function one4_OpeningFcn(hObject, eventdata, handles, varargin)% c0 l3 z" l& E
% This function has no output args, see OutputFcn.. J% V8 |+ K, o! [
% hObject handle to figure
0 ]9 J! M- c+ ^4 |. W: W& g% eventdata reserved - to be defined in a future version of MATLAB& G* J) i% `! ~3 i9 u
% handles structure with handles and user data (see GUIDATA)
' K) E/ t6 a; f9 o5 [! ?% varargin command line arguments to one4 (see VARARGIN)4 @. b1 c0 J) c4 M7 |4 B' |
load('newdata.mat');2 C* P- ~0 G! B
set(handles.uitable1,'Data',newdata);) z8 c, L: \- j# o' p/ t
% Choose default command line output for one4
, O2 m1 q3 i& M/ O0 V, Mhandles.output = hObject;
& ~$ H! o& E4 |
6 x- ^- o- j: h* b% Update handles structure
* `/ v$ C# {5 r; [- O2 W( }8 mguidata(hObject, handles);. G& _# w% y7 V- @9 s1 X5 B
( \/ ?/ e; R6 w3 W! y1 r% UIWAIT makes one4 wait for user response (see UIRESUME)4 X% f M4 v2 V; ?, e2 N) i0 h
% uiwait(handles.figure1);
( [: H5 | F1 s# M2 c6 j3 S" a8 r$ q" i" k) f" L4 `2 {
$ d; g6 E* _( {9 E/ Q; |
% --- Outputs from this function are returned to the command line.. Y5 U( K* Y6 ^; u H/ A
function varargout = one4_OutputFcn(hObject, eventdata, handles) 0 m1 Q. A$ I. w( C1 v4 R) h
% varargout cell array for returning output args (see VARARGOUT);
9 U, N7 {/ n; K9 C" R9 T% hObject handle to figure
. ]! L+ Y7 \, z% H$ l. V% eventdata reserved - to be defined in a future version of MATLAB9 t" j4 }2 s; A$ I- e7 ]$ S
% handles structure with handles and user data (see GUIDATA)% l+ z7 a- i" {0 u9 L- P
5 S. q# t, L4 S" \3 R* s" U
% Get default command line output from handles structure
5 z3 C) L& h4 ^4 E+ K7 V9 i' j; l. f) L代码7 W. A( p' F _0 M( m: w
varargout{1} = handles.output;# F5 f3 L, @& n3 q' i
$ }7 n- N& S( { f% t1 o K- p% D' i1 p7 M1 `
% --- Executes on button press in pb1.: J8 i1 a, ^& W4 E3 `4 o# R
function pb1_Callback(hObject, eventdata, handles)0 v, Y1 Z- Y0 T4 a" k
% hObject handle to pb1 (see GCBO)
& c* m) }) T: P. @) w% eventdata reserved - to be defined in a future version of MATLAB6 ~/ L+ _; Q/ B
% s; x1 l: O6 D$ W7 p( ?# {tab=inputdlg({"基本尺寸","公差等级","上偏差","下偏差",},"减环基本值");" a6 R, n% \2 W/ p
newrow1=str2num(tab{1});# {1 ~( z$ @! H: h, v$ e s
newrow2=str2num(tab{2});, f. f7 _$ F2 D9 @' V. h
newrow3=str2num(tab{3});
1 t& z) P9 K% H- K8 D: G3 [newrow4=str2num(tab{4});0 A0 n# d' h9 R1 X/ ]
newarray={newrow1,newrow2,newrow3,newrow4};2 V5 q: P4 [! B j/ i, h$ m; Z3 X
olddata=get(handles.uitable1,'Data');
3 F2 T3 K6 Y. j0 }8 U8 |newdata=[olddata,newarray];9 e0 Y% r& O F: T8 P- R( ?3 F
% g' S' K0 [+ |5 q/ u3 X. ahandles.tabale=newdata;
5 u% M2 A' L1 R0 d: Ksave('newdata.mat','newData');+ M; u) l( o/ |# Q+ h+ Y
错误信息
) ]7 o P( s7 d0 r/ A5 U/ Q2 j3 M6 t. B# S7 a. f8 u
错误使用 inputdlg (line 108) s! o* G; G2 G6 \+ ~) _3 d' n
NumLines 大小错误。
3 |# E1 M. q% n& G# j9 F7 K4 l& x, p% l/ W: g- u3 \2 I+ ~9 D
出错 o3>add1_Callback (line 108)
' f- k* G/ F e5 utab=inputdlg(prompt,title,lines);9 S( Z2 e! A( A' P5 x+ s" K2 v
1 w9 s b. u+ X2 x* A0 |9 [出错 gui_maiNFCn (line 95)
9 f+ }% B. t+ ?1 v- D$ ]* A feval(varargin{:});
1 `' D% T0 T: I1 p6 j* Y& _! z% v6 X; K
出错 o3 (line 42)" j2 v$ _2 M+ x/ j F$ z
gui_mainfcn(gui_State, varargin{:});
- a5 Q2 h% E0 X1 z& a8 l/ f/ D- ]
1 Z w! Q- d1 c% k( \出错5 V+ V X# D5 g4 k: F5 m X
matlab.graphics.internal.figfile.FigFile/read>@(hObject,eventdata)o3('add1_Callback',hObject,eventdata,guidata(hObject)) y' l6 v) j+ S
计算 UIControl Callback 时出错。' x' j5 ^) e2 r* h9 G/ S
