cadence Design Systems, Inc. netrev 15.5 Thu Jul 21 12:30:24 2011
6 \: s8 n3 }* L# [6 G(C) Copyright 2002 Cadence Design Systems, Inc.& d, D$ c& g" P* [. i5 t5 d
) {# O6 \9 K5 k- R( |
------ Directives ------4 v* z1 R. |+ n) Q0 I) M0 O
4 ]' X( F0 r2 ~
RIPUP_ETCH FALSE;
0 G. L: D0 l9 r Y, yRIPUP_SYMBOLS ALWAYS;
9 A/ Z7 E* ]- `6 T8 ^9 HMISSING SYMBOL AS ERROR FALSE;
. W: N% [0 d5 a& R3 z U" w+ S0 XSCHEMATIC_DIRECTORY 'E:/allegro_0711';6 ~5 Y- y Y1 [4 n- C( x
BOARD_DIRECTORY '';3 }' j, ]' `% \& R9 o1 e( \
OLD_BOARD_NAME 'E:/chenjian/unnamed.brd';& J. B; m3 Z) l' v) P
NEW_BOARD_NAME 'E:/chenjian/unnamed.brd';! h. C, c/ A# Y
& A8 }& Q) g# X! z. N+ {9 b I- I" O
CmdLine: netrev -$ -5 -i E:/allegro_0711 -u -y 1 E:/chenjian/#Taaaaaa01980.tmp
. e8 L; {; ~8 H1 `4 E( w. i" U0 ?* i7 ^$ g% ^( j( r3 K( H* q8 v9 @
------ Preparing to read pst files ------
v, r) W% ~: D) c1 G6 m! f P& P$ n& B, p6 _) ^3 x8 x
Starting to read E:/allegro_0711/pstchip.dat 3 }, U, s( v) v8 b
Finished reading E:/allegro_0711/pstchip.dat (00:00:00.00)$ U: w9 [% J% b' [% m' }
Starting to read E:/allegro_0711/pstxprt.dat 4 e: b( W! t0 O" q! |
Finished reading E:/allegro_0711/pstxprt.dat (00:00:00.00)
& i* Z Q+ @: s% N+ J/ ]* ~Starting to read E:/allegro_0711/pstxnet.dat 0 g z N8 r' t5 d
Finished reading E:/allegro_0711/pstxnet.dat (00:00:00.00)
7 l, G5 a: S- v; t- S- O
# Z+ O% U+ C' J- e/ _4 m; `------ Oversights/Warnings/Errors ------
4 g$ _, |& J7 k7 T K; \ H. R
$ H+ r. W" L, P$ `
, b. u, z! {+ M- j; Y ]: v; n: u#1 WARNING(304) Device/Symbol check warning detected.
/ Q( k7 m5 x2 n5 [7 o8 S1 f2 F* v$ A/ ^. }3 R& s6 a
Symbol 'CC0402' for device 'CAP NP_CC0402_DISCRETE_@10PF' not found in PSMPATH or must be "dbdoctor"ed.( h9 h0 T' D6 t/ ]3 ?2 h( k. {
1 E) \, T, a2 |3 ]4 k#1 ERROR(305) Device/Symbol check error detected.
0 q: ^6 | g- F+ ]
% p7 q0 P# \) ^' \* G3 u) CUnable to load symbol 'LED3MM_2D54_2DP_4D05W' for device 'Y/G LED * 4_2_LED3MM_2D54_2DP_4': Couldn't find padstack: TH45S28D
7 k) V- e4 U3 |" c due to Unable to load Flash symbol TR45C55-15D4.
) D7 a+ k* @* U: s
& D: p4 E6 g7 T8 z/ q! V! s#2 WARNING(304) Device/Symbol check warning detected.* m0 l) z8 T. _; I( D; ^. A2 W
' T2 O! R s7 i, H8 p3 V' \" e
Symbol 'SOIC_1D27X5D16_16SP_10L' for device 'ADM3202ARU_2_SOIC_1D27X5D16_16S' not found in PSMPATH or must be "dbdoctor"ed.+ Z: n- K3 x6 D- E
F$ v6 M3 ~, E" u7 K#3 WARNING(304) Device/Symbol check warning detected.6 V' G7 z% t4 M: r
5 x1 h' Q! \9 B3 C
Symbol 'HEADER5X2_40D' for device 'RS232 4P_0_HEADER5X2_40D_IO_5PX' not found in PSMPATH or must be "dbdoctor"ed.. _% c- X2 b0 N* g' B7 I3 g
- n8 A, O+ v, D k$ @, u `, X9 W: r
#4 WARNING(304) Device/Symbol check warning detected.3 a- z: D; m. C# @6 b
& J$ j. _0 ^5 Q4 P- [
Symbol 'RJ45FS_1X8DP_KINSUN' for device 'RJ45_0_RJ45FS_1X8DP_KINSUN_IO_8' not found in PSMPATH or must be "dbdoctor"ed.3 k& y- y* [/ i- u
5 p) W( o5 N6 q6 O) ]
) E. f% M' [/ l2 e/ pNote: SECTION property definition created
9 n8 f, l: ^9 D* m' J( _) j. k. |) N, k# q
------ Library Paths ------- P: h3 m! D9 H% M; a
MODULEPATH = . 3 K* I* m: ~$ v+ N# u- Q3 E& e3 d' k- p
C:/Cadence/SPB_15.5/share/local/pcb/modules
2 o+ W" X4 `9 D( g+ e
, l, N+ J: p5 DPSMPATH = .
% x- Z8 M X' t/ m! o& t5 k symbols
. A0 R, T; k0 d/ p" }* s ..
* b& C- x' ^ L; s& m; A- V ../symbols
, n) m. s- _& `' E( q/ a9 \9 ^: A8 c C:/Cadence/SPB_15.5/share/local/pcb/symbols
9 q- X' B2 ^- u3 p C:/Cadence/SPB_15.5/share/pcb/pcb_lib/symbols
. ?6 Z3 c) z7 J1 e5 T! T4 f/ E C:/Cadence/SPB_15.5/share/pcb/allegrolib/symbols
' s3 i3 z9 ~+ I1 G4 d0 m3 c A7 k# y4 K1 `
PADPATH = . # _$ l( L4 r7 s. g" k
symbols
0 [5 u2 l* |; c- o5 O .. & a1 N2 K1 u9 H( w8 @
../symbols
, b$ }7 I0 V- X C:/Cadence/SPB_15.5/share/local/pcb/padstacks 6 F/ V% m2 B/ }8 t% W+ b
C:/Cadence/SPB_15.5/share/pcb/pcb_lib/symbols 3 t3 C0 d6 [/ J ~/ n+ [ m
& R1 b; l* Q- `# Q) ^4 C/ O7 a7 f; r
* V: p$ Z) d9 G$ H3 e$ r
------ Summary Statistics ------8 Z, c% M- T) u$ x* F
7 ]! D+ H4 @0 S# u# H
% U3 w4 l; P0 j# s: [" s#2 ERROR(102) Run stopped because errors were detected5 h4 _3 r& C% H" ^+ F
# e, X! n2 X- q* r
netrev run on Jul 21 12:30:24 2011
- Y8 h3 o& P' y. `1 X8 B DESIGN NAME : 'RJ45 CONSOLE_0709'( S+ D, Z8 h1 N8 ]9 O6 y! A% V0 ~
PACKAGING ON Jun 17 2005 00:56:10: E: ~& z8 Y* A3 w7 ?5 b
x. |8 Q- e8 m; \: [ COMPILE 'logic'' P7 l$ ~' |/ r* ?+ p
CHECK_PIN_NAMES OFF7 L- y# W) Q# P7 F7 m
CROSS_REFERENCE OFF4 z' W8 i0 u/ X' |; W
FEEDBACK OFF3 v3 U) s. E5 U e/ n/ M
INCREMENTAL OFF
% _& V* r2 b6 d) H+ T, s INTERFACE_TYPE PHYSICAL
& H" _/ r: N8 E' j* _ MAX_ERRORS 5008 Y6 o7 M' x& J) v; ?4 e
MERGE_MINIMUM 5
7 [; o f* c. i6 i0 q/ w NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
, E: R8 c' L7 R* q3 U2 M7 U" c0 C NET_NAME_LENGTH 24
7 B6 }0 B- Q( {0 _5 t OVERSIGHTS ON
3 [% }. X' M$ P: ^ REPLACE_CHECK OFF
2 M7 f7 P9 j1 x' b' P" F4 M" i9 q SINGLE_NODE_NETS ON% e- E' f) u, C9 S$ \
SPLIT_MINIMUM 0/ E M3 M# t1 B \8 l+ y) V: i$ C& y
SUPPRESS 20. o, f* L8 O+ e `, T% Z" w0 w
WARNINGS ON) A9 L' I- `+ J! `
# U. K" T) H0 L1 |/ f2 g) W: L4 S/ r 2 errors detected
9 j. j. W* O( a9 w$ N9 m6 B- K No oversight detected
* E. m# l' y$ o/ v5 b( N% O. ] 4 warnings detected/ Y4 r% f+ H- G: T d
9 y0 q; G# a! bcpu time 0:00:120 `( Z# g+ v- H
elapsed time 0:00:00 |
