查看: 889|回复: 4
基于matlab GUI彩色图像分割
发表于 2021-7-8 11:23 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
# @; m6 ^) L  R) P: \一、简介
9 _# e7 S7 j6 l# O- v1 c
9 ?' ?* L: E8 P5 x7 |图像分割就是把图像分成若干个特定的、具有独特性质的区域并提出感兴趣目标的技术和过程。它是由图像处理到图像分析的关键步骤。现有的图像分割方法主要分以下几类:基于阈值的分割方法、基于区域的分割方法、基于边缘的分割方法以及基于特定理论的分割方法等。从数学角度来看,图像分割是将数字图像划分成互不相交的区域的过程。图像分割的过程也是一个标记过程,即把属于同一区域的像素赋予相同的编号。7 V% H$ R6 t! M- a* m; X" X
7 r. Z1 _8 r$ A5 N5 ?9 f3 ]7 y
( W$ ]" r$ x6 B8 C1 J. h$ P$ n  k二、源代码- O. `. n. R" |: B3 D% q4 x  i6 l
, v+ R, v" q6 {1 v( D+ W" ]9 f6 O$ x6 s+ A3 |/ L
  • function varargout = ImageGUI(varargin)
  • % IMAGEGUI MATLAB code for ImageGUI.fig
  • %      IMAGEGUI, by itself, creates a new IMAGEGUI or raises the existing
  • %      singleton*.
  • %      H = IMAGEGUI returns the handle to a new IMAGEGUI or the handle to
  • %      the existing singleton*.
  • %      IMAGEGUI('CALLBACK',hObject,eventData,handles,...) calls the local
  • %      function named CALLBACK in IMAGEGUI.M with the given input arguments.
  • %      IMAGEGUI('Property','Value',...) creates a new IMAGEGUI or raises the
  • %      existing singleton*.  Starting from the left, property value pairs are
  • %      applied to the GUI before ImageGUI_OpeningFcn gets called.  An
  • %      unrecognized property name or invalid value makes property application
  • %      stop.  All inputs are passed to ImageGUI_OpeningFcn via varargin.
  • %      *See GUI Options on GUIDE's Tools menu.  Choose "GUI allows only one
  • %      instance to run (singleton)".
  • % See also: GUIDE, GUIDATA, GUIHANDLES
  • % Edit the above text to modify the response to help ImageGUI
  • % Copyright 2011 The MathWorks, Inc.
  • % Last Modified by GUIDE v2.5 09-Jun-2015 20:18:33
  • % Begin initialization code - DO NOT EDIT
  • gui_Singleton = 1;
  • gui_State = struct('gui_Name',       mfilename, ...
  •                    'gui_Singleton',  gui_Singleton, ...
  •                    'gui_OpeningFcn', @ImageGUI_OpeningFcn, ...
  •                    'gui_OutputFcn',  @ImageGUI_OutputFcn, ...
  •                    'gui_LayoutFcn',  [] , ...
  •                    'gui_Callback',   []);
  • if nargin && ischar(varargin{1})
  •     gui_State.gui_Callback = str2func(varargin{1});
  • end
  • ! G% U! j6 J, ]1 K
5 {1 h& N, w2 h* L( V; v- ?
# K% [6 h9 q& h9 @6 ?
三、运行结果
  ?1 x* @5 M$ W0 ~% A9 T: T( j7 @8 k$ A7 K  Z/ Y% N' q7 J0 a
4 q# K" W1 E& ~: X% p( u7 b2 a2 k; A+ X
* c2 x% U/ n. m% f3 S0 m
  F9 `1 K* y& p# `
" P. ?5 g) \: y; V
发表于 2021-7-8 13:31 | 只看该作者
基于matlab GUI彩色图像分割
    慵懒
    2020-6-13 15:46
    发表于 2021-7-8 13:54 | 只看该作者
    基于matlab GUI彩色图像分割
    发表于 2021-7-8 13:55 | 只看该作者
    基于matlab GUI彩色图像分割
    奋斗
    2025-1-1 15:26
  • 签到天数: 584 天
    [LV.9]以坛为家II
    发表于 2021-7-14 09:00 | 只看该作者
    学习学习在学习
    GMT+8, 2025-11-23 23:28 , Processed in 0.140625 second(s), 26 queries , Gzip On.
