t = [1,2,3,4];
- \& \' m& |% V( Z8 n; [c = [1;2;3]; 2 r/ Q1 v2 Y- |! E, a
r = [1,2,3,4];1 V# \6 R: V/ f
n = [1:12];# O6 W1 f% M T. V- R2 i
+ N/ ]. V. B# K8 ~( [* bT = length(t);
2 z! y' m5 O, S0 D) z& P6 D4 XC = length(c); 1 n- c- h6 Z& S5 u. }# {9 o
R = length(r);
4 Q, t" _1 W( T, ] HN = length(n);; Q* L1 h$ D3 a
7 N& I# [3 ^5 ^4 k# R
X = binvar(N,R,C,T,'full');/ `2 c e6 G- m% g7 M7 |1 w
constraint = [];
: x2 Q5 J+ z0 j. v8 r* X; Ffor h=1) E1 U% N. T* z# F# p1 j8 o( |$ _9 m) p
for i = 1:N;; L0 g9 S" R0 e0 a2 u$ W$ m
conn = 0;
+ d' o" z4 @( o for c = 1:C
' U1 z* q @0 G- z2 A* v% I. p1 y for r = 1:R 4 S1 K8 \. w+ T/ T" J% i8 g+ c
X_irch = value(X(i,r,c,h)) % 这个值为什么会是NaN0 |! f. ~5 \# A4 K3 Q3 M9 D
if X_irch == 1
/ _, L0 F3 n( N8 s/ i6 @ P(r,c,h) = 1;; O& j. x6 j/ E& U
end
+ t; k8 C$ z4 p9 x conn = conn + X(i,r,c,h);
# A/ z5 r3 _# I9 K4 ~ \( f end
3 _: o+ Y8 D5 E end
# Y* U5 F5 G7 `. B/ e constraint = constraint + [conn == 1];
% l7 \# f: M/ v: y; v! B" |6 U end
, G7 C" f8 |; _/ `0 Y. Dend% } I. ]" x* t2 V* `
9 ?! \* x# x0 z$ W7 l有注释的那一行的值为什么会是NaN,不是应该取值为0或者1吗?请教大神!) I' o* l8 d, v
