記事本內容如下所示,注:我在自己家里電腦導入可以成功,惟獨在公司里的電腦行不通,' J) e% t* \0 p5 z& r o
自已做的part Type 庫也有拷到公司里,也有添加自已做的part Type 庫,導入PADS Layout- i8 N2 [& P; d) |8 n) e9 Z8 L
就沒有自己所做的PCB封裝.5 v$ }- }$ Q' E$ c$ Z: s- X. p
8 ~" |. I! e) a! V# K9 cReading file -- e:\PADS Projects\padsnet.asc
Q3 }# k% k$ W. ]1 _# a" I0 s: kCan't find part Type item < MS-CARD_PART >6 y$ i; l3 j8 i# {
JP2 [email=MS-CARD_PART@MS-CARD]MS-CARD_PART@MS-CARD[/email]" l! [8 C5 S" s
Can't find part Type item < SD/MMC3.2_PART >
. F6 N) Q1 i7 EJP3 [email=SD/MMC3.2_PART@SD]SD/MMC3.2_PART@SD[/email]' ~( p9 n; g- @) i9 M! J
Can't find part Type item < SM/XD-CARD_PART >$ K- q) j: O7 h
JP1 [email=SM/XD-CARD_PART@SM/XD]SM/XD-CARD_PART@SM/XD[/email]
g* C/ X* w. d& I8 g+ xCan't find part Type item < USB-MINI_PART >' c7 _% h3 ?, F1 I
JP4 [email=USB-MINI_PART@USB-MIINI]USB-MINI_PART@USB-MIINI[/email]# M/ e9 ^$ F( a9 N% j0 v( @& C
Can't find part Type item < AU6457 >
+ K$ f9 z: E8 s. V9 s( {% DU1 [email=AU6457@AU6475A]AU6457@AU6475A[/email]
5 H- W: b" X, w- b) z% i& UCan't find part Type item < PH2.0-5_PART >+ l( h# w$ D$ W8 g+ ]6 t+ i
JP6 [email=PH2.0-5_PART@WAF2001-90S5]PH2.0-5_PART@WAF2001-90S5[/email]$ p* }9 Q7 c) M
Can't find part Type item < AMS117-3.3V >
+ F; h8 G) m- _# N3 N9 SU2 [email=AMS117-3.3V@AMS1117]AMS117-3.3V@AMS1117[/email]
' a u. ^% U( @) |/ T/ v( d; SCan't find part Type item < CF-CARD_PART > r! P$ J; E7 V6 ~. i7 T1 H
JP7 [email=CF-CARD_PART@CF]CF-CARD_PART@CF[/email]; }; k% D# e% a# F% ?6 J. K
*Part name not found JP7. f6 r3 g1 u7 R, T$ i- `2 |
JP7.41 * B1 R* i4 d) T: d5 U. x
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFRST
' a6 ~( W. s( n) A6 s, G*Part name not found JP7: Q5 u6 o3 j3 ^5 u# `: Z2 j) o0 E
JP7.5
8 W6 P( ^& s+ @/ z1 c+ P% z6 q8 m*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD69 D9 H! R ~ m/ ^
' c' C& c0 H6 X) k6 uJP7.23 . t' g" {% }( W+ I& D) D
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFSA21 `3 k5 Q2 p! ]6 u' e, n
*Part name not found JP7% }9 F6 Z9 l) V1 |
JP7.19 . ~7 U0 R; h# K
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFSA1/ ?' }( }0 e1 B. Z* O* b$ [ e& a' ^
, D7 ^8 Y" P/ }2 b c0 oJP7.21
6 ]* [5 k- `9 c*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFSA0
1 h! M- B: W* A' ~*Part name not found JP1
1 y6 j8 n- ^' P, ~; |- yJP1.A11 JP1.7 9 e( W9 I5 |8 \0 v F* J3 g
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDD11 L8 r( m9 O( K# e
2 k. I' @1 ~; JJP1.A10 JP1.6
7 ], k Q. }+ a% ?/ @. W6 ?*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDD0% _; ?8 s: N) ~ N
*Part name not found JP1- A2 d8 |3 Z0 O q# m
JP1.25 JP1.5 JP1.A8 ! b4 i! C6 ]8 k8 M1 ^
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDWPN% {7 ]9 w9 N6 L" T' U
*Part name not found JP1) c: v2 M6 h9 U ^8 U! D
JP1.4 JP1.A7 R8.1 ; z# H3 N) s- |/ \/ y+ f& r
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDWEB, z0 ~" d, W, } {% w7 {
*Part name not found JP14 o) G/ y9 m" S; r0 q0 A3 G( {+ L
JP1.2 JP1.A5 + L( S+ w j; p# c
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDCLE" N. D1 [# v4 H7 t8 Q) w% n
*Part name not found JP1. k; z5 U. B. i3 m* T5 S" x4 y6 ~" i
JP1.3 JP1.A6 ; y' ^3 s Z. v1 X
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDALE
) Z0 h) }6 T& E/ a6 c; l! u/ C# U6 j8 [*Part name not found JP1
7 T$ v! s& U$ D8 C4 j( CJP1.21 JP1.A4 R7.1 , R+ C5 F0 M: Y' b& K
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDCEB
( r: H+ k O: j) s* {*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SDCLK
2 \7 x( P4 u: H7 n$ C w9 _*Part name not found JP2, E: a5 Z) j7 @( m* ?5 N
JP2.4
5 f0 D2 i3 z; s j% R( m1 h; C. w; X*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSD2
+ K, p* g& |4 x& X: E*Part name not found JP2
' o% K$ U" ~ ?( q3 A. D; S- F% tJP2.3
1 x5 V0 E5 K; N*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSD0
; |+ @( f& L" f0 Q*Part name not found U29 B: m- y* @% l4 ^2 z; \; p9 h5 S6 ^
R13.1 R15.2 U2.2 C14.1 C13.1
5 f, C/ b/ c9 |+ z/ H*Part name not found JP7
# x9 E- S3 ~+ g, U- m" y( x9 @C16.1 R4.1 JP7.34
! M, o% r4 ` Z b; n; C2 U) Z6 ~! t*Part name not found JP3
! m1 {( r. |" Y+ X& T7 ?1 [JP3.4 C5.1 ; T$ S5 e- X& s3 F5 E, X" @6 y* n
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SDPWR s6 v+ G2 ?: }7 f
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSPWR6 W5 e8 ?+ h7 J# k. G
*Part name not found JP1+ ?! e" J: z9 E# k
JP1.A18 R8.2 R5.2 JP1.22 JP1.12 + e, g3 w1 t! i+ u/ K' b! R
*Part name not found JP7. b' j; I+ e: Z5 c
JP7.30
I+ P( Z4 T/ T' R, Q. O*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD14
/ A1 e, y+ M% k7 a. n*Part name not found JP7
. d* J8 }9 a+ I6 `JP7.6
* ?! _1 _. [& K8 \/ e( r+ F*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD7
$ D- @: ?6 s$ ?0 T; r9 D. i*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFRDN
' y y$ {8 |' m5 I# I* p8 L*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFWRN
9 I; E( P/ H; P0 h*Part name not found JP1 P2 m& P1 J. w- V5 I, I* b1 x
JP1.16 JP1.A17
: [" R* @5 v) F5 I9 u*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDD73 | Q! _' T$ h1 K U- I [/ ?
*Part name not found JP11 E9 Z0 V2 U1 t# R
JP1.15 JP1.A16 " y8 o2 w& R9 ~0 m4 O
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDD6# x; F: C9 b k+ V
*Part name not found JP1, U6 y7 I! Y) @5 L
JP1.14 JP1.A15
% n$ m9 s$ U. C% k*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDD5
8 c% r0 D1 c2 q6 A& t8 Y*Part name not found JP1
( W8 m6 [' b& w4 @9 EJP1.13 JP1.A14 4 H3 q+ d6 z; x" u& C
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDD4+ q0 j2 C- w- y# ]1 x" ~
*Part name not found JP1: T8 l& _$ S! R0 L' h" S& Y5 M y
JP1.A13 JP1.9 8 X. _' C$ K/ f! D# o( v5 f5 f
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDD3) q8 X% B* k; G0 A+ Y1 K
*Part name not found JP11 }7 ?. d2 W3 Q4 I
JP1.A12 JP1.8 2 s! X/ @8 P9 l8 D, B- B8 m; `( G' Y
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDD2
) k4 x4 i7 {$ m( {9 f/ [; O" g2 M*Part name not found JP3, D+ y/ b. t: ?3 Q4 V1 l
JP3.1 ) u! Q; A* c/ m
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SDD3
; z9 z! ~* C* q*Part name not found JP38 b' D& Q5 x5 ~2 W* B1 _( Q
JP3.9 8 Y( v9 \8 k2 M/ c0 M5 P' l
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SDD2+ ] X( ^2 Y; w6 L0 w9 e# \
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSCLK
! `0 r- I! j( v3 W# C! Z/ {1 v*Part name not found JP2 C' W8 O% q/ T+ f. v2 k- s4 I' Q
JP2.5 7 t4 P& q T* k
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSINS
% v3 j* f( f. h/ D: j*Part name not found JP7* [5 y Q' `. t8 L# p/ c* {2 _
JP7.11 JP7.50 JP7.8 JP7.10 JP7.12 6 |- r1 V2 ^# }' ^" {
*Part name not found JP7" s5 j% U K& c1 d: A5 b0 ]; T/ d
JP7.14 JP7.16 JP1.1 JP1.23 JP1.A1 1 `. H+ j) n* c, f% S1 O
*Part name not found JP19 o# M& s* O4 ?; k; ~
JP1.A9 JP3.3 C5.2 C6.2 C8.2
4 `; E9 U4 g: E. P: w*Part name not found JP4: i- Z" L, W2 q; T
C7.2 C10.2 JP4.4 JP4.5 JP6.4
8 N2 @. e% O# X( m# O" X7 W*Part name not found JP6
3 b% R% S* p4 I9 X! `" H& Z5 FJP6.5 C9.2 C12.2 U2.1 LED1.K - {. A+ o6 x( T" f- z: w! p
, x9 U/ T0 |* EJP7.7 JP7.9 JP7.17 JP7.15 JP7.39
6 ^& g" [, L( @) J9 U& @*Part name not found JP1" p) n% {/ k8 o1 E" B/ o# o
C18.2 C19.2 JP1.26 JP1.11 JP1.10 8 q, M) D1 a) o) h% B$ V
" B; {0 U4 l& }( q7 W/ O6 KC20.2 R2.1 JP7.1 JP1.18 C11.2
, p- ?& [0 q. K+ l5 B*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal VCC1.8
) `4 \- [) @8 e' X6 ~8 Q*Part name not found U1) M7 K/ q6 [+ l' K7 Z k+ @; G6 e
U1.1 JP7.29
) C/ Z2 x# f, g7 @*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD132 n- F6 o$ P' E- h+ `1 ]# u
*Part name not found U1. _) J! x: d+ e( s0 P
U1.2 JP7.4 8 `& U# A! A7 e- n, q+ p
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD5: Z- r; }) Q$ a% l z
*Part name not found U19 ?5 T# e, ] J! C+ I# Y7 G
U1.3 JP7.28
- B9 J& ]( A" B% _*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD12: ^$ F- J8 W* j- N
; D; v7 Y/ i0 Z' Y, [, p0 F! }JP7.3
5 R7 D" }6 ]* `! W; i( [*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD4; s7 G+ U% K k# h! ` q
; d4 i; o* T4 z" m$ U2 \JP7.27 6 J5 d0 N+ l$ A, }' c" U8 }
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD11
0 C& F, i6 S: I- ~*Part name not found JP7
% s1 j0 k# y$ bJP7.2
% h4 `, Q, a- \ S% `" X*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD3
F; } Z' I* f*Part name not found JP7
: e% U R, r& q8 }% R+ M8 f. y, kJP7.25 C15.1
# b% [/ K( y6 v5 K9 E*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFCD
' {# Z0 w% U; H; ?% `, W*Part name not found JP70 o& Z+ u; e6 L3 V
JP7.49 + n, R" ?' @. C2 {9 J* e8 s. a
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD10- v4 v! V$ c( A1 z6 z5 J' s# B
0 X9 N* t, ]* n }JP7.48 0 | ?0 i( R* I0 r4 N+ |: `
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD9
: D/ Z% \. c* X*Part name not found JP7+ ]6 X Z; _. C W5 Z- j9 K/ V
JP7.18
6 D; H7 K) }; @; M4 g3 h, y*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD2- N2 a/ ^$ M. M
*Part name not found JP7$ w' d2 K8 B9 I5 a; C
JP7.47 2 e- s8 T: Z& i4 {; g6 X
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD83 O6 W* L& m( c: N0 _9 i s
*Part name not found JP78 G4 O+ H3 H9 ^- v0 W. Y$ V1 q
JP7.22 * L* A q) S% A6 N8 h2 ^3 T" j& h
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD17 X- ]7 I9 U3 x- I0 Y6 ^
& G: `& n3 }1 c; V3 L2 H1 J, nJP7.20
: k% V4 F) |( N: E5 W$ }*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD03 q. {' f9 {9 [
4 Z# g7 e- z: z$ k. TJP4.3 JP6.3
/ Q1 V; P3 B$ V- P*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal DP
7 P6 K* Y, z( o. T5 {*Part name not found JP4) h! \! Z a2 q, q$ A O8 M- C
JP4.2 JP6.2 ' _. s7 {- a' q$ x% c7 ?
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal DM
' C, J( u( G" O, m0 o: K0 t*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$95441 m& j9 v0 S; J6 [& |, A; A* K4 y
*Part name not found JP7- o0 v4 r+ |1 q% y8 d' `
R3.2 JP7.35 C17.1 % w; `" v6 N6 ]9 a
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFWRN1
3 U! e- x v2 T*Part name not found JP7
2 J8 M$ S) V- W- r+ `# P/ b1 eJP7.42 ?) W( O) L9 g0 V2 v. R& V
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFWTN' T9 n/ ?: `) { B1 \) L$ j
*Part name not found JP1$ g3 I% U' S6 g4 u( M$ [
JP1.19 JP1.A2 R5.1 # g, x1 _5 f' B% j; ^. S
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDRBY
" T6 V$ O5 m d& {, C*Part name not found JP1, _5 ]# s8 t0 h5 }3 C
JP1.20 JP1.A3 R6.1 ! Z% T8 w+ i( j' ~) f
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDREB
! [8 v2 P8 e" K*Part name not found JP1
* _4 q& a* A& }JP1.24
P8 k0 P2 H/ j6 m' W" R*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SMCDN' X/ {; Q' n5 \ O
*Part name not found JP3/ f/ D* Z1 G! U
JP3.2
$ \, u9 ]- }/ K0 H% F* k*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SDCMD% R- G+ f! }2 o6 b" P4 u, j* h
*Part name not found JP78 b4 m! u+ A0 d1 g$ b; }' P3 _6 U
JP7.13 C4.1 JP7.44 JP7.32 JP7.36 3 ~& U$ O. g# x6 {) ]7 p3 f
) z0 p* X+ C$ O0 s8 s* J+ jJP7.38
3 K" f- l( P1 M0 Y- ~5 ^; J*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFPWR; b& {, [, w" e; h5 \
*Part name not found JP1- t) L' M1 C; U$ I) a9 u
JP1.A19
$ i0 H* K" `# f' l*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDCD6 r3 E5 S8 i: e& N1 n/ Q4 S2 ?! j
*Part name not found JP3" c/ k/ j3 R' j) \* W" \
JP3.7
9 C: A0 w0 x$ {; n- {- p. J4 Q*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SDD0* ^5 g" e# a: Q
*Part name not found JP31 a6 I/ t( L3 t6 g8 X
JP3.8 8 X) b3 A f. z! \4 X' ]
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SDD12 a* Y; V$ ?4 S% A
*Part name not found JP30 J5 `4 Z8 ]7 T
JP3.10 + D( ]7 b. C: H! @, p
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SDWP3 }0 K7 S- `7 X7 r0 U3 M8 Y. p7 ^
*Part name not found JP39 W" u, l4 N8 I0 X) x
JP3.11 4 v5 k3 L5 u4 {, r+ L5 Q8 \) I
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SDCD" _7 o* R8 \7 W5 ~ z
*Part name not found JP2. o5 f- K0 \% J& U
JP2.1 8 t5 h2 t& x# e* z9 B8 F* w, y9 z
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSBS
( z' G" s5 v* { m5 B9 E# W*Part name not found JP39 [+ ?+ e) S! E; E
R9.1 JP3.5 C6.1 2 X1 h& O: O& x( E0 |! A* B" C
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SDCLK1
3 b; J' ~7 {/ D; o5 C, q6 K*Part name not found JP2
% e% T: D+ l7 H& R5 rJP2.2
! [7 u- G) Q* O' |* X*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSD1
! x% o% n, O/ F/ B9 \*Part name not found JP4: k, e- ~: Y3 |; o7 l
L1.1 JP4.1 JP6.1
# Q( G7 w' J7 y+ ~2 _*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal +5V. ]+ ^/ i( H2 N
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDCISN
: O8 E& Q. O! C( n: E) c9 c' e*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal DECV
1 f) I! v* e. R3 J* t& M9 l*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal VCCREG
* t* }4 o9 C! V4 f6 Z9 q*Part name not found U2
6 H; R9 O% l# r+ p' c3 E6 VR11.2 L1.2 U2.3 C12.1 C11.1
/ n% @+ b5 K0 v: D% u$ W- \5 D& B5 W*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CLED
; R1 i! q; n, k*Part name not found JP7
+ w8 a( B4 T; l# k; n, ~+ SJP7.31 $ f* |& T! P3 k# i- [( b
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD15/ x( z% Y- x7 {, e
ATTRIBUTE VALUES
$ P6 u4 f/ ~; e& L) h7 ]0 oError: Component U1 not found
* o' m8 V3 g K" x9 `- ]/ }Warning: deleting signal CFRST. T# j$ ^" @: B. F0 N
Warning: deleting signal CFD6
) N- p* ?' P- m7 T0 OWarning: deleting signal CFSA23 F+ k& e5 H- e: f x3 A' r6 W
Warning: deleting signal CFSA1
- d0 B( R. N K' B9 PWarning: deleting signal CFSA0# q/ c7 W6 S. A# H$ d
Warning: deleting signal XDD15 V; o0 F3 c; Z/ [- ~8 y$ F
Warning: deleting signal XDD0
. R3 I- `8 i0 E: `, W6 dWarning: deleting signal XDWPN
$ [) A- y( y+ h* h' S- LWarning: deleting signal XDWEB
6 V5 h m& `5 g: T* \, P' X MWarning: deleting signal XDCLE
; r0 \4 c6 m7 JWarning: deleting signal XDALE; X: K5 a& k& d1 x3 c& ~
Warning: deleting signal XDCEB) J9 A) |8 v2 X7 ]& o5 ^3 B
Warning: deleting signal SDCLK
2 t1 F; U$ G: p% V) C X7 NWarning: deleting signal MSD2
& z) b2 i& m( t! ]$ S4 XWarning: deleting signal MSD00 @9 u6 U! }* A9 \$ ~( O. d
Warning: deleting signal SDPWR& s, n6 M" N* u* |: q4 H
Warning: deleting signal MSPWR0 D( s" y+ c0 F4 C; }% ?+ y/ f) F5 b
Warning: deleting signal CFD14/ S* H' z- P$ N
Warning: deleting signal CFD7 g6 {. B- K l' J
Warning: deleting signal CFRDN
9 ~5 V" A, ` V" DWarning: deleting signal CFWRN
* x' T0 j" {7 eWarning: deleting signal XDD7
; D( r/ A& j6 O3 i, {8 hWarning: deleting signal XDD6
/ x( Q# t2 F# {( gWarning: deleting signal XDD5
! i6 O- c, K6 t- m9 F# {) qWarning: deleting signal XDD4- N+ v5 T5 b. b$ `3 v
Warning: deleting signal XDD3
' H" B& K% H' U0 _- v/ h* rWarning: deleting signal XDD2
/ Y, }# `; y' yWarning: deleting signal SDD3
( N) @4 ]2 p+ R$ o: m) H6 g. x6 @Warning: deleting signal SDD2
3 L; u! k1 R8 iWarning: deleting signal MSCLK
5 }4 E9 `# {( f" M, [5 e; ZWarning: deleting signal MSINS
7 u K6 W. v. L2 r8 D9 BWarning: deleting signal VCC1.8
) K1 U' f4 F0 _" oWarning: deleting signal CFD133 `2 ^* E9 @( E: \* t( U
Warning: deleting signal CFD5
) Y R9 [8 }6 V! q8 GWarning: deleting signal CFD12* f8 O2 I, O M; E& b4 Y* H
Warning: deleting signal CFD4
; x& @8 O4 E! @$ @; W$ m) V1 _Warning: deleting signal CFD11$ U- T, T& j2 v" l
Warning: deleting signal CFD3: Z' v% w1 n/ R, g6 w
Warning: deleting signal CFCD0 X# s7 C, O. R/ k
Warning: deleting signal CFD10
5 L: N# [. `! `0 U# @Warning: deleting signal CFD9
1 q! d' W7 F% B* _: D/ g% }Warning: deleting signal CFD21 V' [4 W1 d8 F* c
Warning: deleting signal CFD8
: Z0 G# P& p0 cWarning: deleting signal CFD1 E2 S! G3 |: c/ \/ n U* P
Warning: deleting signal CFD0
* f! t) t2 l. ]' R) n+ ^& Z- G" t9 `Warning: deleting signal DP
6 S6 w6 G/ ]9 T+ b, }3 F6 JWarning: deleting signal DM' J1 Y& u4 Y/ Z+ f% k0 G, ^
Warning: deleting signal $$$9544
- z K* Y; x0 H1 t* S. qWarning: deleting signal CFWRN1
; ^4 o; \' r( h* B% jWarning: deleting signal CFWTN
2 ]( J F! k( c4 CWarning: deleting signal XDRBY' k8 X- {& u; N
Warning: deleting signal XDREB6 F3 Z$ H: P+ g+ }& W6 ~& b
Warning: deleting signal SMCDN/ W5 E6 j( u. g9 I: M# j7 M, K. i
Warning: deleting signal SDCMD
1 F/ _% ^8 T; }3 ]. HWarning: deleting signal CFPWR( }. r4 l* o. H! ]. o) i# H
Warning: deleting signal XDCD
& ~$ W% ^% n$ A6 q! t* \Warning: deleting signal SDD0
3 m3 H4 i' k; `7 ~- K6 E7 E0 NWarning: deleting signal SDD18 {- F2 y' T4 j' h/ X( X
Warning: deleting signal SDWP/ H# i9 M$ R; _6 ?4 z" W, Z
Warning: deleting signal SDCD
5 L( Q8 L/ y! }Warning: deleting signal MSBS
5 u, b4 {$ a" \1 ~. M' u1 u' rWarning: deleting signal SDCLK1
) ^ _: |+ |5 ]; [6 w4 ]; xWarning: deleting signal MSD1+ _" \, M+ f3 [ M
Warning: deleting signal +5V
: `; n* y4 t' n8 n' }Warning: deleting signal XDCISN `6 A7 L9 P" C6 E, e) I2 L
Warning: deleting signal DECV. }; h; R, m" F
Warning: deleting signal VCCREG1 E. \# Z, N" _7 w3 c5 e
Warning: deleting signal CLED
) x& W5 H# P. C/ D9 g8 ZWarning: deleting signal CFD158 |9 G% _) ]9 i" K
**INPUT WARNINGS FOUND** |
