查看: 246|回复: 1
 使用MFC界面,控制ARM2410S试验箱上的电机,试验箱为博创
发表于 2018-11-2 08:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
7 e4 Z/ I. T" d2 X
使用MFC界面,控制ARM2410S试验箱上的电机,试验箱为博创。7 A3 ^. Q# m+ v, x5 T/ Y- T
电机也可以使用实验箱上的AD电位器来控制,切换控制方式键为“z+enter”: e6 k5 _, E" n3 ]  W% M+ a
4 C8 y" J  M4 V/ L/ T
Linux下程序\xu.c
( J6 m( J% O) H1 C  上位机MFC程序\Debug\SerialPort.obj
5 ]* e3 q+ n: ]4 f  y/ G2 S  .............\.....\SerialPort.sbr
- N5 W( V6 n) ]) f; x  .............\.....\StdAfx.obj
) |4 I  e' n+ x! s; ~8 j5 @! Q  .............\.....\StdAfx.sbr1 I7 u+ |9 e& Y/ W: `6 V& l
  .............\.....\vc60.idb5 ?/ a+ B- Y+ @( |
  .............\.....\vc60.pdb
  E- D) D4 {; o/ J- t  .............\.....\上位机.bsc
: n& l6 X  b, ]& e) M4 f  .............\.....\上位机.exe4 T8 g: d6 Z, M/ l* v, U
  .............\.....\上位机.ilk0 q* |: c/ N& w5 E
  .............\.....\上位机.obj" Q$ G/ K0 g/ b. E7 N
  .............\.....\上位机.pch/ f" L+ k1 Y0 \0 s5 P. C9 y
  .............\.....\上位机.pdb
6 t6 J7 `0 ^/ n  .............\.....\上位机.res* Q: q% {/ B3 y5 S6 n
  .............\.....\上位机.sbr
$ |* |5 I' }: T% K( Z  .............\.....\上位机Dlg.obj
  L" \: |0 j) P$ ]' K) H0 x  .............\.....\上位机Dlg.sbr
* w! J9 }) l' @& o0 t  .............\ReadMe.txt
! j" C9 ~2 O8 }3 ]  .............\res\上位机.ico
& m1 m! l1 s6 R7 _: n, Q9 O9 l  .............\...\上位机.rc20 i. X: X$ ^' i& n8 t6 g8 U6 d
  .............\resource.h
4 j& E1 W' K8 x" R/ K  .............\SerialPort.cpp# R, ~9 q% b3 Z
  .............\SerialPort.h+ d) E2 A" D# n5 z6 `
  .............\StdAfx.cpp
. G3 L8 J' A, E: g+ t2 t/ U  .............\StdAfx.h( \1 f/ F0 }; Q3 P5 n/ _  _' Z
  .............\Timeractive\Debug\regsvr32.trg: ^3 n' `) H/ O1 x$ u6 V! z
  .............\...........\.....\StdAfx.obj5 T1 r5 |! d5 \& o( X: j2 P
  .............\...........\.....\StdAfx.sbr; h/ t# }( F, F3 a( {; s3 g
  .............\...........\.....\Timeractive.bsc
$ i7 W+ i$ b" C, `" U  .............\...........\.....\Timeractive.exp
2 f; ~' w+ G% ?1 Y& r) S8 i  .............\...........\.....\Timeractive.ilk0 [  x0 \0 ~% X
  .............\...........\.....\Timeractive.lib
- i5 X9 d" O  i  .............\...........\.....\Timeractive.obj
' f! y  S+ {9 X  .............\...........\.....\Timeractive.ocx
, Q3 v- @" I$ j! }/ z/ O( L  .............\...........\.....\Timeractive.pch& ^% E# A& b0 p: ]4 Z5 X- y
  .............\...........\.....\Timeractive.pdb
) \1 h) j5 Y& A: W  .............\...........\.....\Timeractive.res6 i: U7 c" `! M) r
  .............\...........\.....\Timeractive.sbr0 }3 J( v. @4 Z7 x
  .............\...........\.....\Timeractive.tlb& r# W! p' B7 _) C* H
  .............\...........\.....\TimeractiveCtl.obj, x1 b- J- @; g" ~6 `3 e
  .............\...........\.....\TimeractiveCtl.sbr
9 X' U$ l1 w( J' j  .............\...........\.....\TimeractivePpg.obj
% V1 \6 Z: `+ R& j  .............\...........\.....\TimeractivePpg.sbr7 W: x* F7 z! N) W8 y+ n
  .............\...........\.....\vc60.idb
$ E- Y6 Z1 E, Y" M  .............\...........\.....\vc60.pdb6 ]' p$ v; z4 O0 |- z
  .............\...........\ReadMe.txt; Y1 Q( ?: F' B& S
  .............\...........\resource.h
5 |6 F  v/ O+ m4 d0 d  .............\...........\StdAfx.cpp
4 K% E( O# f3 ~& @; h8 U) l  .............\...........\StdAfx.h, s1 N! I; s, l2 o0 M6 T
  .............\...........\Timeractive.aps
" f! O$ t1 y" J7 F, C  .............\...........\Timeractive.clw
& R  o: F9 k0 c; B3 ~; s  .............\...........\Timeractive.cpp
( b! o! x3 w$ t1 l7 P  .............\...........\Timeractive.def  J7 H( B4 l/ L6 E
  .............\...........\Timeractive.DSP$ P9 m3 v! [. @7 Z9 R  r- b9 O
  .............\...........\Timeractive.dsw. B7 C1 ?* t$ f% O3 I# B
  .............\...........\Timeractive.h( W) r' x1 b  V
  .............\...........\Timeractive.ico
% g' ?! h) _2 C0 k2 r- g  .............\...........\Timeractive.ncb
, c5 z) g' \9 }' U4 ~  .............\...........\Timeractive.odl. @: X& X& h. o- r! ~
  .............\...........\Timeractive.opt$ m# Y6 i& H; W4 I$ |' s
  .............\...........\Timeractive.plg* k7 R: h, }* J8 T5 t  V5 C
  .............\...........\Timeractive.rc
2 T; Y; V: r' A" P! @# x  .............\...........\TimeractiveCtl.cpp% L4 \4 C* @  R  V% C7 l
  .............\...........\TimeractiveCtl.h
" \# u" \/ }) y' B" |$ F- I  .............\...........\TimeractivePpg.cpp
2 ~' D0 [5 ^9 E1 C2 A: ~% N, \  .............\...........\TimeractivePpg.h
; t0 r. X* B  k# q  .............\上位机.aps2 F2 ]+ f# w+ u7 ~+ l, }
  .............\上位机.clw
( _) ~- {4 e5 ]3 }  .............\上位机.cpp; Z* \, @2 f9 t; _
  .............\上位机.dsp" p) R7 L0 _  b$ m7 m. K- ^0 y
  .............\上位机.dsw% L0 ]3 E* `& k& z( X/ i
  .............\上位机.h, w# a1 U  g, }
  .............\上位机.ncb
4 }; s; W) U: j% ^7 U! U6 _" R  .............\上位机.opt
, I1 [6 g4 R$ V1 R. @  .............\上位机.plg1 X% l+ J( k' [# V1 |
  .............\上位机.rc
$ ^1 [  b) b: a& Z5 J; F: H  .............\上位机Dlg.cpp! ?4 |* x2 d, Y4 ^% E; T
  .............\上位机Dlg.h
4 g* d! S/ |) w4 R* }  .............\Timeractive\Debug
) Y9 f* v$ x) ^- i. j# z$ ?  .............\Debug
. [& b# W  t6 g  .............\res5 v5 M& @) o4 ?4 D, h: Z+ W. |
, T. K2 E" r+ h  Linux下程序- Z( T2 `) s7 A
  上位机MFC程序
1 T: A5 I) ?& L
游客,如果您要查看本帖隐藏内容请回复
. r7 v, w1 a# n+ z  g5 u
GMT+8, 2025-11-24 21:12 , Processed in 0.187500 second(s), 26 queries , Gzip On.
