第二章 虚拟地址到物理地址转换2 Z6 ~" [# S# Z$ `% C: j
; v$ W7 n0 I- x/ t3 K/ X# c$ C& j7 D5 ~
2.1 MMU 硬件VA到PA转换% z+ L( |- @7 G( w8 T! [
4 `2 X8 m, \; _) m
9850K 的cpu是Cortex A7的。3 s c2 m( z8 V- M, l( ]& i9 y
. x( }4 Z5 n. w; q. O7 H# X4 w
. _% `. g: v9 C/ g' B; KThe Cortex-A7 MPCore processorimplements the Extended VMSAv7 MMU, which includes the ARMv7-A Virtual MemorySystem Architecture (VMSA), the Security Extensions, the Large Physical AddressExtensions (LPAE), and the Virtualization Extensions.$ y! p: J3 R6 f+ v. f
4 @2 v3 p4 U; u$ J+ m9 y* J1 r. o4 Z5 K% A2 |' v4 a
5 Q0 B- X- t: M$ p! ?6 |! V2 e
+ v( e" \& x8 ~2 Q
+ B: C- q4 k J! W: xVMSAv7 defines two alternativetranslation table formats:
$ ~) \) y9 |6 Y) U7 _
* K, [$ U' J4 O, ]! p, L9 U; c/ G* E J* V3 o( g U+ b0 N/ E
Short-descriptor format6 y9 V, ~( T# S5 k
8 Y! N7 ^3 @) s. O# `
9 ~$ F* }# c4 U$ i3 b% LThis is the original format definedin issue A of this Architecture Reference Manual, and is the only7 \; V8 ^* `$ K' E/ m- I
. J {& p( N, @
' t8 ` H' x# h1 `7 x# \4 \format supported on implementationsthat do not include the Large Physical Address Extension. It8 |" r9 P% g0 T# r% ~/ F% l, q
/ s/ S1 O4 d t
6 z- [ _" w& Z& V% ]! j" wuses 32-bit descriptor entries inthe translation tables, and provides:
: r2 [) u" n- n
* x. z5 J5 n: g6 F% F* f2 t3 i0 _9 Q( d7 ~5 v
• Up to two levels of address lookup.9 s# G/ F) i/ H9 y3 U$ A; o
. v( Y% O* y( D! G5 M4 o; o1 V/ c; k8 t# j, P% s
• 32-bit input addresses.
. D+ c: W: @8 U$ I: C, p* L1 y
8 ?! P7 w8 y" k3 z# Q4 Z7 f0 f' | ?- D) s" t& f
• Output addresses of up to 40 bits.
: v3 ]' Z" R. l; R5 z* U5 g
* A0 W# Y) s$ A5 D
& U. m$ q9 s4 |: o5 {" C• Support for PAs of more than 32 bits by use of supersections, with16MB granularity.2 i9 ]. B; `6 |4 {7 u6 M
( w% O" g& ]$ S* m1 P/ F8 F8 y
) d9 M3 ~, Y' Q' l• Support for No access, Client, and Manager domains.0 @' S( a& }! O' n
7 J$ {) T; T) y; d. }. u- j5 c* \1 N
1 k: _5 B3 k& E
• 32-bit table entries.6 y W p3 J7 g: M6 d7 x J
" Y8 H, \" X8 N+ e( j ~! K% R: B- g4 E9 E! r3 q8 h
) J. t! S( u" |3 v: C+ U& a
( n; B t+ X# K0 G5 _: ?4 { ALong-descriptor format
4 Y% l5 H$ ^) X% q1 N9 |- w! o1 w: E$ ]4 F/ e6 v* Q" i
" Z- o, z9 r+ A
& _+ t/ F0 ~- _+ j
5 r3 N# v5 n7 T% e9 [* h: Z$ H9 ^- p3 ?% j$ Q7 _
4 g- F3 T! |5 i) ]) Y
9 [5 H: ?( t! b D
. [- o5 T" l/ L! T8 A+ H6 J( s& Q) u3 H) T
6 ]8 @' Z) n) V( o2 N L+ Q5 I( I
. o$ g/ \6 p+ |1 d% M7 W 3 Y0 ^9 k( d- ]" M l# e/ B
; @/ g5 z7 B6 A+ ?0 e8 `
& o( _3 u) S5 W2 `$ I: |
# A4 a" p1 m0 f; ?% K
5 D K3 }# n0 f8 P6 B- U# [ |
