查看: 3388|回复: 6
急求救MXM3.0和3.1
发表于 2016-5-13 20:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
MXM3.0和3.1有什么区别,求大神讲解
% L5 a+ Y. o8 l& d/ z# j7 |
发表于 2016-5-14 12:53 | 只看该作者
洋人的說法!, h2 D$ r7 M: c
; |. w/ f% h8 t. Q4 j1 FMXM 3.1 adds the following things:
; \) N! n  }3 w& |7 k
  • Support for PCI Express 3.0
  • Extra Debugging (Mostly to support 3.0)# b+ _8 [( J# s9 s8 y
. f( q6 k  `: J6 BHere's also what we know, that mostly this is a validation standard change, there are a few NEW pins used on the connector (They were previously "Reserved") so there is not a physical connector change.  3.0 Cards WILL work in 3.1 slots, and 3.1 Cards WILL work in 3.0 slots.  The only change is that if its a 3.1 card it won't work at PCI Express 3.0 speeds (Only 2.0 or 1.0)& Y% d: ~9 ]8 [7 _( U5 `3 C
- s8 n5 z, _# F6 f% L% A Now the real question.. Are the P270, and the EM series 3.0 or 3.1 Slots?  We don't know yet, as we don't have any 3.1 cards to test them with, and Clevo has been tight lipped about it.  I can tell you that the standard has been privatly released for less than 30 days.  So the chances of them doing a whole new motherboard spin to support 3.1 (As there is some addition stuff on the motherboard that has to be added to support PCIe 3.0 speeds) are pretty low at the moment.  But we'll see once we get new generation cards (Hi AMD) that support PCIe 3.0.
" q2 ]1 _  `- y) B. Z9 C! z
: }  V6 x  U' p0 F3 g6 b' x
4 ^" f' z, z5 S
9 i3 @+ t5 r" n) m4 Y8 S! M
( |- ]' d) {& q8 h
发表于 2016-5-14 13:03 | 只看该作者
MXM SIG 官網
" c$ F! v" x# ]3 Z4 _; i: p% j5 ?; r" F' [8 E- j
: e; T6 f) d  ?7 a" mhttp://www.mxm-sig.org/main.cfm?action=specifications3 p% R, ~' J  T2 Z3 z& f0 V
: M% L. ]6 j4 r) B# ~% n
要加入幫會!* c% G0 ^& N& \: f8 V) _
7 ]% v& e# l2 X9 ?+ l* S$ M# l/ t# ~' N* k8 w
狗版主,为什么网址打不开呢?我们现在正好要用mxm接口,想找点资料  详情 回复 发表于 2017-9-11 08:42
发表于 2017-9-11 08:42 | 只看该作者
超級狗 发表于 2016-5-14 13:038 @) h' n6 C% T5 a0 Y
MXM SIG 官網
8 C5 T5 J2 O7 B& m! t+ O: b; ~8 y$ H狗版主,为什么网址打不开呢?我们现在正好要用mxm接口,想找点资料
6 c3 s0 S3 L9 C. t$ R1 [$ @
发表于 2018-2-11 10:57 | 只看该作者
狗版主,MXM SIG 的网址不稳定,打不开。想找点资料。
GMT+8, 2025-11-23 00:59 , Processed in 0.156250 second(s), 24 queries , Gzip On.
