查看: 252|回复: 1
求助:关于am335xd编译报错的问题
    2019-11-19 15:32
    发表于 2020-4-13 13:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    有个问题请教:我下载了tisdk包,里面有的uboot是201109的,我使用的开发板是飞凌的ok335xd,我想自己编译个uboot测试功能,在没有任何修改的情况下编译报错, , 使用的编译命令是:make CROSS_COMPILE=ARM-linux-gnueabihf-  am335x_evm_config
    * O5 T2 b8 A, E: q, E* q) {make CROSS_COMPILE=arm-linux-gnueabihf-  am335x_evm1 @/ E8 p  Y5 z3 D: t* x6 Y, W
    这样编译后报错
    ; l5 Z! P$ X: Q- X: b7 U; @2 z' j" C2 ^
    ake[1]: Entering directory `/root/work/TOD_uboot/335xd_uboot_201109/drivers/net'
    ; {' `" `. n% }/ K( Y' k+ x  P, K0 @make[1]: Leaving directory `/root/work/TOD_uboot/335xd_uboot_201109/drivers/net'' ?1 l- j9 }0 V) u9 }! d/ J
    make[1]: Entering directory `/root/work/TOD_uboot/335xd_uboot_201109/drivers/net') K3 }* K, L: @( M
    arm-linux-gnueabihf-gcc  -g  -Os   -fno-common -ffixed-r8 -msoft-float   -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0x80800000 -DCONFIG_SPL_TEXT_BASE=0x402F0400 -I/root/work/TOD_uboot/335xd_uboot_201109/am335x_evm/include2 -I/root/work/TOD_uboot/335xd_uboot_201109/am335x_evm/include -I/root/work/TOD_uboot/335xd_uboot_201109/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/local/arm/gcc-linaro-arm-linux-gnueabihf-4.7/bin/../lib/gcc/arm-linux-gnueabihf/4.7.3/include -pipe  -DCONFIG_ARM -D__ARM__ -marm  -mabi=aapcs-linux -mno-thumb-interwork -march=armv5 -Wall -Wstrict-prototypes -fno-stack-protector -Wno-format-nonliteral -Wno-format-security   -o /root/work/TOD_uboot/335xd_uboot_201109/am335x_evm/drivers/net/cpsw.o cpsw.c -c5 E' w2 W% \2 s5 H1 P
    cpsw.c: In function ‘cpsw_init’:& K, i' y7 T9 x, C0 e
    cpsw.c:831:8: warning: passing argument 3 of ‘cpdma_submit’ discards ‘volatile’ qualIFier from pointer target type [enabLED by default], A- i- `. [. X# F0 n
    cpsw.c:652:12: note: expected ‘void *’ but argument is of type ‘volatile uchar *’4 F4 n# [& [! e  F' W/ @
    cpsw.c: In function ‘cpsw_phy_init’:+ N* l" |1 J' {0 }8 D
    cpsw.c:923:4: error: ‘CONFIG_PHY_ADDR’ undeclared (first use in this function)$ y( R/ T1 T- {
    cpsw.c:923:4: note: each undeclared identifier is reported only once for each function it appears in
    . O( e% B2 Q/ J0 \3 ^4 N) Ucpsw.c: In function ‘cpsw_register’:
    " L5 p, m. ?& i  acpsw.c:981:12: warning: assignment from incompatible pointer type [enabled by default]0 u0 B+ ]  F$ u/ O6 }: j: i4 N
    make[1]: *** [/root/work/TOD_uboot/335xd_uboot_201109/am335x_evm/drivers/net/cpsw.o] Error 1
    # R) h/ f- k3 M* hmake[1]: Leaving directory `/root/work/TOD_uboot/335xd_uboot_201109/drivers/net'
    / u8 y' {% T4 L" Q+ Bmake: *** [/root/work/TOD_uboot/335xd_uboot_201109/am335x_evm/drivers/net/libnet.o] Error 2
    ) ]7 G! z6 `8 I( ~* J; N
    ) n  O2 h1 w; z2 f- e0 {$ a请教这个是什么错误,我在网上找了半天,别人都是可以编译过的
    $ I$ n7 r( A' }* }
    发表于 2020-4-13 19:56 | 只看该作者
    是不是这个CONFIG_PHY_ADDR未声明啊
    GMT+8, 2025-11-26 01:30 , Processed in 0.140625 second(s), 23 queries , Gzip On.
