TA的每日心情 | 擦汗 2020-1-14 15:59 |
签到天数: 1 天 [LV.1]初来乍到
[Algorithmic Model]7 R- l' |1 m/ r4 ?' U9 I9 _
Executable Windows_VisualStudio_64 a_ami_tx.dll xilinx_gtp_ami_tx.ami: J: u5 S7 j4 [* D, Y
[End Algorithmic Model]. {6 y- J* `9 m5 j3 e0 M w
2 ?( ^! p* c5 u
Warning detected by hpeesofsim in topology check during circuit set up.* p& d1 L6 O4 N; f6 e. @
Number of nodes with only one device attached (topology corrected): 4
/ l2 O: l+ k+ Y- n5 h9 `1 r `' u+ t! sWarning detected by hpeesofsim during TRAN analysis `ChannelSimTransient_ChannelSim'.% |2 m: N+ O: a/ S* D$ ~
Component `X1.SNP1.CMP1':
; z( Z, W3 M9 L- s- X, p ImpMaxFreq is reduced to highest data frequency at 2.000000e+10 Hz. ) \& n( E% p7 M: B) r
Error detected by hpeesofsim in Channel Simulator during circuit set up `ChannelSim'.
, J5 m2 C+ W0 b# }$ a AMIDev::Tx_Init: AMI_Init failed.
6 j1 V* k4 Z$ s: W" r- ^/ v+ [+ O; z8 c1 S% f2 U
有报错
) ?7 a' J8 T) j8 v- u' S& u) Q
5 w7 \6 H0 X" z1 \ |
