三输出光绘出现这个问题Draw holes only NO WARNING: Film contains objects with associated DRCs (1). In the design editor view this film and enable visibility for the associated DRC layer. Verify the DRCs are approved exceptions to your rules. WARNING: rectangle or unfilled shape composed 0 width line found at (2795.275 1318.898) ... ignored. WARNING: rectangle or unfilled shape having Multiple 0 width lines; all will be treated the same as the first. ... ignored. WARNING: Segment with same start and end points at (1026.426 3854.249) will be ignored. Increasing output accuracy may allow segment to be generated.5 o9 i; r7 x, A0 u$ b
