查看: 6976|回复: 4
[Ansys仿真] 原创:allegro与siwave 连接后 原FPM菜单不见的问题解决方法!!!
发表于 2010-4-2 14:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
安装ansoftlink4.1后 , 原先allegro中的 FPM skill程序菜单不见了:, `* ]+ R6 w+ x: q- j
原因:allegro的menupath 变量值被修改为:d:\Ansoft\integrate4/cdsmenus163! [! i, y0 s, `  \; I! P
在此目录下 编辑allegro.men文件 添加代码如下:/ n# R/ h# [( F0 A4 _
// FPM_BEGIN( a; J7 v& i. }' p1 e# F$ T$ N- e
POPUP "F&PM"
4 h* d$ {$ I  UBEGIN; ]- t, j5 b% `
MENUITEM "Quick &Grid","grids"2 l) h! N! Y6 B3 G
MENUITEM "Quick &View","qview"+ f% |: h5 ?/ M% N. O
MENUITEM "check_dir","check_dir"6 m; q4 W& x0 K2 l- N8 ]7 A$ Q
MENUITEM "check_no_refdes","check_no_refdes"5 f; B# y! c& |+ a; ]
MENUITEM "ch_nc_via","ch_nc_via"1 L3 b! n2 O) A5 @  E" }! V
MENUITEM "ch_text_overlap","ch_text_overlap"2 r3 u0 {" N- E) w( \
MENUITEM "colorset","colorset"
. L. P; o& u7 W" X3 V1 {8 K$ o" ^MENUITEM "cot","cot", w$ t4 y3 _4 x0 `  P* \) ^$ [
MENUITEM "DeleteDanglingLines","DeleteDanglingLines"
! N- J2 o- q7 V, `6 SMENUITEM "drc walk","drc walk"  ?8 A$ O2 \3 R1 C
MENUITEM "hl_null_pin","hl_null_pin"* Y; N9 p/ |! d! m
MENUITEM "MoveRefDestoBodyCenter","r2c"' ^9 J* E  w; t% F* g3 G' y
MENUITEM "OrphanNet","OrphanNet") o2 ~/ I) k4 K( C" r2 \
MENUITEM "ref_rot","ref_rot"' t" A+ o6 g, ?) R6 k3 z; }( G7 i- j
MENUITEM "StackVias","StackVias"
) f# Q- }+ G( n6 K: E% TMENUITEM "uc shape","uc shape"
! y4 E& W9 L# p+ AMENUITEM "auto balance","auto balance"8 A( Q# c, S- C# Y
MENUITEM "align_sym","align_sym"
0 F: `% M! W) S8 g1 WMENUITEM "boundaryview","boundaryview"
/ H: s  e$ f, GMENUITEM "conv","conv"/ M# ]8 s- v' c- F% ?* |
MENUITEM "hlvia","hlvia"
1 f3 l1 g) w& `0 VMENUITEM "scalpel","scalpel"0 ]9 t9 P9 Y' k$ g  H1 r# b2 z
END
# _2 s- ]: a; S, B. J// FPM_END
% W; a5 x- ~/ ?9 r5 X- _6 O. u' T此段代码为FPM添加allegro菜单时 自动生成的
( ^8 d2 U5 U0 c) [6 @" m保存文件 重启 问题解决!!!
参与人数 1贡献 +10 收起 理由
袁荣盛 + 10 Not Bad
 楼主| 发表于 2010-4-12 17:40 | 只看该作者
本人用的是16.3版本,使用中发现原16.3有些功能不能用,例如:setup->constraints->Modes 点击后没反应命令提示行 命令无法找到,错误原因ansoft下的allegro.men菜单文件 把Modes的调用命令改掉了,还有一些快捷键不能用,修改方法:打开16.3默认.men文件 复制到ansoft下的allegro.men文件中,并保留POPUP "F&PM",POPUP "ansoft"部分内容,保存文件 重启allegro 问题解决!
发表于 2010-12-21 17:10 | 只看该作者
高人啊!!!!!!!!!
发表于 2011-5-15 21:38 | 只看该作者
happybai ,你用的SIWAVE是哪个版本?
发表于 2011-9-1 15:13 | 只看该作者
15.5乍搞或
GMT+8, 2025-11-22 22:53 , Processed in 0.140625 second(s), 25 queries , Gzip On.
