查看: 878|回复: 4
matlab 错误
发表于 2020-9-29 17:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
错误提示如下:>> mosekdiag' I. m" w/ @: g
Matlab version   : 9.6.0.1072779 (R2019a)( y! t9 T' O" J/ b. y! _* j" B
Architecture     : PCWIN64
0 x1 f# u% T9 j7 d% E7 emosekopt path    : D:\some application\mosek\9.2\toolbox\R2015a\mosekopt.mexw64
3 j1 A! l: o3 |MOSEK version    : 9.2.2
  l( f+ Y% T/ G( h& S9 Q5 R+ aTest linear solve: Error 1008 (MSK_RES_ERR_MISSING_LICENSE_FILE)
0 T% Q- F; T! Z5 H8 jError message    : License cannot be located. The default search path is ';C:\Users\Ge Xiao\6\licenses\mosek.lic;'.  U; f9 ]0 m' N$ `- X
*******************************************************5 j$ n8 z* h+ q2 Y8 L5 [) W
Below is a more detailed debug info to help you identify the problem.: H; y3 R# j$ H! f" L
See the licensing manual and inteRFace manual for troubleshooting tips.% r4 W3 w' I6 s7 N- }
This error is related to licensing.
) \- K# c& L& ~& @5 D) }3 M1 bThe line with "License path" below shows where MOSEK is expecting the license.
. l3 P$ m' \; [" F: O9 A4 [Make sure the license is placed exactly there and is readable and up to date.
0 l/ K: ]: S7 g0 Z8 sTry restarting MATLAB if you installed a new license file.. l8 d: H* n: r7 P+ H. O) d) c6 M2 C1 b
*******************************************************& F& v& @6 o% ~3 V+ r0 P# D
Detailed debug info:
/ X% @$ M3 T$ I1 `/ \. K! |Mosek: Open. u# n& ]8 }: m. N
Mosek: Using matlab (1) or system calloc (0) ? 0
" `  Y$ W5 K+ P, sMosek: Make environment
: e& _8 p! h( MMosek: done. r: 0, adr of new env = 00000000618C1DE0
5 T. i0 q2 [: {- X  z1 `Mosek: Echo intro* G3 u) j2 X2 \" s+ D& j+ y3 j
MOSEK Version 9.2.2(BETA) (Build date: 2020-3-11 08:12:28)+ H4 i4 C" @1 ?8 N! |
Copyright (c) MOSEK ApS, Denmark. WWW: mosek.com% n- Z% ?) h4 f
Platform: Windows/64-X86
% r. o9 a* t- u5 I; [FlexLM- s6 k) A2 K7 [
Version                  : 11.16: e4 e: U. Q! D1 E6 z
Hostname                 : LAPTOP-BCTR9K5U; Y( z. q0 \- u( |6 S% G1 z5 a/ O" F
Host ID                  : "c809a80ecdb6 ca09a80ecdb5 c809a80ecdb5 c809a80ecdb9"5 r* p# _9 b' O+ k  G/ r
License path             : C:\Users\Ge Xiao\6\licenses\mosek.lic* r% ], A9 a4 r0 W
Operating system variables# {0 m+ p+ k( a0 X3 K
PATH                     :
; i' J! N! V! G4 WMosek: Check version; b( K% _) H$ |3 S9 _! M  H% K- h
Mosek: done$ J% Z' m" ]7 g& I8 \+ b0 p& \$ |
错误使用 mosekdiag (line 100)
2 o! R, j0 F( h3 `7 r7 v0 PCould not solve a test problem
; s3 g; B, k# v8 W+ n! f. N, `! M) m2 E
发表于 2020-9-29 17:45 | 只看该作者
帮你顶一下
发表于 2020-9-30 13:22 | 只看该作者
这个问题还没遇到过,帮顶
发表于 2020-9-30 13:29 | 只看该作者
等一个大神,
发表于 2020-9-30 14:26 | 只看该作者
为什么没大神
GMT+8, 2025-11-24 17:11 , Processed in 0.156250 second(s), 23 queries , Gzip On.
