Cypress EZ-USB FX3S5 _8 b% G7 v' [1 e, @; K1 v Q) {
- Integration: Full USB 3.0 Peripheral Controller with built-in PHY
- Storage Support: Support up to 2 memory cards- SD 3.0, eMMC 4.41, SDIO 3.0
- High-Performance: ARM9 with 512 kB RAM for data processing
- Connectivity: I2C, I2S, SPI and UART peripherals
- Flexibility: Configurable 16-bit 100 MHz GPIF II interface connects with any processor/sensor/ASIC/FPGA with parallel port
- Low Power: Low 1.2 V core and independent power domains
- Multitasking: 32 configurable endpoints
- Flexible Clock: Selectable XTAL input from 19.2, 26, 38.4 and 52 MHz
- Small Footprint: 10x10mm 121 ball 0.8mm pitch BGA package
' N+ L b( n2 O7 K # E8 S: B, r: ]+ g* G
' g, r C! g4 c" [ |
