标题:
could not read symbols: File format not recognized
[打印本页]
作者:
uperrua
时间:
2020-4-16 10:29
标题:
- D ~1 X. {/ \3 w3 _
arm-linux-gnueabi-readelf工具解决问题
: _8 c9 E+ Y, q& Q/ x9 v
编译一个32位平台的内核时,出现如下错误提示:
" r; w8 e7 a& J7 r- m) Y. O
* t3 Z+ B2 l% c# X, Q
libschw.a: could not read symbols: File format not recognized
0 e% C1 x# V7 \/ s' g9 w
: A# N6 J" D# h! D R4 q7 K
于是进入相应的目录发现,libschw.a这个文件是存在的,但是为啥编译不过呢,同样的编译在另外一个64位平台却没有这个报错。
z8 a6 ~2 y2 S+ A2 c" I' l) l
+ z6 @+ t* J; k, ?6 |1 g* U
思路:是否与32位64位平台有关?
8 ]1 u- }: M! T) \# M1 N, d
使用readelf来查看一下这个库,
: w2 U9 f$ x2 A3 b+ w- g
$ arm-linux-gnueabi-readelf -h modules/aw_schw/libschw
5 u# s* t2 n* {; h x
File: modules/aw_schw/libschw(aw_schw_lib.o)
! N* e! f/ I7 v! g6 b. K8 i+ J
ELF Header:
( a# [( f* @) R5 b; X
Magic: 7f 45 4c 46 02 01 01 00 00 00 00 00 00 00 00 00
+ ]0 r9 h" N ^. h
Class: ELF64
# m8 i" R, D' r. c. x
Data: 2's complement, little endian
0 J. f2 ~" p5 P+ ?8 Y: O. v5 X
Version: 1 (current)
+ }9 o! o% \6 s
OS/ABI: UNIX - System V
" \8 k8 q! W+ @! z1 t1 f" B7 q
ABI Version: 0
! @; y9 Y. q# \7 j+ A v) P4 q
Type: REL (Relocatable file)
' b) f- n8 d) }$ j
Machine: <unknown>: 0xb7
4 _& D* S4 M9 y( H; N) j5 Q6 N
Version: 0x1
6 i0 F6 ^0 ^ ~! @6 W0 X
Entry point address: 0x0
G! G8 H3 M' i; h2 A! t. }
Start of program headers: 0 (bytes into file)
: K5 D8 e% `/ ~ |" }. t* ~
Start of section headers: 161192 (bytes into file)
" m" T6 }+ e+ g3 N6 U( d% c
Flags: 0x0
' }) n5 Z6 c) `% B/ |+ J9 N2 O
Size of this header: 64 (bytes)
S& |7 D7 { I# L, G3 V
Size of program headers: 0 (bytes)
4 c2 h( t/ S8 x) \4 C& C
Number of program headers: 0
$ K. j, Y# q% s' {$ Z5 ^ [
Size of section headers: 64 (bytes)
3 k( o2 j* _8 E% [9 v
Number of section headers: 29
9 Y, D7 J5 j: g- n9 Q
Section header string table index: 24
5 [5 c l/ X! s7 \" ~6 c7 s( p6 x
果然,这个库显示是64位的,为了兼容32位的,只能修改Makefile,判断到32位时,使用32位的库。
% M l% R% I( G1 ^
+ifeq ($(LICHEE_ARCH),arm64)
4 G% w' G4 `, W/ v' \: M' k+ H
cp libschw libschw.a
" C; W9 b* [, h% w* K7 _9 s0 _) U
+else
4 S( Z/ q6 K6 q6 i' z3 `
+ cp libschw32 libschw.a
8 l0 x- w- l7 }7 R
+endif
, D3 V$ T. _1 ^/ i9 t0 R9 J
重新弄一份新32位的libschw32库后,重新编译,问题解决。
+ q! ?3 j$ J$ v6 E
作者:
NingW
时间:
2020-4-16 18:58
Powered by Discuz! X3.2
