查看: 348|回复: 3
[allegro16.6][10层] MINNOWBOARDMAX-DUAL, Meet MinnowBoard MAX based on Atom ...
发表于 2020-2-3 18:51 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
# z: ~8 c8 Y9 Y[allegro16.6][10层] MINNOWBOARDMAX-DUAL, Meet MinnowBoard MAX based on Atom E3825使用FH8065301567311S R1RB的参考设计(BAYTRAIL_I+2片DDR+ISL95837HRZ-T)原理图和pcb文件
) N( q) j5 b7 U0 R+ S5 t% c+ m3 q9 p. K# d6 Q' h8 W5 `1 O
文件描述:. j! s& r3 Q6 a3 ?8 a* {# z
+ [+ Z( k' Y( b- s. b7 d! R- U) c5 Z9 K1. 作品用途:MINNOWBOARDMAX-DUAL, Meet MinnowBoard MAX based on Atom E3825使用FH8065301567311S R1RB的参考设计. t6 @0 Q1 C$ r( {
2. 软件版本:allegro16.6
$ [" v* ^* X( n! P7 D$ N6 l) y1 U3. 层数:10层
! h4 Q1 {) L" Q) z- a4 E1 b4. 用到的主要芯片:BAYTRAIL_I+2片DDR+ISL95837HRZ-T
+ {9 ^  g1 y& }/ c5. pcb尺寸: 3900*3700 MIL
/ A& w( X$ P8 j! c# ?. F5 {6 a+ |. ]9 B1 u3 K4 b0 L; T+ a+ S% t
作品截图如下:
  N  m+ o$ Y2 @7 q/ H4 v4 R7 c4 W. E4 t' v9 C
顶层截图:0 g7 x7 f* S% T5 I% {
5 z0 _4 s! c/ U底层截图:% ?1 r2 o1 @8 T  [
* Z) i) H1 {1 t4 ^& `; u
- D& Q4 ~9 v, y. @+ l3 G全层截图:6 q+ n9 w- l7 ], e; b, p5 \) x: U
& L2 i& p2 y( U  s) R
% ~1 ~3 I: Y8 a2 v: R( \BOM:
" P& Y$ [+ X# M
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
2-SMDXTAL-2P-32P768KHZ_145-0004789_232.768KHz, ABRACONIC1Y1
2-XFDFNESD-SOD-XFDFN_P_2-XFDFN_D5V0L1BD5V0L1B2LP-7BIC2D7; D9
6605814-6CONN_RJ45_MAGJACK_GIGABIT_66058RJ-45 GigabitIC1J8
BAT54_132_2BAT54A_2_BAT54_132_2_BAT54A-SBAT54A-SIC5D3; D4; D6; D11; D12
BAT54_132_2DIODE_DUAL_BAT54C-S_BAT54_132_2BAT54C-SIC3D5; D8; D10
BATT3_190X610BATTERY_2_BATT3_190X610_BATT HOBATT HOLDER, BS-1225-PCIC1BH1
BGA24_E5_P5_3X3TS3A27518EZQS_BGA24_E5_P5_3X3_TTS3A27518EZQSIC1U4
C0402C0402_C0402_0.1UF0.1uFDISCRETE65C1; C3; C4; C5; C17; C18; C20; C22; C38; C41; C65; C70; C82; C84; C85; C92; C93; C94; C96; C100; C104; C105; C112; C114; C122; C124; C131; C133; C139; C153; C154; C155; C158; C191; C192; C202; C203; C212; C234; C235; C237; C254; C275; C277; C287; C288; C289; C290; C291; C293; C300; C301; C306; C309; C311; C320; C323; C327; C329; C332; C337; C339; C343; C344; C345
C0402C0402_C0402_1.0UF1.0uFDISCRETE63C2; C26; C27; C33; C97; C113; C117; C160; C163; C170; C171; C172; C174; C181; C182; C183; C193; C194; C195; C196; C197; C198; C199; C200; C213; C214; C215; C216; C217; C218; C219; C220; C221; C222; C223; C236; C239; C242; C243; C244; C245; C246; C255; C256; C257; C258; C259; C260; C261; C262; C263; C264; C265; C266; C271; C272; C273; C274; C276; C285; C286; C292; C340
C0402C0402_C0402_150PF150pFDISCRETE2C9; C23
C0402CAP_0.1UF_X5R_0.3V_20% 0402_C040.01uFDISCRETE8C10; C11; C12; C13; C177; C178; C179; C180
C0402CAP NP_C0402_0.1UF0.1uFDISCRETE24C14; C15; C29; C30; C31; C32; C165; C167; C168; C210; C232; C346; C347; C348; C349; C350; C351; C352; C353; C354; C355; C356; C357; C375
C0402C0402_C0402_2200PF2200pFDISCRETE4C24; C229; C270; C296
C0402C0603_C0402_0.1UF0.1uFDISCRETE10C25; C60; C71; C72; C73; C136; C138; C283; C284; C307
C0402C0603_C0402_1.0UF1.0uFDISCRETE6C34; C37; C46; C116; C338; C341
C0402C0402_C0402_0.01UF0.01uFDISCRETE3C35; C47; C173
C0402C0402_C0402_0.022UF0.022uFDISCRETE2C40; C59
C0402C0402_C0402_18PF18pFDISCRETE2C42; C43
C0402CAP_3_C0402_1.0UF1.0uFDISCRETE1C44
C0402C0805_C0402_0.22UF0.22uFDISCRETE1C45
C0402C0402_C0402_1000PF1000pFDISCRETE4C48; C184; C189; C226
C0402C0402_C0402_10PF10pFDISCRETE3C49; C69; C374
C0402C-0805_1_C0402_0.1UF0.1uFDISCRETE15C50; C51; C52; C53; C54; C55; C56; C58; C166; C205; C206; C207; C208; C209; C231
C0402C-0805_1_C0402_1.0UF1.0uFDISCRETE1C57
C0402C0402_C0402_220PF220pFDISCRETE1C63
C0402C0402_C0402_330PF330pFDISCRETE2C64; C186
C0402C0402_C0402_22PF22pFDISCRETE2C106; C152
C0402C0402_C0402_27PF27pFDISCRETE5C119; C175; C176; C252; C253
C0402CAP_2.2UF_X5R_6.3V_10%_0402_C042.2uFDISCRETE2C149; C150
C0402C0402_C0402_33PF33pFDISCRETE2C185; C228
C0402C0402_C0402_560PF560PFDISCRETE2C187; C227
C0402C0402_C0402_470PF470pFDISCRETE1C188
C0402C0603_C0402_0.22UF0.22uFDISCRETE4C190; C204; C325; C342
C0402C0402_C0402_100PF100pFDISCRETE1C310
C0402C0402_C0402_3.3PF3.3PFDISCRETE1C331
C0402C0402_C0402_4700PF4700PFDISCRETE1C358
C0603CAP_10UF_X5R_20%_16V_0603_C060310uFDISCRETE29C6; C8; C19; C28; C95; C107; C115; C118; C151; C156; C159; C162; C230; C241; C247; C250; C251; C267; C299; C302; C324; C326; C335; C336; C359; C360; C361; C362; C367
C0603CAP_0.033UF_X7R_10%_25V_0603_C00.033uFDISCRETE4C36; C39; C61; C62
C0603CAP_0.47UF_X5R_10%_10V_0603_C060.47uFDISCRETE32C108; C109; C110; C111; C123; C125; C130; C132; C134; C135; C142; C143; C144; C145; C146; C147; C318; C319; C321; C322; C330; C333; C363; C364; C365; C366; C368; C369; C370; C371; C372; C373
C0603CAP_4P7UF_X5R_10%_10V_0603_C0604.7uFDISCRETE3C157; C238; C240
C0805C-0805_1_C0805_22UF22uFDISCRETE55C7; C21; C66; C67; C68; C74; C75; C78; C79; C80; C81; C83; C86; C88; C89; C90; C91; C98; C99; C101; C102; C103; C120; C121; C126; C127; C128; C137; C140; C141; C248; C249; C268; C269; C278; C279; C280; C281; C282; C294; C295; C297; C298; C303; C304; C305; C308; C312; C313; C314; C315; C316; C317; C328; C334
C0805C0805_C0805_22UF22uFDISCRETE4C164; C201; C224; C225
C1808CAP_150PF_1000V_0_C1808_150PF150pFDISCRETE1C16
C1808CAP_8200PF_1000V_10%_1_C1808_828200pFDISCRETE3C148; C161; C233
C1808CAP NP_0_C1808_8200PF8200pFDISCRETE2C169; C211
C7343CAP_POL_330UF_POLY_20%_2V_7343_330uFDISCRETE4C76; C77; C87; C129
CHOKE4_0805COM_CHOKE_90_OHM_CHOKE4_0805_ACACM2012-900IC4CHOKE1; CHOKE2; CHOKE3; CHOKE4
CHOKE_NLC252018_SMD_2PINDUCTOR IRON_1_CHOKE_NLC252018IND-4.7U-S-XIC1L8
CHOKE_PT5D1MM_SMDINDUCTOR_0R33M-PT5D1-SMD_CHOKE_0.33uHDISCRETE2L9; L10
CHOKE_PT6D2MM_SMD_2PCHOKE_2R2M-7D3X6D8-PT6D2-SMD_CHPIND-2.2U-SMD-0603-8A-MAGIC1L3
CHOKE_PT6D2MM_SMD_2PCHOKE_1R0M-7D3X6D8-PT6D2-SMD_CHPIND-1U-SMD-0603-11A-MAG-XIC1L11
CONN19_HDMI-1CONN_HDMI_TYPED_TH_CONN19_HDMI-microHDMI_THIC1P1
DFN6_3X3P3MMNCP606_LDO_500MA_DFN6_DFN6_3X3PNCP606IC1U20
DSBGA-8TXS0102YZP_DSBGA-8_TXS0102YZPTXS0102YZPIC2U5; U6
DSBGA-12TXS0104EYZT_DSBGA-12_TXS0104EYZTXS0104EYZTIC8U7; U10; U14; U15; U16; U17; U18; U19
ESOP8_W150_PT50-90X90NCT3012S_1_ESOP8_W150_PT50-90X9NCT3012S-XIC1U35
FB0603FB0805_FB0603_FB_120R_3AFB_120R_3AIC10FB1; FB2; FB4; FB5; FB11; L4; L5; L6; L12; L13
FB0603INDUCTOR_2_FB0603_FB_600R_1.3AFB_600R_1.3AIC1FB3
FB0603BEAD_0_FB0603_FB_120R_3AFB_120R_3AIC1FB6
FB0805FB_220OHMS_2A_0805_FB0805_BKP21BKP2125HS221-TIC2L1; L2
FBGA96_DDR3MICRON_MT41K256M16HA_FBGA96_DDRMICRON MT41K256M16HAIC4MEM1; MEM2; MEM3; MEM4
FCBGA-1170INTEL_ATOM_E3825_5_FCBGA-1170_BBAYTRAIL_IIC1CPU1
FCQFN16_RT7290A_NB669NB670_24V_REG_WLDO_QFN16_1_FCQFNB670IC1U13
FPC_4P10_R_1TPD4EUSB30_0_FPC_4P10_R_1_TPD4UTPD4USB30IC1U29
FUSE_0805FUSE_0_FUSE_0805_FUSE-2A-08-LR-FUSE-2A-08-LR-XIC1F1
HDR2X4HEADER 4X2_1_HDR2X4_HEADER 4X2HEADER 4x2IC1J1
HDR2X13HDR13X2_0P1_HDR2X13_HDR-26HDR-26IC1JP1
HSO8-F4-BMOSFET_NCH_30V_12A_HS08_0_HSO8-SK8603190LIC2U11; U12
LED_0603LED_LTST-C150GKT_1_LED_0603_DISLTST-C191TBKTDISCRETE2D1; D2
MTGH250C156D_PLMHOLE_MTGH250C156D_PL_MHOLEMHOLEIC4H1; H2; H3; H4
PQFN8FDMS3660S_DUAL_2_PQFN8_FDMS3660FDMS3660SIC2U31; U34
QFN21_NB675NB675GL-Z_0_QFN21_NB675_NB675-XNB675-XIC1U37
QFN32_PT04_NCP81102RTL8111GS_0_QFN32_PT04_NCP81102RTL8111GS-CG-XIC1LAN1
QFN40_PT04-92HD89C_1IC-QFN40_ISL95837HRZ_1_QFN40_PTISL95837HRZ-TIC1U27
R0402TB321611U520_1_R0402_0R00R0DISCRETE1FB12
R0402R0402_R0402_2K202K20DISCRETE21R1; R27; R44; R45; R47; R49; R52; R53; R54; R56; R57; R58; R111; R113; R115; R117; R171; R172; R177; R236; R257
R0402RES_10K0_1%_1/10W_0402_R0402_1010K0DISCRETE56R2; R13; R14; R28; R29; R30; R31; R55; R71; R75; R83; R84; R97; R102; R112; R114; R116; R118; R120; R123; R124; R133; R152; R163; R164; R165; R169; R170; R183; R189; R190; R191; R209; R210; R211; R219; R220; R221; R231; R237; R254; R260; R266; R267; R268; R276; R295; R296; R319; R323; R334; R335; R336; R337; R338; R339
R0402R0402_R0402_200R200RDISCRETE3R3; R90; R196
R0402R0402_R0402_4K704K70DISCRETE17R4; R23; R32; R33; R125; R126; R137; R138; R143; R144; R149; R282; R283; R310; R325; R326; R333
R0402R0402_R0402_0R00R0DISCRETE29R5; R18; R20; R22; R26; R36; R51; R59; R65; R66; R91; R98; R99; R103; R121; R122; R151; R178; R199; R227; R235; R243; R248; R261; R293; R300; R302; R306; R353
R0402R0402_R0402_1K001K00DISCRETE13R6; R7; R69; R87; R94; R134; R162; R186; R187; R253; R259; R278; R289
R0402RES_51R0_1%_0P1W_0402_R0402_51R51R0DISCRETE5R8; R9; R10; R19; R21
R0402R0402_R0402_22R022R0DISCRETE4R11; R12; R269; R270
R0402RES_1K00_1P0%_0P1W_0402_R0402_11K00DISCRETE3R15; R16; R17
R0402R0402_R0402_12K112K1DISCRETE3R24; R150; R225
R0402R0402_R0402_9K539K53DISCRETE1R25
R0402R0402_R0402_6K046K04DISCRETE1R34
R0402R0402_R0402_23K723K7DISCRETE1R35
R0402R0402_R0402_10R010R0DISCRETE5R37; R64; R81; R89; R320
R0402R0402_R0402_150R150RDISCRETE3R38; R39; R213
R0402RES_357R_1%_1/10W_0402_R0402_35357RDISCRETE1R40
R0402R0603_R0402_0R00R0DISCRETE15R41; R42; R43; R46; R48; R72; R73; R74; R127; R128; R129; R130; R192; R216; R354
R0402RES_100K_1%_1/10W_0402_R0402_10100KDISCRETE22R50; R82; R119; R147; R154; R155; R156; R157; R173; R174; R180; R182; R273; R274; R292; R299; R301; R303; R309; R322; R324; R340
R0402R0402_R0402_20K020K0DISCRETE5R60; R61; R161; R256; R279
R0402R0402_R0402_649R649RDISCRETE2R62; R249
R0402R0402_R0402_3K573K57DISCRETE1R63
R0402R0402_R0402_11K011K0DISCRETE2R67; R86
R0402R0402_R0402_1R001R00DISCRETE2R68; R88
R0402R0402_R0402_2K552K55DISCRETE1R70
R0402R0402_R0402_10M010M0DISCRETE1R76
R0402R0402_R0402_45R345R3DISCRETE2R77; R185
R0402R_0_R0402_1K001K00DISCRETE6R78; R208; R233; R234; R288; R321
R0402R_0_R0402_15K15KDISCRETE1R79
R0402R0402_R0402_2K612K61DISCRETE1R85
R0402R0402_R0402_2K322K32DISCRETE1R92
R0402R0402_R0402_3K323K32DISCRETE1R93
R0402R0402_R0402_1K911K91DISCRETE2R95; R96
R0402R0402_R0402_20R020R0DISCRETE2R100; R228
R0402R0402_R0402_16R916R9DISCRETE2R101; R201
R0402R0402_R0402_69R869R8DISCRETE4R104; R197; R223; R224
R0402R_0_R0402_2K492K49DISCRETE1R105
R0402R_0_R0402_330R330RDISCRETE1R106
R0402R_0_R0402_0R00R0DISCRETE3R107; R108; R232
R0402R0402_R0402_499K499KDISCRETE2R109; R110
R0402R0402_R0402_121K121KDISCRETE1R131
R0402R0402_R0402_143K143KDISCRETE1R135
R0402R0402_R0402_40K240K2DISCRETE1R136
R0402R0402_R0402_240R240RDISCRETE4R139; R140; R327; R332
R0402R0402_R0402_200K200KDISCRETE2R141; R206
R0402R0402_R0402_33K033K0DISCRETE2R142; R194
R0402RES_470_1/10W_5%_0402_R0402_4K74K75DISCRETE2R146; R148
R0402RES_27K4_1/16W_1%_0402_R0402_2727K4DISCRETE1R153
R0402RESISTOR_R0402_33R033R0DISCRETE7R158; R159; R160; R175; R176; R181; R308
R0402RES_0OHM_5%_1/16W_0402_0_R0402_0R0DISCRETE3R166; R167; R168
R0402RESISTOR_R0402_220R220RDISCRETE3R179; R207; R252
R0402R0402_R0402_402R402RDISCRETE4R184; R217; R218; R239
R0402R0402_R0402_1M001M00DISCRETE1R188
R0402R0402_R0402_2K702K70DISCRETE1R193
R0402R0402_R0402_169K169KDISCRETE1R195
R0402R0402_R0402_6K986K98DISCRETE2R198; R245
R0402R0402_R0402_3K603K60DISCRETE1R200
R0402R0402_R0402_18K718K7DISCRETE2R202; R244
R0402R0402_R0402_3K833K83DISCRETE2R203; R229
R0402R0402_R0402_1K241K24DISCRETE1R212
R0402R0402_R0402_47R547R5DISCRETE1R214
R0402R0402_R0402_4K024K02DISCRETE1R215
R0402R0402_R0402_37K437K4DISCRETE1R226
R0402R0402_R0402_49R949R9DISCRETE5R238; R240; R241; R242; R258
R0402R0402_R0402_80K680K6DISCRETE1R246
R0402R0402_R0402_30K030K0DISCRETE1R247
R0402R0402_R0402_3K013K01DISCRETE1R250
R0402R0402_R0402_73R273R2DISCRETE1R255
R0402R0402_R0402_NTC-10KNTC-10KIC2R262; R285
R0402R_0_R0402_1M001M00DISCRETE1R264
R0402R0402_R0402_NTC-470KNTC-470KIC2R272; R287
R0402R0402_R0402_23R223R2DISCRETE1R280
R0402R0402_R0402_162R162RDISCRETE1R281
R0402R0402_R0402_29R429R4DISCRETE1R284
R0402R0402_R0402_150K150KDISCRETE1R294
R0402R0402_R0402_30R030R0DISCRETE2R304; R305
R0402R_72_R0402_2K202K20DISCRETE1R307
R0402RES_36R0_1%_1/16W_0402_R0402_3636R0DISCRETE24R311; R312; R313; R314; R315; R316; R317; R318; R328; R329; R330; R331; R341; R342; R343; R344; R345; R346; R347; R348; R349; R350; R351; R352
R0603TB321611U520_1_R0603_0R000R00DISCRETE3FB7; FB9; FB10
R0603BEAD_2_R0603_0R000R00DISCRETE1FB8
R0603R0603_R0603_1R001R00DISCRETE1R80
R0603R0805_R0603_0R000R00DISCRETE6R204; R230; R263; R277; R286; R297
R0603R0603_R0603_0R000R00DISCRETE4R222; R251; R265; R275
R0603R1206_R0603_2R202R20DISCRETE2R271; R290
R0603R0603_R0603_4R704R70DISCRETE2R291; R298
R0805RES_0R01_1%_1/8W_0805_R0805_0R00R01DISCRETE1R145
R0805R0805_R0805_0R000R00DISCRETE1R205
R1206R1206_R1206_2R202R20DISCRETE1R132
RAPC712CONN_PWRJACK_RAPC712_0_RAPC712_RAPC712IC1J9
SATA_RASATA_HEADER_RA_0_SATA_RA_047080470804005IC1J3
SD-MICRO-SCHA5B0300MICROSD_CONN_BOTTOM_SD-MICRO-SCSCHA5B0200IC1P2
SHORT2-NMNPSHORT-NMNP_SHORT2-NMNP_SHORT-NMSHORT-NMNPIC4SP1; SP2; SP3; SP4
SIP2JUMPER1X2_0_SIP2_JUMPERJUMPERIC3J5; J6; J7
SIP6SIP6_RA_SIP6_SIP6_RASIP6_RAIC1J4
SM-7351-IND-0603111-1002735_SM-7351-IND-0603_DIFB_220R_2.2ADISCRETE1L7
SM-SW-SPST-4-4SW_B3F-1000_SM-SW-SPST-4-4_DISCB3F-1000DISCRETE1SW1
SMT-5177985-2CONN_5177985-2_SMT-5177985-2_515177985-2IC1J10
SO8-25X75TPS2066DR_SO8-25X75_TPS2066DRTPS2066DRIC1U32
SO8_W200MICRON_SPI_MEM_N25Q064A_SO8_W20MICRON N25Q064AIC1U3
SOP8_W150_PT50IC-SOP8_EEPROM_M24C02-WMN6TP_1_M24C02-WMN6TP-XIC1U33
SOP8_W150_PT50IRF9321-FET_P-CH_SOIC8_1_SOP8_WIRF9321IC1U36
SOP8_W150_PT50-104X120IC-SOP8_APL5933AKAI-TRG_SOP8_W1APL5933IC2U21; U24
SOP8_W150_PT50_3X2D5MMIC-SOP8_APL5912KAC-TRG_1_SOP8_WAPL5912KAC-TRGS-XIC1U38
SOT23-5SN74AUP1G34_DBV_SOT23-5_SN74AUPSN74AUP1G34IC1U1
SOT23-5SN74LVC1G14DBVR_SOT23-5_SN74LVCSN74LVC1G14DBVRIC3U25; U28; U39
SOT23-574LVC1G08_0_SOT23-5_74LVC1G08DB74LVC1G08DBVRIC2U26; U30
SOT23_3LBAV99_1_SOT23_3L_BAV99-7-F-S-XBAV99-7-F-S-XIC2Q2; Q9
SOT23_EBCMMBT3904_SOT23_EBC_MMBT3904MMBT3904IC1Q4
SOT23_GDS_2MOSFET_NCH_30V_3_5A_TSMT3_0_SOTRXR035N03IC3Q5; Q6; Q13
SOT23_GSD2N7002K_SOT23_GSD_2N7002K2N7002KIC5Q7; Q10; Q11; Q12; Q14
SOT23_GSDMOSFET_NCHAN_BSS138_SOT23_GSD_BBSS138IC1Q8
SOT-363MBT3904DW1T1G_0_SOT-363_MBT3904MBT3904IC2Q1; Q3
SSOP24_256P_222LSTPD12S016_24TSSOP_SSOP24_256P_2TPD12S016PWIC1U2
TP30-SMDTEST_PAD_2_TP30-SMD_TEST_PAD_1TEST_PAD_1IC11TP1; TP2; TP4; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24
TP30-SMDTEST_PAD_0_TP30-SMD_TEST_PAD_1TEST_PAD_1IC13TP3; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16
USB13_DUALUSB_LPP_LPUSB1013_3_USB13_DUAL_DUAL_USB_2.0_3.0IC1USB1
U_5_DRLTPD2E001DRL_1_U_5_DRL_TPD2E001TPD2E001IC1U23
U_6_DRYPROT_TPD4S012_3_U_6_DRY_TPD4S01TPD4S012IC2U8; U9
U_10_RSETPD6E001RSE_1_U_10_RSE_TPD6E001TPD6E001IC1U22
WALL2_100LSFAN_JUMPER1X2_WALL2_100LS_SIP2_SIP2_FANIC1J2
XTAL-FSX3M_4P_SMDXTAL-4P-25MHZ_145-0004792_XTAL-25.00MHzIC2Y2; Y3
& U4 w2 ~. @, e9 _9 C3 x附件:  \2 I. m" D; X* P+ A' p8 D3 R
原理图和pcb文件如下:
& _. M# R5 _7 z2 x- W: A- X
游客,如果您要查看本帖隐藏内容请回复
2 a+ J  w2 {) \: `3 I
    2025-11-26 15:08
  • 签到天数: 617 天
    [LV.9]以坛为家II
    发表于 2022-5-28 17:42 | 只看该作者
    下载看看,学习
    GMT+8, 2025-11-27 04:50 , Processed in 0.187500 second(s), 27 queries , Gzip On.
