查看: 538|回复: 3
如何求解如下优化问题
发表于 2020-12-2 14:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
4 G" x4 W/ V% o" ~  P8 C
f=min(abs(0.5*ay_tp1)+abs(0.5*ay_tp2));5 p1 u9 a5 }* C+ ~
s.t.1 n  b* z9 \3 D2 v, R8 C
0<p<10,-10<q<0,q^2-4*p<=0;2*pi/(4*p-q^2)^(1/2)-tf=0;
# o, ?7 v' X1 m8 i3 q%%其中:: \% {+ g( y2 j& |
w=3.75;
9 @! H, A$ @! L+ S9 |' ktf=5;
% l, k5 h: |/ Gtp1=0;+ ]$ D# E; X( Y6 q+ H0 O9 K) K7 l2 X
tp2=2*(pi-atan(q*(4*p-q^2)^(1/2)/(q^2-4*p)))/((4*p-q^2)^(1/2));
$ j9 P9 x5 Y; ]6 h" c8 a  @A1=(4*p/(4*p-q^2))^(1/2);6 i9 w/ J6 E! E( V/ _) K% z
A2=((4*p-q^2)/2)^(1/2);& T7 f4 d& T- v3 ?! Y
A3=q/((4*p-q^2)^(1/2));
- d( j$ h; U2 S( H6 x
: W! l+ Y! c, Hay_tp1=(w*p*exp(q*tp1/2)*A1*sin(((A2/(2^(1/2)))*tp1)+1/A3))/(1-exp(q*tf/2)*A1*sin(A2*tf-atan(A3)));
0 O) ~9 l3 Q% A: k5 r6 h0 r8 ?ay_tp2=(w*p*exp(q*tp2/2)*A1*sin(((A2/(2^(1/2)))*tp2)+1/A3))/(1-exp(q*tf/2)*A1*sin(A2*tf-atan(A3)));
6 q, z$ K% m1 c5 f使用fmincon函数求解时显示 相邻两次迭代点的变化小于预先给定的容忍度。/ f  z4 U9 X0 A
求助大佬。感谢. g6 i- e0 ]) q  z3 S* g8 s3 @
发表于 2020-12-2 15:56 | 只看该作者
路过,帮顶一下
看不懂啊,有心无力哦
发表于 2020-12-2 15:57 | 只看该作者
下面结果参考下:! W: h$ g7 y2 U, y5 ^
Objective Function (Min.): 1.28973902645915E-5  q# e8 Y% P/ N/ l( G5 h# s" G/ R4 [
p: 0.394784176495481
! F- [  j6 B4 s% `7 fq: -4.3001505065871E-5
) I& n. _7 s3 ~: k3 r$ D) z) W6 c( r3 c5 T! P2 y' M
Constrained Functions:
# C; V, j2 X! W% A2 |' g) q1: q^2-4*p-0 = -1.5791367041328
- s/ _  [$ V" c7 h2 t% s" @2: 2*pi/(4*p-q^2)^(1/2)-5-0 = 6.57038867757365E-11
GMT+8, 2025-11-24 11:14 , Processed in 0.156250 second(s), 23 queries , Gzip On.
