| Bill of Material Report (Condensed) | | | | | |
| SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
| 名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
| 467650301_SD | 46765-0301_467650301_SD_46765-0 | 46765-0301 | IC | 1 | U40 |
| 525593652_SD | 525593652_525593652_SD_52559365 | 525593652 | IC | 1 | J8 |
| 541323633_SD | 525593652_541323633_SD_54132363 | 541323633 | IC | 2 | J23; J24 |
| 541323633_SD_TOP | 525593652_541323633_SD_TOP_5413 | 541323633 | IC | 1 | J22 |
| B0603_H80 | BEAD1_B0603_H80_BLM18PG121SN1 | BLM18PG121SN1 | IC | 33 | B1; B2; B5; B6; B7; B8; B10; B11; B12; B13; B14; B15; B18; B19; B20; B23; B24; B25; B26; B27; B28; B29; B30; B31; B36; B37; B38; B39; B41; B42; B43; B44; B45 |
| B0603_H80 | BEAD1_B0603_H80_NC | NC | IC | 2 | B9; B40 |
| B1206_H110 | BEAD1_B1206_H110_BLM31PG330SN1 | BLM31PG330SN1 | IC | 2 | B21; B22 |
| BGA77_P127_H500 | LTM4644IY#PBF_0_BGA77_P127_H500 | LTM4644IY#PBF | IC | 3 | U33; U34; U35 |
| BGA117_P100_H150 | 88E1111-XX-BAB1I000_BGA117_P100 | 88E1111-B2-BAB1I000 | IC | 2 | U14; U44 |
| C0402_H40 | CAPACITOR NP_C0402_H40_0.01UF/1 | 0.01uF/16V | DISCRETE | 130 | C50; C53; C54; C55; C56; C60; C61; C62; C63; C64; C68; C69; C70; C71; C72; C76; C77; C78; C79; C80; C84; C85; C86; C87; C88; C231; C234; C235; C236; C237; C241; C242; C243; C244; C245; C249; C250; C251; C252; C253; C257; C258; C259; C260; C261; C265; C266; C267; C268; C269; C343; C344; C361; C362; C363; C364; C365; C366; C367; C371; C372; C373; C374; C375; C376; C377; C383; C384; C390; C391; C392; C393; C394; C395; C396; C400; C401; C402; C403; C404; C405; C406; C594; C606; C608; C609; C610; C611; C612; C613; C614; C618; C619; C620; C621; C622; C623; C624; C628; C629; C630; C631; C632; C633; C634; C635; C639; C640; C641; C642; C643; C644; C645; C651; C1503; C1504; C1505; C1506; C1507; C1508; C1509; C1510; C1511; C1512; C1513; C1514; C1515; C1516; C1517; C1518 |
| C0402_H40 | CAPACITOR NP_C0402_H40_0.1UF/25 | 0.1uF/25V | IC | 13 | C129; C130; C131; C153; C310; C311; C312; C411; C424; C440; C539; C550; C551 |
| C0402_H60 | CAPACITOR NP_C0402_H60_0.47UF/1 | 0.47uf/16V | IC | 184 | C13; C14; C15; C16; C20; C21; C22; C23; C24; C28; C29; C30; C32; C35; C42; C58; C59; C66; C67; C74; C75; C82; C83; C114; C115; C116; C117; C118; C119; C120; C124; C126; C128; C136; C137; C139; C140; C141; C142; C144; C146; C194; C195; C196; C197; C201; C202; C203; C204; C205; C209; C210; C211; C213; C217; C224; C239; C240; C247; C248; C255; C256; C263; C264; C295; C296; C297; C298; C299; C300; C301; C305; C307; C309; C316; C317; C320; C321; C323; C324; C326; C327; C335; C336; C338; C339; C341; C342; C359; C360; C369; C370; C388; C389; C398; C399; C552; C553; C554; C555; C556; C557; C558; C559; C560; C561; C562; C563; C564; C565; C566; C567; C568; C569; C570; C571; C572; C573; C574; C575; C576; C577; C578; C579; C580; C581; C582; C583; C584; C585; C586; C587; C588; C589; C590; C591; C603; C604; C616; C617; C626; C627; C637; C638; C671; C672; C673; C674; C675; C676; C849; C850; C851; C852; C853; C854; C856; C857; C858; C860; C862; C863; C864; C865; C866; C867; C869; C870; C871; C873; C1524; C1525; C1526; C1527; C1535; C1536; C1537; C1538; C1539; C1540; C1541; C1542; C1543; C1544 |
| C0402_H60 | CAPACITOR NP_C0402_H60_0.1UF/16 | 0.1uF/16V | IC | 200 | C36; C37; C38; C39; C40; C49; C52; C89; C97; C105; C106; C107; C108; C109; C110; C111; C112; C113; C121; C127; C147; C148; C149; C150; C151; C152; C156; C157; C158; C159; C160; C161; C162; C163; C166; C167; C168; C169; C170; C171; C174; C175; C176; C177; C178; C179; C180; C181; C214; C218; C219; C220; C221; C230; C232; C270; C278; C286; C287; C288; C289; C290; C291; C292; C293; C294; C302; C308; C328; C329; C330; C331; C332; C333; C347; C348; C349; C350; C351; C352; C353; C356; C357; C378; C379; C380; C381; C382; C385; C412; C419; C426; C433; C444; C447; C451; C454; C462; C464; C466; C467; C468; C469; C471; C472; C473; C475; C476; C477; C478; C480; C481; C483; C484; C486; C488; C489; C490; C491; C497; C504; C506; C507; C510; C511; C512; C513; C514; C515; C518; C519; C520; C521; C522; C523; C524; C525; C526; C527; C528; C531; C532; C533; C534; C535; C536; C537; C538; C540; C548; C549; C592; C595; C596; C597; C598; C599; C600; C601; C646; C647; C648; C649; C650; C652; C653; C659; C660; C665; C666; C667; C668; C669; C670; C677; C679; C680; C682; C684; C685; C686; C689; C691; C692; C694; C695; C697; C698; C700; C876; C877; C878; C1519; C1520; C1521; C1522; C1523; C1531; C1532; C1533 |
| C0402_H60 | CAPACITOR NP_C0402_H60_1000PF/5 | 1000pF/50V | IC | 7 | C92; C274; C458; C661; C678; C688; C699 |
| C0402_H60 | CAPACITOR NP_C0402_H60_3.3PF/50 | 3.3pF/50V | IC | 4 | C122; C303; C386; C593 |
| C0603_H60 | CAPACITOR NP_C0603_H60_4.7UF/10 | 4.7uF/10V | IC | 51 | C5; C11; C12; C18; C19; C26; C27; C34; C41; C57; C65; C73; C81; C93; C100; C101; C102; C186; C192; C193; C199; C200; C207; C208; C216; C222; C238; C246; C254; C262; C271; C281; C282; C283; C358; C368; C387; C397; C455; C602; C615; C625; C636; C664; C848; C855; C859; C861; C868; C872; C1534 |
| C0805_H110 | CAPACITOR NP_C0805_H110_10UF/10 | 10uF/10V | IC | 44 | C31; C90; C91; C94; C95; C96; C154; C155; C164; C165; C172; C173; C212; C272; C273; C275; C276; C277; C456; C457; C459; C460; C461; C463; C465; C470; C474; C508; C509; C516; C517; C529; C530; C656; C657; C658; C662; C663; C681; C683; C687; C690; C693; C696 |
| C1206_H180 | CAPACITOR NP_C1206_H180_47UF/10 | 47uF/10V | IC | 38 | C6; C7; C8; C103; C104; C187; C188; C189; C284; C285; C345; C346; C354; C355; C414; C415; C417; C420; C428; C429; C431; C434; C446; C449; C450; C452; C479; C482; C485; C492; C494; C496; C605; C607; C654; C655; C794; C1474 |
| C1206_H180 | CAPACITOR NP_C1206_H180_10UF/25 | 10uF/25V | IC | 13 | C407; C408; C409; C410; C421; C422; C423; C425; C439; C441; C442; C443; C1476 |
| CT3528_H190 | CAPACITOR POL_CT3528_H190_100UF | 100uF/6.3V | IC | 43 | C9; C10; C17; C25; C33; C43; C98; C99; C123; C125; C135; C138; C143; C145; C190; C191; C198; C206; C215; C223; C279; C280; C304; C306; C318; C319; C322; C325; C334; C337; C340; C413; C416; C418; C427; C430; C432; C445; C448; C453; C544; C546; C547 |
| CT7343_H290 | CAPACITOR POL_CT7343_H290_330UF | 330uF/6.3V | IC | 8 | C1; C2; C3; C4; C182; C183; C184; C185 |
| CT7343_H290 | CAPACITOR POL_CT7343_H290_150UF | 150uF/10V | IC | 2 | C795; C1475 |
| CT7343_H400 | CAPACITOR POL_CT7343_H400_100UF | 100uF/25V | IC | 4 | C435; C436; C437; C438 |
| D0603 | STM_LED_0_D0603_LED/GREEN | LED/Green | IC | 8 | D2; D3; D4; D5; D11; D12; D13; D14 |
| DC005 | PJ-102A_DC005_DC-005-3 | DC-005-3 | IC | 1 | JT2 |
| D_SMC_H213 | 1P5SMC16AT3G_D_SMC_H213_1.5SMC1 | 1.5SMC16AT3G | IC | 1 | D15 |
| FBGA96_P80_H110 | MT41J256M16RE-15E IT_FBGA96_P80 | MT41K256M16TW-107 IT | IC | 12 | U9; U10; U24; U25; U29; U30; U31; U32; U48; U49; U50; U51 |
| FBGA900_P100_L3100X3100_H315 | XC7X045FFG900_FBGA900_P100_L310 | XC7Z045-2FFG900I | IC | 2 | U1; U16 |
| HEAD1X2_P254_L254_T | HEADER 1X2_HEAD1X2_P254_L254_T_ | 201S-2X1PS-6/3 | IC | 1 | J10 |
| HEAD3X1_P254_L254_T | HEADER 3_HEAD3X1_P254_L254_T_20 | 201S-1X3PS-6/3 | IC | 2 | J20; J21 |
| HEAD7X2_P200_L200_S | HEADER 7X2_HEAD7X2_P200_L200_S_ | 302-2S-14P(shpeak)/2.0DC3-14P(ANUOCONN) | IC | 2 | J2; J5 |
| LED0603_H80 | STM_LED_LED0603_H80_LED/GREEN/0 | LED/Green/0603 | IC | 3 | D1; D10; D16 |
| LGA25_P127_H180 | LTM4622_LGA25_P127_H180_LTM4622 | LTM4622IV#PBF | IC | 1 | U76 |
| LQFP64_P50_L1200X1200_H140 | ADV7511WBSWZ_LQFP64_P50_L1200X1 | ADV7511WBSWZ | IC | 1 | U37 |
| OSC4_P210_L320X250 | OCETDLJ-NF_OSC4_P210_L320X250_5 | 50MHz/LVCOMS | IC | 2 | U78; U79 |
| OSC4_P210_L320X250 | OCETDLJ-NF_OSC4_P210_L320X250_3 | 33.33MHz/LVCOMS | IC | 2 | U80; U81 |
| OSC4_P210_L320X250 | OCETDLJ-NF_OSC4_P210_L320X250_2 | 24MHz/LVCOMS | IC | 1 | U82 |
| OSC4_P210_L320X250 | OCETDLJ-NF_OSC4_P210_L320X250_1 | 25MHz/LVCOMS | IC | 2 | U83; U84 |
| OSC6_P254_L500X320 | SI9121AI-2D2-33E160_OSC6_P254_L | 125MHz/LVPECL | IC | 2 | U74; U75 |
| QFN16_P65_L400X400_H75_T | MAX13035EETE+_QFN16_P65_L400X40 | MAX13035EETE+ | IC | 1 | U77 |
| QFN32_P50_L580X580_H100_T | TLV320AIC3101_QFN32_P50_L580X58 | TLV320AIC3101IRHBT | IC | 1 | U42 |
| QFN_N20_P65_L500X500_T315X315 | TPS74401RGWT_0_QFN_N20_P65_L500 | TPS74401RGWT | IC | 3 | U53; U54; U55 |
| R0402_H40 | RESISTOR_R0402_H40_R0402_NC | R0402_NC | IC | 12 | R1; R2; R11; R12; R58; R116; R118; R119; R174; R225; R297; R332 |
| R0402_H40 | RESISTOR_R0402_H40_4.7K/5% | 4.7K/5% | IC | 40 | R3; R13; R14; R15; R21; R59; R62; R63; R109; R110; R111; R112; R113; R117; R120; R128; R129; R130; R131; R137; R175; R178; R179; R226; R266; R267; R269; R270; R277; R280; R289; R293; R305; R306; R307; R320; R327; R334; R926; R930 |
| R0402_H40 | RESISTOR_R0402_H40_20K/1% | 20K/1% | IC | 14 | R4; R5; R6; R7; R8; R9; R10; R121; R122; R123; R124; R125; R126; R127 |
| R0402_H40 | RESISTOR_R0402_H40_33R/1% | 33R/1% | IC | 2 | R16; R132 |
| R0402_H40 | RESISTOR_R0402_H40_10K/1% | 10K/1% | IC | 28 | R23; R33; R38; R39; R40; R139; R149; R154; R155; R161; R189; R231; R238; R241; R248; R251; R262; R263; R264; R265; R321; R360; R361; R362; R363; R370; R920; R1051 |
| R0402_H40 | RESISTOR_R0402_H40_1K/1% | 1K/1% | IC | 16 | R24; R25; R85; R86; R93; R94; R96; R108; R140; R141; R309; R311; R313; R314; R317; R318 |
| R0402_H40 | RESISTOR_R0402_H40_240R/1% | 240R/1% | IC | 12 | R26; R27; R142; R143; R199; R200; R227; R228; R330; R348; R358; R359 |
| R0402_H40 | RESISTOR_R0402_H40_80.6R/1% | 80.6R/1% | IC | 12 | R28; R29; R144; R145; R195; R196; R197; R198; R364; R365; R366; R367 |
| R0402_H40 | RESISTOR_R0402_H40_40.2R/1% | 40.2R/1% | IC | 100 | R30; R31; R32; R34; R35; R36; R37; R41; R42; R43; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R56; R57; R60; R61; R146; R147; R148; R150; R151; R152; R153; R156; R157; R158; R159; R160; R162; R163; R164; R165; R166; R167; R168; R169; R170; R171; R172; R173; R176; R177; R201; R202; R203; R204; R205; R206; R207; R208; R209; R210; R211; R212; R213; R214; R215; R216; R217; R218; R219; R220; R221; R222; R223; R224; R331; R333; R335; R336; R337; R338; R339; R340; R341; R342; R343; R344; R345; R346; R347; R349; R350; R351; R352; R353; R354; R355; R356; R357 |
| R0402_H40 | RESISTOR_R0402_H40_330R/5% | 330R/5% | IC | 13 | R64; R65; R75; R76; R77; R78; R180; R181; R191; R192; R193; R194; R322 |
| R0402_H40 | R_R0402_H40_100R/1% | 100R/1% | IC | 6 | R66; R927; R928; R929; R931; R932 |
| R0402_H40 | R_R0402_H40_4.7K/5% | 4.7K/5% | IC | 1 | R67 |
| R0402_H40 | R_R0402_H40_22R/5% | 22R/5% | IC | 14 | R68; R69; R70; R71; R72; R74; R115; R184; R185; R186; R187; R188; R190; R319 |
| R0402_H40 | RESISTOR_R0402_H40_49.9R/1% | 49.9R/1% | IC | 20 | R83; R84; R87; R88; R89; R90; R91; R92; R229; R230; R294; R298; R299; R300; R301; R302; R303; R304; R328; R329 |
| R0402_H40 | RESISTOR_R0402_H40_4.99K/1% | 4.99K/1% | IC | 3 | R95; R308; R373 |
| R0402_H40 | R_R0402_H40_0R/5% | 0R/5% | IC | 7 | R101; R102; R105; R295; R296; R316; R933 |
| R0402_H40 | RESISTOR_R0402_H40_0R/5% | 0R/5% | IC | 10 | R232; R236; R237; R239; R242; R246; R247; R249; R252; R261 |
| R0402_H40 | RESISTOR_R0402_H40_90.9K/1% | 90.9K/1% | IC | 6 | R233; R234; R235; R243; R244; R245 |
| R0402_H40 | RESISTOR_R0402_H40_30.1K/1% | 30.1K/1% | IC | 1 | R250 |
| R0402_H40 | RESISTOR_R0402_H40_40.2K/1% | 40.2K/1% | IC | 3 | R258; R259; R921 |
| R0402_H40 | RESISTOR_R0402_H40_887R/1% | 887R/1% | IC | 1 | R273 |
| R0402_H40 | RESISTOR_R0402_H40_1K/5% | 1K/5% | IC | 6 | R285; R288; R291; R292; R325; R326 |
| R0402_H40 | RESISTOR_R0402_H40_4.53K/1% | 4.53K/1% | IC | 1 | R368 |
| R0402_H40 | RESISTOR_R0402_H40_1.13K/1% | 1.13K/1% | IC | 1 | R369 |
| R0402_H40 | RESISTOR_R0402_H40_3.57K/1% | 3.57K/1% | IC | 1 | R371 |
| R0402_H40 | RESISTOR_R0402_H40_2.87K/1% | 2.87K/1% | IC | 1 | R372 |
| R0402_H40 | RESISTOR_R0402_H40_2.49K/1% | 2.49K/1% | IC | 1 | R374 |
| R0402_H40 | R_R0402_H40_324K/1% | 324K/1% | IC | 1 | R934 |
| R0402_H40 | RESISTOR_R0402_H40_25.8K/1% | 25.8K/1% | IC | 1 | R1049 |
| R0402_H40 | RESISTOR_R0402_H40_8.25K/1% | 8.25K/1% | IC | 1 | R1050 |
| R0402_H40 | RESISTOR_R0402_H40_19.1K/1% | 19.1K/1% | IC | 1 | R1078 |
| R0603 | RESISTOR_R0603_R_NM | R_NM | IC | 2 | R323; R324 |
| R0603_H60 | RESISTOR_R0603_H60_330R/5% | 330R/5% | IC | 4 | R103; R107; R310; R312 |
| R0603_H60 | RESISTOR_R0603_H60_4.7K/5% | 4.7K/5% | IC | 4 | R114; R183; R268; R315 |
| R0603_H60 | R_R0603_H60_13.3K/1% | 13.3K/1% | IC | 1 | R253 |
| R0603_H60 | RESISTOR_R0603_H60_33R/1% | 33R/1% | DISCRETE | 1 | R271 |
| R0603_H60 | RESISTOR_R0603_H60_10K/5% | 10K/5% | IC | 1 | R272 |
| R0603_H60 | RESISTOR_R0603_H60_5.6K/1% | 5.6K/1% | IC | 1 | R278 |
| R0603_H60 | RESISTOR_R0603_H60_22R/5% | 22R/5% | DISCRETE | 5 | R281; R282; R283; R284; R290 |
| R0603_H60 | RESISTOR_R0603_H60_51K/1% | 51K/1% | IC | 7 | R1071; R1072; R1073; R1074; R1075; R1076; R1077 |
| RJ45_HR911130C | HR911130C_RJ45_HR911130C_HR9111 | HR911130CE | IC | 2 | J3; J9 |
| SLP2510P8 | RCLAMP0524P_TCT_SLP2510P8_RCLAM | RCLAMP0524P.TCT | IC | 3 | U38; U39; U41 |
| SON10_P50_L285_H100 | TPS51200DRCT_SON10_P50_L285_H10 | TPS51200DRCT | IC | 4 | U11; U26; U36; U52 |
| SOP16_P127_L1030X1065 | MT25QL256ABA8ESF-OSIT_SOP16_P12 | MT25QL256ABA8ESF-0SIT | IC | 4 | U2; U3; U18; U19 |
| SOT23_3_H100 | 2N7002-7-F_SOT23_3_H100_2N7002 | 2N7002 | IC | 2 | Q1; Q2 |
| SOT23_5_H130 | SN74LVC1G08_SOT23_5_H130_SN74LV | SN74LVC1G08DBV | IC | 2 | U15; U45 |
| SOT23_6_H145 | TPS3808G18DBV_SOT23_6_H145_TPS3 | TPS3808G25DBV | IC | 4 | U4; U8; U17; U23 |
| STEREO_JACK_STX-3120-5B | STX-3120-5B_STEREO_JACK_STX-312 | STX-3120-5B | IC | 1 | J7 |
| TF-15X15 | TF-15X15A_TF-15X15_TF-15X15 | TF-15X15 | IC | 1 | J25 |
| TOM-1545P-R | TOM-1545L-R_TOM-1545P-R_TOM-154 | TOM-1545P-R | IC | 1 | U46 |
| TP_HOLE | TP_SMD_S_TP_HOLE_TP_HOLE | TP_HOLE | IC | 20 | TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20 |
| TSSOP16_P65_L640_H120 | SN74AVC4T245PW_TSSOP16_P65_L640 | SN74AVC4T245PW | IC | 3 | U12; U27; U47 |
