作品名:[AD 10][4层]TDA8026 PCB和原理图共享下载
- ?4 f3 [; S o2 I2 |1 ]
: k# A+ f! Y+ h/ \9 q文件描述9 o' `7 y, W5 ]
1. 软件版本:AD 102 h; ^$ a% k2 c/ k5 j# L) {& [, @6 r
2. 层数:4层板
* ?: Q. t6 `, ~ J$ V$ `3. 用到的主要芯片:TDA8026
' z+ B6 ^2 G: }, S4. PCB尺寸:64.5mm*56.7mm
7 N- h% j( {7 j& O/ ?
, K5 ^& U, W/ u V作品截图如下:
3 P5 ?& a7 l6 h顶层截图:1 g m2 b5 h$ I" p! z9 r @0 ?
5 d( C7 f- ] K C' h- n
$ M2 D" e; q) W, I" c
底层截图:7 v. T" { `3 ], k# D
1 z: Y# ]' L( J7 U% K1 C& x
( D6 x" \* N- }3 F7 R; o全层截图:
9 v3 W: e9 X# N) I, L3 L4 m
# u4 @, ^- b, ^9 L/ O
2 a! W V# T) F5 l3 J, R* ?( }$ o
叠层信息截图如下:6 D8 `% _2 K$ O* w2 ^9 [
( T9 a4 W7 k' M3 ]; {
# d2 i' Y( o3 D( r- N2 v7 z
BOM:
8 |3 j% A6 k& g6 h5 s| Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | | 0.1uF | C1, C2, C6, C7, C8, C9, C10 | C0603 | 7 | | 1uF | C3 | C0603 | 1 | | 33uF/16V | C4, C11 | CET-B | 2 | | 10uF | C5 | C0805 | 1 | | IN5817 | D1 | SMA | 1 | | YE XIN KF-011 | J1 | IC_CARD_1 | 1 | | SAM/SIM_1 | J2, J3, J4, J5 | SIM-5 | 4 | | HEADER 10X2 | J6 | IDC20-1 | 1 | | CON2 | J7 | SIP2 | 1 | | JP_3 | JP1, JP2, JP3 | SIP3 | 3 | | JP_2 | JP4, JP5, JP6 | SIP2 | 3 | | 10uH | L1 | L-5.5X5.5 | 1 | | 1.5K | R1, R2 | R0603 | 2 | | 0R | R3, R6, R7, R8, R10, R12 | R0603 | 6 | | NC | R4, R17, R18 | R0603 | 3 | | 100K | R5, R9, R11, R13 | R0603 | 4 | | 33R | R14, R15 | R0603 | 2 | | 10K | R16 | R0603 | 1 | | VCC1 | TP1 | TP | 1 | | RST1 | TP2 | TP | 1 | | CLK1 | TP3, TP28 | TP | 2 | | IO1 | TP4, TP26 | TP | 2 | | C41 | TP5 | TP | 1 | | C81 | TP6 | TP | 1 | | VCC2 | TP7 | TP | 1 | | RST2 | TP8 | TP | 1 | | CLK2 | TP9, TP29 | TP | 2 | | IO2 | TP10, TP27 | TP | 2 | | VCC3 | TP11 | TP | 1 | | RST3 | TP12 | TP | 1 | | CLK3 | TP13 | TP | 1 | | IO3 | TP14 | TP | 1 | | VCC4 | TP15 | TP | 1 | | RST4 | TP16 | TP | 1 | | CLK4 | TP17 | TP | 1 | | IO4 | TP18 | TP | 1 | | VCC5 | TP19 | TP | 1 | | RST5 | TP20 | TP | 1 | | CLK5 | TP21 | TP | 1 | | IO5 | TP22 | TP | 1 | | SCL | TP23 | TP | 1 | | SDA | TP24 | TP | 1 | | IRQN | TP25 | TP | 1 | | TDA8026 | U1 | TFBGA64 | 1 |
" Z7 H+ ~0 W, C# n+ Q附件:( J. Q: \( Y& M% S2 l- v; q3 v$ t
原理图和PCB源文件如下:
+ j$ l$ J2 j2 z1 w4 k9 {
( R) F9 r \% P8 X3 p8 u0 m/ `1 c; `
