查看: 2154|回复: 22
[allegro16.6][4层] 24口网络交换机 (IP1826-D+IP108A+网口)pcb文件
发表于 2020-1-3 17:52 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
0 i/ G4 \+ ?& K, p$ V% ^[allegro16.6][4层] 24口网络交换机 (IP1826-D+IP108A+网口)pcb文件
2 o2 R4 q/ l6 p: O( T" X/ S$ Y# z  |( `: f, y9 \: A' z/ l) a
文件描述:" o; B% B- a3 O7 S' ]; ~  m$ d
9 y: [6 D6 R* j, r$ B2 }& E: ?1. 作品用途: 24口网络交换机" W0 K6 g# a5 _8 M
2. 软件版本:allegro16.6
! V2 g4 e  z4 L4 S9 Q% B' R1 B3. 层数:4层2 k, e0 N' q# A0 O% p$ g
4. 用到的主要芯片:IP1826-D+IP108A+网口
. i( a- L) a: Y# }9 P) u/ T5. pcb尺寸: 258.4*174MM
$ {! m# s( N1 q+ f* w  B7 g  `: Q0 w; |3 n! R
作品截图如下:
' q; @+ `# L% C% x  l3 C
5 O. ^1 n7 E6 |4 Y3 z顶层截图:
+ y. Y( P& x7 M/ J* T 5 `8 @2 {" F+ s- w/ t( X
底层截图:( H  s- W* }8 ~1 k) p
% ?" J3 @" \, B  {6 S6 m% ^. r
" X5 ^7 P# l" Z& y# B+ ]  s
全层截图:+ s1 Z  t  f) M; O! e! E
+ f! ^  P& |  m) S2 x* R
, K& M9 Z  @/ w$ }$ y
0 B) |$ M9 D9 E1 e& C9 l  M3 xBOM:
/ y# ~1 g& k! L& c7 u
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
8P4RRESISTOR DIP 4_8P4R_33X433X4IC2RN1; RN2
18P_DIPTRANS_1901000BASE-T DUALPORT XFORMER_0_1G1801DGIC2T1; T2
CAPC2-100-250CAPACITOR POL_CAPC2-100-250_100100u-16VIC8CP7; CP9; CP12; CP13; CP15; CP16; CP18; CP19
CAP_D6_3CAP_CAP_D6_3_22UF22UFIC1C4
CAP_D8P3D5_P2D5CAP-PN_0_CAP_D8P3D5_P2D5_470UF470uFIC2C229; C230
CAP_D8P3D5_P2D5CAP_A_CAP_D8P3D5_P2D5_470UF470uFIC1CE3
CAP_D8P3D5_P2D5CAPACITOR POL_CAP_D8P3D5_P2D5_1470u /25VIC1CP6
CAP_D8P3D5_P2D5CAPACITOR POL_CAP_D8P3D5_P2D5_4470uF_16VIC1CP10
CAP_D10P5_P3D5CAP-PN_0_CAP_D10P5_P3D5_470UF470uFIC1C227
CAP_D10P5_P3D5CAP-PN_0_CAP_D10P5_P3D5_1000UF1000uFIC1C234
CAP_D10P5_P3D5CAPACITOR POL_CAP_D10P5_P3D5_47470u /25VIC1CP1
CC0402CAP NP_2_CC0402_0.1U0.1uIC1C9
CC0402CAP NP_1_CC0402_100PFNC100pFNCIC1C10
CC0402CAP NP_3_CC0402_0.1UF0.1uFIC2C11; C17
CC04020_0_CC0402_0.1UF0.1uFIC73C20; C21; C22; C23; C24; C25; C26; C27; C28; C29; C30; C35; C40; C41; C42; C43; C44; C45; C46; C47; C48; C49; C50; C51; C52; C53; C64; C65; C68; C69; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C98; C99; C100; C101; C102; C103; C104; C105; C106; C107; C108; C109; C110; C111; C112
CC0402CAP NP_1_CC0402_30PF30pFIC1C31
CC0402CAP NP_1_CC0402_30PF NC30pF NCIC1C32
CC0402CAP NP_1_CC0402_22P22PIC2C33; C34
CC0402CAP NP_CC0402_0.01U0.01uIC1C36
CC04020_0_CC0402_1NF1nFIC1C39
CC04020_0_CC0402_0.01UF0.01uFIC11C54; C55; C56; C57; C58; C59; C60; C66; C67; C338; C339
CC0402CAP NP_0_CC0402_0.1U0.1uIC72C114; C115; C116; C120; C122; C125; C127; C129; C132; C133; C134; C135; C137; C138; C139; C140; C141; C142; C143; C144; C145; C146; C147; C148; C149; C151; C153; C156; C158; C161; C163; C165; C168; C169; C170; C171; C173; C174; C175; C176; C177; C178; C179; C180; C181; C182; C183; C184; C185; C187; C189; C192; C194; C197; C199; C201; C204; C205; C206; C207; C209; C210; C211; C212; C213; C214; C215; C216; C217; C218; C219; C220
CC0402CAP_1_CC0402_1UF1uFIC1C223
CC0402CAP NP_0_CC0402_0.1UF0.1uFIC4C248; C249; C250; C251
CC0402CAP_CC0402_10NF10nFIC1C255
CC0402CAP_CC0402_0.1UF0.1uFIC2C260; C261
CC0402CAP_CC0402_3.3NF3.3nFIC1C262
CC04020_0_CC0402_18PF18pFIC2C274; C275
CC0402CAP NP_6_CC0402_0.1UF0.1uFIC45C342; C343; C344; C345; C346; C347; C348; C350; C351; C358; C363; CG4; CG14; CG16; CG18; CG19; CG20; CG22; CG23; CG24; CG25; CG26; CG28; CG29; CG30; CG31; CG32; CG33; CG39; CG49; CG51; CG52; CG53; CG55; CG56; CG57; CG58; CG59; CG60; CG61; CG66; CG67; CG68; CG69; CG70
CC0402CAP NP_6_CC0402_1UF1uFIC9C349; C352; C357; CG15; CG17; CG34; CG50; CG62; CG65
CC0402CAP NP_6_CC0402_0.1U0.1UIC7C355; C356; C359; C360; C362; C364; C365
CC0402CAP NP_6_CC0402_0.1NF0.1nFIC1C361
CC0402CAP NP_6_CC0402_22P22PIC4CG1; CG2; CG36; CG37
CC0402CAP NP_6_CC0402_10NF10nFIC8CG5; CG7; CG10; CG12; CG40; CG42; CG45; CG47
CC0402CAP NP_6_CC0402_470PF/NC470pF/NCIC2CO3; CO10
CC0402CAP NP_5_CC0402_0.1UF0.1uFIC1CW30
CC0603CAP NP_CC0603_0.1U0.1uIC2C1; C8
CC0603CAP_1_CC0603_0.1UF0.1uFIC3C221; C228; C231
CC0603CAP_1_CC0603_0.01UF0.01uFIC1C222
CC0603CAP_CC0603_0.1UF0.1uFIC1C259
CC0805CAP_1_CC0805_10UF10uFIC1C225
CC08050_0_CC0805_10UF10uFIC5C246; C247; CP11; CP14; CP17
CC0805CAP_0_CC0805_10UF10uFIC1C263
CC0805CAP NP_6_CC0805_10UF10uFIC2CG8; CG43
CC0805CAP NP_CC0805_10UF10uFIC6CG21; CG27; CG35; CG54; CG63; CG64
CC1206CAP NP_2_CC1206_1000P/2KV1000P/2KVIC12C119; C124; C131; C136; C155; C160; C167; C172; C191; C196; C203; C208
CC1206CAP NP_2_CC1206_1000PF 2KV1000pF 2KVIC4C224; C226; C232; C233
CC1206CAP NP_6_CC1206_1NF 2KV(1206)1nF 2kv(1206)IC5CG3; CG13; CG38; CG48; CO15
COIL_D1D5_P350INDUCTOR_3_COIL_D1D5_P350_6,8UH6,8uHIC1L13
COIL_D1D5_P350INDUCTOR_3_COIL_D1D5_P350_20UH20uHIC1L43
DIP8-100-30024LC024_DIP8-100-300_24C32B-DIP24C32B-DIPIC1U10
DIP_4P_157CON8_0_DIP_4P_157_CON4CON4IC1JR1
ESDCAP_0_ESD_UDD32C05L01UDD32C05L01IC2ESD1; ESD2
HEAD-20PPINROW10X2_0.1E_FRAME_HEAD-20P_pinrow10x2_0.1e_FrameIC1J4
HOLE125-8STARHOLE125-8STAR_2_HOLE125-8STAR_HHOLE125-8STARIC4M1; M2; M4; M7
ID-BOARDHOLD_0_ID-BOARD_HOLD_0HOLD_0IC6ID1; ID2; ID3; ID4; ID5; ID6
LC0805INDUCTOR_0_LC0805_100BEAD100BEADIC21L1; L2; L3; L4; L5; L6; L10; L11; L12; L18; L19; L22; L24; L26; L28; L30; L32; L34; L36; L38; L40
LC0805INDUCTOR_1_LC0805_80RBEAD80RBEADIC3L7; L8; L9
LC0805BEAD/0805_1_LC0805_80RBEAD80RBEADIC14LG1; LG2; LG18; LG19; LG20; LG21; LG22; LG23; LG25; LG26; LG27; LG28; LG29; LG31
LC0805BEAD/0805_1_LC0805_BEADNCBEADNCIC2LG24; LG30
LED4-100MLED 4_1_LED4-100M_LED?LED?IC1D2
LEDX2LED_DOUBLE_0_LEDX2_LEDX2*LEDx2*IC1LED4
MOL_14JP14_0_MOL_14_JP14JP14IC1J5
QFN-68IP403_2_QFN-68_IP403IP403IC1U15
QFP64-IP1001_64IP1001_QFP64-IP1001_64_IP1001IP1001IC2U21; U22
QFP128B-50-1420LIP210_5_QFP128B-50-1420L_IP210IP210IC1U7
QFP128B-50-1420LIP108A_9_QFP128B-50-1420L_IP108IP108AIC3U12; U13; U14
QFP144-050-2020HIP1826-C_3_QFP144-050-2020H_IP1IP1826-DIC1U11
RC0402R_2_RC0402_10K10KIC3R6; R358; R463
RC0402R_2_RC0402_1K1KIC1R7
RC0402R_2_RC0402_00IC5R8; R148; R150; R153; R156
RC0402R_2_RC0402_5.6K5.6KIC1R9
RC0402R_2_RC0402_4.7K4.7KIC30R18; R39; R41; R53; R63; R64; R119; R120; R122; R123; R137; R139; R140; R142; R143; R144; R167; R169; R170; R172; R173; R174; R350; R351; R352; R487; R489; R490; R492; R493
RC0402R_2_RC0402_2222IC62R27; R47; R50; R51; R54; R57; R58; R59; R60; R62; R65; R67; R70; R73; R74; R75; R76; R77; R78; R79; R83; R86; R88; R89; R90; R91; R94; R96; R98; R103; R105; R106; R107; R108; R109; R111; R112; R113; R114; R115; R118; R125; R127; R128; R129; R131; R132; R133; R134; R135; R138; R145; R151; R154; R158; R161; R162; R163; R164; R165; R168; R175
RC0402R_RC0402_1K1KIC2R28; R30
RC0402R_RC0402_10K10KIC1R29
RC0402R_RC0402_3333IC3R31; R34; R429
RC0402R_2_RC0402_1.5K1.5KIC1R40
RC0402R_2_RC0402_4.7K_14.7KIC4R42; R48; R55; R99
RC0402R_2_RC0402_4.7K NC4.7K NCIC39R43; R49; R52; R61; R66; R69; R71; R72; R116; R117; R121; R124; R141; R171; R359; R360; R361; R362; R363; R364; R373; R374; R375; R376; R377; R378; R379; R380; R381; R382; R383; R384; R478; R480; R482; R485; R486; R488; R491
RC0402R_2_RC0402_3333IC3R44; R45; R46
RC0402R_2_RC0402_1M1MIC2R56; R365
RC0402R_2_RC0402_6.19K 1%6.19K 1%IC4R68; R126; R146; R176
RC0402R_5_RC0402_75R1%75R1%IC22R110; R130; R147; R149; R152; R159; R345; R346; R347; R349; RG3; RG4; RG5; RG6; RG7; RG18; RG31; RG33; RG34; RG35; RG36; RG47
RC0402R_2_RC0402_4.7K(NC)4.7K(NC)IC2R136; R166
RC0402R_5_RC0402_22R22RIC4R155; R348; RG2; RG30
RC0402R_RC0402_7575IC48R177; R179; R180; R182; R183; R185; R186; R188; R189; R191; R192; R194; R195; R197; R202; R208; R233; R235; R236; R238; R239; R241; R242; R244; R245; R247; R248; R250; R251; R253; R254; R257; R289; R291; R292; R294; R295; R297; R298; R300; R301; R303; R304; R306; R307; R309; R310; R312
RC0402R_RC0402_49.949.9IC96R198; R199; R200; R201; R203; R204; R205; R206; R209; R210; R211; R212; R213; R214; R215; R216; R217; R218; R219; R220; R221; R222; R223; R224; R225; R226; R227; R228; R229; R230; R231; R232; R255; R258; R259; R260; R261; R262; R263; R264; R265; R266; R267; R268; R269; R270; R271; R272; R273; R274; R275; R276; R277; R278; R279; R280; R281; R282; R283; R284; R285; R286; R287; R288; R313; R314; R315; R316; R317; R318; R319; R320; R321; R322; R323; R324; R325; R326; R327; R328; R329; R330; R331; R332; R333; R334; R335; R336; R337; R338; R339; R340; R341; R342; R343; R344
RC0402RES/0402_2_RC0402_10K-1%10k-1%IC1R354
RC0402RES/0402_2_RC0402_9.1K9.1KIC1R355
RC0402RES/0402_2_RC0402_26.1K-1%26.1k-1%IC1R356
RC0402R_RC0402_4.7K NC4.7K NCIC5R366; R367; R368; R369; R370
RC0402R_RC0402_510 NC510 NCIC1R371
RC0402R_RC0402_4.7K4.7KIC4R372; R430; R476; R494
RC0402R_6_RC0402_4.7K4.7KIC2R386; R388
RC0402R_6_RC0402_20K20KIC1R389
RC0402R_6_RC0402_00IC1R392
RC0402R_0_RC0402_330330IC3R483; R484; R495
RC0402R_0_RC0402_10K10KIC1R496
RC0402R_0_RC0402_1K1KIC1R497
RC0402R_0_RC0402_330R330RIC2R500; R501
RC0402R_5_RC0402_1M1MIC2RG1; RG32
RC0402R_5_RC0402_5.1K5.1KIC16RG8; RG22; RG23; RG24; RG26; RG29; RG37; RG51; RG52; RG53; RG54; RG55; RG58; RG60; RG120; RG121
RC0402R_5_RC0402_49.9R1%49.9R1%IC16RG10; RG11; RG13; RG14; RG16; RG17; RG19; RG20; RG39; RG40; RG42; RG43; RG45; RG46; RG48; RG49
RC0402R_5_RC0402_6.19K 1%6.19K 1%IC4RG21; RG50; RG61; RG62
RC0402R_5_RC0402_5.1K NC5.1K NCIC4RG25; RG28; RG57; RG59
RC0402R_5_RC0402_4.7K NC4.7K NCIC2RG27; RG56
RC0402R_5_RC0402_2222IC2RG119; RG123
RC0402R_5_RC0402_0 NC0 NCIC2RG122; RG124
RC0402R_5_RC0402_49.9 1%49.9 1%IC4RO4; RO5; RO14; RO15
RC0402R_5_RC0402_10K10KIC4RO25; RO26; RO27; RO28
RC0402R_4_RC0402_00IC1RW31
RC0402R_4_RC0402_10K10KIC3RW32; RW33; RW35
RC0402R_4_RC0402_0NC0NCIC1RW34
RC0402R_4_RC0402_1010IC1RW36
RC0402R_4_RC0402_120120IC1RW37
RC0603RESISTOR_0_RC0603_1K 1%1K 1%IC2R4; R5
RC0603RES_RC0603_1.4K1.4KIC1R23
RC0603RES_RC0603_15K15KIC1R25
RC0603RES_RC0603_1K1KIC1R26
RC0603RES/0402_2_RC0603_100K100KIC1R353
RC0805RES_RC0805_1010IC1R1
RC0805R_6_RC0805_00IC1R387
RJ45RJ45A-2_2_RJ45_RJ45A-2RJ45A-2IC1P1
RJ45_LED2X4_2X2RJ45_LED2X4_2X2_RJ45_LED2X4_2X2RJ45_LED2X4_2x2IC3RJ1; RJ2; RJ3
SIP-4P-100CON4_SIP-4P-100_HEADER 4HEADER 4IC1JR2
SL0805BEAD-SA_1_SL0805_100BREAD100BREADIC1L15
SL0805INDUCTOR_0_SL0805_80RBEAD80RBEADIC1L17
SOICEMP1482_2_SOICE_AIC2858AIC2858IC1U6
SOP8-50-150AEEPROM_SOP8-50-150A_24C32B_SOP24C32B_SOPIC1U9
SOP-8G5201_SOP-8_APW7120KAPW7120KIC1Q2
SOT23MOSFET N_2_SOT23_BAT54CBAT54CIC1D4
SOT23ADM706R_SOP8_0_SOT23_IMP809IMP809IC1U3
SOT232SC2411K_2_SOT23_2SC2411K2SC2411KIC2U23; U24
SOT263-3C1084_3_SOT263-3C_10841084IC1U2
SOT-89PNP 2SB1386_0_SOT-89_PNP 2SB138PNP 2SB1386IC2QG1; QG2
SOT_23BPW37/TO_0_SOT_23_2N39042N3904IC1Q5
SPGCAP_1_SPG_BK1-MBK1-MIC2SPG1; SPG2
SR2V08R_1_SR2V08_7575IC24R178; R181; R184; R187; R190; R193; R196; R207; R234; R237; R240; R243; R246; R249; R252; R256; R290; R293; R296; R299; R302; R305; R308; R311
SW-PUSH-FSW PUSHBUTTON_1_SW-PUSH-F_DEFAUDefaultIC1SW1
TF-208DGPE68515_11_TF-208DG_20PT1024X20PT1024XIC12T3; T4; T5; T6; T7; T8; T9; T10; T11; T12; T13; T14
TO252MOSFET N_6_TO252_AP60T03HAP60T03HIC2Q1; Q3
TSOP48SST39VF088_0_TSOP48_SST39VF1682SST39VF1682&1-70/MX29LV160DB/EN29LV160BBIC1U111
TSW6-RGSW KEY-SPDT_2_TSW6-RG_2P2T2P2TIC1SW2
XTAL2-200AXTAL_1_XTAL2-200A_25MHZ25MHZIC4XG1; XG2; Y3; Y4
附件:( i, V' P8 ?! K: H5 R& l
PCB文件如下:
: c# e  D# g" Y) W& s/ ]; e
游客,如果您要查看本帖隐藏内容请回复
4 q- ?! R# A" h0 i& s% }
: s/ K: g: t# B$ _" b: E
发表于 2022-8-23 16:05 | 只看该作者
该用户从未签到  四级会员(40)  Rank: 4Rank: 4Rank: 4Rank: 4   发消息         2#  发表于 2020-4-24 09:43 | 只看该作者 [allegro16.6][4层] 24口网络交换机 3 z
    2025-4-3 15:12
    发表于 2020-4-24 10:55 | 只看该作者
    9 D- g+ b1 ^' P1 K, R! ^
    [allegro16.6][4层] 24口网络交换机 8 B
    2021-11-24 15:34
    发表于 2022-9-1 09:50 | 只看该作者
    1111111111111111111111111111111, N2 c4 x. _" N- ^1 l
    " W0 P! [  N5 S& T
    发表于 2020-4-24 09:45 | 只看该作者
    本帖最后由 qq1358942282 于 2020-4-24 10:52 编辑 & r* [  O0 I0 S
    + _/ e. p7 a4 J0 s6 S# i只有PCB没有原理图
    发表于 2020-5-21 09:05 | 只看该作者
    大神,学习一下
    ; |& N! ?! c- b
    2020-10-24 15:33
    发表于 2021-2-19 16:47 | 只看该作者
    XUEXIXUEXIXUEXIXUEXI4 y2 O2 K5 H# e, y  G. M
    发表于 2021-4-5 17:00 | 只看该作者
    谢谢您的分享
    发表于 2021-5-13 17:42 | 只看该作者
    谢谢谢谢谢谢谢谢谢谢谢谢谢谢
    发表于 2021-6-16 18:18 | 只看该作者
    您好 学习一下 谢谢 分享
    ; p0 N& M( P' W
    14#
    发表于 2021-6-24 16:57 | 只看该作者
    谢谢分享。谢谢分享0 {8 B4 l/ Z1 o" }
    15#
    发表于 2021-6-25 22:09 | 只看该作者
    " @( F( }2 k# G. S- V# z' x6 O[allegro16.6][4层] 24口网络交换机
    16#
    发表于 2021-12-5 13:39 | 只看该作者
    好东西啊好东西啊5 F3 V8 i1 i. _% {/ X% b
    奋斗
    2022-10-13 15:25
  • 签到天数: 19 天
    [LV.4]偶尔看看III
    17#
    发表于 2022-3-16 09:09 | 只看该作者
    谢谢分享一下
    ; U8 P3 V" p" G2 G0 _! K/ Z" I
    GMT+8, 2025-11-27 00:24 , Processed in 0.187500 second(s), 29 queries , Gzip On.
