TA的每日心情 | 衰 2020-4-15 15:20 |
签到天数: 1 天 [LV.1]初来乍到
+ [! ~! |) p) d7 i# i; U4 I9 n% h
把原理图生成的网表去掉,一样报错,是不是不能用网络标号,只能直接连的线才可以从PCB更新到SCH
9 @! o& }0 [" K6 l6 d{ Using PSTWRITER 16.6.0 d001Jan-07-2019 at 14:02:47 }5 B4 x- k$ X; _" N6 D
- w8 x0 F a: [7 D5 ]
INFO(ORCAP-36108): Starting the Swp file dumping process ... P7 K: R9 o* s, [
Loading netlist files ...4 ^9 @. z+ c& q* b
Loading... E:\MYPROJECT\CADENCE\804_A3P\A3P_SX72_MBOARD\PINSWAP/pstchip.dat
1 {' G8 L9 I8 f `, z; {5 D B& F& e h o* Z+ c$ D
Loading... E:\MYPROJECT\CADENCE\804_A3P\A3P_SX72_MBOARD\PINSWAP/pstxprt.dat
8 d: ], c( p' D( P g; _
+ G8 d4 ~3 l C9 E) YLoading... E:\MYPROJECT\CADENCE\804_A3P\A3P_SX72_MBOARD\PINSWAP/pstxnet.dat
4 h- g% r; f- [* R( u6 rpackaging the design view...Loading physical design view ...Loading... E:\MYPROJECT\CADENCE\804_A3P\A3P_SX72_MBOARD\PINSWAP/funcview.dat# B& x: c ~& d8 P
#549 ERROR(SPCODD-549): No physical part found for COMP_DEVICE_TYPE=CONN SOCKET 40X2_2_DIP80_CONN S, regenerate the netlist to sync with Allegro board. ~, W; T0 c- `5 Q7 ]$ X
ERROR(SPCODD-516): Line Number: 4
X# Q9 `$ l T' w, _/ g1 A#549 ERROR(SPCODD-549): No physical part found for COMP_DEVICE_TYPE=CONN SOCKET 32_5_DIP32_CONN SOC, regenerate the netlist to sync with Allegro board.
) J5 S( ^7 [% ~ ERROR(SPCODD-516): Line Number: 5# n' X5 J$ X9 f
6 n6 \' u7 S, A* ^4 R+ v0 `5 ^& { ERROR(SPCODD-516): Line Number: 6
4 b1 y# e0 y; B6 {& H+ J$ u# K#549 ERROR(SPCODD-549): No physical part found for COMP_DEVICE_TYPE=CONN RCPT 40X2_1_DIP80_CONN RCP, regenerate the netlist to sync with Allegro board.
0 \0 @2 K& i! P1 J# G$ ~, G& B ERROR(SPCODD-516): Line Number: 7
5 \' ?4 ]! |4 V2 s#549 ERROR(SPCODD-549): No physical part found for COMP_DEVICE_TYPE=CONN SOCKET 64X2/SM_2_DIP128_CO, regenerate the netlist to sync with Allegro board.0 A2 G+ u# m* ?
ERROR(SPCODD-516): Line Number: 8
% s" D a$ p, F2 g- |4 L#1 ERROR(ORCAP-36027): Unable to read physical netlist data.
8 V6 _ }3 G0 {& E D#2 ERROR(ORCAP-36025): Aborting Swap file creation... Please correct the above errors and retry.3 N* o3 x+ ^$ U n( P
" M" B+ |5 Z' _& w" x |
