查看: 417|回复: 1
matlab好像删错东西,帮助文档用不了了!!!!!
发表于 2020-2-26 17:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本来是下载另一个软件,但是捆绑了一堆破玩意,一气之下就全删了,删完之后,用matlab的时候才发现好像帮助文档用不了了。。。是不是删错东西了?????求大神指点指点=-=' I8 X6 L$ \/ K
# J3 d1 Z" ~6 l8 R  ^- ^- v2 u
错误使用 docsearch (line 34)9 ?4 R9 h8 j  `3 |: S
Java exception occurred:
2 j1 [& `$ o: |7 @' A$ ]java.lang.NullPointerException
& Z" F- }; E! A7 C% F8 n, |& u/ {, `/ y) o6 \
        at com.mathworks.html.UrlTransformer.transformUrl(UrlTransformer.java:15)7 t& G3 w# C9 X1 h# O3 W
/ ^. I& _9 U  n) K        at com.mathworks.html.UrlBuildeRFactory.toUrlBuilder(UrlBuilderFactory.java:15)
. B8 b; L* S. z
9 n7 ?! P+ @* k) l  Q  P3 V+ W        at com.mathworks.html.UrlBuilder.fromUrl(UrlBuilder.java:87)
) f* T2 ]" {+ K) I. C9 O/ Y, y
' h# N( O( B* x; @        at com.mathworks.help.helpui.DocRoot.buildSearchPageUrl(DocRoot.java:176)
7 @) W$ ?( ~$ V/ ~& G% g. B" _
( w$ {3 v' t* t* C9 a% m        at com.mathworks.help.helpui.DocRoot.buildSearchPageUrl(DocRoot.java:163)
3 K% D9 _6 Y/ K6 E4 ?: u  N: o5 g0 S- ^& ?7 X  q# @  ]' c
        at com.mathworks.mde.help.JsHelpBrowser.docSearch(JsHelpBrowser.java:197)* J( |) p8 E4 n3 m9 u+ e/ C
) F7 Z, C, l8 R: g3 F
        at com.mathworks.mlservices.MLHelpServices.docSearch(MLHelpServices.java:257)
" {, {' U; b& M. V" l; r9 q7 i  i1 Z: Y1 r2 n
( t/ f0 ~8 A3 [6 @' h8 j
2 }$ @6 v& S+ e1 Z) z+ T% V
/ k; U2 j3 K" U% m, D: u$ [
& I4 q# V: `- t4 ~' e, S
% `0 y! i& v* B
: p3 M7 i; h2 i; X9 X
: f" h$ j- U8 O
* s. Z& Y5 f. r4 w" u" C0 pException in thread "AWT-EventQueue-0": java.lang.NullPointerException
; b2 D: s2 \9 v/ Z        at com.mathworks.mlwidgets.help.DocConfigUrlBuilder.getUrlForDocConfig(DocConfigUrlBuilder.java:29)
4 }" S. ^5 Q+ P0 E$ G! i+ W        at com.mathworks.mlwidgets.help.LightweightHelpPanel.getNavigationUrl(LightweightHelpPanel.java:268)
7 `3 V: v/ S6 N$ I/ m        at com.mathworks.mlwidgets.help.LightweightHelpPanel.setCurrentLocation(LightweightHelpPanel.java:162)
4 m( t8 u5 N6 Y9 W; m! @3 v        at com.mathworks.mde.help.JsHelpBrowserClient.setCurrentLocation(JsHelpBrowserClient.java:192)
7 I8 ?1 N3 d/ J4 ?9 P, \% w" ~        at com.mathworks.mde.help.JsHelpBrowserClient.showClient(JsHelpBrowserClient.java:244)1 ~' K2 c4 Y$ \5 w
        at com.mathworks.mde.help.JsHelpBrowser$OpenInNewBrowser.openBrowser(JsHelpBrowser.java:368)8 ]2 p+ U2 l! e6 W- y2 E
        at com.mathworks.mde.help.JsHelpBrowser$JsHelpBrowserRunnable.createAndShowBrowser(JsHelpBrowser.java:320)9 v8 `4 t' e# w2 l4 x6 n$ ^
        at com.mathworks.mde.help.JsHelpBrowser$JsHelpBrowserRunnable.run(JsHelpBrowser.java:315)4 Q- c& @' E& W- @
        at com.mathworks.mde.help.JsHelpBrowser.doHelpBrowserTask(JsHelpBrowser.java:282). X& ~2 @5 p) }
        at com.mathworks.mde.help.JsHelpBrowser.doHelpBrowserTask(JsHelpBrowser.java:276)' ~. {6 b( P7 h" T- h' n+ J
        at com.mathworks.mde.help.JsHelpBrowser.invoke(JsHelpBrowser.java:56)/ [, c6 U: Z% z, J4 Q
        at com.mathworks.mde.help.JsHelpBrowser.invoke(JsHelpBrowser.java:47)
9 x% C9 a1 u; ]3 X$ }# S        at com.mathworks.mlservices.MLHelpServices.invoke(MLHelpServices.java:41). q, I9 r# h4 O8 y7 J& o$ r' }) m
        at com.mathworks.mde.desk.MLDesktop$HelpProductPageAction.actionPerformed(MLDesktop.java:3241)# C% k2 B1 G' f6 p
        at com.mathworks.mwswing.ChildAction.actionPerformed(ChildAction.java:214)
, V4 B9 |2 v1 L; P4 u1 q        at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
; |6 Q+ T. [: m7 M4 d        at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)9 J9 ^9 ~6 _& [
        at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
9 U, Y8 Q- r: o* U7 ~5 Z        at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)& ~% O. o" n: f
        at com.mathworks.toolstrip.plaf.RegularButtonUI$RegularToolstripButtonListener.mouseReleasedImpl(RegularButtonUI.java:348)
3 u* t7 A/ `0 R4 G1 n' q' B        at com.mathworks.toolstrip.plaf.RegularButtonUI$RegularToolstripButtonListener.mouseReleased(RegularButtonUI.java:338)% x0 r) P3 F- J: E8 t
        at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289)
- B5 `( U& l$ D, k: E' |7 f        at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289)
8 W- V/ t7 c7 x8 N; f3 I  \        at java.awt.Component.processMouseEvent(Component.java:6539)
" g. K1 n; _& S, t* T1 K  x        at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)% D: I3 b9 F! y
        at com.mathworks.mwswing.MJButton.processMouseEvent(MJButton.java:350)
% B- ]$ z" v1 m) \) }+ T+ u        at java.awt.Component.processEvent(Component.java:6304)5 X5 T- x+ J( b% T
        at java.awt.Container.processEvent(Container.java:2239)8 H# M1 D, N/ z6 t  F" a5 t
        at java.awt.Component.dispatchEventImpl(Component.java:4889)) `) w/ i0 P5 M5 @
        at java.awt.Container.dispatchEventImpl(Container.java:2297)
6 P( k2 v, y/ W7 S        at java.awt.Component.dispatchEvent(Component.java:4711)3 n. d) ^0 @' z  H) o' p1 a
        at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904)
1 [& w- |" C( J% s( @' @" C        at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4535)
+ v# }+ a8 X. s$ j. v        at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476)
8 k, u. ], [# @        at java.awt.Container.dispatchEventImpl(Container.java:2283)  {7 E1 F* @; M4 H& u# `
        at java.awt.Window.dispatchEventImpl(Window.java:2746)$ E- ?# C$ U  }2 P! Q
3 R& I3 N4 T& N! \        at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)" _+ S+ X, |4 `
        at java.awt.EventQueue.access$500(EventQueue.java:97)
, r& N( F! ?* p- {: ^- S2 m  V+ B        at java.awt.EventQueue$3.run(EventQueue.java:709)
: }7 u( X" _$ x: s        at java.awt.EventQueue$3.run(EventQueue.java:703)
; c( P" J! {8 w  Y5 ^  Q1 }        at java.security.AccessController.doPrivileged(Native Method)
% p- z4 }0 p+ o5 }: c- S        at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
" D! S& N1 S! W) `        at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)% B# X4 c2 Z$ t; a
        at java.awt.EventQueue$4.run(EventQueue.java:733)' l) I* I8 h' k# B# d9 B# i8 P
        at java.awt.EventQueue$4.run(EventQueue.java:731)
' v! ~9 t( _/ m8 _! }; x# e; D        at java.security.AccessController.doPrivileged(Native Method)1 R' e! h( U8 I% u6 @
4 i, v! }& s: O4 b        at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
+ D4 r! ?9 t, ^; O1 J( f        at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
3 ]# g# t4 L; {$ V) u        at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)- w: G1 v( _  t8 U( J9 k
        at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
  k  _% O3 _! w        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
0 P& u- H- @; ]5 M: m( o0 c        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)4 O- O) U" G& s& }
        at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
0 ]4 s: z0 ~6 ^" K8 R( f
* X  `/ e: ?- _2 z0 a7 U
( L$ c2 h/ {9 p5 j0 t& S2 Z1 i  L
  ^( T+ }# f+ m# R+ F0 d3 S- ~. @
???????????????????????????????( \3 e* v. u5 S; G) z; V
这是什么玩意?help' C) o7 ^& S% U) z+ ^( o* b
. l% I$ E: s: @' \; s8 H0 U( Z
% S! R. S* }- S: |+ g; }
" q; ^; `- p8 _/ c+ v
GMT+8, 2025-11-24 04:12 , Processed in 0.156250 second(s), 23 queries , Gzip On.
