查看: 29430|回复: 223
更新Allegro17.4_006号补丁SPB v17.40.006 Hotfix
    2021-2-2 15:32
  • 签到天数: 3 天
    [LV.2]偶尔看看I
    发表于 2020-5-2 10:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    ( W- F2 ^8 B' X! H$ `
    5 d7 X' e$ D9 ~% y下载链接:
    游客,如果您要查看本帖隐藏内容请回复
    发表于 2020-5-4 21:56 | 只看该作者
    Fixed CCRs: SPB 17.4 HF006
    7 b5 v9 w+ e. b5 w- x* e# X4 m$ H$ e" Y04-30-2020
    * j8 @2 U2 m) }2 O: C========================================================================================================================================================8 y! [+ t9 }+ ^5 V+ k
    CCRID   Product            ProductLevel2 Title( B* _! w8 f' @3 k& @4 p- a5 \6 J
    0 t- [  _' ]+ u2194747 ALLEGRO_EDITOR     DFM           Minimum gap DFM error within same polygon not caught7 v, E! Q# f3 p. P2 o, g
    2233051 ALLEGRO_EDITOR     DFM           Copper Spacing: Thru via hole to Non signal shape DRC not working with BB via+ x6 i- `: D+ k  x0 u
    2238666 ALLEGRO_EDITOR     DFM           DFF Silkscreen constraints showing DRC even though there is no violation.
    ) i3 H; J; T' O) r) g+ l7 s1938592 ALLEGRO_EDITOR     EDIT_ETCH     Not able to use AiDT option to length match the traces.) |% u/ w! p% \$ [2 a1 h( l; D
    1960535 ALLEGRO_EDITOR     EDIT_ETCH     AiDT does not work for buses with width larger than minimum width% s" `3 k& _: D) w" Y) h- g5 `
    2036229 ALLEGRO_EDITOR     EDIT_ETCH     AiDT does not work on Non-default min Width- y' G0 [4 ?& T, f, y" Q8 e
    2157973 ALLEGRO_EDITOR     EDIT_ETCH     AiDT is not working due to line width constraints; n! ^9 q: J/ }! A3 u) F
    2175464 ALLEGRO_EDITOR     EDIT_ETCH     auto tuning in AiDT fails to tune differential pairs
    % b$ e- ^' t* B2223214 ALLEGRO_EDITOR     EDIT_SHAPE    Menus for Shape Operations are missing from OrCAD menu set+ {/ ?* k3 g: Z' k  \9 u8 q
    2213659 ALLEGRO_EDITOR     INTERACTIV    Last placed component is unplaced in Allegro PCB Editor because cross placement is picking that component7 ?+ `: r6 H* w
    2216410 ALLEGRO_EDITOR     INTERACTIV    Issue with cross place from OrCAD Capture to PCB Editor: placed part selected
    - b* X  e. ^3 }) C2 Y- _2 ]3 z# y" O2253831 ALLEGRO_EDITOR     INTERFACES    Release 17.2-2016, HotFix065: Some arc segments not mirrored properly on exporting PDF with Film mirrored checked
    2 I4 d  f+ a) S+ e5 r2254260 ALLEGRO_EDITOR     INTERFACES    Arc lines not flipping correctly in PDF in HotFix004 and HotFix005 when the film is mirrored
    6 I+ V1 S+ g/ U( v2226610 ALLEGRO_EDITOR     NC            Backdrill_pressfit_connector - the bottom side drill passes are not getting excluded
    ' F( O& v; }* W3 [7 ~4 {" u) f+ N2228366 ALLEGRO_EDITOR     NC            Setting 'BACKDRILL_OVERRIDE' to 'TOP:TOP:BOTTOM:BOTTOM' does not work  o7 @& l0 O( i  S9 D
    2230619 ALLEGRO_EDITOR     NC            PCB Editor stops responding when creating Layer Pairs in the Backdrill Layer Pair Initialization window.
    % J1 z: X" S* ~; z2 Z# D8 ~. l8 D& D! z2241339 ALLEGRO_EDITOR     NC            Setting 'Backdrill_Override' to 'top:top:bottom:bottom' leads to incorrect  backdrill analysis result
    ' ^( @5 N( N4 u) p  k2236280 ALLEGRO_EDITOR     PAD_EDITOR    Drill tool size reverts to original value
    : g; d' N/ }- X1 \* _2232567 ALLEGRO_EDITOR     PLACEMENT     Place manually by library takes long time in HotFix 064* ]' W2 Z. l: Z0 L9 q) l6 W) }
    2243727 ALLEGRO_EDITOR     PLACEMENT     Allegro PCB Editor crashes on Place Manual
    " ^) g! ?% F9 y0 t$ U1 |5 _2246145 ALLEGRO_EDITOR     PLACEMENT     Place manually by 'library' as the source takes much longer than it used to in release 16.6.* e# R0 }2 N$ i7 v" j, m. x7 l
    2215844 ALLEGRO_EDITOR     SHAPE         Route Keepout prevents correct shape update
    ) L, s/ p9 }6 z* O6 N2234915 ALLEGRO_EDITOR     SHAPE         PCB Editor crashes on selecting 'Trim corner' popup option in Shape Edit mode
    , _3 S, V2 m6 M: [2078335 ALLEGRO_EDITOR     SKILL         Discrepancy with axlAddSelectBox() and axlSingleSelectBox() definition  I$ N  b$ q4 H. N- o/ R
    2223446 ALLEGRO_EDITOR     SKILL         Casing of axlDBTextBlockFindName(); R5 Q( }( a3 \3 z& X5 F6 S
    2231369 ALLEGRO_EDITOR     SKILL         Invalid option type warning when using "axlFilmCreate("test" ?polyCutLayer nil)"7 K- [) W! _9 `1 B5 S  a6 x
    2235666 ALLEGRO_EDITOR     UI_FORMS      Export parameters window is small and cannot be scaled up in HotFixes 003 and 004
    - Z5 G+ s9 n: Z' ^$ P2239984 ALLEGRO_EDITOR     UI_FORMS      Callback function for form not invoked if multiple fields are selected by dragging mouse6 n: \! f& H( W3 y! w
    2167454 ALLEGRO_EDITOR     UI_GENERAL    Custom commands and HTML XProbe: Triggering actions from HTML files# A6 {+ F* P% _6 N1 I
    2227489 ALLEGRO_EDITOR     UI_GENERAL    HTML cross probing in release 17.4 works partially; v5 _! G3 e7 n* e
    2222689 ALLEGRO_LIB_CRT    CORE          Edit External Padstack from LC) _" N+ h& v0 K! _* [5 C& }
    2233072 CAPTURE            CONNECTIVITY  OrCAD Capture stops responding on transferring occurrence property to instance
      X; t3 h, r( U- y8 c) g9 y2237520 CAPTURE            GENERAL       Issue with CIS toolbar translation in Japanese: Capture crashes4 o$ C( Z1 Q0 i' D8 i7 {
    2220792 PSPICE             PROBE         Release 17.4-2019, PSpice: Unable to read simulation messages in summary window& x% Y* [& z( W
    2239253 PSPICE             PROBE         Message summary dialog in PSpice in release 17.4-2019 does not show message) X5 }2 q& e" R  j7 E
    2234913 PULSE              CORE          Data node crash because of going out of memory
    " L; ^( @6 f7 D$ f/ m, s2 X4 {2236450 PULSE              CORE          Database syntax error: server out of memory
    - |' c3 v3 G! j' `2 ]  r5 r2222469 PULSE              UNIFIED_SEARC OrCAD Capture Search Providers crash with specific part placement
    2 n0 P8 g& c/ u% b2233638 PULSE              UNIFIED_SEARC Capture crashes when trying to use Place > Search Providers
    # X1 b5 |. `7 i1913829 SPECCTRA           LICENSING     Cannot run SPECCTRA with an OrCAD PCB Expert license* S- {" L2 a) g& K8 [% k( P0 B2 v3 l
    2212091 SPECCTRA           LICENSING     Include OrCAD PCB Router license for autorouting in OrCAD PCB Expert suite (PO9205)
    ! A0 l  a8 M3 u1 d, ]
    发表于 2020-11-9 22:52 | 只看该作者
    sen1233 发表于 2020-5-2 16:328 ?  V* x; z$ B& M" I
    先留个记号。使用过17.4的软件总体感觉还不错,上来折腾折腾新补丁看
    6 j. S2 M9 [6 q! N4 t/ j5 @0 U
    你好,请问一下17.4版本在哪里下的,是否有下载地址分享一下的?
    * Q; ], o( G. i7 ]0 ]3 k: m
    3 |0 [1 C7 v! J- t' G1 K( {
    2023-8-4 15:22
    发表于 2021-4-11 18:11 | 只看该作者
                    顶    起
    * x  s( s! p" f& \% p( n) L
    发表于 2020-5-2 11:46 | 只看该作者
    更新这么快,谢谢分享!
    2025-11-24 15:32
  • 签到天数: 807 天
    [LV.10]以坛为家III
    发表于 2020-5-2 11:55 | 只看该作者
    谢谢分享!下载学习一下!
    4 F1 [3 M4 Z- w' @7 s- D. F" |
    2025-11-25 15:00
  • 签到天数: 738 天
    [LV.9]以坛为家II
    发表于 2020-5-2 13:05 | 只看该作者
    这个也太快了吧
    2020-2-27 15:47
  • 签到天数: 25 天
    [LV.4]偶尔看看III
    发表于 2020-5-2 13:27 | 只看该作者
    谢谢分享kkkkkkkkkkk
    8 z! w. d& P6 g! {$ l" L6 u
    2024-2-9 15:00
  • 签到天数: 191 天
    [LV.7]常住居民III
    发表于 2020-5-2 13:29 | 只看该作者
    更新这么快,谢谢分享!
    : [; Z! c0 e) {+ x* t
    发表于 2020-5-2 16:06 | 只看该作者
    谢谢分享啦
    ) B/ Q& _8 H9 [! \8 P
    发表于 2020-5-2 16:32 | 只看该作者
    先留个记号。使用过17.4的软件总体感觉还不错,上来折腾折腾新补丁看" Z, ?- j% B$ z( ~' ]3 F
    你好,请问一下17.4版本在哪里下的,是否有下载地址分享一下的?  详情 回复 发表于 2020-11-9 22:52
    16#
    发表于 2020-5-2 19:38 | 只看该作者
    好快呀,谢谢楼主分享) {/ g# I1 \0 F1 h5 a# {
    17#
    发表于 2020-5-2 20:47 | 只看该作者
    #在这里更新这么快快速回复#
    GMT+8, 2025-11-26 16:48 , Processed in 0.156250 second(s), 26 queries , Gzip On.
