| Bill of Material Report (Condensed) |
| SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
| 名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
| 8P4C | SMD_CAP-PACK-8P4C | YES | DISCRETE | 11 | SCN1; SCN3; SCN4; SCN5; SCN6; SCN7; SCN8; SCN9; SCN10; SCN13; SCN14 |
| 8P4R | SMD_R-PACK-8P4R | YES | DISCRETE | 100 | RN1; RN2; RN3; RN4; RN6; RN8; RN9; RN10; RN11; RN12; RN13; RN14; RN15; RN16; RN17; RN18; RN19; RN20; RN21; RN22; RN23; RN24; RN25; RN26; RN27; RN28; RN29; RN30; RN31; RN32; RN33; RN34; RN35; RN36; RN37; RN38; RN39; RN40; RN41; RN42; RN43; RN44; RN45; RN46; RN47; RN48; RN49; RN50; RN51; RN52; RN53; RN54; RN55; RN56; RN57; RN58; RN59; RN60; RN61; RN62; RN63; RN65; RN66; RN68; RN69; RN70; RN73; RN74; RN86; RN87; RN99; RN101; RN102; RN103; RN104; RN105; RN106; RN107; RN108; RN109; RN110; RN111; RN112; RN113; RN114; RN115; RN116; RN117; RN118; RN119; RN120; RN121; RN122; RN123; RN124; RN125; RN126; RN127; RN128; RN129 |
| AGPUNIVERSAL | DIP_AGP-SLOT_132P | AGP SLOT UNIVERSAL | IO | 1 | AGP1 |
| AUDIO-GAME | DIP_CONN_AUDIO-GAME | AUDIO_CONN-PC99 | IC | 1 | AUDIO_GAME1 |
| BAT | DIP_COIN_BAT | BATTERY SOCKET | DISCRETE | 1 | BAT1 |
| C1206 | SMD_CAP_1206 | YES | DISCRETE | 38 | CB19; CB20; CB21; CB22; CB23; CB24; CB25; CB26; CB27; CB38; CB39; CB40; CB41; CB42; CB43; CB44; CB45; CB68; CB69; CB70; CB71; CB75; CB76; CB79; CB80; CB81; CB82; CB104; CB105; CB106; CB107; CB108; CB109; CB226; CB227; CB228; CB229; CB230 |
| CAP250 | DIP_CAP_D250MIL | | DISCRETE | 1 | C16 |
| CN1X4-2MMWH | DIP_CONN_CDIN_1X4-PP20 | | IO | 1 | CN12 |
| CN1X4-25MMWH | DIP_CONN_CDIN_1X4-PP25 | | IO | 1 | CN11 |
| COIL-17MM | DIP_COIL_L165-P89-H140 | YES | DISCRETE | 3 | L7; L9; L11 |
| CT_TYPE-C | SMD_CAP_TYPE-C | | IC | 2 | C26; C27 |
| DB9M | DIP_CONN_DTYPE-9P | | IO | 2 | COM1; COM2 |
| DB25FD | DIP_CONN_DTYPE-25P | | IO | 1 | COM_LPT1 |
| DIMM184 | DIP_DDR-SLOT-184P | DIMM184-NYLOW-W | DISCRETE | 2 | DDR1; DDR2 |
| DIP_CAP_D130-P50 | DIP_CAP_D130-P50 | | IO | 14 | CE1; CE3; CE5; CE8; CE10; CE12; CE13; CE14; CE15; CE16; CE17; CE20; CE25; CE27 |
| DO1545-12 | SMD_DIODE_DO1545-12 | | DISCRETE | 14 | D1; D2; D3; D8; D9; D10; D11; D12; D13; D18; D27; D28; D29; D30 |
| DRILL-150_PAD-300 | DRILL-150_PAD-300 | | IO | 7 | MH1; MH2; MH3; MH4; MH5; MH6; MH7 |
| EC_D50-P20-H70 | DIP_CAP_D50-P20 | | IC | 47 | CE6; CE7; CE9; CE19; CE21; CE23; CE24; CE26; CE30; CE31; CE32; CE33; CE37; CE42; CE49; CE52; CE53; CE54; CE56; CE57; CE58; CE62; CE65; CE66; CE67; CE68; CE69; CE73; CE74; CE75; CE86; CE87; CE88; CE89; CE90; CE92; CE94; CE95; CE98; CE101; CE102; CE103; CE104; CE105; CE108; CE109; CE110 |
| EC_D60-P25-H70 | DIP_CAP_D63-P25 | | IC | 4 | CE22; CE35; CE96; CE97 |
| EC_D80-P35-H110 | DIP_CAP_D80-P35 | | DISCRETE | 4 | CE70; CE79; CE106; CE107 |
| EC_D100-P50-H200 | DIP_CAP_D100-P50 | | DISCRETE | 7 | CE18; CE28; CE29; CE34; CE64; CE91; CE93 |
| FAN_CONN | DIP_FAN_1X3P | | IO | 2 | FAN2; FAN3 |
| FDD_CNTR_2X17 | DIP_BOX-HEADER_2X17 | | DISCRETE | 1 | FDD1 |
| H1102 | SMD_H1102_SOP16 | | IC | 1 | T1 |
| HEADER_2X4 | HEADER_2X4 | | IC | 1 | JP4 |
| IDE | DIP_BOX-HEADER_2X20_P20NC | | IO | 2 | IDE1; IDE2 |
| JP2 | DIP_HEADER_1X2P | | IO | 1 | RT1 |
| JP3 | DIP_HEADER_1X3P | | IO | 5 | JP1; JP3; JP6; JP7; JP8 |
| JP5 | DIP_HEADER_1X5P | | IO | 2 | J1; J2 |
| JP5X2 | DIP_HEADER_2X5P | | IO | 2 | USB1; USB2 |
| JP6X2 | DIP_HEADER_2X6P | | IO | 1 | J3 |
| JP8X2V | DIP_HEADER_2X8P | | IC | 1 | J5 |
| L0603 | SMD_L_0805 | | DISCRETE | 4 | L20; L24; L32; L33 |
| L0805 | SMD_L_0805 | | DISCRETE | 31 | L1; L2; L3; L4; L5; L8; L10; L12; L13; L19; L21; L23; L26; L30; L35; L36; L49; L50; L51; L52; L53; L54; L55; L56; L57; L58; L59; L60; L61; L62; L63 |
| MINI-SMDC110 | SMD_POLY-SW_MINI-C110 | | DISCRETE | 4 | FS1; FS2; FS3; FS4 |
| PCISLOT | DIP_PCI-SLOT_120P | | IO | 3 | PCI1; PCI2; PCI3 |
| PLCC32 | SMD_PLCC32 | | IC | 1 | U27 |
| POWER-ATX | DIP_ATXPWR_2X10P | | IO | 1 | ATXPWR2 |
| POWER_2X2P | DIP_ATXPWR_2X2P | | DISCRETE | 1 | ATXPWR1 |
| PQFP128 | SMD_TQFP128 | | IC | 1 | U22 |
| PS2X2 | DIP_CONN_KB-PS2 | | IO | 1 | PS2KBMS1 |
| RJ45_USB | DIP_CONN_USB-RJ45 | | DISCRETE | 1 | CN2 |
| SMD-SSOP56 | SMD-SSOP56 | | IC | 1 | U14 |
| SMD_CAP_0603 | SMD_CAP_0603 | | IC | 412 | C2; C3; C4; C6; C7; C8; C9; C10; C12; C13; C15; C18; C19; C20; C22; C23; C24; C25; C28; C29; C30; C31; C52; C57; C58; C59; C63; C64; C74; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C98; C101; C102; C103; C104; C105; C106; C107; C108; C110; C111; C112; C115; C116; C120; C121; C122; C123; C124; C125; C452; C453; C509; C512; C513; C532; C533; C534; C535; C536; C537; C538; C539; C540; C541; C542; C543; C544; C545; C546; C547; C548; C549; C550; C551; C552; C553; C554; C555; C556; C557; C558; C559; C560; C561; C562; C563; C564; C565; C566; C567; C568; C569; C570; C571; C572; C573; C574; C575; C576; C577; C578; C579; C580; C581; C582; C583; C584; C585; C586; C587; C588; C589; C590; C591; C592; C593; C594; C595; C596; C597; C598; C599; CB2; CB5; CB8; CB9; CB10; CB13; CB16; CB17; CB18; CB30; CB31; CB32; CB33; CB34; CB36; CB37; CB46; CB47; CB48; CB49; CB50; CB51; CB52; CB53; CB57; CB58; CB59; CB60; CB61; CB62; CB63; CB64; CB65; CB66; CB67; CB72; CB73; CB74; CB77; CB78; CB83; CB84; CB85; CB86; CB87; CB88; CB89; CB90; CB91; CB92; CB93; CB94; CB96; CB97; CB98; CB99; CB100; CB101; CB102; CB103; CB110; CB111; CB112; CB115; CB117; CB119; CB123; CB125; CB126; CB127; CB128; CB129; CB131; CB132; CB133; CB134; CB135; CB136; CB137; CB138; CB139; CB140; CB142; CB143; CB144; CB145; CB147; CB148; CB149; CB150; CB151; CB152; CB153; CB156; CB157; CB158; CB160; CB161; CB162; CB163; CB164; CB165; CB166; CB167; CB168; CB169; CB170; CB171; CB172; CB173; CB174; CB179; CB180; CB181; CB184; CB190; CB191; CB192; CB193; CB194; CB195; CB196; CB197; CB198; CB199; CB200; CB201; CB202; CB203; CB204; CB205; CB206; CB207; CB208; CB209; CB210; CB211; CB212; CB213; CB216; CB217; CB218; CB219; CB221; CB225; CB255; CB256; CB257; CB258; CB259; CB260; CB262; CB263; CB264; CB265; CB266; CB267; CB268; CB269; CB270; CB271; CB272; CB273; CB274; CB275; CB276; CB278; CB279; CB280; CB281; CB282; CB304; CB305; CB306; CB307; CB308; CB309; CB310; CB311; CB312; CB313; CB314; CB315; CB316; CB317; CB318; CB319; CB320; CB321; CB322; CB323; CB324; CB325; CB326; CB327; CB328; CB329; CB330; CB331; CB332; CB334; CB335; CB337; CB338; CB339; CB340; CB341; CB342; CB343; CB344; CB345; CB346; CB347; CB348; CB349; CB350; CB351; CB352; CB353; CB354; CB355; CB356; CB357; CB358; CB359; CB360; CB361; CB362; CB363; CB364; CB365; CB366; CB367; CB368; CB369; CB370; CB371; CB372; CB373; CB374; CB375; CB376; CB377; CB378; CB379; CB380; CB381; CB382; CB383; CB384; CB385; CB386; CB387; CB388; CB389; CB390; CB391; CB392; CB393; CB400; CB401; CB402; CB403; CB404; CB405; CB406; CB407 |
| SMD_CAP_0805 | SMD_CAP_0805 | 1u | IC | 1 | C600 |
| SMD_R_0603 | SMD_R_0603 | | IC | 363 | R2; R3; R4; R10; R11; R12; R13; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R27; R28; R29; R30; R31; R32; R33; R34; R35; R36; R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R48; R49; R51; R52; R53; R55; R56; R57; R58; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R71; R72; R73; R74; R75; R77; R78; R79; R80; R81; R82; R83; R84; R85; R86; R87; R88; R89; R90; R93; R94; R95; R96; R100; R101; R102; R103; R108; R109; R110; R115; R117; R119; R125; R135; R136; R137; R138; R142; R147; R148; R149; R150; R151; R155; R156; R157; R161; R163; R164; R169; R170; R176; R177; R178; R179; R184; R185; R186; R187; R188; R189; R190; R191; R192; R193; R194; R195; R196; R197; R198; R199; R200; R201; R202; R203; R204; R206; R207; R208; R209; R210; R211; R213; R215; R216; R217; R221; R224; R229; R230; R231; R232; R233; R234; R235; R236; R237; R238; R239; R240; R241; R242; R243; R255; R256; R257; R258; R259; R260; R261; R262; R263; R264; R265; R266; R269; R270; R271; R272; R273; R274; R275; R276; R277; R278; R284; R285; R286; R287; R289; R290; R295; R297; R300; R304; R306; R307; R308; R309; R310; R311; R313; R315; R316; R317; R318; R322; R324; R330; R331; R332; R333; R334; R335; R338; R339; R341; R342; R343; R344; R345; R346; R347; R348; R353; R354; R355; R356; R357; R363; R371; R372; R374; R437; R438; R439; R440; R441; R444; R445; R446; R447; R448; R492; R493; R494; R495; R496; R497; R498; R499; R500; R501; R502; R505; R507; R508; R509; R510; R511; R512; R515; R516; R517; R518; R519; R520; R521; R522; R523; R524; R525; R526; R527; R528; R529; R530; R531; R533; R535; R536; R537; R538; R541; R542; R543; R544; R545; R546; R547; R548; R549; R550; R551; R552; R553; R554; R555; R556; R557; R558; R559; R560; R561; R562; R563; R564; R565; R566; R567; R568; R569; R570; R571; R572; R573; R574; R575; R576; R577; R578; R579; R580; R581; R582; R583; R584; R585; R586; R587; R588; R589; R590; R591; R592; R593; R594; R595; R596; R597; R598; R599; R600; R601; R602; R603; R604; R605; R606; R607; R608; R609; R610; R611; R612; R613; R614; R615; R616; R617; R618; RA1; RB1; RC1 |
| SMD_R_0805 | SMD_R_0805 | | IC | 6 | R8; R9; R442; R443; R539; R540 |
| SMD_VT8235_BGA487 | SMD_VT8235_BGA487 | | DISCRETE | 1 | U20 |
| SMD_VT8754_BGA858 | SMD_VT8754_BGA858 | | IC | 1 | U15 |
| SOP8 | SMD_SOP8 | | IC | 6 | Q13; Q18; U10; U16; U18; U33 |
| SOP14 | SMD_SOP14 | | IC | 5 | U3; U7; U21; U24; U28 |
| SOP16 | SMD_SOP16 | | IC | 2 | U4; U6 |
| SOT23-5 | SMD_SOT23-5 | | IC | 2 | U36; U37 |
| SOT23-BCE | SMD_SOT23-BCE | | DISCRETE | 8 | Q12; Q15; Q16; Q30; Q32; Q34; Q36; Q39 |
| SOT23-GDS | SMD_SOT23-GDS | | DISCRETE | 5 | Q9; Q11; Q14; Q19; Q31 |
| SOT223-123 | SMD_SOT223-123 | | DISCRETE | 1 | Q38 |
| SOT223-BCE | SOT223-BCE | | IC | 1 | Q17 |
| SSOP28 | SSOP28 | | IC | 1 | U5 |
| SSOP48 | SMD_SSOP48 | | IC | 1 | U19 |
| TO92-123 | DIP_TO92-123 | | DISCRETE | 1 | Q24 |
| TO92-RAC | TO92-RAC | | IC | 1 | Q8 |
| TO252-GDS | SMD_TO252-GDS | | DISCRETE | 3 | Q21; Q28; Q37 |
| TO263AB-GDS | SMD_TO263AB-GDS | | DISCRETE | 7 | Q1; Q2; Q3; Q4; Q5; Q6; Q7 |
| TQFP48 | SMD_TQFP48 | | IC | 1 | U17 |
| TSSOP20 | SMD_TSSOP20 | | IC | 2 | U8; U38 |
| WOL | DIP_CONN-WOL_1X3P | | IO | 1 | J4 |
| XTAL_49US | DIP_XTAL_49US | | DISCRETE | 3 | Y1; Y2; Y3 |
| XTAL_CYLINDER | DIP_XTAL_CYLINDER | | DISCRETE | 1 | Y4 |
| ZIF478 | SMD_ZIF478 | | IC | 1 | U11 |
附件:
