查看: 402|回复: 1
基于S3C2440的OV7670摄像头的裸机程序、、对了解OV7670的硬件...
发表于 2018-11-2 10:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
2 P$ d9 k6 O# t1 g
基于S3C2440的OV7670摄像头的裸机程序、、对了解OV7670的硬件编程可能有点用处哦。。特别是初学者
: a2 N9 B! p5 J9 m5 @; U- w3 k" }( t5 Z0 T5 n
camera_OV7670
7 v- q/ D. d7 d# @( s  .............\camera_OV7670.mcp. V3 p; r! }- u' d# K( \
  .............\camera_OV7670_Data
( ^% p0 F1 ~. U5 k  .............\..................\CWSettingsWindows.stg, \" |/ L2 n! I: ?( e4 ~& l( b
  .............\..................\Debug% Q# `  a9 C3 h0 Q
  .............\..................\DebugRel
' z) ?* E- H8 u3 ~0 b  .............\..................\........\camera_OV7670.axf9 p8 z+ W/ u$ j7 S; Y7 \% K5 E) c
  .............\..................\........\camera_OV7670.bin
# O2 o- u" `* L$ x8 f9 T$ Q/ g6 ~  .............\..................\........\ObjectCode
- N9 x3 H1 }* Q( i/ E  .............\..................\........\..........\2440init.o' h1 |3 M( q' y& d  S
  .............\..................\........\..........\2440lib.o
; l+ A5 f8 Q8 q; E- Y! b% K5 e  .............\..................\........\..........\2440slib.o! H$ j3 }. e. j) k! V9 t  K% |
  .............\..................\........\..........\camif.o
; Y) w1 j# k+ E( e/ @# `% D$ p+ h  .............\..................\........\..........\camproset.o" o0 W" N* h2 F* D  Y' Q
  .............\..................\........\..........\main.o- V6 x8 k' x5 F8 a
  .............\..................\........\..........\mmu.o
( t/ Q6 ^0 Z* g  .............\..................\........\..........\nand.o0 R* I* X& v: s3 ?0 H) c
  .............\..................\........\..........\Test_OV7670.o/ @% i% _8 ^7 n* }' x/ G
  .............\..................\........\..........\TFT_API.o
$ u, _$ s5 X  U$ E, L5 a  .............\..................\........\..........\TFT_Driver.o2 i  B" x  U1 g; u  h
  .............\..................\........\..........\uart.o
- R" f/ V) H! n0 T6 O* o" d( i3 A; \  .............\..................\........\TargetDataWindows.tdt, s6 W8 ^- G- m6 C) i6 J+ K" A! D8 m
  .............\..................\.....\TargetDataWindows.tdt
! B# ]& u; R  x  |  |6 B3 M  .............\..................\Release  Z) v& {: G2 \/ ^: e
  .............\..................\.......\TargetDataWindows.tdt+ V8 b. @6 s- U7 ~
  .............\main.c/ s. K% [: a! Y
  .............\Source
5 X0 H5 h5 N% o2 g( Y; o  .............\......\camdata.h
$ U5 K3 U1 f  h. I  .............\......\camdef.h
. z1 t/ l& L3 O  .............\......\camera_sccb.c
8 @2 w% ^6 P- A; ]/ F  ~  .............\......\camera_sccb.h
2 I2 `; v% [0 L) [  .............\......\camif.c
8 u" i6 K# Z2 H0 l4 ]( Z  .............\......\camif.h# v' S, S" B/ V7 D5 N
  .............\......\camproset.c: o5 @! }* d: g9 B8 N; q
  .............\......\camproset.h2 b7 e0 O' M' h. Y: A/ m
  .............\......\Test_OV7670.c4 w; V: M( N0 m2 @. H
  .............\......\Test_OV7670.h) ^6 R7 N' |! x6 ~; F3 R% s: H  U
  .............\system" f, z2 e3 e; I, G; F+ I
  .............\......\inc
( @8 N" j0 W7 G; }$ z  .............\......\...\2440addr.h8 X2 |1 X) R( Z7 n
  .............\......\...\2440addr.inc: @$ i( G7 x) M! V0 f. s; g" H0 [6 Y
  .............\......\...\2440lib.h" |( Q" m4 c( l# j/ C6 A
  .............\......\...\2440slib.h
0 Y+ J5 j5 S3 [$ |6 l6 w  .............\......\...\def.h
" N; Q3 H1 Z. u; R5 \5 H( K. Q  ]  .............\......\...\MEMCfg.inc7 D, B* h9 [' w! _
  .............\......\...\mmu.h: g) P7 j8 ^2 Q2 o" Y6 u1 Y' C: F
  .............\......\...\nand.h
  W$ s5 _5 G0 Y2 a' o2 }) p  .............\......\...\Option.h
5 Y# O3 [2 @- U  N, Y( d$ j8 V  .............\......\...\Option.inc
! S% u7 y' K) d* l6 ?  .............\......\...\uart.h
# M# v4 q* Q8 e  .............\......\src
) w6 ^3 h9 \2 j+ }( H" f, j# P  .............\......\...\2440init.s
5 G% I, ^. \$ i  .............\......\...\2440lib.c% Z6 P( f& B4 A! G- P" j
  .............\......\...\2440slib.s, L% ]0 a; N  E6 Z, F
  .............\......\...\mmu.c
! F- u$ n6 r+ b' G( l! D  .............\......\...\nand.c
$ ~% A; c, {2 ]$ j6 R- L: G  .............\......\...\uart.c
1 o  R; _/ l' F& V  .............\TFT
) m: g, ~. T$ {  n  .............\...\TFT_API.c
6 o) l, X9 j3 i7 k) \  .............\...\TFT_API.h
$ g$ [' L7 Y, w, \0 ]/ P  .............\...\TFT_Config.h$ o  Y2 S. h5 d3 ]
  .............\...\TFT_Driver.c
% R( \( H- y6 u3 |) I. t- R  .............\...\TFT_Driver.h
游客,如果您要查看本帖隐藏内容请回复
& e5 D9 q0 Q5 F9 i+ e" G
GMT+8, 2025-11-25 01:09 , Processed in 0.156250 second(s), 26 queries , Gzip On.
