查看: 2902|回复: 27
[allegro16.6][16层]XILINX Zynq-7000 ZC702参考板(SOC_IRON_CL484+88E1116R+3...
发表于 2020-1-2 17:51 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
# r2 f5 c* @6 W: j- r
[allegro16.6][16层]XILINX  Zynq-7000  ZC702参考板(SOC_IRON_CL484+88E1116R+3片DDR)原理图和pcb文件
8 H- x9 q! M$ p# {/ P$ v5 t: w! o1 l1 J  {
文件描述:9 _# r( Z; C9 z  T/ g
4 G2 O' \; |/ t, b0 M0 U1. 作品用途:XILINX  Zynq-7000  ZC702参考板
' _2 F$ q6 K; ]4 o6 j$ p2. 软件版本:allegro16.62 [# ~; a. z  A- L+ F% K9 S
3. 层数:16层
  |  I& s+ s* Z' A% T: x3 |, ]4. 用到的主要芯片:SOC_IRON_CL484+88E1116R+3片DDR
5 ?, m3 W; |2 i5. pcb尺寸:7750*7150 MIL; N) A- |0 R7 u5 W
* J5 d2 m4 @- _
作品截图如下:
; y6 b. S0 @! `" a  `# [2 \
8 ^2 @- R& ^: J7 X7 h: [5 _$ J顶层截图:
3 @' h6 l( X$ O+ X: F( U + D# R1 v% w- ~9 S% ^' F
底层截图:( V( n. N1 R- n
% U/ V+ }) ?. A2 @5 U6 f
4 Y: U0 |0 ?8 q" t' O, `5 i* Z6 o+ l全层截图:
+ N: x5 `$ y  {) W. r4 V/ v7 B9 y$ I - o: x5 U. |' ~% o
3 ?9 d% I3 L5 Y" z# Y% B0 b9 U% t0 Y! C: E+ B
BOM:' Q% d' p7 D; B! x( g
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
20149_9_020149.9IC2R95; R96
201100_0201100IC2R168; R417
4020_1UF_04020.1UFIC149C1; C2; C3; C4; C5; C6; C7; C8; C9; C10; C11; C12; C23; C24; C25; C26; C27; C28; C29; C30; C31; C32; C33; C34; C35; C36; C37; C38; C39; C40; C41; C42; C43; C44; C45; C46; C47; C48; C49; C50; C51; C52; C53; C54; C56; C57; C58; C59; C60; C61; C62; C63; C64; C65; C66; C67; C68; C69; C70; C71; C84; C85; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C98; C99; C100; C101; C102; C103; C104; C105; C106; C107; C108; C109; C110; C111; C112; C113; C114; C115; C116; C117; C118; C119; C120; C121; C122; C123; C124; C125; C126; C127; C128; C129; C130; C131; C413; C415; C416; C417; C418; C425; C426; C427; C428; C429; C430; C431; C432; C433; C434; C435; C436; C437; C438; C439; C440; C441; C442; C443; C444; C502; C503; C504; C505; C506; C509; C510; C511; C518; C519; C521; C522; C523; C524; C525; C526
4022_2UF_04022.2UFIC1C137
4020_022UF_04020.022UFIC2C158; C159
4020_01UF_04020.01UFDISCRETE25C192; C193; C194; C203; C204; C205; C206; C207; C208; C209; C210; C211; C212; C213; C214; C216; C217; C218; C219; C220; C445; C446; C447; C448; C449
4020_01UF_0402DNPDISCRETE1C202
402DNP_C_0402DNPIC1C221
4020_068UF_04020.068UFIC29C280; C281; C282; C283; C284; C285; C286; C287; C288; C289; C290; C291; C292; C470; C471; C472; C473; C474; C475; C476; C477; C478; C479; C480; C481; C482; C483; C484; C485
4021000PF_04021000PFIC5C294; C295; C296; C297; C424
4024700PF_04024700PFIC1C304
402820PF_0402820PFIC10C315; C316; C317; C318; C319; C320; C321; C322; C323; C324
40218PF_040218PFIC6C330; C331; C332; C333; C334; C335
4020_47UF_04020.47UFIC68C336; C337; C338; C339; C340; C341; C342; C343; C344; C345; C346; C347; C348; C349; C350; C351; C352; C353; C354; C355; C356; C357; C358; C359; C360; C361; C362; C363; C364; C365; C366; C367; C368; C369; C370; C371; C372; C373; C374; C375; C376; C377; C378; C379; C380; C381; C382; C383; C384; C385; C386; C387; C486; C487; C488; C489; C490; C491; C492; C493; C494; C495; C496; C497; C498; C499; C500; C501
4021UF_04021UFIC1C414
4024_7K_04024.7KDISCRETE72R1; R2; R13; R14; R15; R16; R20; R26; R27; R28; R29; R30; R31; R32; R33; R34; R35; R36; R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R51; R53; R54; R55; R56; R57; R58; R59; R60; R61; R302; R319; R320; R321; R322; R352; R354; R356; R357; R367; R368; R369; R370; R371; R372; R373; R374; R375; R376; R380; R381; R398; R399; R400; R401; R408; R413; R414; R418; R419; R429
4024_7K_0402DNPDISCRETE2R17; R18
40210_0K_040210.0KIC46R52; R177; R178; R179; R180; R181; R182; R183; R184; R185; R186; R187; R188; R189; R190; R191; R192; R193; R194; R195; R196; R197; R198; R199; R200; R201; R202; R203; R204; R205; R206; R207; R208; R209; R210; R211; R212; R213; R214; R215; R308; R366; R386; R421; R423; R428
40280_6_040280.6IC3R62; R63; R323
4024_22K_04024.22KIC10R65; R66; R67; R68; R69; R70; R71; R72; R73; R74
40220_5K_040220.5KIC7R85; R86; R87; R88; R89; R90; R91
402249_0402249IC4R92; R93; R379; R420
40222_040222IC1R94
402787_0402787IC6R97; R98; R99; R100; R102; R103
402DNP_R_0402DNPIC17R101; R216; R217; R218; R219; R220; R221; R222; R223; R360; R394; R395; R396; R397; R430; R431; R432
402887_0402887IC1R107
40227_4K_040227.4KIC1R108
4022_43K_04022.43KIC5R109; R110; R111; R112; R113
4025_62K_04025.62KIC1R114
40230_040230IC21R115; R116; R117; R118; R119; R120; R121; R123; R124; R126; R127; R128; R129; R130; R131; R132; R133; R134; R135; R136; R137
4028_06K_04028.06KIC3R138; R139; R140
4021_07K_04021.07KIC1R141
40286_6K_040286.6KIC1R142
402100_0402100IC6R170; R171; R172; R173; R174; R175
402100K_0402100KDISCRETE1R226
402100K_0402100KDISCRETE1R227
4020_04020IC21R228; R229; R230; R231; R232; R233; R234; R235; R236; R237; R238; R239; R240; R241; R363; R425; R426; R427; R433; R434; R435
4021_00K_04021.00KDISCRETE31R242; R243; R244; R245; R247; R248; R249; R250; R251; R252; R253; R254; R255; R256; R257; R258; R259; R260; R261; R262; R263; R264; R265; R266; R267; R268; R269; R270; R271; R310; R387
4021_00K_0402DNPDISCRETE1R246
4022_7K_04022.7KIC1R272
4022_00K_04022.00KIC7R273; R274; R275; R388; R389; R390; R391
402261_0402261IC18R276; R277; R278; R279; R280; R316; R317; R318; R393; R404; R405; R406; R407; R409; R410; R411; R412; R416
40260_4_040260.4IC2R281; R282
4021_0M_04021.0MIC2R295; R296
4024_99K_04024.99KIC1R297
40275K_040275KIC4R298; R299; R300; R301
40240_2_040240.2IC23R325; R326; R327; R328; R329; R330; R331; R332; R333; R334; R335; R336; R337; R338; R339; R340; R341; R342; R343; R344; R345; R346; R347
402240_0402240IC4R348; R349; R350; R351
40224_9_040224.9IC2R402; R403
60310UF_060310UFIC1C148
6031UF_06031UFIC16C177; C178; C179; C180; C181; C182; C183; C184; C185; C186; C187; C188; C189; C190; C191; C512
6034_7UF_06034.7UFIC5C325; C326; C327; C328; C329
603FERRITE-120_0603FERRITE-120IC1L6
603FERRITE-220_0603FERRITE-220IC19L8; L9; L10; L11; L12; L13; L14; L15; L16; L17; L18; L19; L20; L21; L22; L23; L24; L25; L31
603330_0603330IC1R324
0603_SHORT0603_SHORT0603_SHORTIC11Z1; Z2; Z3; Z4; Z5; Z6; Z7; Z8; Z9; Z10; Z11
80510UF_080510UFIC2C83; C271
8054_7UF_08054.7UFIC58C222; C223; C224; C225; C226; C227; C228; C229; C230; C231; C232; C233; C234; C235; C236; C237; C238; C239; C240; C241; C242; C243; C244; C245; C246; C247; C248; C249; C250; C251; C252; C263; C264; C265; C266; C267; C268; C269; C450; C451; C452; C453; C454; C455; C456; C457; C458; C459; C460; C461; C462; C463; C464; C465; C466; C467; C468; C469
805100PF_0805100PFIC4C513; C514; C515; C516
805FERRITE-600FERRITE-600IC5L1; L2; L3; L4; L5
120622UF_120622UFIC5C132; C133; C134; C135; C136
120647UF_120647UFIC11C138; C139; C140; C141; C142; C143; C144; C145; C146; C147; C520
1206100UF_1206100UFIC17C160; C161; C162; C163; C164; C165; C166; C167; C168; C169; C170; C171; C172; C173; C174; C175; C176
12065_6UF_12065.6UFIC1C270
120610UF_120610UFIC11C401; C402; C403; C404; C406; C407; C408; C409; C410; C411; C412
121010UF_121010UFIC9C149; C150; C151; C152; C153; C154; C155; C156; C157
1224_SMTLVK25R005FER0.005IC10R75; R76; R77; R78; R79; R80; R81; R82; R83; R84
87832_1420MOLEX-87832-142087832-1420IC1J2
27730214472773021447FERRITE-78IC5L26; L27; L28; L29; L30
ASP_134603_01ASP_134603_01ASP_134603_01IC2J3; J4
BNX016-01BNX016-0150MOHMIC1U78
CAP_F330UF_8_3MMX8_3MM330UFIC6C396; C397; C398; C399; C400; C517
CON23_MOLEX_HDMI_RA500254_1927500254-1927IC1P1
CONN_USB_MINI_B_THCONN_USB_MINI_B_THCONN_USB_MINI_B_THIC1J17
CON_MOLEX_87832_1020HDR_2X5_ALTHDR_2X5_ALTIC1J52
CON_MOLEX_SD_6784067840-800167840-8001IC1J64
CON_MOL_5569_6P39-30-1060_JACK_500X54039-30-1060IC1J60
DIGILENT_USB_JTAG2DIGILENT_USB_JTAG2DIGILENT_USB_JTAG_2IC1U23
DIO_DFS1150_7DFLS1150DFLS1150IC1D4
EFS_R_PDSS_T22PTD08D210WPTD08D210WACIC5U17; U18; U19; U20; U21
EVQ_11L07KEVQ-11L07KEVQ-11L07KIC2SW1; SW2
FBGA_DDR3_78PMT41J256M8HX_15EMT41J256M8HX_15EIC4U66; U67; U68; U69
GND_SHORTGND_SHORTGND_SHORTIC1Z12
HDR_1X2HDR_1X2HDR_1X2IC16J5; J6; J7; J8; J9; J10; J11; J12; J13; J14; J15; J43; J44; J53; J56; J65
HDR_1X2DNP_HDR_1X2DNPIC1J16
HDR_1X3DNP_HDR_1X3DNPIC5J20; J21; J22; J25; J26
HDR_1X3HDR_1X3HDR_1X3IC12J27; J28; J30; J31; J32; J33; J34; J35; J36; J37; J38; J70
HDR_1X3_LOCK_MOLEXWM2701-ND22_11_2032IC1J61
HDR_1X6HDR_1X6HDR_1X6IC1J62
HDR_2X6HDR_2X6HDR_2X6IC2J54; J63
HDR_BOX_2X5HDR-2X5-SHR_HDR-2X5-SHRHDR_BOX_2X5IC1J59
HSMF_C15XHSMF-C155LED-GRN-REDIC1DS2
LED_0603LED-GRN-SMT_LED_0603LED-GRN-SMTIC14DS3; DS6; DS7; DS8; DS12; DS15; DS16; DS17; DS18; DS19; DS20; DS21; DS22; DS23
LED_0603LED-GREEN-SMT_LED_0603LED-GRN-SMTIC4DS4; DS13; DS14; DS24
LED_0603LED-RED-SMT_LED_0603LED-RED-SMTIC1DS5
LED_0805LED-RED-SMTLED-RED-SMTIC1DS1
LQFP100_14X14ADV7511ADV7511IC1U40
MH_250H125HOLE_MH_125_250MH_125_250IC6MH1; MH2; MH3; MH4; MH5; MH6
ML621S_DNML621S_DNML621S_DNIC1B2
MSOP_8INA333_MSOP-8INA333IC10U45; U46; U47; U48; U49; U50; U51; U52; U53; U54
OSCON_C616SVPF180M180UFIC5C298; C299; C300; C301; C302
OSC_EG2121CA_6PSIT9102200MHZIC1U43
OSC_SIT8102_PKG2SIT810212.00000MHZIC1U31
OSC_SIT8103_PKG2SIT810333.33333MHZIC1U65
PFC_S_PQFP_G80UCD9248PFC_QFP50P14X14-80UCD9248PFCIC3U32; U33; U34
QFN_24PCA9548ARGER_QFN24PCA9548ARGERIC1U44
QFN_28CP2103GM_MLP-28CP2103GMIC1U36
QFN_6488E1116R88E1116RIC1U35
QFN_RSW_10SN74AVC2T245SN74AVC2T245IC1U8
RCLAMP0524PRCLAMP0524PRCLAMP0524PIC4DP1; DP2; DP3; DP4
RJ45_HFJ11_1G01ERJ45_HFJ11-1G01ERJ45IC1P2
RTC8564JE_VSOJ_20RTC8564JE_VSOJ_20RTC8564JEIC1U16
SAMTEC_TST_110_XX_X_DSAMTEC_TST_110_XX_X_DTST-110-01-G-DIC3J40; J41; J58
SC70_5NC7SZ66NC7SZ66P5XIC2U25; U26
SC70_5SN74LVC1G08SN74LVC1G08IC1U64
SC70_6SN74AVC1T45SN74AVC1T45IC4U37; U38; U39; U71
SC70_6SN74LVC1G11SN74LVC1G11IC1U62
SC70_6NC7WZ07NC7WZ07IC3U83; U84; U86
SI570570BAB000544DG_5X710MHZ-810MHZIC1U28
SMT_CRYS_224MHZ_HC49SD24.000MHZIC1X2
SO16_50P300X413N25Q128AN25Q128AIC1U41
SOC_IRON_CL484SOC_IRON_CL484SOC_IRON_CL484IC1U1
SOD_123BZX84C4V7_SOT23BZT52C5V1-TPIC3D1; D2; D3
SOD_123BAT54T1GBAT54T1GIC3D5; D6; D7
SOIC_8TJA1040TJA1040IC1U14
SOIC_8PCA9517PCA9517IC2U56; U57
SOIC_14TXS0104ETXS0104EIC1U3
SON10_TPS51200TPS51200DRCTTPS51200DRCTIC1U22
SOP127P500X600_8MIC2025_SOP8MIC2025IC1U13
SOT23_3REF3012AIDBZT_SOT23_3REF3012AIDBZTIC1U29
SOT143SP0503BAHT_SOT143SP0503BAHTGIC1X3
SOT_23BAS40_04_SOT23BAS40-04IC1D8
SOT_23NDS331N_SOT23NDS331NIC17Q1; Q3; Q7; Q8; Q9; Q11; Q12; Q13; Q14; Q15; Q16; Q17; Q18; Q19; Q20; Q21; Q22
SOT_89FCX491A_SOT_89FCX491AIC3Q4; Q5; Q6
SPDT_SW_DIP_5SPDT_SW_DIP_5SPDT_SW_DIP_5IC1SW16
SW_450_5001201M2S3ABE2_SLIDE_2POS1201M2S3AQE2IC1SW11
SW_SDA_3PSDA02H1SBDSDA02H1SBDIC3SW10; SW12; SW15
SW_TL3301_G_4PTL3301EF100QG-NDTL3301EF100QGIC5SW4; SW5; SW7; SW13; SW14
T-18_AXIAL1N5335BRLG1N5335BRLGIC5D9; D10; D11; D12; D13
TANT_C150UF_TANT_C150UFIC1C293
TANT_D330UF_LOW_ESR330UFIC10C305; C306; C307; C308; C309; C310; C311; C312; C313; C314
TANT_R120UF_TANT_R120UFIC1C303
TBD13TXS0102TXS0102IC1U81
TCA6416APWRTCA6416APWRTCA6416AIC1U80
TO_PMOD_7LMZ12002LMZ12002IC1U30
TP_KEY_MINITP_5004_YELLOWYELLOWIC1J39
TP_KEY_MINITP_5001_BLACKBLACKIC4J66; J67; J68; J69
TP_KEY_MINITP_5000_REDREDIC1J71
TQFN_16MAX16025MAX16025IC1U2
TS5A3359TS5A3359DCURTS5A3359DCURIC3U75; U76; U77
TS518FE_FL35ETS518FE_FL35ETS518FE-FL35EIC1B1
TSOT_5ADP123ADP123IC1U10
TSSOP8_65P440X300MMM24C08-WDW6TPM24C08-WDW6TPIC1U7
TSSOP_16CD74HC4051_TSSOP-16CD74HC4051IC3U4; U5; U6
TSSOP_20SN74LV541APWRSN74LV541APWRIC1U15
TSSOP_20TXS0108ETXS0108EIC2U70; U79
USB3320_QFN32USB3320_QFN32USB3320IC1U9
WQFN24TXS02612TXS02612IC1U61
XTAL_MA506XTAL_MA50625.00MHZIC1X1
ZX62D_AB_5P8ZX62D_AB_5P8ZX62D_AB_5P8IC1J1
附件:
! X3 y- t/ M& K' \原理图和PCB文件如下:
5 z5 H, S& s% X! e
游客,如果您要查看本帖隐藏内容请回复
; ]) }3 y, w& e" v- Z8 ]& `! ]$ D$ ~. g+ B8 D# k
    2024-8-26 15:16
    发表于 2020-7-15 20:50 | 只看该作者
    还不错,感谢楼主无私分享
      J; G6 D. q( k1 L9 g
    2023-8-17 15:04
  • 签到天数: 82 天
    [LV.6]常住居民II
    发表于 2023-1-14 09:30 | 只看该作者
    这16层的主板成本够高。
    2020-10-26 15:52
    发表于 2023-1-12 10:48 | 只看该作者
    学习一下,谢谢分享
    2021-10-7 15:37
  • 签到天数: 44 天
    [LV.5]常住居民I
    发表于 2020-4-15 18:16 | 只看该作者
    谢谢楼主的分享
    “来自电巢APP”
    发表于 2020-7-15 18:55 | 只看该作者
    感谢楼主分享
    “来自电巢APP”
    2025-11-26 15:07
  • 签到天数: 1280 天
    [LV.10]以坛为家III
    发表于 2020-10-14 06:26 | 只看该作者
    谢谢提醒
    “来自电巢APP”
    发表于 2020-10-14 14:16 | 只看该作者
    kankankankan
    8 P+ J8 {+ J$ T4 Y5 D
    2025-11-26 15:15
  • 签到天数: 137 天
    [LV.7]常住居民III
    发表于 2020-11-2 20:21 | 只看该作者
    6666666666
    发表于 2020-12-15 19:42 | 只看该作者
    感谢楼主分享  A! ?# |: l, @
    14#
    发表于 2020-12-15 21:43 | 只看该作者
    3 E& P8 F, U/ C/ c5 z2 f( S感谢楼主分享
    擦汗
    2021-9-6 15:33
  • 签到天数: 68 天
    [LV.6]常住居民II
    15#
    发表于 2020-12-22 10:52 | 只看该作者
    非常优秀,谢谢分享!!
    16#
    发表于 2021-3-10 16:41 | 只看该作者
    感谢楼主分享- `  }+ m6 [; s2 l0 s6 m; p* U' ^
    2020-1-8 15:27
    17#
    发表于 2021-4-16 10:58 | 只看该作者
    学习一下,谢谢分享!!!!!!!+ K9 l# R4 s' `# @
    GMT+8, 2025-11-27 00:50 , Processed in 0.203125 second(s), 29 queries , Gzip On.
