查看: 1051|回复: 11
[allegro16.6][4层] 安防监控 摄像头(FH8610+MT9V139+MP2122)pcb文件
发表于 2020-2-4 17:00 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
7 D9 B7 G# A/ F( f7 W* s4 T
$ b/ j2 p6 f* b& O8 Q
  F% u: E2 Z5 B1 b5 G1 U文件描述:1 X1 Y+ V$ _3 l, u
0 s' ^) e) |1 D) |( A' j, k1 }1. 作品用途: 安防监控 摄像头
5 l4 E" j% `# G7 f; `$ `! K2. 软件版本:allegro16.6
5 G# d! @$ V( E3. 层数:4层
% c, _: Z( ?; {8 D+ y4. 用到的主要芯片:FH8610+MT9V139+MP2122) Z8 D/ H7 l" L" |: w, l0 s
5. pcb尺寸: 1574.804*1574.804 MIL
! B) p4 d+ F% o/ J
" H# Y8 s, W8 ]) G作品截图如下:
* @9 q. G# G. n* J. l) C
- K' n/ y( [5 F) N- b$ u8 o6 i$ n顶层截图:
9 L1 ^3 g) c1 r! v; @: O3 o # g9 T# V3 d. c& G
底层截图:4 Q  b: b( T+ L! U8 z% V
+ D, {; Y/ y# x9 p7 U
9 v( g  `! k7 o/ g全层截图:
5 b+ S! {0 R1 I+ N, k3 L& } 9 ~0 G& N8 e# l1 K. f, z8 v
' s8 i/ C$ h$ f
BOM:5 a! b/ `$ X6 ]+ m
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BGA63_065SENSOR_ARX550_2_BGA63_065_MT9V1MT9V139IC1U1
C0402CAPNP_0_C0402_20PF20pFIC1C1
C0402CAPNP_0_C0402_12PF12pFIC1C2
C0402CAP NP_C0402_0.1UF0.1uFIC39C3; C4; C5; C8; C9; C10; C11; C12; C13; C14; C17; C18; C19; C20; C21; C22; C23; C24; C25; C26; C27; C28; C29; C30; C31; C32; C33; C34; C35; C36; C39; C40; C42; C46; C47; C48; C51; C53; C57
C0402CAPNP_1_C0402_20PF20pFIC1C6
C0402CAPNP_1_C0402_12PF12pFIC1C7
C0402CAP NP_C0402_0.01UF0.01uFIC4C15; C43; C45; C54
C0402CAP NP_2_C0402_0.1UF0.1uFIC1C37
C0402C0603_1_C0402_0.1UF0.1uFIC1C49
C0402CAP NP_1_C0402_0.1UF0.1uFIC2C55; C61
C0402CAP NP_C0402_NCNCIC1C56
C0402CAP_1_C0402_2.2UF2.2uFIC1C59
C0402CAP_1_C0402_15NF15nFIC1C60
C0402CAP_1_C0402_8.2NF8.2nFIC1C62
C0402C0603_0_C0402_NCNCIC1C64
C1206CAP_0_C1206_4.7UF/10V4.7uF/10VIC2C16; C52
C1210CAP_0_C1210_22UF/10V22uF/10VIC2C41; C44
CRYSTAL-3X8CRYSTAL_0_CRYSTAL-3X8_32.768KHZ32.768KHzIC1Y2
DBV_RPDSOG5A52815_4_DBV_RPDSOG5_BU28TD3WGBU28TD3WGIC1U6
DY49SCRYSTAL_0_DY49S_24MHZ24MHzIC1Y1
L0603BEAD_L0603_BEADBEADIC5FB2; FB3; FB4; FB7; FB8
MHF_3PADBNC-5_1_MHF_3PAD_MHFMHFIC1J1
PC_LENS_SOCKET_20MMCMOS SENSOR OV9710-LEN_0_PC_LENLens Socket-17mmx17mmx20mmIC1J2
QFN68_THCMOS SENSOR OV9710-VL1A_65_QFN6FH8610IC1U2
R0402RES_4_R0402_1M1MIC1R1
R0402RES_4_R0402_10M10MIC1R2
R0402RESISTOR_0_R0402_NCNCIC1R3
R0402RESISTOR_0_R0402_10K10KIC7R4; R6; R9; R10; R11; R12; R13
R0402RESISTOR_0_R0402_1K1KIC1R5
R0402RESISTOR_0_R0402_100K100KIC2R7; R8
R0402RESISTOR_0_R0402_806K 1%806K 1%IC2R14; R15
R0402RESISTOR_0_R0402_182K 1%182K 1%IC1R17
R0402RESISTOR_0_R0402_825K 1%825K 1%IC1R18
R0402RES_1_R0402_10K10KIC2R19; R35
R0402RES_2_R0402_10K10KIC10R20; R21; R24; R25; R26; R27; R34; R36; R38; R39
R0402R0603_0_R0402_1M1MIC1R22
R0402R0603_2_R0402_10K10KIC1R23
R0402R0603_1_R0402_4.7K4.7KIC3R28; R43; R44
R0402RESISTOR_0_R0402_4.7K4.7KIC3R30; R31; R32
R0402R0603_1_R0402_100R100RIC4R33; R37; R41; R42
R0402RES_0_R0402_0R0RIC1R40
SE6MMCAP_SE6MM_100UF/16V100uF/16VIC1C63
SIP2_15MM4 HEADER_0_SIP2_15MM_2PIN_1.5MM2Pin_1.5mmIC1CN5
SIP2_125MM4 HEADER_0_SIP2_125MM_2PIN_1.252Pin_1.25mmIC1CN1
SIP2_127MM4 HEADER_0_SIP2_127MM_2PIN_1.272Pin_1.27mmIC1CN2
SIP3_125MMCON2_14_SIP3_125MM_3PIN_1.25MM3Pin_1.25mmIC1CN6
SIP4_125MMCON2_9_SIP4_125MM_4PIN_1.25MM4Pin_1.25mmIC1CN4
SIP10_125MMCON2_13_SIP10_125MM_10PIN_1.25M10Pin_1.25mmIC1CN3
SO8_200MIL14024_2_SO8_200MIL_W25Q32W25Q32IC1U3
SOD-123MAZ8056_0_SOD-123_DISCRETE_NCNCDISCRETE1D2
SOP8_127-620X500CS4334_0_SOP8_127-620X500_AZ620AZ6208BMIC1U5
SOT_23D_BAV70_0_SOT_23_BAV70BAV70IC1D1
SOT_23PNP BCE_0_SOT_23_2N39062N3906IC1Q1
SOT_23NPN BCE_0_SOT_23_2N39042N3904IC1Q2
SOT_23MQ_AF2301P_1_SOT_23_AF2301PAF2301PIC1Q3
SPT5B28INDUCTOR_SPT5B28_4.7UH4.7uHIC1L1
SPT5B28INDUCTOR_SPT5B28_2.2UH2.2uHIC1L2
TPTESTPOINT_0_TP_TESTPOINTTestPointIC2TP18; TP19
TPC30TESTPOINT_0_TPC30_TESTPOINTTestPointIC17TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17
TSOT23-8A52815_9_TSOT23-8_MP2122MP2122IC1U4
WIFI-135X13_DIPSN74LVC2T45_5_WIFI-135X13_DIP_BBL-W8782IC1U7
附件:
3 G2 y$ E/ E; L% g& A* X8 g0 }' nPCB文件如下:4 z" l  d8 d# D+ H' ^
游客,如果您要查看本帖隐藏内容请回复
2 c/ B! C$ H% \) y) W. P6 y# f: l3 l2 U2 {8 r5 s* [
    2021-7-30 15:37
  • 签到天数: 97 天
    [LV.6]常住居民II
    发表于 2021-2-14 15:26 | 只看该作者
    不错,学习了。- L( h$ F0 u2 Z
    发表于 2021-2-18 00:52 | 只看该作者
    Thanks for the sharing the file
    发表于 2021-2-24 10:50 | 只看该作者
    不错,学习了。
    发表于 2024-6-17 10:42 | 只看该作者
    谢楼主提供文件
    2024-6-17 15:02
    发表于 2024-6-17 11:54 | 只看该作者
    谢谢楼主共享,楼主好人啊
    2022-3-3 15:06
    发表于 2025-1-11 14:51 | 只看该作者
    感谢分享,学习学习。. z  E, q6 p7 K6 L( Y9 J
    擦汗
    2025-11-26 15:30
  • 签到天数: 225 天
    [LV.7]常住居民III
    发表于 2025-1-12 11:03 | 只看该作者
    不错,学习了。' C- [6 r# w% [* @
    , V  N+ K" l7 T6 B
    2025-8-12 15:01
  • 签到天数: 25 天
    [LV.4]偶尔看看III
    发表于 2025-7-14 18:15 | 只看该作者
    感谢分享,学习学习。
    发表于 2025-8-20 10:59 | 只看该作者
    66666666666666666666666666664 ]8 T) X) B3 u1 ^3 R# v/ W8 Z+ U
    GMT+8, 2025-11-26 22:21 , Processed in 0.171875 second(s), 27 queries , Gzip On.
