标题: 导出ODB++ 提示报警 [打印本页]
作者: ZMS_CHINA    时间: 2015-6-25 14:11
标题: 导出ODB++ 提示报警
WARNING: Since the starting (6.7322835,7.6968501)(mm) and the ending (6.7322831,7.6968504)(mm) coordinates of the arc are to close, it will be interpreted as an arc of 360 degrees per ODB++ standards and can potentially cause problems.6 J9 A5 F* M8 K1 e- {) @# ]
* R- z5 Q' `& D7 L2 a7 G" ~' c
WARNING: Since the starting (1.3133467,3.0012447)(mm) and the ending (1.3133473,3.0012450)(mm) coordinates of the arc are to close, it will be interpreted as an arc of 360 degrees per ODB++ standards and can potentially cause problems.
: K9 Z; j0 o$ r; Z8 @7 M0 [5 z' T- c" H5 L: A
报警提示的坐标都是在原点附近的,我尝试着把原点设置到-100,-100的位置,报警的坐标也就涨到10,10的样子,不像是PCB上面的线,不知道哪边设置有问题
" v+ s& R( U* J5 B* a+ x+ I* ]; ?
作者: zorro123    时间: 2015-6-25 18:07
thanks
