| Bill of Material Report (Condensed) |
| SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
| 名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
| 0603BL | L_0603_0603BL_BLM15HG102SN1D | BLM15HG102SN1D | IC | 4 | L6; L22; L25; L26 |
| 0603BL | L_0603_0603BL_68NH | 68nH | IC | 2 | L23; L24 |
| 0603BL | L_0603_0603BL_2.2NH | 2.2nH | IC | 3 | L28; L30; L32 |
| 0603BL | L_0603_0603BL_27NH | 27nH | IC | 3 | L29; L31; L33 |
| 0603R | R_0603R_0603R_1K | 1K | IC | 2 | R46; R47 |
| 1812 | DIODE TAZ BI-DIR_1812_BA301N | BA301N | IC | 6 | D31; D33; D34; D38; D40; D41 |
| 1812R | RESISTOR_1812R_2R | 2R | IC | 2 | R289; R298 |
| 1812R | RESISTOR_1812R_FSMD020 | FSMD020 | IC | 2 | R670; R671 |
| BGA84-32-1509E | H5P1G63EFR | H5P1G63EFR | IC | 2 | U20; U21 |
| BGA441-32-2323 | HI3515 | HI3515_VSS | IC | 1 | U29 |
| BUZ-7R6X12R0-0R9 | BUZZER_BUZ-7R6X12R0-0R9_BUZZER | BUZZER | IC | 1 | BZ1 |
| CON10-6R0X6R0-5 | MCX8362S1_0_CON10-6R0X6R0-5_MCX | MCX823S1 | IC | 3 | J61; J62; J63 |
| CON20VP2R54-1X4TM | TP1X4_CON20VP2R54-1X4TM_TP1X4 | TP1X4 | IC | 1 | J66 |
| CON20VP2R54-1X5TM | CON4_SIP4-2_0_CON20VP2R54-1X5TM | CON4 | IC | 1 | J2 |
| CON20VS2R54-1X12TM-1 | TP1X12_CON20VS2R54-1X12TM-1_TP1 | TP1x12 | IC | 1 | J65 |
| CON21VP2R50-2TM | CON2_SIP2-2_0_CON21VP2R50-2TM_C | CON2 | IC | 1 | J13 |
| CON21VP2R50-2TM-1 | CON2_SIP2-2_0_CON21VP2R50-2TM-1 | CON2_SIP2-2_5A | IC | 3 | J53; J54; J67 |
| CPCSM-4R6X10R0-1 | TC_3528_CPCSM-4R6X10R0-1_330UF/ | 330uF/35V | IC | 5 | C295; C296; C498; C1060; C1061 |
| CTP-JT-3502 | HK2J387S-9B_1_CTP-JT-3502_HKZJ3 | HKZJ387S-9B | IC | 2 | J58; J59 |
| DB15F_DB9M | VGA_RS232_0_DB15F_DB9M_VGA_RS23 | VGA_RS232 | IC | 1 | J5 |
| DB-6-17M5X30M-3M | RCA JACK_1_DB-6-17M5X30M-3M_DUA | DUAL_BNC | IC | 2 | J49; J50 |
| DMMELF | 1N4148_0_DMMELF_1N4148 | 1N4148 | IC | 3 | D24; D36; D37 |
| DO3316P | INDUCTOR_1_DO3316P_4.7UH | 4.7uH | IC | 3 | L19; L20; L27 |
| DO3316P | INDUCTOR_1_DO3316P_2.2UH | 2.2uH | IC | 1 | L21 |
| GND12 | TESTPOINT_HOLE_A | TESTPOINT | IC | 2 | TP1; TP2 |
| GND12 | TEST | TEST | IC | 3 | TS1; TS4; TS7 |
| HOLE_SM_7R50D3R50 | SB_HOLE_SM_7R50D3R50_SB | SB | IC | 4 | SB1; SB2; SB3; SB4 |
| HSOT353 | ESDA6V1W5 | ESDA6V1W5 | IC | 1 | D20 |
| IDC8-3_81AR | HEADER 8X2_IDC16-2_0_IDC8-3_81A | HEADER 4X2_IDC8-3_81AR | IC | 1 | J9 |
| IDC16-3_81AR | HEADER 8X2_IDC16-2_54AR_IDC16-3 | HEADER 8X2_IDC16 | IC | 2 | J55; J56 |
| IDC20-DTM1-A | HU5_200PNA_S53T_FA | HU5_200PNA_S53T_FA | IC | 1 | J29 |
| JRC-27F | JRC-27F/05S_JRC-27F_JRC-27F/05S | JRC-27F/05S | IC | 2 | JK1; JK2 |
| LGA120H-3030A | LGA120H-MC509_LGA120H-3030A_(S1 | LGA120H-MC509 | IC | 1 | U74 |
| MASK1 | MARK_MASK1_MARK | MARK | IC | 9 | FJ1; FJ2; FJ3; FJ4; FJ5; FJ6; FJ7; FJ8; FJ9 |
| PMR0104-200RQ | 174552_1 | 174552_1 | IC | 1 | J17 |
| PSW3-RA | RA22KKFR0FL_D1 | PSW3_B | IC | 1 | S4 |
| QFP48HA-50-0707L | RTL8201CP | RTL8201CP | IC | 1 | U23 |
| QFP128C-40-1414L | TW2865 | TW2866 | IC | 1 | U13 |
| R2512 | RES_H_3_R2512_003R | 003R | IC | 4 | R531; R535; R538; R1128 |
| RJ45_USB_100 | RJ45_SOKET_0_RJ45_USB_100_RU3-2 | RU3-261A1R11 | IC | 1 | J6 |
| S028-18X10 | SJA1000_0_S028-18X10_SJA1000 | SJA1000 | IC | 1 | U38 |
| SATA7-1_27SA | SATA-DIP7A_0_SATA7-1_27SA_SATA- | SATA-DIP7A | IC | 2 | CN2; CN3 |
| SBAT2-3209 | 796136_1 | 796136_1 | IC | 1 | U1002 |
| SC0402 | CAP_SC0402_100NF | 100nF | IC | 115 | C21; C67; C68; C69; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C98; C99; C100; C101; C102; C103; C104; C105; C106; C107; C108; C109; C110; C111; C112; C113; C114; C115; C116; C117; C118; C119; C120; C121; C122; C123; C124; C125; C126; C127; C128; C129; C130; C131; C132; C133; C134; C135; C136; C137; C138; C139; C140; C141; C142; C143; C144; C145; C147; C148; C149; C150; C151; C152; C153; C154; C155; C156; C157; C158; C159; C160; C161; C162; C163; C164; C165; C166; C169; C170; C172; C352; C353; C354; C400; C401; C402; C403; C404; C405; C406; C407; C425 |
| SC0402 | CAP_SC0402_10NF | 10nF | IC | 8 | C214; C215; C216; C217; C218; C219; C220; C221 |
| SC0402 | C_0603C_SC0402_100NF | 100nF | IC | 1 | C222 |
| SC0603 | C_0603C_SC0603_20PF | 20PF | IC | 2 | C167; C168 |
| SC0603 | C_0603C_SC0603_100NF | 100nF | IC | 107 | C171; C174; C175; C176; C177; C178; C179; C182; C183; C184; C185; C186; C187; C188; C189; C190; C191; C192; C194; C204; C205; C206; C207; C208; C209; C210; C211; C212; C223; C228; C229; C230; C231; C232; C233; C234; C235; C236; C237; C238; C240; C241; C242; C243; C244; C245; C259; C260; C261; C262; C263; C264; C265; C266; C267; C276; C304; C305; C306; C307; C308; C309; C310; C318; C319; C320; C321; C322; C323; C324; C325; C326; C327; C328; C329; C338; C339; C340; C346; C347; C410; C411; C500; C501; C502; C503; C504; C505; C506; C507; C509; C510; C512; C513; C518; C519; C520; C690; C691; C692; C693; C1062; C1063; C1064; C1065; C1067; C1074 |
| SC0603 | CAP_SC0603_10NF | 10nF | IC | 5 | C180; C368; C369; C370; C371 |
| SC0603 | C_0603C_SC0603_47PF | 47PF | IC | 1 | C224 |
| SC0603 | CAP_SC0603_100NF | 100nF | IC | 11 | C253; C254; C255; C256; C316; C317; C355; C356; C357; C358; C1041 |
| SC0603 | C_0603C_SC0603_22PF | 22pF | IC | 4 | C343; C344; C514; C515 |
| SC0603 | C_0603C_SC0603_270PF/NC | 270pF/nc | IC | 1 | C345 |
| SC0603 | C_0603C_SC0603_33PF | 33pF | IC | 6 | C348; C620; C1043; C1044; C1045; C1075 |
| SC0603 | C_0603C_SC0603_10NF | 10nF | IC | 3 | C359; C409; C1066 |
| SC0603 | CAP_NP_V_3_SC0603_2.2NF | 2.2nF | IC | 4 | C360; C419; C421; C1054 |
| SC0603 | CAP_NP_V_3_SC0603_1000PF | 1000pF | IC | 8 | C366; C367; C414; C416; C418; C422; C1052; C1056 |
| SC0603 | CAP_SC0603_1NF | 1nF | IC | 2 | C372; C375 |
| SC0603 | C_0603C_SC0603_100PF | 100pF | IC | 2 | C1046; C1049 |
| SC0603 | C_0603C_SC0603_1NF | 1nF | IC | 5 | C1047; C1048; C1050; C1051; C1069 |
| SC0805 | C_0603C_SC0805_2.2UF | 2.2UF | IC | 1 | C374 |
| SC1206 | CAP_SC1206_10UF/25V | 10uF/25V | IC | 7 | C12; C391; C446; C448; C463; C548; C549 |
| SC1206 | CAP_NP_V_3_SC1206_22UF/25V | 22uF/25V | IC | 4 | C361; C420; C423; C1055 |
| SC1206 | CAP_NP_V_3_SC1206_10UF/25V | 10uF/25V | IC | 4 | C363; C364; C365; C1053 |
| SCRSMA | ZHCS750/SOT_2_SCRSMA_B320A-13-F | B320A-13-F(20V/3A) | IC | 4 | D9; D10; D11; D44 |
| SD2723 | 15SMC18A_E3_9C | 15SMC18A | IC | 1 | D1 |
| SF6127 | 0451005MRL | 0451005MRL | IC | 2 | F2; F3 |
| SIM_CARD_SOCKET | SIM_CARD_1_SIM_CARD_SOCKET_SIM_ | SIM_Card_InteRFace | IC | 1 | J19 |
| SIP8-2R54 | HEADER 5X2_IDC10-2_0_SIP8-2R54_ | HEADER8X1 | IC | 1 | J7 |
| SL0805 | MGGB2012U101HT_LF | MGGB2012U101HT_LF | IC | 4 | C412; LB2; LB3; LB4 |
| SL1206 | MGLB3216_060T_LF | MGLB3216_060T_LF | IC | 13 | LB1; LB5; LB6; LB11; LB12; LB13; LB14; LB15; LB16; LB23; LB24; LB25; LB26 |
| SMA | P3100_SMA_BS0080M | BS0080M | IC | 3 | D18; D32; D35 |
| SMA | P3100_SMA_BS0250MS | BS0250MS | IC | 3 | D39; D42; D43 |
| SO8 | AOZ1012_0_SO8_AOZ1013AI | AOZ1013AI | IC | 4 | U67; U68; U72; U77 |
| SO8-150 | SMDA03C_0_SO8-150_SMDA03C | SMDA03C | IC | 1 | U73 |
| SO8-150 | SMDA03C_0_SO8-150_SMDA05C | SMDA05C | IC | 2 | U75; U76 |
| SOP8-50-150 | ADM706RAR | MAX706SESA | IC | 1 | U11 |
| SOP8-50-150 | ADM3485EAR_REEL7 | ADM3485EAR_REEL7 | IC | 1 | U12 |
| SOP8-50-150 | TJA1050T_SOP8-50-150_TJA1050T | TJA1050T | IC | 1 | U14 |
| SOP8-50-150 | MIC2505_2 | MIC2505-2 | IC | 1 | U26 |
| SOP8-50-173 | FMS6143_A | FMS6143_A/nc | IC | 1 | U15 |
| SOP8-50-173 | NCS2563 | TSH343/nc | IC | 1 | Z1 |
| SOP14-50-150 | MM74HC08MX | 74LS08 | IC | 1 | U25 |
| SOP16-6_2-1_27 | ULN2003AFW_SOP16-6_2-1_27_ULN20 | ULN2003AFW | IC | 1 | U27 |
| SOP16-7-1_27 | PS2801-4-F3_SOP16-7-1_27_PS2801 | PS2801-4-F3 | IC | 4 | U33; U34; U35; U36 |
| SOP16-10-1_27 | DS1338C-33_0_SOP16-10-1_27_DS13 | DS1338C-33 | IC | 1 | U19 |
| SOP16-26-208-255 | ICL3232EIA_T | MAX3232E | IC | 1 | U22 |
| SOP56-20-720 | S29GL256N10TFI010 | S29GL256P10TFI010 | IC | 1 | U2 |
| SOT23 | GSOT05C_GS08 | GSOT05C_GS08 | IC | 3 | D2; D28; D29 |
| SOT23 | PSOT12C_LF_T7 | PSOT12C_LF_T7 | IC | 2 | D21; D22 |
| SOT23 | IRLML5203TR | IRLML5203TR | IC | 2 | Q2; Q3 |
| SOT23 | MMBT2222ALT1G | MMBT2222ALT1G | IC | 2 | Q7; Q8 |
| SOT23 | BC847AE6327 | BC847AE6327 | IC | 9 | Q14; Q15; Q16; Q17; Q18; Q19; Q20; Q21; Q22 |
| SOT23-5B | SN74LVC1G125DBVR | SN74LVC1G125DBVR | IC | 2 | U17; U18 |
| SOT23-6A | SRV05_4TCT | SRV05-4TCT | IC | 1 | U24 |
| SOT23-6 | SN74LVC1T45DBVTG4_SOT23-6_SN74L | SN74LVC1T45DBVTG4 | IC | 2 | U41; U42 |
| SOT223 | AMC1117-1.8SK_SOT223_AMC1117-1. | AMC1117-1.2SK | IC | 1 | U1 |
| SOT263-5C | MIC29302BUTR | MIC29302BU | IC | 1 | U28 |
| SR0402 | R_0603R_SR0402_1K | 1K | IC | 4 | R65; R226; R227; R231 |
| SR0603 | R_0603R_SR0603_1MEG | 1MEG | IC | 2 | R11; R532 |
| SR0603 | R_0603R_SR0603_0R/NC | 0R/NC | IC | 3 | R12; R19; R326 |
| SR0603 | R_0603R_SR0603_4.7K | 4.7K | IC | 39 | R13; R14; R15; R20; R21; R109; R126; R127; R128; R129; R164; R165; R166; R167; R168; R169; R171; R192; R248; R250; R251; R430; R435; R442; R451; R473; R511; R518; R519; R520; R521; R522; R523; R526; R529; R1012; R1013; R1041; R1051 |
| SR0603 | R_0603R_SR0603_0R | 0R | DISCRETE | 34 | R16; R17; R18; R123; R196; R197; R198; R199; R256; R258; R259; R260; R261; R327; R328; R329; R330; R354; R355; R356; R357; R358; R359; R360; R361; R450; R533; R1009; R1010; R1023; R1132; R1133; R1134; R1165 |
| SR0603 | R_0603R_SR0603_33R | 33R | DISCRETE | 78 | R23; R24; R25; R26; R27; R28; R31; R32; R33; R34; R35; R36; R37; R57; R58; R151; R152; R160; R161; R162; R163; R172; R173; R203; R205; R236; R237; R339; R340; R341; R342; R343; R344; R345; R346; R347; R348; R349; R350; R351; R352; R353; R452; R453; R454; R455; R456; R457; R458; R459; R460; R461; R502; R503; R504; R505; R506; R507; R508; R509; R510; R513; R514; R515; R516; R517; R525; R528; R628; R1095; R1100; R1157; R1158; R1159; R1160; R1161; R1162; R1164 |
| SR0603 | R_0603R_SR0603_100R | 100R | IC | 16 | R63; R64; R262; R263; R371; R372; R375; R376; R377; R378; R381; R382; R474; R545; R546; R1115 |
| SR0603 | R_0603R_SR0603_10K/NC | 10K/nc | IC | 8 | R66; R67; R68; R69; R70; R71; R72; R73 |
| SR0603 | R_0603R_SR0603_10K | 10K | IC | 5 | R74; R75; R76; R437; R438 |
| SR0603 | R_0603R_SR0603_4.7K_1% | 4.7K_1% | IC | 1 | R85 |
| SR0603 | R_0603R_SR0603_120R | 120R | IC | 2 | R86; R154 |
| SR0603 | R_0603R_SR0603_2.7K | 2.7K | IC | 1 | R97 |
| SR0603 | R_0603R_SR0603_49.9R | 49.9R | IC | 4 | R119; R120; R121; R122 |
| SR0603 | R_0_SR0603_2.2K | 2.2K | IC | 15 | R131; R132; R133; R134; R135; R136; R137; R138; R273; R274; R275; R276; R278; R279; R1169 |
| SR0603 | R_0_SR0603_1K | 1K | IC | 8 | R139; R141; R142; R143; R144; R145; R146; R147 |
| SR0603 | R_0603R_SR0603_330R | 330R | IC | 10 | R148; R178; R239; R550; R551; R552; R553; R554; R1118; R1144 |
| SR0603 | R_0603R_SR0603_4.7K/NC | 4.7K/NC | IC | 1 | R170 |
| SR0603 | R_0603R_SR0603_5.1K | 5.1K | IC | 14 | R175; R176; R177; R179; R180; R181; R182; R183; R184; R185; R186; R187; R188; R238 |
| SR0603 | R_0603R_SR0603_190R | 190R | IC | 1 | R189 |
| SR0603 | R_0603R_SR0603_10K_1% | 10K_1% | IC | 1 | R191 |
| SR0603 | R_0603R_SR0603_51K | 51K | IC | 1 | R193 |
| SR0603 | R_0603R_SR0603_2.49K | 2.49K | IC | 1 | R194 |
| SR0603 | R_0603R_SR0603_1.78K | 1.78K | IC | 2 | R195; R219 |
| SR0603 | R_0603R_SR0603_1.5K | 1.5K | IC | 1 | R200 |
| SR0603 | R_0603R_SR0603_12K | 12K | IC | 1 | R202 |
| SR0603 | R_0603R_SR0603_1K | 1K | IC | 28 | R220; R221; R222; R223; R224; R225; R228; R229; R233; R234; R241; R242; R243; R244; R245; R246; R321; R322; R431; R512; R524; R629; R1011; R1098; R1099; R1121; R1166; R1168 |
| SR0603 | R_0603R_SR0603_51R | 51R | IC | 1 | R230 |
| SR0603 | RES_H_3_SR0603_20R | 20R | IC | 4 | R235; R490; R494; R1123 |
| SR0603 | R_0603R_SR0603_1K/NC | 1K/NC | IC | 1 | R240 |
| SR0603 | R_0_SR0603_0R | 0R | IC | 3 | R270; R271; R1171 |
| SR0603 | R_0_SR0603_2.21K | 2.21K | IC | 1 | R277 |
| SR0603 | R_0_SR0603_4.7K | 4.7K | IC | 10 | R281; R282; R283; R284; R285; R286; R287; R1150; R1151; R1170 |
| SR0603 | R_0603R_SR0603_2K | 2K | IC | 1 | R365 |
| SR0603 | R_0603R_SR0603_100R/NC | 100R/nc | IC | 2 | R373; R374 |
| SR0603 | R_0603R_SR0603_75R | 75R | IC | 6 | R384; R385; R386; R387; R470; R471 |
| SR0603 | R_0603R_SR0603_75/NC | 75/nc | IC | 8 | R389; R390; R392; R393; R397; R400; R401; R1089 |
| SR0603 | RES_V_0_SR0603_52.5K | 52.5K | IC | 1 | R491 |
| SR0603 | RES_V_0_SR0603_0R | 0R | IC | 4 | R492; R499; R501; R1124 |
| SR0603 | RES_H_3_SR0603_10K | 10K | IC | 8 | R493; R496; R500; R536; R539; R1114; R1126; R1127 |
| SR0603 | RES_H_3_SR0603_49.9K | 49.9K | IC | 2 | R495; R1129 |
| SR0603 | RES_H_3_SR0603_27K | 27K | IC | 1 | R497 |
| SR0603 | RES_V_0_SR0603_2.49K | 2.49K | IC | 1 | R498 |
| SR0603 | R_0603R_SR0603_33R/NC | 33R/NC | IC | 1 | R527 |
| SR0603 | RES_V_0_SR0603_31.6K | 31.6K | IC | 1 | R530 |
| SR0603 | RES_H_3_SR0603_20K | 20K | IC | 1 | R540 |
| SR0603 | R_0603R_SR0603_100K | 100K | IC | 1 | R1021 |
| SR0603 | R_0_SR0603_33R | 33R | IC | 2 | R1090; R1091 |
| SR0603 | R_0603R_SR0603_2.2K | 2.2K | IC | 11 | R1116; R1119; R1120; R1122; R1130; R1137; R1139; R1146; R1147; R1148; R1149 |
| SR0603 | RES_V_0_SR0603_37.5K | 37.5K | IC | 1 | R1125 |
| SR0603 | R_0603R_SR0603_2.2K/NC | 2.2K/nc | IC | 2 | R1142; R1143 |
| SRN8-1608 | YC164_JR_0733R | 33R*4 | IC | 2 | RN11; RN12 |
| SRN8-1608 | YC164_JR_0733RL | 33R*4 | DISCRETE | 4 | RN13; RN14; RN15; RN16 |
| STC3216 | TC_3528_STC3216_10UF | 10uF | IC | 51 | C1; C2; C3; C4; C5; C6; C7; C8; C9; C10; C11; C14; C16; C17; C18; C19; C20; C23; C26; C27; C28; C31; C32; C33; C34; C35; C37; C38; C39; C40; C41; C42; C51; C52; C53; C54; C55; C56; C57; C58; C59; C62; C63; C65; C146; C202; C396; C408; C517; C1042; C1073 |
| STC7343 | TC_3528_STC7343_100UF/10V | 100uF/10V | IC | 6 | C61; C362; C415; C417; C447; C1057 |
| SW6X6S | TL1105SF160R | TL1105SF160R | IC | 1 | S5 |
| SX2-1205 | ESB240000F20D33 | 24MHz | IC | 2 | X1; X4 |
| SX2-1205 | XJHEEC25000 | 25MHz | IC | 1 | X3 |
| SX4-0705 | HXO32A2700000MTS | 54MHz | IC | 2 | OSC1; OSC2 |
| TP1M00 | TESTPOINT_5_TP1M00_TP | TP | IC | 32 | TP3; TP4; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP29; TP30; TP31; TP32; TP33; TP34; TP35; TP36; TP37; TP38; TP41; TP42; TP43; TP44; TP45; TP46; TP47; TP48; TP49; TP50; TP51; TP52; TP53 |
| TP1X3 | TP1X3_TP1X3_TP1X3 | TP1X3 | IC | 1 | J57 |
| TQFP100 | LCMXO256-T100/TN100_0_TQFP100_L | LCMXO256-T100/TN100 | IC | 1 | U37 |
| TSSOP14-0R65-4R40 | TXB0104_0_TSSOP14-0R65-4R40_TXB | TXB0104 | IC | 1 | U40 |
| TSSOP24-0R65-4R40 | SN74LVCC3245AIDBREP_TSSOP24-0R6 | SN74LVCC3245A | IC | 1 | U39 |
附件:
