查看: 2595|回复: 22
[allegro16.6][6层] nxp 电信级网关芯片LS1043参考板(PLS1043ASE7QQA+RTL8211FS+6...
发表于 2020-2-5 18:56 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][6层] nxp 电信级网关芯片LS1043参考板(PLS1043ASE7QQA+RTL8211FS+6V49205BNLGI)pcb文件, Y; |* ]6 j' ]: F
3 c; C% D; U  n# h1 c文件描述:
# F8 b1 s7 W7 ]9 C2 Q
8 l: l; L/ S. N3 M# R3 k0 u1 }0 z# q9 c1. 作品用途: nxp 电信级网关芯片LS1043参考板0 q0 y& v5 _' `+ w$ {0 X
2. 软件版本:allegro16.66 ]9 L! [. g5 h; f3 |8 {
3. 层数:6层
# ~% N& M2 e) i1 B1 s4. 用到的主要芯片:PLS1043ASE7QQA+RTL8211FS+6V49205BNLGI! c) i! w5 f6 h9 x6 f% }0 ?! a' j
5. pcb尺寸: 6693*6693 MIL
- B8 I( ^* Y' s/ n4 e3 t% ]
; W8 [0 `- u, U* i2 X; D# C+ `作品截图如下:$ c) D8 C+ R+ _3 ]/ q+ T: z/ H! x
: c) Y4 z. e# k4 C$ D
顶层截图:
4 o+ w+ E6 }0 N% d) G/ u
/ ]( J' j" J- Z& y- `% I底层截图:
: |8 t2 h+ ]4 r: t1 m( a
  {" p/ c; f+ C4 G+ R, u9 x  X5 t" j* c2 m8 [
全层截图:
7 G: U% t; c8 k 4 d( m/ p; _$ C( S' }
0 _6 d$ q9 Y& L8 [叠层阻抗信息如下:
9 K% o, M, `# k! L
; w* u! p3 W) ]BOM:2 ^2 V; s% ~" g" g. p
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
1812FUSE_RESETTABLE_1812_IC_1.25MM_2.6AIC2F1; F2
AQFN138_0P65_12X12_EPVSC8514_QFN_138P_AQFN138_0P65_1VSC8514_QFNIC1U10
BGA68_1P27_9X15MMLTM4649EY-BGA68_BGA68_1P27_9X15LTM4649IC1U18
BGA77_1P27_15X9MMLTM4644_BGA_77P_BGA77_1P27_15X9LTM4644IC1U13
BGA256_1MM_17X17LCMXO1200C-3FTN256C_BGA256_1MM_LCMXO1200C-3FTN256CIC1U27
BGA324_1MM_19X19MM_C019SAQR105_BGA324_BGA324_1MM_19X19MAQR105-B1IC1U9
BGA_621_0P8_21X21LS1043_BGA621_REVF_BGA_621_0P8_PLS1043ASE7QQAIC1U29
CASE_H_ALCAP_POL_CASE_H_AL_DISCRETE_10.5330uFDISCRETE1C32
CC0201CAP_NP_CC0201_DISCRETE_0.33 MM_0.01UFDISCRETE14C152; C153; C156; C158; C159; C161; C165; C168; C351; C640; C654; C655; C656; C657
CC0201CAP_NP_CC0201_DISCRETE_0.33MM_10.1UFDISCRETE89C417; C422; C423; C424; C426; C427; C428; C430; C431; C432; C433; C435; C436; C437; C438; C439; C441; C442; C443; C444; C445; C454; C455; C456; C457; C462; C470; C471; C472; C473; C474; C477; C478; C479; C480; C482; C486; C488; C489; C490; C492; C493; C494; C495; C496; C497; C501; C504; C507; C509; C510; C512; C513; C514; C516; C520; C521; C523; C526; C527; C528; C529; C530; C531; C532; C533; C534; C540; C541; C542; C544; C545; C551; C552; C554; C557; C558; C560; C561; C562; C565; C570; C571; C572; C573; C651; C652; C653; C658
CC0201CAP_NP_CC0201_DISCRETE_0.33MM_21500PFDISCRETE14C429; C440; C463; C481; C483; C498; C499; C500; C505; C506; C515; C517; C518; C535
CC0201CAP_NP_CC0201_DISCRETE_0.33MM_31uFDISCRETE4C453; C469; C476; C538
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.56M1000PFDISCRETE2C1; C41
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_50.1UFDISCRETE54C2; C54; C55; C56; C57; C58; C61; C70; C71; C72; C79; C80; C157; C160; C163; C164; C166; C167; C171; C172; C175; C176; C181; C182; C183; C190; C191; C193; C194; C214; C216; C230; C231; C232; C233; C234; C241; C242; C248; C253; C254; C262; C263; C275; C287; C291; C305; C330; C353; C358; C359; C365; C372; C373
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6350.01uFDISCRETE9C10; C302; C303; C304; C310; C311; C312; C338; C414
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_2470pFDISCRETE2C12; C13
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_32.2UFDISCRETE50C14; C16; C17; C18; C184; C185; C186; C187; C195; C196; C197; C198; C199; C200; C202; C203; C204; C205; C213; C225; C226; C227; C228; C244; C245; C246; C247; C249; C256; C257; C258; C259; C264; C265; C266; C267; C279; C280; C281; C282; C288; C289; C290; C293; C294; C295; C296; C297; C298; C299
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.552.2uFDISCRETE2C15; C673
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_5680pFDISCRETE1C19
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_10.1UFDISCRETE157C23; C24; C25; C26; C27; C28; C82; C87; C90; C105; C109; C117; C118; C119; C122; C124; C125; C126; C129; C130; C131; C132; C133; C148; C149; C150; C151; C169; C170; C173; C174; C177; C178; C179; C180; C208; C209; C211; C212; C217; C218; C219; C220; C221; C222; C236; C240; C251; C252; C269; C270; C271; C272; C273; C274; C314; C315; C318; C321; C324; C348; C349; C352; C354; C356; C357; C360; C361; C362; C364; C366; C369; C370; C371; C374; C376; C378; C379; C380; C381; C383; C387; C390; C391; C392; C393; C395; C398; C447; C448; C449; C450; C451; C452; C487; C502; C503; C508; C511; C519; C522; C524; C536; C537; C543; C567; C568; C577; C589; C590; C592; C593; C596; C599; C600; C607; C613; C614; C615; C616; C617; C618; C619; C620; C621; C626; C627; C628; C629; C630; C631; C633; C634; C635; C636; C637; C638; C639; C641; C642; C643; C644; C645; C646; C647; C648; C649; C650; C668; C669; C670; C671; C672; C674; C676; C756; C757
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_41.0UFDISCRETE20C31; C34; C66; C85; C92; C154; C155; C235; C284; C285; C286; C334; C355; C363; C367; C386; C421; C632; C675; C677
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_618PFDISCRETE2C33; C35
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_810PFDISCRETE1C39
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_90.1uFDISCRETE9C50; C51; C52; C75; C76; C88; C375; C556; C755
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_72.2uFDISCRETE11C62; C84; C339; C350; C413; C418; C420; C466; C467; C549; C553
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_71.0UFDISCRETE10C74; C89; C377; C382; C384; C388; C394; C397; C399; C400
CC0402_25CAP_NP_CC0402_25_DISCRETE_0._156.8PFDISCRETE2C77; C78
CC0402_25CAP_NP_CC0402_25_DISCRETE_0._160.22uFDISCRETE1C91
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6MM1.0UFDISCRETE4C93; C110; C576; C595
CC0402_25CAP_NP_CC0402_25_DISCRETE_0._120.47uFDISCRETE4C94; C578; C598; C601
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_10.01UFDISCRETE2C99; C111
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_322PFDISCRETE14C134; C135; C136; C137; C138; C139; C140; C141; C142; C143; C144; C145; C146; C147
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_40.1uFDISCRETE11C162; C201; C206; C229; C243; C250; C255; C316; C317; C327; C332
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_222PFDISCRETE1C238
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M100pFDISCRETE1C268
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_80.022UFDISCRETE3C346; C415; C564
CC0402_25CAP_NP_CC0402_25_DISCRETE_0._103000pFDISCRETE7C410; C412; C419; C461; C468; C539; C559
CC0402_25CAP_NP_CC0402_25_DISCRETE_0._112.2UFDISCRETE1C411
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_91.0UFDISCRETE8C622; C623; C624; C625; C663; C664; C665; C666
CC0402_25CAP_NP_CC0402_25_DISCRETE_0._140.1uFDISCRETE3C759; C760; C763
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9 M4.7uFDISCRETE11C20; C95; C96; C123; C128; C475; C547; C602; C603; C604; C761
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_122UFDISCRETE17C44; C45; C97; C98; C100; C101; C102; C103; C104; C106; C107; C108; C112; C113; C114; C115; C416
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_210uFDISCRETE17C53; C65; C67; C81; C224; C239; C260; C261; C319; C320; C340; C425; C434; C465; C491; C546; C555
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.95M4.7uFDISCRETE8C207; C210; C277; C278; C306; C307; C308; C309
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.87M1000PFDISCRETE1C389
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_14.7uFDISCRETE7C587; C588; C591; C594; C597; C605; C606
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM1000pFDISCRETE1C3
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_322uFDISCRETE11C6; C9; C237; C276; C313; C329; C341; C342; C343; C344; C345
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_147UFDISCRETE13C21; C46; C47; C48; C49; C59; C60; C189; C292; C325; C326; C464; C548
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4547uFDISCRETE3C36; C37; C38
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_422UFDISCRETE25C64; C68; C396; C401; C404; C405; C406; C407; C408; C409; C458; C484; C550; C566; C569; C574; C575; C579; C580; C581; C582; C583; C584; C585; C586
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UFDISCRETE16C83; C188; C368; C525; C563; C609; C610; C611; C612; C659; C660; C661; C662; C667; C762; C764
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_247UFDISCRETE1C215
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_522UFDISCRETE1C446
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_622uFDISCRETE3C459; C460; C485
CC1206_OVCAP_NP_CC1206_OV_DISCRETE_1.9 M100UFDISCRETE11C69; C127; C192; C300; C301; C331; C333; C335; C336; C337; C347
CC7343CAP_POL_CC7343_DISCRETE_4.3MM_1100UFDISCRETE2C40; C86
CC7343-31CAP_POL_CC7343-31_DISCRETE_2.1M470uFDISCRETE2C121; C385
CON5_USB_B_UBBUSB_MINI_B_SKT_CON5_USB_B_UBB_IUSB MINI-BIO1J20
CON19_RJ-45_LED_80MIL_TH_RACON_RJ45_19P_CON19_RJ-45_LED_80RJ45-19IO1J3
CON28_SD_MMC_SM_29P4X16P6MMSD_MMC_CARD_28P_CON28_SD_MMC_SM5911M50001-LFIO1J21
CONN2X20_20X7MM_PCI_EXTCONN_SOCKET_20X2_CONN2X20_20X7MCONN MICRO EDGE 2x20IO1J11
CON_2RH_10_50CONN_HDR_5X2_CON_2RH_10_50_IO_3HDR 2X5IO1J18
CON_2X26_0P8_SMTMINI_PCI_LATCH_52P_CON_2X26_0P8CON 2X26 MINI PCI EXPRESSIO1P5
CON_18P_USB3_RA_THGSB311231HR_USB18P_CON_18P_USB3GSB311231HRIO1J2
CON_RJ45_2X1_MAG_LEDRJ45_MAG_2X1_LED_CON_RJ45_2X1_MRJ45 13X2PORTSIO3P1; P2; P3
CON_RJ45_16F_50_TH_RACONN_RJ45_STACKED_16P_CON_RJ45_5569381-1IO1J4
DFN6_0P5_3X2_EPLT3085EDCB_6P_DFN6_0P5_3X2_EP_ILT3085IC2U15; U30
DFN10LTC3568IDD_PBF_10_DFN10_IC_0.8MLTC3568IC1U8
DFN_14SP3011_DFN_14P_DFN_14_IC_0.55MMSP3011IC2U3; U4
DIODE_BIDIR_0402DIODE_TVS_BIDIR_DIODE_BIDIR_040SESD0402X1BNIC13TVS1; TVS2; TVS3; TVS4; TVS5; TVS6; TVS7; TVS8; TVS9; TVS10; TVS11; TVS12; TVS13
FBGA78_0P8_9X11P5MT40A512M8_FBGA78_0P8_9X11P5_ICMT40A512M8IC4U37; U38; U39; U40
HDR1X3_THHDR_1X3_HDR1X3_TH_IO_12.04MM_21HDR 1X3IO1J17
HDR102HDR_SHRD_2X1_HDR102_IO_9.45MM_2HDR 1X2IO2J5; J6
HDR102_TMMCONN_HDR_1X2_HDR102_TMM_IO_7.51X2IO4J10; J12; J13; J14
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3IO1J22
HDR106_TH_TSWCONN_HDR_6X1_HDR106_TH_TSW_IO_8HDR 1X6IO1J8
HDR205_10M_50_SMCONN_HDR_5X2_HDR205_10M_50_SM_IFTSH-105-01-L-DVIO1J16
IND2_4P3SQ_XFL4020INDUCTOR_IND2_4P3SQ_XFL4020_DIS1uHDISCRETE2L24; L25
IND2_XFL3010INDUCTOR_IND2_XFL3010_DISCRETE_1uHDISCRETE2L26; L27
IND4_CHOKE_0805DLW43_IND4_CHOKE_0805_DISCRETE_90OHMDISCRETE3L12; L13; L38
IND_0402INDUCTOR_IND_0402_DISCRETE_0.551000OHMDISCRETE8L3; L4; L6; L7; L8; L9; L10; L11
IND_0603BEAD_FERRITE_IND_0603_DISCRETE_120OHMDISCRETE8F4; F5; F6; L21; L28; L29; L39; L40
IND_0603BEAD_FERRITE_IND_0603_0.95MM_18120OHMDISCRETE2L5; L14
IND_0603IND_IND_0603_DISCRETE_0.65MM_18100 OHM@100MHZDISCRETE6L16; L20; L23; L35; L36; L37
IND_0603BEAD_IND_0603_DISCRETE_0.95MM_1600OHMDISCRETE1L22
IND_0603ABEAD_FERRITE_IND_0603A_DISCRETEBLM18KG121TN1DISCRETE6F3; F7; F8; F11; F12; F13
IND_0805BEAD_IND_0805_DISCRETE_1.05MM_1MPZ2012S101ADISCRETE1L19
IND_0805BEAD_IND_0805_DISCRETE_1.05MM_2600 OHMDISCRETE2L33; L34
IND_742792021INDUCTOR_IND_742792021_DISCRETE22 OHMDISCRETE2L31; L32
IND_DLW5BS_2020DLW43_IND_DLW5BS_2020_DISCRETE_DLW5BTM251TQ2DISCRETE1L30
IND_NFE31PNFE31P_IND_NFE31P_DISCRETE_1.75NFE31PT222Z1E9LDISCRETE2L1; L2
IND_SPH2020INDUCTOR_IND_SPH2020_DISCRETE_12.2uHDISCRETE2L17; L18
IND_SPH2520INDUCTOR_IND_SPH2520_DISCRETE_11.5UHDISCRETE1L15
LED2_2P54_6P6X4P3MMLED_LED2_2P54_6P6X4P3MM_IC_7.55LED_YELIC1D12
LED2_2P54_6P6X4P3MMLED_LED2_2P54_6P6X4P3MM_IC_7._1LED_GRNIC1D13
LED4_2P54_9P3X4P5MMLED_DUAL_SEP2_YG_LED4_2P54_9P3XLED GRN/YLWIC7D5; D6; D7; D8; D9; D10; D11
LED_0603LED_LED_0603_IC_0.67MM_370-7656LED GREENIC3D1; D3; D4
LED_0603LED_LED_0603_IC_0.8MM_370-75083LED REDIC1D2
LQFP64MK22FX512_LQFP_64P_LQFP64_IC_1.MK22FX512VLH12IC1U42
MLP8_1P27_8X6N25Q128A13EF840E_9P_MLP8_1P27_8N25Q128A13EF840EIC1U32
MSO8ADT7461_MSO8_IC_1.1MM_315-75543ADT7461IC1U45
MSOP_10_0P5_3X3INA220AIDGST_MSOP_10_0P5_3X3_ICINA220AIDGSTIC1U47
MTG156_PTHMOUNT_HOLE_MTG156_PTH_IC_0.05MMMOUNTING HOLEIC4BH1; BH2; BH3; BH4
OSC6_7P5X5_SMOSC_6P_D_OSC6_7P5X5_SM_IC_1.55M156.25MHzIC1Y2
PCI_36_EXPRESS_CONN_THPCI EXPRESS X1_PCI_36_EXPRESS_CPCI EXPRESS 36IO1P4
PJ-102AHDC POWER JACK_PJ-102AH_IO_11MM_CON_1_PWRIO1J1
PQFN16_0P4_2P65X1P85TXBN0304_QFN16_PQFN16_0P4_2P65XTXBN0304RSVRIC1U19
PQFN16_0P4_2P65X1P85SN74AVC4T774RSVR_16P_PQFN16_0P4SN74AVC4T774RSVRIC1U49
QFN32_5X5831724KILFT_VFQFN_32P_QFN32_5X5831724KILFTIC1U25
QFN48_0P5_7X7_TAB5P656V49205BNLGI_QFN_48P_QFN48_0P5_6V49205BNLGIIC1U24
QFN56_0P5_8X8_EP4P1X4P4MC34VR500V1ES_56P_QFN56_0P5_8X8PC34VR500V4ESIC1U33
QFN_48_0P4_6X6MMRTL8211_48P_QFN_48_0P4_6X6MM_ICRTL8211FSIC2U11; U12
QSOP16PI3B3257_QSOP_16P_QSOP16_IC_1.7PI3B3257QEIC2U20; U21
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_4330DISCRETE11R1; R14; R16; R37; R145; R189; R372; R408; R409; R430; R459
RC0402_25RES_RC0402_25_DISCRETE_0.45 MM_0DISCRETE41R2; R3; R4; R32; R33; R38; R39; R71; R72; R114; R115; R117; R161; R247; R249; R251; R253; R256; R258; R269; R270; R271; R272; R273; R274; R328; R329; R330; R331; R332; R333; R335; R337; R338; R339; R340; R342; R343; R493; R495; R499
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_9100KDISCRETE6R5; R17; R18; R268; R295; R358
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__84.7KDISCRETE28R6; R42; R50; R52; R57; R58; R59; R60; R61; R63; R64; R65; R66; R81; R82; R84; R87; R88; R243; R244; R246; R248; R255; R259; R263; R264; R266; R294
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_4100DISCRETE4R8; R9; R116; R498
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_472.0KDISCRETE1R10
RC0402_25RES_RC0402_25_DISCRETE_0.4 MM_4200 OHMDISCRETE8R13; R21; R23; R24; R211; R212; R213; R214
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_623.2KDISCRETE1R15
RC0402_25RES_RC0402_25_DISCRETE_0.40 _103.32KDISCRETE1R22
RC0402_25RES_RC0402_25_DISCRETE_0.45 M_10DISCRETE9R26; R30; R47; R75; R228; R229; R232; R236; R238
RC0402_25RES_RC0402_25_DISCRETE_0.40 _16412KDISCRETE1R27
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__94.7KDISCRETE5R29; R334; R341; R352; R451
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0KDISCRETE27R34; R76; R77; R103; R118; R149; R164; R190; R310; R311; R319; R461; R462; R463; R471; R474; R475; R476; R477; R480; R481; R482; R483; R485; R486; R487; R488
RC0402_25RES_RC0402_25_DISCRETE_0.40 _222.49KDISCRETE2R35; R36
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__74.7KDISCRETE8R40; R43; R55; R68; R191; R235; R237; R472
RC0402_25RES_RC0402_25_DISCRETE_0.40 _2626.1DISCRETE2R45; R46
RC0402_25RES_RC0402_25_0.45 MM_470-753940DISCRETE1R54
RC0402_25RES_RC0402_25_DISCRETE_0.4 MM_710KDISCRETE4R56; R70; R78; R96
RC0402_25RES_RC0402_25_0.4 MM_470-30454_100DISCRETE1R62
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_24.7KDISCRETE6R79; R89; R90; R91; R92; R102
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__52.0KDISCRETE4R93; R148; R281; R375
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__60DISCRETE8R94; R95; R157; R162; R165; R166; R192; R469
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_133DISCRETE4R97; R98; R327; R503
RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_110DISCRETE3R101; R127; R129
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_156DISCRETE4R105; R106; R123; R497
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_275DISCRETE1R109
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_34.7KDISCRETE71R111; R113; R144; R146; R275; R277; R279; R283; R286; R289; R292; R296; R304; R305; R306; R308; R313; R317; R354; R355; R357; R360; R368; R369; R373; R376; R377; R379; R381; R383; R386; R387; R390; R391; R394; R397; R398; R399; R401; R403; R404; R406; R407; R410; R412; R415; R417; R419; R420; R421; R422; R423; R424; R426; R429; R431; R433; R434; R435; R436; R437; R439; R440; R444; R447; R452; R454; R457; R473; R484; R496
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__249.9DISCRETE6R121; R125; R142; R143; R345; R346
RC0402_25RES_RC0402_25_0.4MM_470-76090_110DISCRETE10R124; R130; R134; R135; R136; R137; R138; R139; R140; R141
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_482DISCRETE2R126; R128
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__3475DISCRETE1R131
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__433DISCRETE5R132; R133; R428; R489; R490
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_5150KDISCRETE1R147
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_768KDISCRETE2R154; R155
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_839DISCRETE30R167; R168; R169; R170; R171; R172; R173; R174; R175; R177; R178; R179; R180; R181; R182; R183; R184; R185; R186; R187; R188; R193; R194; R195; R196; R197; R198; R199; R200; R396
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_1220DISCRETE8R217; R218; R219; R220; R221; R222; R223; R224
RC0402_25RES_RC0402_25_0.41MM_470-75626_4.7KDISCRETE1R227
RC0402_25RES_RC0402_25_DISCRETE_0.40 _118.25KDISCRETE1R231
RC0402_25RES_RC0402_25_DISCRETE_0.40 _12324KDISCRETE1R241
RC0402_25RES_RC0402_25_DISCRETE_0.40 _13887KDISCRETE1R242
RC0402_25RES_RC0402_25_DISCRETE_0.4 MM_16.65KDISCRETE1R245
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_51KDISCRETE31R254; R276; R278; R280; R284; R287; R290; R293; R297; R307; R314; R370; R374; R378; R384; R385; R388; R395; R400; R405; R411; R416; R425; R427; R432; R438; R448; R449; R455; R456; R458
RC0402_25RES_RC0402_25_DISCRETE_0.40 _141.96KDISCRETE1R260
RC0402_25RES_RC0402_25_DISCRETE_0.40 _15143KDISCRETE1R267
RC0402_25RES_RC0402_25_DISCRETE_0.40 _1760.4KDISCRETE3R282; R285; R356
RC0402_25RES_RC0402_25_DISCRETE_0.40 _18210KDISCRETE1R288
RC0402_25RES_RC0402_25_DISCRETE_0.40 _19604DISCRETE2R291; R351
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_1010DISCRETE8R298; R300; R362; R364; R366; R367; R491; R492
RC0402_25RES_RC0402_25_DISCRETE_0.4 MM_215KDISCRETE1R299
RC0402_25RES_RC0402_25_DISCRETE_0.4 MM_31DISCRETE4R301; R302; R303; R316
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_110DISCRETE10R309; R312; R315; R318; R347; R348; R380; R389; R441; R445
RC0402_25RES_RC0402_25_DISCRETE_0.4 MM_5200DISCRETE4R322; R323; R324; R353
RC0402_25RES_RC0402_25_DISCRETE_0.40 _2168DISCRETE2R336; R344
RC0402_25RES_RC0402_25_DISCRETE_0.40 _2340.2KDISCRETE1R359
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_121.5KDISCRETE1R363
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_13330 OHMDISCRETE1R365
RC0402_25RES_RC0402_25_DISCRETE_0.40 _245.1DISCRETE4R371; R382; R402; R418
RC0402_25RES_RC0402_25_DISCRETE_0.4 MM_6200DISCRETE1R392
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_140.33 OHMDISCRETE2R393; R414
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_15698DISCRETE1R413
RC0402_25RES_RC0402_25_DISCRETE_0.40 _25162DISCRETE2R442; R443
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_161.0KDISCRETE1R453
RC0402_25RES_RC0402_25_DISCRETE_0.40 _27240DISCRETE4R464; R465; R466; R467
RC0402_25RES_RC0402_25_DISCRETE_0.40 _2836DISCRETE2R468; R470
RC0402_25RES_RC0402_25_0.4MM_470-75416_110.0KDISCRETE2R478; R479
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 M_12.0KDISCRETE1R25
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 M_2330DISCRETE1R69
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470DISCRETE10R73; R74; R225; R226; R233; R234; R239; R240; R501; R502
RC0603_OVRES_RC0603_OV_DISCRETE_0.5 MM_4620DISCRETE1R80
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_410KDISCRETE3R156; R160; R163
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_11KDISCRETE2R159; R460
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 MM_330DISCRETE12R201; R202; R203; R204; R205; R206; R207; R208; R209; R210; R215; R216
RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0KDISCRETE2R153; R158
RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_40DISCRETE3R325; R326; R361
RC1206_OVRES_RC1206_OV_DISCRETE_0.75MM_41.0MDISCRETE1R7
RES4_7P1X6P9_SMRES_4PIN_RES4_7P1X6P9_SM_DISCRE0.001DISCRETE1R110
SC-701G126_SC-70_IC_1.1MM_312-78261_SN74LVC1G126IC1U23
SKT_BAT_225X886_3VBATTERY_SKT_3V_SKT_BAT_225X886_WBA-3B2 UIC1BT1
SO8MMDF4N01HD_SO8_IC_1.75 MM_312-3NTMD6N02R2IC3Q2; Q3; Q4
SO8_1P27_4X5MX25V4006E_8P_SO8_1P27_4X5_IC_1MX25V4006EIC1U7
SO8_PAKFDMS6681Z_SO8_PAK_IC_1.10MM_480FDMS6681ZIC1Q5
SOD123ZDIODE_SOD123_IC_1.35MM_480-776MMSZ5245BIC1D14
SOT23-40X40DUALDIODE_CC_SOT23_SHTKY_SOT23-BAT54C-7-FIC1D15
SOT23_AMOSFET_N_SOT23_A_IC_1.11MM_480-MGSF2N02ELT1GIC1Q1
SOT23_ADIODE_2LINE_ESD_SOT23_A_IC_1.15GSOT05C-GS08IC1U43
SOT143-25X60MAX811_SOT143-25X60_IC_1.22 MM_MAX811IC1U1
SSOP8_DCUPCA9306DCUR_SSOP8_DCU_IC_0.9MM_PCA9306DCURIC1U14
SSOP8_DCUSN74LVC2T45DCUT_8P_SSOP8_DCU_ICSN74LVC2T45IC3U35; U36; U41
SSOP1474-125_14P_SSOP14_IC_2MM_312-7974LVC125ADBIC1U34
SSOP16SP3232E_SSOP16_IC_1.99MM_312-77SP3232IC2U5; U6
SW3_SLIDE_RA_THTS03ABE_SW3_SLIDE_RA_TH_IC_12.71101M2S3AV2QE2IC1SW2
SW_4P_7P1X15P8SW_TACT-SPST-2_SM1_SW_4P_7P1X15TL1105NF160QIC1SW1
SW_DIP16_8POS_SMSW_DIP_8_SW_DIP16_8POS_SM_IC_2.218-8LPSTIC3SW3; SW4; SW5
TDFN10_0P5_3P1X3P1MAX1558H_TDFN_10P_TDFN10_0P5_3PMAX1558HIC1U2
TDFN10_0P5_3P1X3P1LT3065_DFN10_TDFN10_0P5_3P1X3P1LT3065IC2U17; U46
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030IO20TP1; TP2; TP3; TP4; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21
TPAD_040TESTLOOP_TPAD_040_IO_0.1MM_211-TPAD_040IO1TP5
TSOP56_0P5_18_4X14_INMEM_FLASH_1GB_TSOP56_TSOP56_0P5MT28EW01GIC1U28
TSSOP8CAT24C04_SO8_TSSOP8_IC_1.2MM_33CAT24C05IC1U44
UQFN10_0P4_1P45X1P85PI3USB42ZME_10P_UQFN10_0P4_1P45PI3USB42ZMEIC1U16
USOP-8PT7C433833_MSOP_8P_USOP-8_IC_1.PT7C4338IC1U48
VFBGA63_0P8_9X11MT29F4G08ABBDAH4_VFBGA63_0P8_9XMT29F4G08ABBDAH4-ITXIC1U26
XO6_2P54_7X5MMXTAL_WX703_6P_XO6_2P54_7X5MM_IC125MHZIC1Y3
XTAL4_3P3X2P6_SM_FLXTAL_13Y_XTAL4_3P3X2P6_SM_FL_IC50MhzIC1Y1
XTAL4_3P3X2P6_SM_FLXTAL_13Y_XTAL4_3P3X2P6_SM_FL__125MHzIC1Y4
XTL2_ECS_SMXTAL_XTL2_ECS_SM_IC_8.84MM_230-32.768KHzIC1Y7
XTLOSC4_2P54_3P3X2P6CLKGEN-SM_XTLOSC4_2P54_3P3X2P6_32.768KHzIC1Y5
XTLOSC4_5X3MM_SMCRYSTAL_JXS63_XTLOSC4_5X3MM_SM_8MHZIC1Y6
附件:
; B4 b; N, I4 d+ dPCB文件如下:
/ [* x; H8 {, G- o. Q  X0 Q2 X$ U
游客,如果您要查看本帖隐藏内容请回复
4 s2 Y$ E' }6 J3 f8 W& u
    2025-11-26 15:28
  • 签到天数: 884 天
    [LV.10]以坛为家III
    发表于 2021-7-14 10:21 | 只看该作者
    dddddddddddddddddddddddd& i0 @; X! j; ^" p' c# J/ f
    发表于 2022-3-3 15:21 | 只看该作者
    very good, thanks a lot
    2024-8-26 15:16
    发表于 2021-7-12 10:18 | 只看该作者
    这个比较好,感谢分享4 i+ m/ G2 b! {* p5 {5 d
    发表于 2020-11-4 15:19 | 只看该作者
    能否给予参考,谢谢。
    & a- ?, }3 f& O4 ~( ~* Y( U
    2024-6-2 15:34
  • 签到天数: 120 天
    [LV.7]常住居民III
    发表于 2020-11-4 20:20 | 只看该作者
    非常感谢,好东西
    发表于 2020-12-11 21:22 | 只看该作者
    有源文件吗?
    “来自电巢APP”
    奋斗
    2021-11-30 15:19
  • 签到天数: 31 天
    [LV.5]常住居民I
    发表于 2021-4-9 16:10 | 只看该作者
    貌似很强大9 O, Y' ]. r/ M" N( r4 p
    擦汗
    2020-1-14 15:59
    发表于 2021-5-12 23:14 | 只看该作者
    看里面的参考设计' [" K- Q& W% V) r6 b% `, x
    14#
    发表于 2021-9-15 09:47 | 只看该作者
    看看学习学习
    16#
    发表于 2021-10-21 17:09 | 只看该作者
    能否给予参考,谢谢。5
    GMT+8, 2025-11-26 22:01 , Processed in 0.218750 second(s), 29 queries , Gzip On.
