( S% l; G2 K6 o% w6 l9 U
看了fill函数该调用命令形式的帮助文档,但对下例中的涂色问题仍不理解,请教大神,非常感谢!0 @; |8 y, O$ e6 Z$ @
fill(X,Y,C) creates filled polygons from the data in X and Y with vertex color specified by C. C is a vector or matrix used as an index into the colormap. If C is a row vector, length(C) must equal size(X,2) and size(Y,2); if C is a column vector, length(C) must equal size(X,1) and size(Y,1). If necessary, fill closes the polygon by connecting the last vertex to the first- h7 q' r2 f+ b. Z
" r R5 q$ w8 ~5 F; F- e0 h( Q# C0 Y9 ]% x( E- [' n
实例:/ _; l- i' H% v! p- ^/ i2 p
clc;
/ t* t1 f# {# o6 d& ?clear all;
- x* d. ~) ?' p1 k' ^. u! L, k; hx=[0 1 1 0];
$ S3 u4 U* ]* ` { y7 I0 \7 l0 S' iy=[0 0 1 1]; %定义四个点 [0 0] [1 0] [1 1] [0 1]5 N j. [) a6 s7 ^
H_F=fill(x,y,[0 0.1 0.2 0.6]); %定义四个点的C值. ?) R7 ]; M2 X
$ T5 z% z( B( D
这里定义颜色没有用'r'等字符定义,好像也不是直接定义RGB Value。似乎是一个顶点用一个数值定义了颜色,想知道涂色规律是什么。 |
