OWARNING [Via Placement]: Via39481::GND at (160.065mm, 65.631mm) with lower node on Signal$BOTTOM has a placement warning$ b J: |$ P6 M M7 i' l- H$ o
WARNING [Via Placement]: Via39591::GND at (153.665mm, 69.631mm) with lower node on Signal$BOTTOM has a placement warning
- x7 o4 L' P- ?, [WARNING [Via Placement]: Via39611::GND at (160.065mm, 69.631mm) with lower node on Signal$BOTTOM has a placement warning
* L+ S! Y/ G( o: H, ZWARNING [Via Placement]: Via39621::GND at (158.465mm, 69.631mm) with lower node on Signal$BOTTOM has a placement warning1 Z. j# R8 S( e' M3 w( B Y2 j0 w
WARNING [Via Placement]: Via39631::GND at (157.665mm, 69.631mm) with lower node on Signal$BOTTOM has a placement warning
& G, Q5 u2 F8 T" vWARNING [Via Placement]: Via39641::GND at (155.265mm, 69.631mm) with lower node on Signal$BOTTOM has a placement warning( |# J3 H( r B4 ~/ @
WARNING [Via Placement]: Via39651::GND at (156.065mm, 69.631mm) with lower node on Signal$BOTTOM has a placement warning
$ v+ s% R$ M8 X& G0 Z3 I/ WWARNING [Via Placement]: Via39661::GND at (154.465mm, 69.631mm) with lower node on Signal$BOTTOM has a placement warning9 D8 l6 V4 \; I$ Y& ^5 z3 |% B6 t9 q- R
WARNING [Via Placement]: Via39671::GND at (159.265mm, 69.631mm) with lower node on Signal$BOTTOM has a placement warning1 c& K2 u* y/ w1 P& B; o
WARNING [Via Placement]: Via40277::GND at (152.065mm, 37.437mm) with lower node on Signal$BOTTOM has a placement warning
& y* p+ N. o. e: ]0 {WARNING [Via Placement]: Via40552::GND at (153.665mm, 37.437mm) with lower node on Signal$BOTTOM has a placement warning
4 k) Q- m, W+ i$ d c! HWARNING [Via Placement]: Via40585::GND at (152.865mm, 37.437mm) with lower node on Signal$BOTTOM has a placement warning% L/ C" b/ b- y$ h
WARNING [Via Placement]: Via40673::GND at (159.265mm, 37.437mm) with lower node on Signal$BOTTOM has a placement warning; a! M3 s! `4 ]
WARNING [Via Placement]: Via40684::GND at (155.265mm, 37.437mm) with lower node on Signal$BOTTOM has a placement warning
) |( {3 s; G* k, x* g% }0 zWARNING [Via Placement]: Via40695::GND at (156.865mm, 37.437mm) with lower node on Signal$BOTTOM has a placement warning4 M; U0 a* t& z( z4 s
WARNING [Via Placement]: Via40706::GND at (157.665mm, 37.437mm) with lower node on Signal$BOTTOM has a placement warning( X* T' W. m5 ~+ }
WARNING [Via Placement]: Via40717::GND at (156.065mm, 37.437mm) with lower node on Signal$BOTTOM has a placement warning4 M, r# }; i7 ~2 P d
WARNING [Via Placement]: Via40728::GND at (158.465mm, 37.437mm) with lower node on Signal$BOTTOM has a placement warning
* j3 I) f/ m+ R9 N3 UWARNING [Via Placement]: Via41135::GND at (152.865mm, 23.086mm) with lower node on Signal$BOTTOM has a placement warning
' M- H4 h+ I( l* K. B! IWARNING [Via Placement]: Via41146::GND at (153.665mm, 23.086mm) with lower node on Signal$BOTTOM has a placement warning$ M3 H' T! X# S
WARNING [Via Placement]: Via41179::GND at (158.465mm, 23.086mm) with lower node on Signal$BOTTOM has a placement warning
8 x; I6 E7 x& u! {5 FWARNING [Via Placement]: Via41223::GND at (157.665mm, 23.086mm) with lower node on Signal$BOTTOM has a placement warning
% O' Q! ?: H* J* `' DWARNING [Via Placement]: Via41234::GND at (156.865mm, 23.086mm) with lower node on Signal$BOTTOM has a placement warning4 T6 O9 w* s; T! Q; _
WARNING [Via Placement]: Via41278::GND at (159.265mm, 23.086mm) with lower node on Signal$BOTTOM has a placement warning
$ p& U% J; ]& e: t5 D3 X0 XWARNING [Node Placement]: Node155676!!2::GND at (160.333mm, 86.927mm) on layer Signal$BOTTOM has a placement warning.
: ^+ m, o9 c6 d X7 N9 K( r" e
+ r/ V3 v9 P8 D8 _) I9 v: I![]()
C- R8 r* ~. v7 F5 h; s; H! a: e |
