查看: 749|回复: 2
电磁兼容(EMC)术语缩写中英文对照
发表于 2018-11-1 13:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
电磁兼容EMC)术语缩写中英文对照
a.c.or AC
" D" L. V3 ^3 R- u# y5 _& @; Valternating current交流电+ G. i% T7 `( d$ ?6 I9 D
4 G  |* d( P1 b3 ~+ x% ?/ h- eACEC
2 J& {, o* k; i3 [& p! a# L4 cadvisory committee on electromagnetic compatibility电磁兼容顾问委员会
2 h8 U$ u( W0 P3 \5 X
' I: v$ d) g9 S* s' zADSL
$ d# \2 V- ^+ w% u9 I/ P# ~asymmetric DSL非对称数字用户环路
* W5 w! [  x6 Y# C6 e/ M& w; T, {' P  B& s7 Y& D
AE : f" N# ?5 R# _/ v! a. R0 F$ M
auxiliary equipment辅助设备
* {( V# A9 y  s! `! \( g% M7 T0 Y, R3 G9 v3 V, f5 A9 L8 T
AF
6 X1 O- x. _3 A& B8 laudio frequency音频1 x, U! V8 r+ i  m! n* V" j! y+ \& ^
& [2 B( l  P3 ?AM
6 \, P5 F. s. s6 }1 j0 m1 aamplitude modulation调幅
% v9 C3 W, x& t0 j5 Q) d0 w4 z9 Q4 q- `4 ?, ]+ z' q
AN
0 F9 ^/ N) ]4 I7 [: [access network接入网% X$ J9 L/ q( U" ^7 A( D3 `0 v
, v0 N4 H! ]& n2 {2 K' ~ANE
* d$ H" c" T' Q+ ?9 S7 k' @5 f4 r& ^& Raccess network equipment 接入网设备
( b! V+ K! M+ y" C; d9 F4 p6 e" u, O) x; h
CDMA . G3 W- @' M8 k; H6 x
code division multiple access码分多址$ I" y& t7 z. R# L$ T; U
  P7 R$ p+ e" m/ H0 Z
CDN  ' H  t7 h- c$ h0 O
coupling/decoupling network 耦合/去耦网络, z" a- Y1 B  g3 w/ n
3 X0 F6 H5 }) }$ ?6 X" k( y, y. ?CIGRE
5 a. S: o$ Z- g$ yinternational conference on large HV electric systems 国际大电网会议! \) J- b+ {/ H! Y! o5 k. G4 |
- F9 V. s2 B3 G7 e: n, z
CISPR  : \. b5 w' Q) g; C! l
international special committee on radio inteRFerence 国际无线电干扰特别委员会0 t/ ]. u; [4 \& g6 m
$ {9 h/ |' Z. I4 B& m3 ?( H! Z
CPE
! a: I9 r4 n+ s; S: f+ U! Xcustomer premises equipment 用户驻地设备/ b! L  j8 q( }4 r/ n
3 [& R  w5 y/ tCRT
& q4 W8 O- N3 n( n! Tcathode ray tube 阴极射线管( g& S- X+ x; Q
7 v, V* ~0 \& M, f( X4 t# j) L1 h
d.c.or DC 2 D; z! F" h! W" W
direct current 直流电* u# a* {2 {/ C5 t3 ]1 W, P; _
5 @% C& U) N  Cdpf
0 o" ^& ^. j8 k5 |" ^$ wdedicated power feed 专用供(馈)电+ o- D, |: k" D% Q
2 \" c& F) Y! S  h9 Z  R6 j7 p" |DSL
7 G. o) H0 D; o3 j. Bdigital subscriber loop 数字用户环路/ f3 A; q0 u& T
+ c) A: t+ D" M6 w
EFT/B
$ o2 {! [% r7 h) y2 @" eelectrical fast transient /burst 电气快速瞬变/突发
8 F% M& s6 B( y( v% u0 H7 q2 ^/ P" u# E
EIRP
' m' Y( x/ C8 s$ ^! Q) B0 Qequivalent isotropically radiated power 等效全向辐射功率
. x: n" T$ o3 }1 l4 x5 n5 i. }" o6 s" f: [. J4 g
EMC
7 Z, Z3 E/ n0 g( ]0 z& x8 G! celectromagnetic compatibility 电磁兼容性
( o% Q7 B5 ?. Q" g1 b! m4 Z  d6 Y& P! i3 T# Y
emf 2 w* O& ~  K$ b' z7 A
electro-morive force 电动势
- s; W$ ?# O+ e2 x( E
6 X, m6 v" B0 [6 l9 HEMF
* m5 P5 E+ E$ P) T# {electro-magnetic field 电磁场
6 N2 j/ C4 z4 Y1 B5 Y! S$ z" Q5 q0 x; \7 v, G
EPR ; S6 q' o5 n8 ?7 T" o" {+ U" ]5 y
earth potential rise 地电位升高
8 C9 J  M! R9 x' u) r) Y' D( K9 |2 \' F& |( S4 {0 z5 L
ERP
1 _5 F& b+ ~3 N# _7 J. Ieffective radiated power 有效辐射功率0 @, j# o! u' O8 C7 i# y' I
) p/ o% f% N" k6 d; eESD
. B8 b+ m: P/ K6 x% Oelectrostatic discharge 静电放电3 q  [- c$ a! b' T( l3 U
0 R, q" E! y" g' A3 F& W
EUT
: G% z( G. g) g7 t0 m* Tequipment under 受试设备/ V" A$ K/ J' d: T, N, I) _6 P: n
% a( |4 \6 I" k% k9 q+ L4 TGDT
+ Q' x) |$ H! |) m$ wgas discharge tube 气体放电管; n' g+ G: ]: q4 A9 U
( T& R% k$ f! J' N5 w& d' V  UGV
! u5 I+ P& ]8 j, ?high voltage 高电压
9 t* l% c5 z( R  `1 O3 R: |! ^. q3 t+ Y* C9 T9 k' ?
ICNIRP 8 M- q' Q! F. P8 Y* X0 _9 f
international commission on non-ionizing radiation protection 国际非电离辐射保护委员会; X0 C( U0 p# a1 n" S/ V/ _
& U. h2 k$ Q4 @& H2 yIEC ) q# O. t2 d# y3 \4 m/ t/ z) W: X8 ~
international electrotechnical commission 国际电工委员会- {$ X) P* g" f$ |- d. i
/ \; U; C5 n0 m' N% W1 k: H  \
ISDN
, e3 S: ~9 H; e( }, E& x* U* Lintegrated services digital network 综合业务数字网2 W6 P& }8 ^+ F) x* d! [! T" B
3 x2 Z6 N3 r& H$ o1 w  Y( P) b) N$ WISM . Q! |8 }- p- x1 R6 |' R" K
industrial, scientific and medical (equipment) 工业的,科学的和医学的(设备)9 g* U. l- G7 a! ^! U
! s; q+ X3 O- \7 n' E' [( fITE ; d7 E0 ]# d5 O
information technology fquipment 信息技术设备
: r$ M6 x0 D$ p% j
) I7 ^% j4 N4 w2 N3 |% KITU-T
; ]7 e5 G, S4 P, F3 m8 t8 {) ~international telecommunication union-telecommunication standardization sector
& c) G5 `, b* w. p) c% \1 c国际电信联盟电信标准局" ?% k, L" y" j0 @5 j# R% i
; m3 P* r0 B# R+ zLCL ) E# W( i2 F, B% w
longitudinal conversion loss 纵向转换损耗
! \: J0 |7 T/ z$ {7 D# x* ?
" S) M+ {) N; t8 M3 FLCTL
) q. d7 q/ l& H  Alongitudinal conversion transfer loss 纵向转换传输损耗
  Y6 `& @7 h; {4 M! w+ m2 C- i- t- U0 W" \
LE # Q  X) H% S$ q) J
local exchange 本地交换! o% ]. I3 R2 W
- l! Y6 Y  l: o- i$ Q4 D% V- S
LEMP 4 e; W* e7 `$ C, G) }) v
lightning electromagnetic pulse 雷电电磁脉冲
3 n# ~) P- w4 Y: \; f  k/ r2 ~0 r
LI ) o, s7 c! P7 y. ?+ H8 t$ L( s6 r
line interface 线路接口
$ i) X1 ^" r- |% ^2 _3 C( a( R3 e( r/ w- |  g. ]  H6 n$ t& n8 _
LPS . n7 t% `1 R* \' W4 r# X
lightning protection system 雷电保护系统( a) j4 T6 d6 v! r& f1 }+ I
; O' I9 @! u2 |7 O$ m$ q* k0 G
LPZS % v7 ]( n( s0 I: k
lightning protection zone 雷电保护区
  v- X6 P* O3 G9 k( x0 T5 [0 j, ]- T6 P8 v* y2 I
LT
$ ~3 }/ ^9 c" W2 x* b6 Qline termination 线路终端
0 v5 [+ W/ N% ~  a$ q6 f# q& O, H
. t. ~; ~- S7 m) dMDF $ H( e) K4 M, E: Y  {
main distribution frame 总配线架4 g  g: Q; r& [! T2 H2 S
1 `6 _6 v4 A6 E. h
MOV
& a  Z8 j7 D6 @; J  |' kmetal-oxide varistor 金属氧化压敏电阻 7 k* n- J$ s! @% K! A( q
9 a7 n) I* \6 d6 M
n.a. 2 W& a0 T3 p* c
not applicable 不可用, r( f2 E9 M& S* M
) x" P9 V) N2 w+ L
NT 8 E. S* z1 g5 C) A/ B8 R1 P! l
network termination 网络终端
4 Y0 k" i4 ^$ V5 b. W' Z6 d! Y( C) w7 Q' I, A2 A0 I/ d
OATS
6 Z0 A  l( e9 u! c* v: d! C! Bopen area test site 开阔试验场
1 F9 M' J' i, P7 \% a3 k2 t* B
1 {8 u6 Q/ l& ?- w5 No/c
; b, S' O2 p+ d! U& Y( S. x4 g# Mopen circuit 开放电路
- `/ B. b  W# S2 ?3 K) }6 B: `1 F! f- T! z3 y& f/ u
pfv 5 w7 }: `' L. f( b5 L
power feeding voltage 供电电压
8 p: [* a0 Y! U, D0 N# O/ Y4 t; G
. E! _) l( b, q3 I$ F) ZPNI 3 {7 h, E$ q! b  ?- W  `4 C" k, Z, y
public network interface 公用网接口: G# p; G+ ~6 y4 e2 L" _
/ e& ^7 g4 w! r; C
PRBS
6 V+ o8 y" h9 v2 [4 Lpseudo random bit sequence 伪随机比特序列
* l) g5 P8 \# X/ b0 G, Q
9 e7 [1 _* t1 k1 K- dPSTN
/ P( m: c+ w4 u: Lpublic switched telephone network 公用交换电话网
2 ^* T4 M4 b2 y- ^! ]- @7 l
' ?: n& V! `2 w4 ]% ]+ _PTC $ U9 u& n% K3 B- I* X4 y+ V
positive temperature coefficient(resistor) 正温度系数( d2 z8 N4 J+ Z! c) {
& K+ i* M* U( Z: |5 cRF ! Y3 U0 R# j7 R6 ^3 o2 R
radio frequency 无线电频率7 s- C- P/ r3 r5 B
) x/ w0 z0 u. c9 Y6 X2 BRFI & K6 a$ l; I+ `/ P4 ]% k
radio frequency interference 射频接口( }# x6 L1 n! x( T# D1 u* e
. k; [  P6 _! u. K  W7 SRFT ; \! Y& e1 x# D
remote feeding telecommunications circuit 远供通信电路
+ A. v: P1 [: ~% y% @* C  A- r' S
) }6 ^& Q9 k( X$ |( xRFT-G
0 x/ O& Y! p# k0 `remote feeding telecommunications circuit-current limited 远供通信电路-限电流
2 H% [# y- K8 o0 S* g8 l5 @1 e* b( J! S/ o
RFT-V ) u* r( B5 a5 d
remote feeding telecommunications circuit-voltage limited 远供通信电路-限电压
) b( h$ e) f* K* c& g5 c) `$ s
- Q/ Y: a; g6 X5 N8 P: QRSE ( Y$ ]; |0 Y7 m7 x! v" V
remote switching fquipment 远端交换设备
! l: n! }$ ]/ p  G$ u$ _  [
7 e! G! M. K* V2 ZSA 8 W$ O  u( G" _; }: V
specific absorption 比吸收能
; U. y' i$ ^) u" ^* {) L: _! A7 N+ n: N# p, E1 y
SA
# w& I! p- b, }! wsemi-conductor arrester 半导体避雷器2 F5 F+ F" A0 n% v. z; {3 E/ }
3 V% V( v2 c. k, O
SAA
& \8 O- h* B+ D* w$ b% [0 W3 ssemi-conductor arrester assembly 半导体避雷器组件0 @! e& R/ M$ c; I; k
1 o! E/ W5 O! F5 i2 d" S- _
SAR
' H/ }# R% H( x7 R4 ]) {2 Yspecific absorption rate 吸收率4 E! H6 M; O  ^( G: C( q
, q! x- y( @, ]/ M) J
SAP
. p2 O2 N, p1 l* A: P2 d8 Pspecific absorption power 吸收功率% c$ {  a! m. ^, a: w
. Q+ ?9 P  o% e3 C/ ^! ~, ^SELV . A2 M% b; x4 w5 \; q
safety extra low voltage 安全超低电压- g! }; d4 g1 N" Y0 z
4 ~- c' d. g/ }+ TSLIC $ G# Z  z! r9 W3 U4 l+ c% j
subscriber line interface circuit 用户线路接口电路. Q; Q. }4 u2 g+ Y2 w
. k3 Q- d  }/ y0 J( FSPD
, C5 g0 r7 }* w9 W  l! lsurge protective device 浪涌保护元件
( e0 D; w' Y5 F7 {' A$ l, n
3 g1 i3 ?) N2 N! X! k& J  E/ }SPL ( ?% T6 Q& H# l8 ?
sound pressure level 声压级6 Z/ p# q$ e+ q1 b. D* d
( T# c3 `* \/ C6 cSSA 3 Y2 M1 Z0 Y" H3 W7 i( w  E/ J
solid state arrester 固体避雷器
( E/ J# Q* }' R. t. P% C- t" o1 G' H3 ?3 w4 y6 h9 e
TCE : A' J- C# ?) Q) z
telecommunication centre equip电信中心设备) a9 J! _/ a# ]3 _" s, q; T
& U3 }* T) Z' N6 N& mTDMA
/ k' z6 G* a8 ?( ?. J$ ftime division multiple access 时分多址2 `' A8 c  m9 `" |% b; G2 W8 h
( p3 |% \: E, E+ [
TN ' r, C# G9 j& I" h/ Y
trunk network 干线网: ~' K' S) I" D" |/ J: q
" C5 k: I5 @2 |1 A, c+ b
TNV
4 R4 |4 J& K9 u% Q" itelecommunication network voltage 电信网电压
% z: ~  ]5 r" G6 j1 W# n- s- L4 L3 g0 I- W
RSD
8 e  p8 ~% M2 G! D5 I8 yuniversal serial bus 通用串联总线' {' A7 |( v$ r) h5 J0 i6 K+ d1 F
3 S6 @* e( }$ b2 q0 H6 o2 M* _
RPS
6 ]% W; t# N! n3 \! ]( Z' Cuninterruptible power supply 不间断电源
4 f* l( [+ Q4 C% B" n
4 M& K8 m2 `" X  ^VDSL ) Q: ~9 t4 g' {. ?5 S' i' i( c7 R
very high speed DSL 调整用户数字环路- B8 o+ N5 u# U5 S9 w8 O5 r
+ ?6 W! T/ s8 _/ }
VDU % l( \+ Q  g5 t. s  {9 }/ K9 Q4 f, Q
visual display unit 视频显示单元1 _' p' c) M& [# [. J8 P! |
  [& ~2 g* q% x) R$ N/ jUIC   D( c6 A# I+ a. Y* _( S0 T
international union of railway 国际铁路联盟
! k; J1 H+ @& O5 d- a( i- @# U! h7 f" ~, J! u+ H
xDSL % P- p3 h# ~" X  Q  r
digital subscriber loop x数字用户环路
1 ^- p: f. C3 H. T& p" z* {5 ^# a
GMT+8, 2025-11-23 14:51 , Processed in 0.187500 second(s), 24 queries , Gzip On.
