I have skill for align.
axlCmdRegister(
"align_sym"
'align_sym
procedure( align_sym( )
(prog ()
when( axlOKToProceed()
_ASInitVar()
_ASCreateFormFile()
_ASInitPARMForm()
while( fini == nil
_ASsetsymmaster()
if( _ASFormData->group == t && fini == nil then
_ASselectGrp()
if( _ASFormData->horizontal == t then
_ASMoveHorzComp( cmpgrp)
else
_ASMoveVertComp( cmpgrp)
if( _ASFormData->tolerance == t && fini == nil then
_ASHorzSelTol()
else
_ASVertSelTol()
if( _ASFormData->window == t && fini == nil then
_ASWindSel()
else
cmpgrp = nil
);end-while
axlUIPopupSet( nil)
);endwhen
);end-prog
);endprocedure
;-----------------------define master component location-------------------
(defun _ASsetsymmaster ( )
(prog ()
_ASPopUpA()
setq( efound nil)
while( (efound == nil) && (fini == nil)
axlMsgPut("Select Key Component.")
good = nil
mpinl = nil
pnloc = nil
axlSetFindFilter( ?enabled (list "symbols" )
?onButtons (list "symbols"))
axlOpenFindFilter()
if( fini == nil && axlSingleSelectPoint( ) then
elem = axlGetSelSet()
axlMsgPut( "Key Component %L Selected." car(elem)->refdes)
else
if( fini == nil then axlMsgPut( "Nothing Found, Select Again."))
);end-if
axlHighlightObject( elem)
if(_ASFormData->top == t && (car elem)->isMirrored == nil then
good = t
);endif
if(_ASFormData->bottom == t && (car elem)->isMirrored == t then
good = t
);endif
if(_ASFormData->both == t then good = t)
if(good == t then
;---------stor current data
setq(locat (car elem)->xy)
setq(cmpid (car elem)->refdes)
setq(cmpname (car elem)->name)
setq(cmptype (car elem)->type)
setq(cmprot (car elem)->rotation)
setq(cmpmir (car elem)->isMirrored)
efound = t
if( _ASFormData->pin == t then
r = 1
setq( mpinl car(elem)->pins)
while( nthelem( r mpinl) != nil
if( nthelem( r mpinl)->number == "1" then
setq( pnloc nthelem( r mpinl)->xy)
++r
if( pnloc == nil then
efound == nil
axlMsgPut("Component Selected Has No Pin 1.")
axlMsgPut("Reset Parameters And Try Again.")
else
axlDehighlightObject( elem)
axlMsgPut( "Selected Component is not on Selected Layer.")
axlSubSelectAll()
);endif
);endif
);end-while
axlCancelEnteRFun()
);end-prog
);end-defun
;-------------------select components by group-----------------------
(defun _ASselectGrp ()
(prog ()
if( efound == t && cmpgrp == nil then
grsel = nil
_ASPopUpB()
axlOpenFindFilter()
while( (grsel == nil && efound == t)
axlMsgPut("Select Component to be Aligned.")
good = nil
if( grsel == nil then
if( axlSingleSelectPoint( ) then
setq( gelem axlGetSelSet())
axlMsgPut( "Component %L Group Selected." car(gelem)->refdes)
else
if( grsel == nil then axlMsgPut( "Nothing Found, Select Again."))
);end-if
);end-if
if(_ASFormData->top == t && (car gelem)->isMirrored == nil then
good = t
);endif
if(_ASFormData->bottom == t && (car gelem)->isMirrored == t then
good = t
);endif
if(good == t then
if( (car gelem)->type == "PACKAGE" then
cmpgrp=cons( nthelem( 1 gelem) cmpgrp)
axlHighlightObject( cons( car(elem) cmpgrp))
else
axlMsgPut( "Component Not A PACKAGE Type")
axlDehighlightObject( gelem)
);end-if
else
axlMsgPut( "Component Is Not On Appropriate Layer")
);endif
);endif
);end-while
return( cmpgrp)
);end-if
axlCancelEnterFun()
);end-prog
);end-defun
;-------------------select by vertical orientation------------------
(defun _ASVertSelTol ()
(prog ()
if( efound == t then
i = 1
good = nil
mlocat = pnloc
else
mlocat = locat
setq(allsym axlDBGetDesign()->symbols)
setq(allcmp axlDBGetDesign()->components)
while( nthelem( i allsym) != nil
if( nthelem( i allsym)->type == "PACKAGE" && nthelem( i allsym)->refdes != car(elem)->refdes then
r = 1
setq( tpinl nthelem( i allsym)->pins)
while( nthelem( r tpinl) != nil
if( nthelem( r tpinl)->number == "1" then
setq( tlocat nthelem( r tpinl)->xy)
++r
else
setq( tlocat (nthelem(i allsym)->xy))
if( (car tlocat) <= ( car mlocat)+_ASFormData->tol && (car tlocat) >= ( car mlocat)-_ASFormData->tol then
good = t
);endif
good = t
);endif
setq( srefdes (nthelem(i allsym)->refdes))
h = 1
while( nthelem( h allcmp) != nil
if( (nthelem( h allcmp)->name) == srefdes && good == t then
if( _ASFormData->class == "Any" || nthelem( h allcmp)->class == _ASFormData->class then
cmpgrp=cons(nthelem( i allsym) cmpgrp)
axlMsgPut( "Component %L Selected." srefdes)
);end-if
);endif
++h
);end-while
);end-if
good = nil
);end-if
++i
);endwhile
efound = nil
fini = nil
);end-if
return( cmpgrp)
);end-prog
);end-defun
;-------------------select by horizontal orientation------------------
(defun _ASHorzSelTol ()
(prog ()
i = 1
good = nil
mlocat = pnloc
else
mlocat = locat
if( nthelem( i allsym)->type == "PACKAGE" then
r = 1
++r
else
if((cadr tlocat) <= ( cadr locat)+_ASFormData->tol && (cadr tlocat) >= ( cadr locat)-_ASFormData->tol then
good = t
);endif
good = t
);endif
h = 1
if( ( nthelem( h allcmp)->name) == srefdes && good == t then
axlMsgPut( "Component %L Selected" srefdes)
);end-if
);end-if
++h
);end-while
);end-if
);end-if
++i
);end-while
efound = nil
fini = nil
return( cmpgrp)
);end-prog
);end-defun
;-------------------select by window ---------------------------------
(defun _ASWindSel ()
(prog ()
i = 1
good = nil
axlOpenFindFilter()
axlSingleSelectBox()
allsym = axlGetSelSet()
if( allsym == nil then axlMsgPut( "No Elements Found."))
good = t
);endif
good = t
);endif
h = 1
axlHighlightObject( nthelem( i allsym))
axlMsgPut( "Component %L Window Selected." srefdes)
);end-if
);end-if
++h
);end-while
);end-if
good = nil
++i
);end-while
);endif
efound = nil
return( cmpgrp)
);end-prog
);end-defun
;-------------------relocate vertical position -----------------------
(defun _ASMoveVertComp (cmpgrp)
(prog ()
i = 1
tmpnew= nil
ocmpdata=nil
ocmpmir=nil
ocmprot=nil
olocat=nil
while( nthelem( i cmpgrp) != nil
if( nthelem( i cmpgrp)->refdes != cmpid then
cmpdata=nil
tlocat = nil
setq(tlocat nthelem( i cmpgrp)->xy)
setq(tcmpid nthelem( i cmpgrp)->refdes)
setq(tcmpname nthelem( i cmpgrp)->name)
setq(tcmptype nthelem( i cmpgrp)->type)
setq(tcmprot nthelem( i cmpgrp)->rotation)
setq(tcmpmir nthelem( i cmpgrp)->isMirrored)
cmpdata=cons(tcmpid cmpdata)
cmpdata=cons(tcmptype cmpdata)
cmpdata=cons(tcmpname cmpdata)
ocmpdata = cons( cmpdata ocmpdata)
ocmpmir = cons( tcmpmir ocmpmir)
olocat = cons( tlocat olocat)
ocmprot = cons( tcmprot ocmprot)
nlocat=nil
plocat = nil
npinl = nil
axlMsgPut("%L " npinl)
;-------------define the new vertical orientation
r = 1
npinl=nthelem( i cmpgrp)->pins
while( nthelem( r npinl) != nil
if( nthelem( r npinl)->number == "1" then
plocat= nthelem( r npinl)->xy
nlocat=cons(nthelem( 2 tlocat) nlocat)
voffs = (nthelem( 1 tlocat) - nthelem(1 plocat))
nlocat=cons(( car(pnloc) + voffs) nlocat)
++r
else;
nlocat=cons(nthelem( 1 locat) nlocat)
;-------------delete present stuff
z = 1
setq( pindat nthelem( i cmpgrp)->pins)
while( nthelem( z pindat) != nil
h=1
setq(pinsel nthelem( z pindat)->branch->children)
while( nthelem( h pinsel) != nil
if( nthelem( h pinsel)->objType == "via" then
dellst = cons( nthelem( h pinsel) dellst)
if( nthelem( h pinsel)->objType == "path" then
++h
);endwhile
axlDeleteObject(dellst)
dellst = nil
++z
);endwhile
axlDehighlightObject(nthelem( i cmpgrp))
axlDeleteObject(nthelem( i cmpgrp))
r = 1
axlDBRefreshId( nthelem( r npinl))
++r
);end-while
;-------------add newer symbol
tmpnew = cons( car(axlDBCreateSymbol( cmpdata nlocat tcmpmir tcmprot)) tmpnew)
);endif
++i
);endwhile
setq( elem nil)
setq( grsel nil)
setq( cmpgrp nil)
);end-prog
);end-defun
;-------------------relocate Hoizontal position ----------------------
(defun _ASMoveHorzComp (cmpgrp)
(prog ()
i = 1
tmpnew= nil
ocmpdata=nil
ocmpmir=nil
ocmprot=nil
olocat=nil
cmpdata=nil
nlocat=nil
;-------------define the new horizontal orientation
r = 1
setq( npinl nthelem( i cmpgrp)->pins)
setq( plocat nthelem( r npinl)->xy)
voffs= nthelem( 2 tlocat) - nthelem(2 plocat)
nlocat=cons( ( cadr(pnloc) + voffs ) nlocat)
nlocat=cons( nthelem( 1 tlocat) nlocat)
);endif
++r
);endwhile
else
nlocat=cons(nthelem( 2 locat) nlocat)
nlocat=cons(nthelem( 1 tlocat) nlocat)
);endif
z = 1
h=1
++h
dellst = nil
++z
r = 1
++r
);end-while
);endif
++i
);endwhile
setq( elem nil)
setq( grsel nil)
);end-prog
);end-defun
;-------------------Parameter form data ------------------
defun( _ASInitParmForm () ;
(prog ()
(let ( form)
form = axlFormCreate( (gensym) "align_sym.form" '(se outer) '_ASParmCallBk t )
_ASFormPtr = form
if( ( _ASFormData == nil ) then
setq( _ASFormData t)
(axlFormBuildPopup form "class" '(("Any" "Any") ("IC" "IC") ("IO" "IO") ("DISCRETE" "DISCRETE")))
(axlFormSetField form "class" "Any")
putprop( _ASFormData "Any" 'class)
(axlFormSetField form "horizontal" t)
putprop( _ASFormData t 'horizontal)
(axlFormSetField form "vertical" nil)
putprop( _ASFormData nil 'vertical)
(axlFormSetField form "pin" nil)
putprop( _ASFormData nil 'pin)
(axlFormSetField form "origin" t)
putprop( _ASFormData t 'origin)
(axlFormSetField form "top" t)
putprop( _ASFormData t 'top)
(axlFormSetField form "bottom" nil)
putprop( _ASFormData nil 'bottom)
(axlFormSetField form "both" nil)
putprop( _ASFormData nil 'both)
(axlFormSetField form "group" t)
putprop( _ASFormData t 'group)
(axlFormSetField form "window" nil)
putprop( _ASFormData nil 'window)
(axlFormSetField form "tolerance" nil)
putprop( _ASFormData nil 'tolerance)
(axlFormSetField form "tol" 250.000 )
putprop( _ASFormData 250.000 'tol)
axlFormDisplay( form)
);end-if
);end-let
);end-prog
);end-defun
;---------------Form Call Back-----------------------------------------------
defun( _ASParmCallBk (form)
case( get(_ASFormPtr 'curField)
( "class" putprop( _ASFormData get(_ASFormPtr 'curValue) 'class))
( "horizontal" putprop( _ASFormData get(_ASFormPtr 'curValue) 'horizontal))
( "vertical" putprop( _ASFormData get(_ASFormPtr 'curValue) 'vertical))
( "pin" putprop( _ASFormData get(_ASFormPtr 'curValue) 'pin))
( "origin" putprop( _ASFormData get(_ASFormPtr 'curValue) 'origin))
( "top" putprop( _ASFormData get(_ASFormPtr 'curValue) 'top))
( "bottom" putprop( _ASFormData get(_ASFormPtr 'curValue) 'bottom))
( "both" putprop( _ASFormData get(_ASFormPtr 'curValue) 'both))
( "group" putprop( _ASFormData get(_ASFormPtr 'curValue) 'group))
( "window" putprop( _ASFormData get(_ASFormPtr 'curValue) 'window))
( "tolerance" putprop( _ASFormData get(_ASFormPtr 'curValue) 'tolerance))
( "tol" putprop( _ASFormData get(_ASFormPtr 'curValue) 'tol))
( "done" _ASDone() )
( "cancel" _ASCancel() )
);case
);end-defun
;--------------- Pop up while selecting but not by group --------------------
defun( _ASPopUpA ()
popupA = axlUIPopupDefine( nil
(list (list "Done" '_ASDone)
(list "Oops" '_ASoops)
(list "Cancel" '_ASCancel)))
axlUIPopupSet( popupA )
);end-defun
;--------------- Pop up for group selection --------------------------------
defun( _ASPopUpB ()
popupB = axlUIPopupDefine( nil
(list (list "Complete" '_AScomplete)
axlUIPopupSet( popupB )
);end-defun
;--------------- Cancel Call--------------------------------
defun( _ASCancel ()
(prog ()
i=1
pindat = nil
pinsel = nil
dellst = nil
while( nthelem( i tmpnew) != nil
z = 1
setq( pindat nthelem( i tmpnew)->pins)
h=1
++h
dellst = nil
++z
);endwhile
axlDeleteObject(nthelem( i tmpnew))
r = 1
++r
);end-while
++i
);end-while
i = 1
while( nthelem( i ocmpdata) != nil
axlDBCreateSymbol(
nthelem(i ocmpdata)
nthelem(i olocat)
nthelem(i ocmpmir)
nthelem(i ocmprot)
++i
);end-while
elem = nil
cmpgrp = nil
_ASDone()
);end-prog
);endfun
;----------------- DONE Call--------------------------------
defun( _ASDone ()
(prog ()
setq( grsel t)
if( elem != nil then axlDehighlightObject( elem))
if( cmpgrp != nil then axlDehighlightObject( cmpgrp))
setq( grsel t)
setq( fini t)
if(isFile("align_sym.form") then
deleteFile("align_sym.form")
setq( elem nil)
setq( cmpgrp nil)
axlFormClose(_ASFormPtr)
axlCancelEnterFun()
axlClearSelSet()
axlCloseFindFilter()
axlUIPopupSet( nil)
);end-fun
;--------------- Complete Picks ----------------------------
defun( _AScomplete ()
(prog ()
setq( grsel t)
axlCancelEnterFun()
_ASPopUpA()
setq( efound nil)
);end-defun
;--------------- Oops command-------------------------------
defun( _ASoops ()
(prog ()
axlDehighlightObject( car( cmpgrp))
cmpgrp = cdr(cmpgrp)
good = nil
gelem = nil
else
elem = nil
efound = nil
);end-if
if( elem == nil then axlMsgPut( "Nothing In Buffer To Oops."))
axlCancelEnterFun()
return( cmpgrp)
);endprog
);end-defun
;--------------- initialize variables -------------------
defun( _ASInitVar ()
(prog ()
elem = nil
mpinl = nil
pnloc = nil
plocat = nil
mlocat = nil
gelem = nil
dellst = nil
pindat = nil
pinsel = nil
tmpnew = nil
ocmpdata=nil
ocmpmir=nil
ocmprot=nil
olocat=nil
_ASFormData = nil
_ASFormPtr = nil
fini = nil
tol = 0
axlUIPopupSet( nil)
fini = nil
cmpgrp = nil
);end-prog
);end-defun
;-----------------create form file -------------
defun( _ASCreateFormFile ()
frmfle = outfile("align_sym.form")
fprintf( frmfle "FILE_TYPE=FORM_DEFN VERSION=2\nFORM\nFIXED\n")
fprintf( frmfle "PORT 67 13\nHEADER \"Component Alignment Form\"\n")
fprintf( frmfle "POPUP <CURSPOP>\"Any\"\"1\",\"IC\"\"2\",\"IO\"\"3\",\"DISCRETE\"\"4\".\n")
fprintf( frmfle "POPUP <PRINTP>\"to File\"\"0\",\"to Printer\"\"1\",\"to Script\"\"2\".\n")
fprintf( frmfle "\nTILE\n\n")
fprintf( frmfle "TEXT \"Class:\"\nTLOC 32 18\nTGROUP \"Select Mode\"\nENDTEXT\n")
fprintf( frmfle "FIELD top\nFLOC 3 12\n FGROUP\"Alignment Layer\"\nCHECKLIST\"Top\" \"alg\"\n ENDFIELD\n\n")
fprintf( frmfle "FIELD bottom\nFLOC 3 14\nFGROUP \"Alignment Layer\"\nCHECKLIST \"Bottom\" \"alg\"\nENDFIELD\n\n")
fprintf( frmfle "FIELD both\nFLOC 3 16\nFGROUP \"Alignment Layer\"\nCHECKLIST \"Both\" \"alg\"\nENDFIELD\n\n")
fprintf( frmfle "FIELD horizontal\nFLOC 3 5\nFGROUP \"Direction\"\nCHECKLIST \"Horizontal\" \"dirg\"\nENDFIELD\n\n")
fprintf( frmfle "FIELD vertical\nFLOC 3 7\nFGROUP \"Direction\"\nCHECKLIST \"Vertical\" \"dirg\"\nENDFIELD\n\n")
fprintf( frmfle "FIELD origin\nFLOC 35 7\nFGROUP \"Alignment Point\" \nCHECKLIST \"Origin\" \"alpg\"\nENDFIELD\n\n")
fprintf( frmfle "FIELD pin\nFLOC 35 5\nFGROUP \"Alignment Point\" \nCHECKLIST \"Pin 1\" \"alpg\"\nENDFIELD\n\n")
fprintf( frmfle "FIELD group\nFLOC 25 12\nFGROUP \"Select Mode\"\nCHECKLIST \"Group\" \"slmg\"\nENDFIELD\n\n")
fprintf( frmfle "FIELD window\nFLOC 25 14\nFGROUP \"Select Mode\"\nCHECKLIST \"Window\" \"slmg\"\nENDFIELD\n\n")
fprintf( frmfle "FIELD tolerance\nFLOC 25 16\nFGROUP \"Select Mode\"\nCHECKLIST \"Tolerance\" \"slmg\"\nENDFIELD\n\n")
fprintf( frmfle "FIELD tol\nFLOC 40 16\nFGROUP \"Select Mode\"\nREALFILLIN 10 10\n DECIMAL 4\nENDFIELD\n\n")
fprintf( frmfle "FIELD class\nFLOC 40 18\nFGROUP \"Select Mode\"\nENUMSET 12\nPOP \"CURSPOP\"\nENDFIELD\n\n")
fprintf( frmfle "FIELD done\nFLOC 2 22\n MENUBUTTON \"Done\" 9 3\nENDFIELD\n\n")
fprintf( frmfle "FIELD print\nFLOC 28 22\n MENUBUTTON \"Print\" 9 3\n POP \"PRINTP\"\nENDFIELD\n\n")
fprintf( frmfle "FIELD cancel\nFLOC 55 22\n MENUBUTTON \"Cancel\" 9 3\nENDFIELD\n\n")
fprintf( frmfle "GROUP \"Alignment Layer\"\nGLOC 2 10\nGSIZE 20 11\nENDGROUP\n\n")
fprintf( frmfle "GROUP \"Direction\"\nGLOC 2 2\nGSIZE 30 8\nENDGROUP\n\n")
fprintf( frmfle "GROUP \"Alignment Point\"\nGLOC 34 2\nGSIZE 30 8\nENDGROUP\n")
fprintf( frmfle "GROUP \"Select Mode\"\nGLOC 24 10\nGSIZE 40 11\nENDGROUP\n\n")
fprintf( frmfle "\nENDTILE\n\nENDFORM\n")
close(frmfle)
);end-defun
