查看: 966|回复: 8
[allegro16.3][4层]MCIMX6UL-EVK评估板(PCIMX6G3CVM05AA+DDR_SODIMM+DDR3)原理图...
发表于 2019-12-20 14:39 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.3][4层]MCIMX6UL-EVK评估板(PCIMX6G3CVM05AA+DDR_SODIMM+DDR3)原理图和pcb文件
% o& \6 ^. ?: Y7 M# a2 z; w
文件描述:
5 Q1 i- \+ O! t9 o* v5 t
1. 作品用途:MCIMX6UL-EVK评估板
2. 软件版本:allegro16.3
3. 层数:4层
4. 用到的主要芯片:PCIMX6G3CVM05AA+DDR_SODIMM+DDR3
5. PCB尺寸:2661.41*1667.23 MIL
作品截图如下:
* ]! [0 i+ z% \, J8 `! v
顶层截图:
' g9 [0 F' A2 Y8 Y5 g1 U, o6 L5 s
底层截图:
- @* B" u, J/ i% t- u
* |, |) H( E& k  j# d/ M4 e5 F
全层截图:
; v4 I! f1 N  T) A6 n( [
" t4 f5 ]7 |; v9 E7 \6 ?5 r4 u
叠层阻抗信息:
1 V( T, X$ K9 @
BOM:
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
97C04SW_DIP-4_SM_97C04_IC_1.65 MM_51DHN-04IC1SW601
0402_CCCAP_NP_0402_CC_DISCRETE_0.55MM_0.22uFDISCRETE12C102; C103; C108; C109; C111; C112; C113; C118; C119; C121; C123; C124
0402_CCCAP_NP_0402_CC_DISCRETE_0.65MM_4.7uFDISCRETE12C107; C117; C223; C301; C304; C308; C316; C709; C718; C721; C723; C732
0402_CCCAP_NP_0402_CC_DISCRETE_0.55M_10.22UFDISCRETE28C201; C202; C203; C204; C205; C206; C207; C208; C209; C210; C212; C213; C214; C215; C216; C217; C218; C219; C220; C221; C226; C401; C402; C403; C404; C405; C413; C737
0402_CCCAP_NP_0402_CC_DISCRETE_0.55M_20.1uFDISCRETE45C222; C224; C303; C305; C306; C309; C310; C311; C313; C315; C318; C319; C321; C322; C323; C409; C410; C501; C703; C706; C707; C708; C710; C713; C715; C717; C719; C722; C724; C726; C728; C731; C733; C735; C736; C740; C741; C742; C802; C804; C806; C808; C811; C815; C818
0402_CCCAP_NP_0402_CC_DISCRETE_0.55M_32.2pFDISCRETE2C229; C230
0402_CCCAP_NP_0402_CC_DISCRETE_0.6MM_11.0UFDISCRETE8C312; C407; C411; C412; C738; C809; C812; C816
0402_CCCAP_NP_0402_CC_DISCRETE_0.59MM_18PFDISCRETE8C415; C416; C417; C418; C505; C506; C507; C508
0402_CCCAP_NP_0402_CC_DISCRETE_0.56MM_0.022UFDISCRETE1C720
0402_CCCAP_NP_0402_CC_DISCRETE_0.55M_41000pFDISCRETE1C739
0402_CCRES_0402_CC_DISCRETE_470-75555_1KDISCRETE8R101; R511; R514; R617; R618; R619; R620; R624
0402_CCRES_0402_CC_DISCRETE_470-75557_10KDISCRETE17R201; R202; R203; R303; R315; R317; R318; R319; R320; R321; R322; R402; R403; R710; R722; R733; R740
0402_CCRES_0402_CC_DISCRETE_470-30776_240DISCRETE3R204; R205; R209
0402_CCRES_0402_CC_DISCRETE_470-30315_470DISCRETE1R206
0402_CCRES_0402_CC_DISCRETE_470-80487_1.5KDISCRETE3R207; R208; R512
0402_CCRES_0402_CC_DISCRETE_0.4 MM_47010KDISCRETE28R301; R503; R507; R613; R623; R625; R626; R631; R633; R634; R636; R637; R638; R639; R640; R641; R643; R644; R645; R646; R647; R648; R649; R650; R651; R652; R653; R654
0402_CCRES_0402_CC_DISCRETE_470-75394_0DISCRETE16R302; R304; R305; R306; R307; R309; R310; R323; R324; R404; R412; R515; R517; R701; R709; R726
0402_CCRES_0402_CC_DISCRETE_470-75589_10DISCRETE7R406; R407; R408; R409; R410; R411; R413
0402_CCRES_0402_CC_DISCRETE_470-79978_1MDISCRETE2R513; R755
0402_CCRES_0402_CC_DISCRETE_0.4MM_470-2.0KDISCRETE1R520
0402_CCRES_0402_CC_DISCRETE_0.40 MM_47215KDISCRETE1R706
0402_CCRES_0402_CC_DISCRETE_0.40 MM__1147KDISCRETE1R707
0402_CCRES_0402_CC_DISCRETE_0.40 MM__21.5MDISCRETE1R708
0402_CCRES_0402_CC_DISCRETE_470-31082_160KDISCRETE2R713; R723
0402_CCRES_0402_CC_DISCRETE_470-75597_100KDISCRETE3R715; R725; R735
0402_CCRES_0402_CC_DISCRETE_470-31088_180KDISCRETE1R717
0402_CCRES_0402_CC_DISCRETE_470-31015_40.2KDISCRETE1R718
0402_CCRES_0402_CC_DISCRETE_470-31093_200KDISCRETE2R719; R724
0402_CCRES_0402_CC_DISCRETE_470-31135_464KDISCRETE1R720
0402_CCRES_0402_CC_DISCRETE_470-31102_243KDISCRETE1R721
0402_CCRES_0402_CC_DISCRETE_470-30164_51DISCRETE3R734; R736; R737
0402_CCRES_0402_CC_DISCRETE_470-30454_100DISCRETE1R757
0603_CCCAP_NP_0603_CC_DISCRETE_1MM_15022UFDISCRETE9C101; C106; C116; C211; C314; C705; C714; C727; C817
0603_CCCAP_NP_0603_CC_DISCRETE_1.016MM10uFDISCRETE15C120; C122; C225; C408; C701; C702; C704; C711; C712; C716; C725; C729; C730; C801; C803
0603_CCCAP_NP_0603_CC_DISCRETE_0.9 MM_4.7uFDISCRETE1C805
0603_CCBEAD_0_0603_CC_DISCRETE_0.95MM_120OHMDISCRETE2L801; L802
BGA96_0P8_9P15X14P154G_DDR3_SDRAM_256MX16_96P_BGA96MT41K256M16HA-125:EIC1U201
BGA289_0P8_14X14PCIMX6G3CVM05AA_PBGA_289P_BGA28PCIMX6G3CVM05AAIC1U101
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4547uFDISCRETE1C813
CON8_FLASH_1P1MM_SMCAH11-08163-S107_8P_CON8_FLASH_CAH11-08163-S107IO1J301
IND_4020IND_IND_4020_DISCRETE_2.2MM_1801uHDISCRETE3L701; L702; L703
MLP8_1P27_8X6N25Q128A13EF840E_9P_MLP8_1P27_8N25Q256A13EF840IC1U303
RC0603_OVRES_RC0603_OV_DISCRETE_470-80860DISCRETE1R732
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440DISCRETE3R728; R729; R730
SOD523DIODE_SCHTKY_SOD523_IC_0.7MM_48RB521S-30IC2D702; D705
SODIMM_67589CONN_EDGE_200P_SODIMM_67589_IO_DDR_SODIMM_EDGE FINGERSIO1P801
SOD_523DIODE_SCHTKY_SOD_523_IC_0.7MM_4RB521S30T1GIC2D102; D103
SOT23-3-1P95RT9169_3P_SOT23-3-1P95_IC_1.295RT9169-33GVLIC1U701
SOT23-3-1P95RT9169_3P_SOT23-3-1P95_IC_1.2_1RT9169-18GVLIC1U705
SOT23-5RT9193-33PB_SOT23-5_IC_1.295MM_RT9193IC1U704
SOT23-5_AUM1750S-00_5P_SOT23-5_A_IC_1.25UM1750S-00IC1U707
SOT323_32SK3018_SOT323_3_IC_0.9MM__RYU0RYU002N05IC2Q501; Q701
SOT323_32SK3018_SOT323_3_IC_0.9MM_480-72SK3018IC6Q702; Q703; Q704; Q705; Q706; Q707
SOT-23SGM803_SOT23-3P_SOT-23_IC_1.25MUM803RSIC1U501
SOT_143UM805_4P_SOT_143_IC_1.22MM_315-UM805REIC1U708
SW_DIP2_SMSW_DIP-2_SW_DIP2_SM_IC_1.65 MM_DHN-02IC1SW602
TESTPOINT_35MILT POINT R_TESTPOINT_35MIL_IC_0.TP_35MILIC38TP212; TP214; TP216; TP301; TP303; TP502; TP503; TP504; TP505; TP506; TP507; TP508; TP701; TP702; TP703; TP704; TP705; TP706; TP707; TP708; TP709; TP710; TP801; TP802; TP803; TP804; TP805; TP806; TP807; TP808; TP809; TP810; TP811; TP812; TP813; TP814; TP815; TP816
TPAD_015TESTLOOP_TPAD_015_IO_0.1MM_211-TPAD_015IO10TP201; TP202; TP203; TP204; TP205; TP206; TP207; TP208; TP402; TP403
TSOT23_8_0P65_2X1MP2159GJ_8P_TSOT23_8_0P65_2X1_IMP2159GJIC2U702; U706
TSOT23_8_0P65_2X1MP2144GJ_TSOT23_8P_TSOT23_8_0P6MP2144GJIC1U703
XTAL2-3P2X1P5-SMXTAL_XTAL2-3P2X1P5-SM_IC_0.65MM32.768kHzIC1Y502
XTLOSC4_3P2X2P5MM_SMOSC3_XTLOSC4_3P2X2P5MM_SM_IC_1.24MHzIC1Y503
附件:
原理图和PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
7 m. R& u. ?8 ^( x  c! N
    2021-5-20 15:23
  • 签到天数: 48 天
    [LV.5]常住居民I
    发表于 2021-3-11 09:18 | 只看该作者
    可以下载吗  学习下
    发表于 2021-3-11 10:07 | 只看该作者
    very good, thanks a lot
    2025-11-26 15:28
  • 签到天数: 884 天
    [LV.10]以坛为家III
    发表于 2021-7-8 13:26 | 只看该作者
    ddddddddddddddd
    2 W1 d9 _7 u2 B$ D6 Y
    发表于 2021-10-29 14:34 | 只看该作者
    参考SODIMM_204金手指的尺寸
    发表于 2022-1-5 13:01 | 只看该作者
    4+.123435692
    发表于 2023-9-13 14:19 | 只看该作者
    看看66666666666
    GMT+8, 2025-11-27 02:49 , Processed in 0.171875 second(s), 27 queries , Gzip On.
